path: root/drivers/input/serio/Kconfig
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-23Input: olpc_apsp - depend on ARCH_MMPJean Delvare
The OLPC XO-1.75 and XO-4 are ARM-based laptops, using the Marvell MMP architecture, so don't present this driver on other architectures except for build-testing purposes. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2019-01-13Merge tag 'v4.20' into nextDmitry Torokhov
Merge with mainline to bring in the new APIs.
2018-11-15Input: olpc_apsp - drop CONFIG_OLPC dependencyLubomir Rintel
CONFIG_OLPC is specific to the x86 platform code, while the driver is for an ARM-based laptop. Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-06-15docs: fix broken references with multiple hintsMauro Carvalho Chehab
The script: ./scripts/documentation-file-ref-check --fix Gives multiple hints for broken references on some files. Manually use the one that applies for some files. Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Acked-by: James Morris <james.morris@microsoft.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Jonathan Corbet <corbet@lwn.net>
2018-01-18Input: remove at32psifCorentin Labbe
Since AVR32 arch is gone, at32psif driver is useless. Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2017-08-28Input: PS/2 gpio bit banging driver for serio busDanilo Krummrich
This driver provides PS/2 serio bus support by implementing bit banging with the GPIO API. The GPIO pins, data and clock, can be configured with a node in the device tree or by generic device properties (GDP). Writing to a device is supported as well, though it is possible timings can not be halt as they are tough and difficult to reach with bit banging. Therefore it can be configured (also in DT and GDP) whether the serio write function should be available for clients. This driver is for development purposes and not recommended for productive use. However, this driver can be useful e.g. when no USB port is available or using old peripherals is desired as PS/2 controller chips getting rare. This driver was tested on bcm2825 and on Kirin 960 and it worked well together with the atkbd and psmouse driver. Signed-off-by: Danilo Krummrich <danilokrummrich@dk-develop.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-10-27Input: add userio moduleStephen Chandler Paul
Debugging input devices, specifically laptop touchpads, can be tricky without having the physical device handy. Here we try to remedy that with userio. This module allows an application to connect to a character device provided by the kernel, and emulate any serio device. In combination with userspace programs that can record PS/2 devices and replay them through the /dev/userio device, this allows developers to debug driver issues on the PS/2 level with devices simply by requesting a recording from the user experiencing the issue without having to have the physical hardware in front of them. Signed-off-by: Stephen Chandler Paul <cpaul@redhat.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-06-29Input: arc_ps2 - add HAS_IOMEM dependencySebastian Ott
Fix this compile error: drivers/built-in.o: In function `arc_ps2_probe': /mnt/linux/drivers/input/serio/arc_ps2.c:206: undefined reference to `devm_ioremap_resource' Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2015-01-26Input: serio - add support for Alwinner A10/A20 PS/2 controllerVishnu Patekar
This driver implements support for PS2 controller found on Allwinner A10, A20 SOCs. It has been tested on A20 Olimex-Lime2 board and also on A10. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-23Input: olpc_apsp - fix dependencies of OLPC AP-SP driverJean Delvare
I don't think the OLPC AP-SP driver is generally useful without OLPC support. So make it depend on OLPC, unless build testing is enabled. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-01-02Input: i8042 - cleanup SERIO_I8042 dependenciesMark Salter
Remove messy dependencies from SERIO_I8042 by having it depend on one Kconfig symbol (ARCH_MIGHT_HAVE_PC_SERIO) and having architectures which need it select ARCH_MIGHT_HAVE_PC_SERIO in arch/*/Kconfig. New architectures are unlikely to need SERIO_I8042, so this avoids having an ever growing list of architectures to exclude. Signed-off-by: Mark Salter <msalter@redhat.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Updates for the input subsystem. You will get an new drivers for Hyper-V synthetic keyboard and for Neonode zForce touchscreens, plus a bunch of driver fixes and cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (49 commits) Revert "Input: ALPS - add support for model found on Dell XT2" arm: dts: am335x sk: add touchscreen support Input: ti_am335x_tsc - fix spelling mistake in TSC/ADC DT binding Input: cyttsp4 - replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO Input: mma8450 - add missing i2c_set_clientdata() in mma8450_probe() Input: mpu3050 - add missing i2c_set_clientdata() in mpu3050_probe() Input: tnetv107x-keypad - make irqs signed for error handling Input: add driver for Neonode zForce based touchscreens Input: sh_keysc - enable the driver on all ARM platforms Input: remove a redundant max() call Input: mousedev - allow disabling even without CONFIG_EXPERT Input: allow deselecting serio drivers even without CONFIG_EXPERT Input: i8042 - add PNP modaliases Input: evdev - fall back to vmalloc for client event buffer Input: cypress_ps2 - do not consider data bad if palm is detected Input: cypress_ps2 - remove useless cast Input: fix PWM-related undefined reference errors Input: ALPS - change secondary device's name Input: wacom - not all multi-interface devices support touch Input: nspire-keypad - add missing clk_disable_unprepare() on error path ...
2013-10-31Input: allow deselecting serio drivers even without CONFIG_EXPERTTom Gundersen
There is plenty of consumer hardware (e.g., mac books) that does not use AT keyboards or PS/2 mice. It therefore makes sense for distro kernels to build the related drivers as modules to avoid loading them on hardware that does not need them. As such, these options should no longer be protected by EXPERT. Moreover, building these drivers as modules gets rid of the following ugly error during boot: [ 2.337745] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 3.439537] i8042: No controller found Signed-off-by: Tom Gundersen <teg@jklm.no> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-10-08Merge tag 'v3.12-rc4' into nextDmitry Torokhov
Merge with mainline to bring in changes to input subsystem that were committed through other trees.
2013-09-25input: i8042: drop dependency on ARCH_SHARKLinus Walleij
Delete the configuration option for the Shark machine from the i8042 Kconfig, as the machine is deleted from the kernel. Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-19Input: add a driver to support Hyper-V synthetic keyboardK. Y. Srinivasan
Add a new driver to support synthetic keyboard. On the next generation Hyper-V guest firmware, many legacy devices will not be emulated and this driver will be required. I would like to thank Vojtech Pavlik <vojtech@suse.cz> for helping me with the details of the AT keyboard driver. I would also like to thank Dan Carpenter <dan.carpenter@oracle.com> and Dmitry Torokhov <dmitry.torokhov@gmail.com> for their detailed review of this driver. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-29Input: i8042 - disable the driver on ARC platformsMischa Jonker
It causes crashes when enabled, and we don't have such a peripheral anyway on ARC platforms. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-07-02Merge branch 'next' into for-linusDmitry Torokhov
Prepare first set of updates for 3.11 merge window.
2013-06-30Input: add OLPC AP-SP driverDaniel Drake
The OLPC XO-1.75 and XO-4 laptops include a PS/2 touchpad and an AT keyboard, yet they do not have a hardware PS/2 controller. Instead, a firmware runs on a dedicated core ("Security Processor", part of the SoC) that acts as a PS/2 controller through bit-banging. Communication between the main cpu (Application Processor) and the Security Processor happens via a standard command mechanism implemented by the SoC. Add a driver for this interface to enable keyboard/mouse input on this platform. Original author: Saadia Baloch Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-06-10Input: add missing dependencies on CONFIG_HAS_IOMEMBen Hutchings
Several drivers don't build on s390 with CONFIG_PCI disabled as they require MMIO functions. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org # 3.9 Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-03-17Merge tag 'v3.9-rc3' into nextDmitry Torokhov
Merge with mainline to bring in module_platform_driver_probe() and devm_ioremap_resource().
2013-03-12Input: add support for GRLIB APBPS2 PS/2 Keyboard/MouseDaniel Hellstrom
APBPS2 is a PS/2 core part of GRLIB found in SPARC32/LEON products. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-02-28input: disable i8042 PC Keyboard controller for s390Heiko Carstens
Just add s390 to the list of architectures that don't want this driver. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-13Input: add couple of missing GENERIC_HARDIRQS dependenciesHeiko Carstens
When removing the !S390 dependency from drivers/input/Kconfig a couple of drivers don't compile because they have a dependency on GENERIC_HARDIRQS. So add the missing dependencies. Fixes e.g. this one: drivers/input/keyboard/lm8323.c: In function ‘lm8323_suspend’: drivers/input/keyboard/lm8323.c:801:2: error: implicit declaration of function ‘irq_set_irq_wake’ [-Werror=implicit-function-declaration] Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-02-06input: drop unnecessary dependencies on TTYJoe Millenbach
Backing out changes made in earlier TTY removal patch. Switched to only one dependency in SERPORT on TTY instead of many incorrect dependencies. Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22Input: serio - add ARC PS/2 driverMischa Jonker
This adds support for the PS/2 block that is used in various ARC FPGA platforms. Signed-off-by: Mischa Jonker <mischa.jonker@synopsys.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-11-30OMAP1: drop AMS_DELTA_FIQ config optionJanusz Krzysztofik
This patches removes a config option that was used to select a FIQ handler to be build for Amstrad Delta, as required by the on-board serio interface driver. Not having any problem reports received since it was introduced in 2.6.35, the FIQ handler can now be built and initialized by default, thus reqiring no extra config option. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-11-02Kconfig: typo: boad -> boardMichael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-18Input: serio - add support for PS2Mult multiplexer protocolDmitry Eremin-Solenikov
PS2Mult is a simple serial protocol used for multiplexing several PS/2 streams into one serial data stream. It's used e.g. on TQM85xx series of boards. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-07-07Revert "Input: fixup X86_MRST selects"Feng Tang
This reverts commit 0b28bac5aef7bd1ab213723df031e61db9ff151a. After adding x86_platform's detection for i8042 controller, we don't need the force dependency on !X86_MRST any more Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Feng Tang <feng.tang@intel.com> LKML-Reference: <1278342202-10973-5-git-send-email-feng.tang@intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-06-22Input: fixup X86_MRST selectsRandy Dunlap
Some of the recent X86_MRST additions make some "select"s conditional on X86_MRST but missed some related kconfig symbols, causing: drivers/built-in.o: In function `ps2_end_command': (.text+0x257ab2): undefined reference to `i8042_check_port_owner' drivers/built-in.o: In function `ps2_end_command': (.text+0x257ae1): undefined reference to `i8042_unlock_chip' drivers/built-in.o: In function `ps2_begin_command': (.text+0x257b40): undefined reference to `i8042_check_port_owner' drivers/built-in.o: In function `ps2_begin_command': (.text+0x257b6f): undefined reference to `i8042_lock_chip' when SERIO_I8042=m, SERIO_LIBPS2=y, KEYBOARD_ATKBD=y. We need to make i8042 dependant upon !X86_MRST and allow deselecting atkbd on Moorestown even when !CONFIG_EMBEDDED. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jacob Pan <jacob.jun.pan@intel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-25input: serio: disable i8042 for non-cayman sh platforms.Paul Mundt
The sh64 cayman platform is the only sh board that ships with an i8042, so we just hide it for all of the others. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-05input: serio: add support for Amstrad Delta serial keyboardportJanusz Krzysztofik
The patch introduces a serio driver that supports a keyboard serial port found on the Amstrad Delta videophone board. After initializing the hardware, the driver reads its input data from a buffer filled in by the board FIQ (Fast Interrupt Request) handler. Standard AT keyboard driver (atkbd) will be used on top of the serio layer for handling the E3 keyboard (called mailboard) connected to the port. Since the device generated scancodes differ from what the atkbd expects, a custom key code to scan code table must be loaded from userspace for the keyboard to be useable. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-12Input: add driver for Altera PS/2 controllerThomas Chou
This patch adds a new SERIO driver to support the Altera University Program PS/2 controller. [dtor@mail.ru: assorted cleanups] Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-05Input: libps2 - fix dependancy on i8042Dmitry Torokhov
libps2 can not be built in if i8042 is a module, all other combinations are allowed. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-05-21microblaze: Kconfig: Enable drivers for MicroblazeMichal Simek
2008-11-27[ARM] clps7500: remove supportRussell King
The CLPS7500 platform has not built since 2.6.22-git7 and there seems to be no interest in fixing it. So, remove the platform support. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-07Input: add new serio driver for Xilinx XPS PS2 IPJohn Linn
Added a new driver for Xilinx XPS PS2 IP. This driver is a flat driver to better match the Linux driver pattern. Signed-off-by: Sadanand <sadanan@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-15Input: add PS/2 serio driver for AVR32 devicesHans-Christian Egtvedt
Add support for the PSIF peripheral on AVR32 AP7 devices. It is implemented as a serio driver and will behave like a serio 8042 device. The driver has been tested with a Dell keyboard capable of running on 3.3 volts and a Logitech mouse on the STK1000 + STK1002 starter kit. The Logitech mouse was hacked by cutting the cord and using a bi-directional voltage converter to get the required 5 volt I/O level. For more information about the PSIF module, see the datasheet for AT32AP700X at http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-11-23Blackfin arch: punt CONFIG_BFIN -- we already have CONFIG_BLACKFINMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-24Input Serio: Blackfin doesnt support I8042 - make sure it doesnt get selectedMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2006-10-09[PATCH] m68k/HP300: Enable HIL configuration optionsGeert Uytterhoeven
Enable HIL configuration options on HP300 Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Fix several typos in drivers/Matt LaPlante
2005-07-11Input: serio_raw - fix Kconfig helpNeil Brown
Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
