It turns out that the keymaps in the wistron driver are almost the
same, the main difference being some keys which may not exist and
leds which might not be present. Therefore it's possible to write
a generic keymap which would allow the use of an unknown keyboard
with little drawbacks. The user can select it specifying the parameter
"keymap=generic".
Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net>
Acerhk supports already a lot of laptops. Lets import its database so
that everyone can benefit of the work of Olaf Tauber. Only the "tm_new"
laptops were imported. "tm_old" laptops could be possible but requires
more testing and probably only few laptops are still alive. "dritek"
laptops should probably be imported into a different driver. Also compress
the keymaps by fitting each entry on an int. Most of the dmi matching was
written based on google searches, so it's rather prone to errors. That's
why I'm asking people to confirm it works.
Support to generate switch input events was added as some laptops indicate
lid open/close through this interface.
This adds the following hardware:
Acer TravelMate 370
Acer TravelMate 380
Acer TravelMate C300
Acer TravelMate C100
Acer TravelMate C110
Acer TravelMate 250
Acer TravelMate 350
Acer TravelMate 620
Acer TravelMate 630
Acer TravelMate 220
Acer TravelMate 230
Acer TravelMate 260
Acer TravelMate 280
Acer TravelMate 360
Acer TravelMate 2100
Acer TravelMate 2410
Acer Aspire 1500
Acer Aspire 1600
Acer Aspire 3020
Acer Aspire 5020
Medion MD 2900
Medion MD 40100
Medion MD 95400
Medion MD 96500
Fujitsu Siemens Amilo 7820
Add support for Acer TravelMate 610 to wistron_btns. All special keys
are detected, but the 2 leds are not handled (yet).
Tested on Cobalt Qube2.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Tested on a Amilo D8820.
Signed-off-by: Michael Leun <ml@newton.leun.net>
This patch adds support for the buttons on the Atlas wallmount
touchscreen.
Signed-off-by: Jaya Kumar <jayakumar.acpi@gmail.com>
Acked-by: Len Brown <len.brown@intel.com>
Clean up several code points in which the return code from misc_register is
not handled properly.
Several modules failed to deregister various hooks when misc_register fails,
and this patch cleans them up. Also there are a few modules that legitimately
don't care about the failure status of misc register. These drivers however
unilaterally call misc_deregister on module unload.
Since misc_register doesn't initialize the list_head in the init_routine if it
fails, the deregister operation is at risk for oopsing when list_del is
called. The initial solution was to manually init the list in the miscdev
structure in each of those modules, but the consensus in this thread was to
consolodate and do that universally inside misc_register.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Olaf Hering <olh@suse.de>
annotations
In preparation for moving check_signature, change these users from asm/io.h
to linux/io.h
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Enable HIL configuration options on HP300
Signed-off-by: Kars de Jong <jongk@linux-m68k.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
The key mappings are the same as the older Acer TravelMate 240.
Signed-off-by: Ashutosh Naik <ashutosh.naik@gmail.com>
If either wifi or bluetooth button has been detected, the code
would break off the loop. But there are laptops that have both
types of buttons, so the loop has to continue checking.
Signed-off-by: Reiner Herrmann <reiner@reiner-h.de>
Remove __initdata markings from keymaps as they are used during
normal driver operations.
The userspace interface of the force feedback part is changed and
documentation in uinput.h is updated accordingly. MODULE_VERSION
is also incremented to reflect the revision.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Wistron MS 2111 (aka Medion 'Titanium' MD 9783, aka ALDI PC,
aka Fujitsu-Siemens AMILO D7800, aka ...) has 5 extra buttons,
map them. Unfortunately we only have DMI data for the Medion
box.
Sparcspkr and power drivers are converted, to make sure it works.
Eventually the SBUS device layer will use this as a sub-class.
I really cannot cut loose on that bit until sparc32 is given the
same infrastructure.
The current pcspkr code combines the device and driver registration.
This patch splits these, putting the device registration in the arch
specific code.
PowerPC and MIPS only have the pcspkr present sometimes.
Signed-off-by: Michael Neuling <mikey@neuling.org>
98kbd{,-io} and 98spkr all went out with PC98 subarch. Remove stale Makefile
entries that remained.
Signed-off-by: Arthur Othieno <apgo@patchbomb.org>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
This is a driver for beeper found in LinkSys NSLU2 boxes. It should work
on any ixp4xx based platform.
offset can never be < 0 because it has type size_t. The driver
currently oopses on insmod if BIOS does not support the interface,
instead of refusing to load.
Signed-off-by: Miloslav Trmac <mitr@volny.cz>
Use no_llseek function.
Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com>
Cc: "Brian S. Julin" <bri@calyx.com>
Acked-by: Vojtech Pavlik <vojtech@suse.cz>
Cc: Dmitry Torokhov <dtor_core@ameritech.net>
Do not use platform_device_register_simple() as it is going away,
implement ->probe() and ->remove() functions so manual binding and
unbinding would work.
Introduce a Kconfig symbol SPARC that is defined on both the sparc and
sparc64 architectures.
This symbol makes some dependencies more readable.
If thread that submitted FF request gets interrupted somehow it
will release request structure and ioctl handler will work with
freed memory. TO prevent that from happening switch to using
wait_for_completion instead of wait_for_completion_interruptible.
Also introduce proper locking when creating/deleting device.
Try to save battery power by disabling wifi and bluetooth on suspend.
Register wistron-bios as a platform device, restore WIFI and
Bluetooth state upon resume.
Also fix a potential issue with some notebooks:
The current code assumes the response to bios_wifi_get_default_setting is
either 1 (disabled) or 3 (enabled), or wifi isn't supported. The BIOS
response appears to be a bit field w/ 0x1 indicating hardware presence, 0x2
indicating actiation status, and the other 6 bits being unknown/reserved --
with the patch, these 6 bits are ignored.
Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org>
