path: root/drivers/input/misc
2014-10-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A bunch of fixes for minor defects reported by Coverity, a few driver fixups and revert of i8042.nomux change so that we are once again enable active MUX mode if box claims to support it" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Revert "Input: i8042 - disable active multiplexing by default" Input: altera_ps2 - use correct type for irq return value Input: altera_ps2 - write to correct register when disabling interrupts Input: max77693-haptic - fix potential overflow Input: psmouse - remove unneeded check in psmouse_reconnect() Input: vsxxxaa - fix code dropping bytes from queue Input: ims-pcu - fix dead code in ims_pcu_ofn_reg_addr_store() Input: opencores-kbd - fix error handling Input: wm97xx - adapt parameters to tosa touchscreen. Input: i8042 - quirks for Fujitsu Lifebook A544 and Lifebook AH544 Input: stmpe-keypad - fix valid key line bitmask Input: soc_button_array - update calls to gpiod_get*()
2014-10-31Input: max77693-haptic - fix potential overflowDmitry Torokhov
Expression haptic->pwm_dev->period * haptic->magnitude is of type 'unsigned int' and may overflow. We need to convert one of the operands to u64 before multiplying, instead of casting result (potentially overflown) to u64. Reported by Coverity: CID 1248753 Acked-by : Jaewon Kim <jaewon02.kim@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-10-28Input: ims-pcu - fix dead code in ims_pcu_ofn_reg_addr_store()Dmitry Torokhov
Coverity pointed out that at return point error is always 0 so the conditional is not needed. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-10-24Input: soc_button_array - update calls to gpiod_get*()Alexandre Courbot
Add the new flags argument to calls of (devm_)gpiod_get*(). Currently both forms (with or without the flags argument) are valid thanks to transitional macros in <linux/gpio/consumer.h>. These macros will be removed once all consumers are updated and the flags argument will become compulsory. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-10-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "Mostly simple bug fixes, although we do have one brand new driver for Microchip AR1021 i2c touchscreen. Also there is the change to stop trying to use i8042 active multiplexing by default (it is still possible to activate it via i8042.nomux=0 on boxes that implement it)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - add Thrustmaster as Xbox 360 controller vendor Input: xpad - add USB ID for Thrustmaster Ferrari 458 Racing Wheel Input: max77693-haptic - fix state check in imax77693_haptic_disable() Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backend Input: alps - fix v4 button press recognition Input: i8042 - disable active multiplexing by default Input: i8042 - add noloop quirk for Asus X750LN Input: synaptics - gate forcepad support by DMI check Input: Add Microchip AR1021 i2c touchscreen Input: cros_ec_keyb - add of match table Input: serio - avoid negative serio device numbers Input: avoid negative input device numbers Input: automatically set EV_ABS bit in input_set_abs_params Input: adp5588-keys - cancel workqueue in failure path Input: opencores-kbd - switch to using managed resources Input: evdev - fix EVIOCG{type} ioctl
2014-10-16Input: max77693-haptic - fix state check in imax77693_haptic_disable()Jaewon Kim
The check to see whether the device is already disabled in max77693_haptic_disable() was inversed, this change corrects it. Signed-off-by: Jaewon Kim <jaewon02.kim@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-10-16Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backendChang Huaixin
xenkbd_disconnect_backend doesn't free grant table entry. This bug affects live migration. xenkbd_disconnect_backend uses gnttab_end_foreign_access_ref to handle grant table entry which doesn't really free an entry. Thus every time we do xenkbd_resume, grant table entry increses by one. As an grant table entry occupies 8 bytes, an grant table page has at most 512 entries. Every 512 times we do xenkdb_resume, grant table pages increses by one. After around 3500 times of live migration, grant table pages will increase by 7, causing too many pages to populate and hitting max_pages limit when assigning pages.Thus assign_pages will fail, so will live migration. Signed-off-by: Chang Huaixin <huaixin.chx@alibaba-inc.com> Acked-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-10-11Merge tag 'stable/for-linus-3.18-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen updates from David Vrabel: "Features and fixes: - Add pvscsi frontend and backend drivers. - Remove _PAGE_IOMAP PTE flag, freeing it for alternate uses. - Try and keep memory contiguous during PV memory setup (reduces SWIOTLB usage). - Allow front/back drivers to use threaded irqs. - Support large initrds in PV guests. - Fix PVH guests in preparation for Xen 4.5" * tag 'stable/for-linus-3.18-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (22 commits) xen: remove DEFINE_XENBUS_DRIVER() macro xen/xenbus: Remove BUG_ON() when error string trucated xen/xenbus: Correct the comments for xenbus_grant_ring() x86/xen: Set EFER.NX and EFER.SCE in PVH guests xen: eliminate scalability issues from initrd handling xen: sync some headers with xen tree xen: make pvscsi frontend dependant on xenbus frontend arm{,64}/xen: Remove "EXPERIMENTAL" in the description of the Xen options xen-scsifront: don't deadlock if the ring becomes full x86: remove the Xen-specific _PAGE_IOMAP PTE flag x86/xen: do not use _PAGE_IOMAP PTE flag for I/O mappings x86: skip check for spurious faults for non-present faults xen/efi: Directly include needed headers xen-scsiback: clean up a type issue in scsiback_make_tpg() xen-scsifront: use GFP_ATOMIC under spin_lock MAINTAINERS: Add xen pvscsi maintainer xen-scsiback: Add Xen PV SCSI backend driver xen-scsifront: Add Xen PV SCSI frontend driver xen: Add Xen pvSCSI protocol description xen/events: support threaded irqs for interdomain event channels ...
2014-10-06xen: remove DEFINE_XENBUS_DRIVER() macroDavid Vrabel
The DEFINE_XENBUS_DRIVER() macro looks a bit weird and causes sparse errors. Replace the uses with standard structure definitions instead. This is similar to pci and usb device registration. Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2014-09-24Input: soc_button_array - convert to platform busJin Yao
ACPI device enumeration mechanism changed a lot since 3.16-rc1. ACPI device objects with _HID will be enumerated to platform bus by default. For the existing PNP drivers that probe the PNPACPI devices, the device ids are listed explicitly in drivers/acpi/acpi_pnp.c. But ACPI folks will continue their effort on shrinking this id list by converting the PNP drivers to platform drivers, for the devices that don't belong to PNP bus in nature. Signed-off-by: Jin Yao <yao.jin@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-15Input: palmas-pwrbutton - fix typo in the license stringNishanth Menon
Follow the license string convention indicated in include/linux/module.h (don't capitalize v). This fixes following randconfig warning: FATAL: modpost: GPL-incompatible module palmas-pwrbutton.ko uses GPL-only symbol 'platform_driver_unregister' Fixes: adff5962fdd2 ("Input: introduce palmas-pwrbutton") Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-15Input: palmas-pwrbutton - use IRQF_ONESHOTNishanth Menon
make C=2 CHECK="scripts/coccicheck" MODE=report COCCI=scripts/coccinelle/misc/irqf_oneshot.cocci ./drivers/input/misc/palmas-pwrbutton.o Reports: drivers/input/misc/palmas-pwrbutton.c:213:9-29: ERROR: Threaded IRQ with no primary handler requested without IRQF_ONESHOT Palmas power button just needs threaded IRQ handler since I2C operations are involved and there is nothing in non-threaded primary handler we could do. So mark the request with ONESHOT as it should have been done in these cases. Fixes: adff5962fdd2 ("Input: introduce palmas-pwrbutton") Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-11Input: add haptic driver on max77693Jaewon Kim
This driver to supports the haptic controller on MAX77693 Multifunction device with PMIC, CHARGER, LED, MUIC, HAPTIC. This driver supports external pwm and LRA (Linear Resonant Actuator) motor. User can control the haptic device via force feedback framework. Signed-off-by: Jaewon Kim <jaewon02.kim@samsung.com> Acked-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-11Input: introduce palmas-pwrbuttonNishanth Menon
Many palmas family of PMICs have support for interrupt based power button. This allows the device to notify the processor of external push button events over the shared palmas interrupt. However, this event is generated only during a "press" operation. Software is supposed to poll(sigh!) for detecting a release event. The PMIC also supports ability to power off independent of the software decisions when the button is pressed for a long duration if the PMIC is appropriately configured on the platform. Even though the function is similar to twl4030_pwrbutton, it is substantially different in operation to belong to a new driver of it's own. Based on original work done by Girish S Ghongdemath <girishsg@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-08Input: add support for the DRV2667 haptic driverDan Murphy
Adding support for the DRV2667 haptic driver. This device has the ability to store vibration patterns in RAM and execute them once the GO bit is set. The initial driver sets a basic waveform in the first waveform sequence and will play the waveform when the GO bit is set and will continously play the waveform until the GO bit is unset. Data sheet is here: http://www.ti.com/product/drv2667 Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-09-03Merge tag 'v3.17-rc3' into nextDmitry Torokhov
Sync with mainline to bring in Chrome EC changes.
2014-08-26Input: drv260x - add check for ERM mode and LRA LibrariesDan Murphy
Add a check to ensure that LRA libraries are not mixed with the ERM mode. If ERM mode and the Library is empty "OR" the LRA library then exit, as the LRA and empty libraries are not applicable for the ERM actuator. Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-08-26Input: drv260x - remove unused definesDan Murphy
Removing some #defines that are not and should never be used pertaining to I2C. Removing: define DRV260X_ALLOWED_R_BYTES 25 define DRV260X_ALLOWED_W_BYTES 2 define DRV260X_MAX_RW_RETRIES 5 define DRV260X_I2C_RETRY_DELAY 10 Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-08-19Input: drv260x - add TI drv260x haptics driverDan Murphy
Add the TI drv260x haptics/vibrator driver. This device uses the input force feedback to produce a wave form to driver an ERM or LRA actuator device. The initial driver supports the devices real time playback mode. But the device has additional wave patterns in ROM. This functionality will be added in future patchsets. Product data sheet is located here: http://www.ti.com/product/drv2605 Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-08-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: - big update to Wacom driver by Benjamin Tissoires, converting it to HID infrastructure and unifying USB and Bluetooth models - large update to ALPS driver by Hans de Goede, which adds support for newer touchpad models as well as cleans up and restructures the code - more changes to Atmel MXT driver, including device tree support - new driver for iPaq x3xxx touchscreen - driver for serial Wacom tablets - driver for Microchip's CAP1106 - assorted cleanups and improvements to existing drover and input core * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (93 commits) Input: wacom - update the ABI doc according to latest changes Input: wacom - only register once the MODULE_* macros Input: HID - remove hid-wacom Bluetooth driver Input: wacom - add copyright note and bump version to 2.0 Input: wacom - remove passing id for wacom_set_report Input: wacom - check for bluetooth protocol while setting OLEDs Input: wacom - handle Intuos 4 BT in wacom.ko Input: wacom - handle Graphire BT tablets in wacom.ko Input: wacom - prepare the driver to include BT devices Input: hyperv-keyboard - register as a wakeup source Input: imx_keypad - remove ifdef round PM methods Input: jornada720_ts - get rid of space indentation and use tab Input: jornada720_ts - switch to using managed resources Input: alps - Rushmore and v7 resolution support Input: mcs5000_ts - remove ifdef around power management methods Input: mcs5000_ts - protect PM functions with CONFIG_PM_SLEEP Input: ads7846 - release resources on failure for clean exit Input: wacom - add support for 0x12C ISDv4 sensor Input: atmel_mxt_ts - use deep sleep mode when stopped ARM: dts: am437x-gp-evm: Update binding for touchscreen size ...
2014-08-06Merge branch 'next' into for-linusDmitry Torokhov
Prepare first round of input updates for 3.17.
2014-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcDavid S. Miller
Conflicts: arch/sparc/mm/init_64.c Conflict was simple non-overlapping additions. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-25Input: soc_button_array - add missing memory allocation checkPramod Gurav
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-21sparcspkr: use sbus_*() primitives for IOSam Ravnborg
The memory are mapped using of_ioremap() which is an indication this is sbus memory. Shift all uses of inb/outb to the sbus variants. The inb/outb methods uses ASI_PHYS_BYPASS_EC_E_L, whereas sbus_ variants uses ASI_PHYS_BYPASS_EC_E. The difference is if the reads/writes are done in native or little endian. But for byte reads/writes there is no difference so this does not matter for inb/outb - and this driver only uses the byte variants. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-21Input: uinput - add UI_GET_VERSION ioctlDavid Herrmann
This ioctl is the counterpart to EVIOCGVERSION and returns the uinput-version the kernel was compiled with. Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-21Input: uinput - uinput_validate_absbits() cleanupDavid Herrmann
This moves basic checks and setup from uinput_setup_device() into uinput_validate_absbits() to make it easier to use. This way, we can call it from other places without copying the boilerplate code. Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-18Input: keyspan_remote - remove unnecessary break after gotoFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-18Input: sirfsoc-onkey - fix GPL v2 license string typoBjorn Helgaas
Per license_is_gpl_compatible(), the MODULE_LICENSE() string for GPL v2 is "GPL v2", not "GPLv2". Use "GPL v2" so this module doesn't taint the kernel. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-06-07Input: max8997_haptic - add error handling for regulator and pwmSachin Kamat
Let's start checking return value of regulator_enable and pwm_enable to avoid errors. Fixes the following warning: drivers/input/misc/max8997_haptic.c:185:19: warning: ignoring return value of ‘regulator_enable’, declared with attribute warn_unused_result [-Wunused-result] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-29Input: ab8500-ponkey - switch to using managed resourcesHimangi Saraogi
Let's switch the driver to use managed resources, this will simplify error handling and driver unbinding logic. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-29Input: max8925_onkey - switch to using managed resourcesHimangi Saraogi
2014-05-29Input: 88pm860x_onkey - switch to using managed resourcesHimangi Saraogi
2014-05-28Input: soc_button_array - remove duplicate inclusion of input.hSachin Kamat
input.h was included twice. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-18Input: ims-pcu - fix uninitialized use of 'error' in ims_pcu_buffers_alloc()Christian Engelmayer
In case allocation via usb_alloc_coherent() fails in ims_pcu_buffers_alloc(), the function jumps to the exit path without initializing local variable 'error' that is used as return value. Detected by Coverity - CID 1016531. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-14Merge tag 'v3.15-rc5' into nextDmitry Torokhov
Merge with Linux 3.15-rc5 to sync up Wacom and other changes.
2014-05-14Input: pmic8xxx-pwrkey - set sane default for debounce timeStephen Boyd
If the debounce time is 0 our usage of ilog2() later on in this driver will cause undefined behavior. If CONFIG_OF=n this fact is evident to the compiler, and it emits a call to ____ilog2_NaN() which doesn't exist. Fix this by setting a sane default for debounce and failing to probe if debounce is 0 in the DT. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-14Input: rotary_encoder - make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-14Input: gpio-beeper - make of_device_id array constJingoo Han
2014-05-14Input: gpio-beeper - simplify GPIO handlingAlexander Shiyan
This patch simplifies GPIO handling in the driver by using GPIO functions based on descriptors. As a result this driver now can be used for boards without DT support. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-14Input: twl6040-vibra - use devm functionsFabio Estevam
Using devm_regulator_bulk_get() and devm_input_allocate_device() can make the code cleaner and smaller as we do not need to manually free resources the error and remove paths. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "Just a few fixups to various drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - fix touchpad initialization on Gigabyte U2442 Input: tca8418 - fix loading this driver as a module from a device tree Input: bma150 - extend chip detection for bma180 Input: atkbd - fix keyboard not working on some LG laptops Input: synaptics - add min/max quirk for ThinkPad Edge E431
2014-04-24Input: bma150 - extend chip detection for bma180Dr. H. Nikolaus Schaller
This driver has been used while on the OpenPhoenux GTA04 with a BMA180. Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-04-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "The main change is that we now publish "firmware ID" for the serio devices to help userspace figure out the kind of touchpads it is dealing with: i8042 will export PS/2 port's PNP IDs as firmware IDs. You will also get more quirks for Synaptics touchpads in various Lenovo laptops, a change to elantech driver to recognize even more models, and fixups to wacom and couple other drivers" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - add support for newer elantech touchpads Input: soc_button_array - fix a crash during rmmod Input: synaptics - add min/max quirk for ThinkPad T431s, L440, L540, S1 Yoga and X1 Input: synaptics - report INPUT_PROP_TOPBUTTONPAD property Input: Add INPUT_PROP_TOPBUTTONPAD device property Input: i8042 - add firmware_id support Input: serio - add firmware_id sysfs attribute Input: wacom - handle 1024 pressure levels in wacom_tpc_pen Input: wacom - references to 'wacom->data' should use 'unsigned char*' Input: wacom - override 'pressure_max' with value from HID_USAGE_PRESSURE Input: wacom - use full 32-bit HID Usage value in switch statement Input: wacom - missed the last bit of expresskey for DTU-1031 Input: ads7846 - fix device usage within attribute show Input: da9055_onkey - remove use of regmap_irq_get_virq()
2014-04-22Input: soc_button_array - fix a crash during rmmodLejun Zhu
When the system has zero or one button available, trying to rmmod soc_button_array will cause crash. Fix this by properly handling -ENODEV in probe(). Signed-off-by: Lejun Zhu <lejun.zhu@linux.intel.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-04-19Input: da9055_onkey - remove use of regmap_irq_get_virq()Adam Thomson
Using platform_get_irq_byname() to retrieve the IRQ number returns the VIRQ number rather than the local IRQ number for the device. Passing that value then into regmap_irq_get_virq() causes a failure because the function is expecting the local IRQ number (e.g. 0, 1, 2, 3, etc). This patch removes use of regmap_irq_get_virq() to prevent this failure from happening. Signed-off-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-04-05Merge tag 'pwm/for-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm changes from Thierry Reding: "The legacy HAVE_PWM Kconfig symbol is finally being retired. Thanks a lot to Sascha Hauer for doing that. Three new drivers are added: Freescale FTM, Cirrus Logic CLPS711X and Intel Low Power Subsystem. An assortment of fixes and cleanups rounds things off for this release cycle" * tag 'pwm/for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: pxa: Constify OF match table pwm: pxa: Fix typo "pwm" -> "PWM" Revert "pwm: pxa: Use of_match_ptr()" pwm: add support for Intel Low Power Subsystem PWM pwm: Add CLPS711X PWM support pwm: atmel: correct CDTY calculation pwm: atmel: Fix polarity handling Documentation: Add device tree bindings for Freescale FTM PWM. pwm: Add Freescale FTM PWM driver support pwm: pxa: Use of_match_ptr() pwm: samsung: Use SIMPLE_DEV_PM_OPS macro pwm: renesas-tpu: Add dependency on HAS_IOMEM pwm: Remove obsolete HAVE_PWM Kconfig symbol
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "The first round of updates for the input subsystem. Just new drivers and existing driver fixes, no core changes except for the new uinput IOCTL to allow userspace to fetch sysfs name of the input device that was created" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (43 commits) Input: edt-ft5x06 - add a missing condition Input: appletouch - fix jumps when additional fingers are detected Input: appletouch - implement sensor data smoothing Input: add driver for SOC button array Input: pm8xxx-vibrator - add DT match table Input: pmic8xxx-pwrkey - migrate to DT Input: pmic8xxx-keypad - migrate to DT Input: pmic8xxx-keypad - migrate to regmap APIs Input: pmic8xxx-keypad - migrate to devm_* APIs Input: pmic8xxx-keypad - fix build by removing gpio configuration Input: add new driver for ARM CLPS711X keypad Input: edt-ft5x06 - add support for M09 firmware version Input: edt-ft5x06 - ignore touchdown events Input: edt-ft5x06 - adjust delays to conform datasheet Input: edt-ft5x06 - add DT support Input: edt-ft5x06 - several cleanups; no functional change Input: appletouch - dial back fuzz setting Input: remove obsolete tnetv107x drivers Input: sirfsoc-onkey - set the capability of reporting KEY_POWER Input: da9052_onkey - use correct register bit for key status ...
2014-03-30Input: add driver for SOC button arrayLejun Zhu
This patch adds support for the GPIO buttons on some Intel Bay Trail tablets originally running Windows 8. The ACPI description of these buttons follows "Windows ACPI Design Guide for SoC Platforms". Signed-off-by: Lejun Zhu <lejun.zhu@linux.intel.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-30Input: pm8xxx-vibrator - add DT match tableStephen Boyd
The driver is only supported on DT enabled platforms. Convert the driver to DT so that it can probe properly. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
