path: root/drivers/input/misc
2010-03-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset table Input: ALPS - fix stuck buttons on some touchpads Input: wm831x-on - convert to use genirq Input: ads7846 - add wakeup support Input: appletouch - fix integer overflow issue Input: ad7877 - increase pen up imeout Input: ads7846 - add support for AD7843 parts Input: bf54x-keys - fix system hang when pressing a key Input: alps - add support for the touchpad on Toshiba Tecra A11-11L Input: remove BKL, fix input_open_file() locking Input: serio_raw - remove BKL Input: mousedev - remove BKL Input: add driver for TWL4030 vibrator device Input: enable remote wakeup for PNP i8042 keyboard ports Input: scancode in get/set_keycodes should be unsigned Input: i8042 - use platfrom_create_bundle() helper Input: wacom - merge out and in prox events Input: gamecon - fix off by one range check Input: wacom - replace WACOM_PKGLEN_PENABLED
2010-03-11Input: wm831x-on - convert to use genirqMark Brown
Now that the WM831x core has been converted to use genirq for the interrupt controller there is no need for the client drivers to use a WM831x-specific API rather than just calling genirq directly. Also fixes a leak of the IRQ during init failure - the error path free_irq() was using NULL rather than the driver data as the data pointer so free_irq() wouldn't have matched. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: add driver for TWL4030 vibrator deviceJari Vanhala
TWL4030 Vibrator implemented via Force Feedback interface. This uses MFD TWL4030 codec and own dynamic workqueue. Signed-off-by: Jari Vanhala <ext-jari.vanhala@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-08Input: scancode in get/set_keycodes should be unsignedDmitry Torokhov
The HID layer has some scan codes of the form 0xffbc0000 for logitech devices which do not work if scancode is typed as signed int, so we need to switch to unsigned it instead. While at it keycode being signed does not make much sense either. Acked-by: Márton Németh <nm127@freemail.hu> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-07input: Support onkey in 88pm860xHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits) Input: atkbd - release previously reserved keycodes 248 - 254 Input: add KEY_WPS_BUTTON definition Input: ads7846 - add regulator support Input: winbond-cir - fix suspend/resume Input: gamecon - use pr_err() and friends Input: gamecon - constify some of the setup structures Input: gamecon - simplify pad type handling Input: gamecon - simplify coordinate calculation for PSX Input: gamecon - fix some formatting issues Input: gamecon - add rumble support for N64 pads Input: wacom - add device type to device name string Input: s3c24xx_ts - report touch only when stylus is down Input: s3c24xx_ts - re-enable IRQ on resume Input: wacom - constify product features data Input: wacom - use per-device instance of wacom_features Input: sh_keysc - enable building on SH-Mobile ARM Input: wacom - get features from driver info Input: rotary-encoder - set gpio direction for each requested gpio Input: sh_keysc - update the driver with mode 6 Input: sh_keysc - switch to using bitmaps ...
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-02-28Merge branch 'next' into for-linusDmitry Torokhov
2010-02-24Input: winbond-cir - fix suspend/resumeDavid Härdeman
This fixes suspend/resume problem with the driver caused by the fact that ACPI _DIS method would completely power off the SP3 module leaving the output lines (including IRQ lines) in an undefined state. This could cause spurious interrupts and requires reinitializing hardware from scratch during resume. This fixes: http://bugzilla.kernel.org/show_bug.cgi?id=15257 Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-02-10Input: rotary-encoder - set gpio direction for each requested gpioAndrew Clayton
Even with the correct pin mux settings, you still need to explicitly set the gpio direction. Call gpio_direction_input() after each requested gpio. Signed-off-by: Andrew Clayton <andrew@digital-domain.net> Signed-off-by: Mark Somerville <mark@scottishclimbs.com> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-04Input: uinput - mark as non-seekableDmitry Torokhov
Seeking does not make sense for uinput so let's use nonseekable_open to mark the device non-seekable. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-29Input: uinput - remove BKL from uinput_open functionThadeu Lima de Souza Cascardo
Commit 8702965848ed4bee27486a3e3d2ae34ebba6dd83 pushed down the BKL into uinput open function. However, there's nothing that needs locking in there. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: update multi-touch protocol documentation Input: add the ABS_MT_PRESSURE event Input: winbond-cir - remove dmesg spam Input: lifebook - add another Lifebook DMI signature Input: ad7879 - support auxiliary GPIOs via gpiolib
2010-01-28Input: winbond-cir - remove dmesg spamDavid Härdeman
I missed converting one dev_info call to deb_dbg before submitting the driver. Without this change, a message will be printed to dmesg for each button press if a RC6 remote is used. Signed-off-by: David Härdeman <david@hardeman.nu> Cc: stable <stable@kernel.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-28ACPI: replace acpi_integer by u64Lin Ming
acpi_integer is now obsolete and removed from the ACPICA code base, replaced by u64. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-21Merge commit 'v2.6.33-rc5' into nextDmitry Torokhov
2010-01-09Input: make i2c device ids constantMárton Németh
The id_table field of the struct i2c_driver is defined as constant in <linux/i2c.h> so it makes sense to mark the initialization data also constant. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: iforce - wait for command completion when closing the device Input: twl4030-pwrbutton - switch to using threaded IRQ Input: twl4030_keypad - switch to using threaded IRQ Input: lifebook - add CONFIG_DMI dependency Input: wistron - fix test for CONFIG_PM Input: psmouse - fix compile warning in hgpk module Input: matrix-keypad - handle cases when GPIOs can't be wakeup sources Input: iforce - fix oops on device disconnect Input: ff-memless - add notion of direction to for rumble effects Input: ff-memless - another fix for signed to unsigned overflow Input: ff-memless - start playing FF effects immediately Input: serio - do not mark kseriod freezable anymore Input: speed up suspend/shutdown for PS/2 mice and keyboards
2009-12-29Input: twl4030-pwrbutton - switch to using threaded IRQFelipe Balbi
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-29Input: wistron - fix test for CONFIG_PMRakib Mullick
This should fix the following compile warning: drivers/input/misc/wistron_btns.c:1331:5: warning: "CONFIG_PM" is not defined Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-13mfd: Rename all twl4030_i2c*Balaji T K
This patch renames function names like twl4030_i2c_write_u8, twl4030_i2c_read_u8 to twl_i2c_write_u8, twl_i2c_read_u8 and also common variable in twl-core.c Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Rename twl4030* driver files to enable re-useSantosh Shilimkar
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030 for OMAP3. The common modules like RTC, Regulator creates opportunity to re-use the most of the code from twl4030. This patch renames few common drivers twl4030* files to twl* to enable the code re-use. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-13mfd: Fix memleak in pcf50633_client_dev_registerLars-Peter Clausen
Since platform_device_add_data copies the passed data, the allocated subdev_pdata is never freed. A simple fix would be to either free subdev_pdata or put it onto the stack. But since the pcf50633 child devices can rely on beeing children of the pcf50633 core device it's much more elegant to get access to pcf50633 core structure through that link. This allows to get completly rid of pcf5033_subdev_pdata. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Paul Fertser <fercerpav@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits) Input: appletouch - give up maintainership Input: dm355evm_kbd - switch to using sparse keymap library Input: wistron_btns - switch to using sparse keymap library Input: add generic support for sparse keymaps Input: fix memory leak in force feedback core Input: wistron - remove identification strings from DMI table Input: psmouse - remove identification strings from DMI tables Input: atkbd - remove identification strings from DMI table Input: i8042 - remove identification strings from DMI tables DMI: allow omitting ident strings in DMI tables Input: psmouse - do not carry DMI data around Input: matrix-keypad - switch to using dev_pm_ops Input: keyboard - fix lack of locking when traversing handler->h_list Input: gpio_keys - scan gpio state at probe and resume time Input: keyboard - add locking around event handling Input: usbtouchscreen - add support for ET&T TC5UH touchscreen controller Input: xpad - add two new Xbox 360 devices Input: polled device - do not start polling if interval is zero Input: polled device - schedule first poll immediately Input: add S3C24XX touchscreen driver ...
2009-12-09Merge branch 'bkl-drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: agp: Remove the BKL from agp_open inifiband: Remove BKL from ipath_open() mips: Remove BKL from tb0219 drivers: Remove BKL from scx200_gpio drivers: Remove BKL from pc8736x_gpio parisc: Remove BKL from eisa_eeprom rtc: Remove BKL from efirtc input: Remove BKL from hp_sdc_rtc hw_random: Remove BKL from core macintosh: Remove BKL from ans-lcd nvram: Drop the bkl from non-generic nvram_llseek() nvram: Drop the bkl from nvram_llseek() mem_class: Drop the bkl from memory_open() spi: Remove BKL from spidev_open drivers: Remove BKL from cs5535_gpio drivers: Remove BKL from misc_open
2009-12-07Input: dm355evm_kbd - switch to using sparse keymap libraryDmitry Torokhov
2009-12-07Input: wistron_btns - switch to using sparse keymap libraryDmitry Torokhov
The keymap manipulation code was split into a library module, so let's make us of it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-04Input: wistron - remove identification strings from DMI tableDmitry Torokhov
The driver does not reference identification strings in DMI table and since these strings are no longer required by DMI core we can safely remove them and save some memory. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-23Input: do not overwrite the first part of phys stringMárton Németh
Use strlcat() to append a string to the previously created first part. Signed-off-by: Márton Németh <nm127@freemail.hu> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-05Merge commit 'v2.6.32-rc6' into nextDmitry Torokhov
2009-11-02Input: winbond-cir - select LEDS_TRIGGERSDavid Härdeman
drivers/input/misc/winbond-cir.c depends on LEDS_TRIGGERS so add an appropriate select to drivers/input/misc/Kconfig Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-02Merge commit 'v2.6.32-rc5' into for-linusDmitry Torokhov
2009-10-18Input: add open and close methods for polled devicesSamu Onkalo
Optional open and close methods for preparing and closing the device. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-18Input: hp_sdc_rtc - fix test in hp_sdc_rtc_read_rt()Roel Kluin
If left unsigned the hp_sdc_rtc_read_i8042timer() return value will not be checked correctly. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-14input: Remove BKL from hp_sdc_rtcThomas Gleixner
cycle_kernel_lock() was added during the big BKL pushdown. It should ensure the serializiation against driver init code. In this case there is nothing to serialize. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <20091010153349.884891604@linutronix.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Dmitry Torokhov <dtor@mail.ru>
2009-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - print debug data when testing AUX IRQ delivery Input: libps2 - fix dependancy on i8042 Input: fix rx51 board keymap Input: ad7879 - pass up error codes from probe functions Input: xpad - add BigBen Interactive XBOX 360 Controller Input: rotary_encoder - fix relative axis support Input: sparkspkr - move remove() functions to .devexit.text Input: wistron_btns - add DMI entry for Medion WIM2030 laptop
2009-10-05Input: rotary_encoder - fix relative axis supportH Hartley Sweeten
When the rotart_encoder driver is used to report relative axis information the "steps" in the platform data could be missing since it's not relevant. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-05Input: sparkspkr - move remove() functions to .devexit.textUwe Kleine-König
The function bbc_remove and grover_remove are used only wrapped by __devexit_p so define it using __devexit. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-05Input: wistron_btns - add DMI entry for Medion WIM2030 laptopSebastian Frei
Signed-off-by: Sebastian Frei <dr.nop@gmx.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24input: fix build failures caused by Kconfig Winbond WPCD376I Consumer IR ↵Ingo Molnar
hardware driver Kconfig entry Fix these warnings: drivers/built-in.o: In function `apanel_remove': apanel.c:(.text+0x56e852): undefined reference to `led_classdev_unregister' drivers/built-in.o: In function `apanel_probe': apanel.c:(.text+0x56eae3): undefined reference to `led_classdev_register' drivers/built-in.o: In function `acpi_fujitsu_hotkey_add': fujitsu-laptop.c:(.text+0x5d7647): undefined reference to `led_classdev_register' fujitsu-laptop.c:(.text+0x5d76b5): undefined reference to `led_classdev_register' drivers/built-in.o: In function `wbcir_probe': winbond-cir.c:(.devinit.text+0x5f375): undefined reference to `led_classdev_register' winbond-cir.c:(.devinit.text+0x5f663): undefined reference to `led_classdev_unregister' drivers/built-in.o: In function `wbcir_remove': winbond-cir.c:(.devexit.text+0x7f23): undefined reference to `led_classdev_unregister' drivers/built-in.o: In function `fujitsu_cleanup': fujitsu-laptop.c:(.exit.text+0xbe37): undefined reference to `led_classdev_unregister' fujitsu-laptop.c:(.exit.text+0xbe53): undefined reference to `led_classdev_unregister' It happens because the new INPUT_WINBOND_CIR driver relies on new-leds infrastructure - but does not select it in drivers/input/misc/Kconfig. But it selects LEDS_CLASS, which confuses a number of other drivers into thinking that all the leds infrastructure is in place. Fix this by selecting NEW_LEDS as well, like similar drivers do. Eventually, this whole leds infrastructure complexity should be cleaned up, it's been going on for years. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: David Härdeman <david@hardeman.nu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add driver for Atmel AT42QT2160 Sensor Chip Input: max7359 - use threaded IRQs Input: add driver for Maxim MAX7359 key switch controller Input: add driver for ADP5588 QWERTY I2C Keypad Input: add touchscreen driver for MELFAS MCS-5000 controller Input: add driver for OpenCores Keyboard Controller Input: dm355evm_keys - remove dm355evm_keys_hardirq Input: synaptics_i2c - switch to using __cancel_delayed_work() Input: ad7879 - add support for AD7889 Input: atkbd - rely on input core to restore state on resume Input: add generic suspend and resume for input devices Input: libps2 - additional locking for i8042 ports
2009-09-22input: add a driver for the Winbond WPCD376I Consumer IR hardwareDavid Härdeman
Add a driver for the the Consumer IR (CIR) functionality of the Winbond WPCD376I chipset (found on e.g. Intel DG45FC motherboards). Signed-off-by: David Härdeman <david@hardeman.nu> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17Input: dm355evm_keys - remove dm355evm_keys_hardirqDmitry Torokhov
The genirq already provides default hard IRQ handler for threaded IRQs, no need to implement our own here. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-17input: PCAP2 misc input driverDaniel Ribeiro
This is a driver for misc input events for the PCAP2 PMIC, it handles the Power key and the Headphone button. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: Ilya Petrov <ilya.muromec@gmail.com> Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17input: Add support for the WM831x ON pinMark Brown
The WM831x series of PMICs support control of initial power on through the ON pin on the device with soft control of the pin at other times. Represent this to userspace as KEY_POWER. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-13Input: wistron_btns - add keymap for AOpen 1557Dmitry Torokhov
This one does not have anything useful in DMI either so again we need to use: force=1 keymap=aopen1557 Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
