path: root/drivers/input/misc
2006-05-29Input: wistron - add support for AOpen Barebook 1559asmasc@theaterzentrum.at
2006-04-05Input: wistron - add support for Fujitsu N3510John Reed Riley
2006-04-05Input: wistron - add signature for Amilo M7400Stefan Rompf
2006-03-14Input: pcspkr - separate device and driver registrationMichael Neuling
The current pcspkr code combines the device and driver registration. This patch splits these, putting the device registration in the arch specific code. PowerPC and MIPS only have the pcspkr present sometimes. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-02-19Input: uinput - semaphore to mutex conversionDmitry Torokhov
2006-02-15Input: kill remnants of 98kbd{,-io} and 98spkrArthur Othieno
98kbd{,-io} and 98spkr all went out with PC98 subarch. Remove stale Makefile entries that remained. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-02-15Input: ixp4xx-beeper - fix compile errorAlessandro Zummo
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-29Input: add ixp4xx beeper driverAlessandro Zummo
This is a driver for beeper found in LinkSys NSLU2 boxes. It should work on any ixp4xx based platform. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
2006-01-10Input: wistron - do not crash if BIOS does not support interfaceMiloslav Trmac
offset can never be < 0 because it has type size_t. The driver currently oopses on insmod if BIOS does not support the interface, instead of refusing to load. Signed-off-by: Miloslav Trmac <mitr@volny.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-08[PATCH] small hp_sdc_rtc cleanup: use no_llseekMarcelo Tosatti
Use no_llseek function. Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com> Cc: "Brian S. Julin" <bri@calyx.com> Acked-by: Vojtech Pavlik <vojtech@suse.cz> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
2005-12-28Input: wistron - convert to the new platform device interfaceDmitry Torokhov
Do not use platform_device_register_simple() as it is going away, implement ->probe() and ->remove() functions so manual binding and unbinding would work. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-12-22[SPARC]: introduce a SPARC Kconfig symbolAdrian Bunk
Introduce a Kconfig symbol SPARC that is defined on both the sparc and sparc64 architectures. This symbol makes some dependencies more readable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-21Input: sparcspkr - register with driver core as a platfrom deviceDmitry Torokhov
2005-12-21Input: m68kspkr - register with driver core as a platfrom deviceDmitry Torokhov
2005-12-21Input: pcspkr - register with driver core as a platfrom deviceDmitry Torokhov
2005-12-20Manual merge with Linus (conflict in drivers/input/misc/wistron_bnts.c)Dmitry Torokhov
2005-12-15[PATCH] drivers/input/misc/wistron_btns.c NULL noise removalAl Viro
2005-12-11Input: wistron - add Acer TravelMate 240 to DMI tableAshutosh Naik
Signed-off-by: Ashutosh Naik <ashutosh.naik@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: uinput - don't use "interruptible" in FF codeDmitry Torokhov
If thread that submitted FF request gets interrupted somehow it will release request structure and ioctl handler will work with freed memory. TO prevent that from happening switch to using wait_for_completion instead of wait_for_completion_interruptible. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: uinput - add UI_SET_SWBIT ioctlDmitry Torokhov
2005-11-20Input: uinput - convert to dynalloc allocationDmitry Torokhov
Also introduce proper locking when creating/deleting device. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: wistron - disable wifi/bluetooth on suspendMiloslav Trmac
Try to save battery power by disabling wifi and bluetooth on suspend. Signed-off-by: Miloslav Trmac <mitr@volny.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: wistron - add PM supportDmitry Torokhov
Register wistron-bios as a platform device, restore WIFI and Bluetooth state upon resume. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: wistron - convert to dynamic input_dev allocationDmitry Torokhov
2005-11-20Input: wistron - add support for Acer Aspire 1500 notebooksBernhard Rosenkraenzer
Also fix a potential issue with some notebooks: The current code assumes the response to bios_wifi_get_default_setting is either 1 (disabled) or 3 (enabled), or wifi isn't supported. The BIOS response appears to be a bit field w/ 0x1 indicating hardware presence, 0x2 indicating actiation status, and the other 6 bits being unknown/reserved -- with the patch, these 6 bits are ignored. Signed-off-by: Bernhard Rosenkraenzer <bero@arklinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: wistron - disable for x86_64Andrew Morton
On x86_64: {standard input}:233: Error: suffix or operands invalid for `push' {standard input}:233: Error: suffix or operands invalid for `pop' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-20Input: add Wistron driverDmitry Torokhov
A driver for laptop buttons using an x86 BIOS interface that is apparently used on quite a few laptops and seems to be originating from Wistron. This driver currently "knows" only about Fujitsu-Siemens Amilo Pro V2000 (i.e. it can detect the laptop using DMI and it contains the keycode->key meaning mapping for this laptop) and Xeron SonicPro X 155G (probably can't be reliably autodetected, requires a module parameter), adding other laptops should be easy. In addition to reporting button presses to the input layer the driver also allows enabling/disabling the embedded wireless NIC (using the "Wifi" button); this is done using the same BIOS interface, so it seems only logical to keep the implementation together. Any flexibility possibly gained by allowing users to remap the function of the "Wifi" button is IMHO not worth it when weighted against the necessity to run an user-space daemon to convert button presses to wifi state changes. Signed-off-by: Miloslav Trmac <mitr@volny.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-11-07[PATCH] kfree cleanup: misc remaining driversJesper Juhl
This is the remaining misc drivers/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in misc files in drivers/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Acked-by: Roland Dreier <rolandd@cisco.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <len.brown@intel.com> Acked-by: "Antonino A. Daplas" <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Input: pcspkr - fix setting name and phys for the deviceDmitry Torokhov
2005-10-30[PATCH] CONFIG_IA32Brian Gerst
Add CONFIG_X86_32 for i386. This allows selecting options that only apply to 32-bit systems. (X86 && !X86_64) becomes X86_32 (X86 || X86_64) becomes X86 Signed-off-by: Brian Gerst <bgerst@didntduck.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] missing bits in sparkspkr conversionAl Viro
2005-10-28[PATCH] Input: convert driver/input/misc to dynamic input_dev allocationDmitry Torokhov
Input: convert driver/input/misc to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-17[PATCH] uniput - fix crash on SMPDmitry Torokhov
Only signal completion after marking request slot as free, otherwise other processor can free request structure before we finish using it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30Input: make name, phys and uniq be 'const char *' because onceDmitry Torokhov
set noone should attempt to change them. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-30Input: uinput - use completions instead of events and manualDmitry Torokhov
wakeups in force feedback code. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-06-30Input: clean up uinput driver (formatting, extra braces)Dmitry Torokhov
2005-06-01Input: return correct value when setting up absolute device via uinipt.Ian Campbell
uinput_alloc_device() is supposed to return the number of bytes read, the value is returned to uinput_write() and from there to userspace. If EV_ABS is set then it returns the value from uinput_validate_absbits() instead, which is zero when everything is ok instead of the count. Signed-off-by: Ian Campbell <icampbell@arcom.com> Acked-by: Aristeu Rozanski <aris@cathedrallabs.org> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
