CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Since commit 1c6c69525b ("genirq: Reject bogus threaded irq requests")
threaded IRQs without a primary handler need to be requested with
IRQF_ONESHOT, otherwise the request will fail. This patch adds the
IRQF_ONESHOT to input drivers where it is missing. Not modified by
this patch are those drivers where the requested IRQ will always be a
nested IRQ (e.g. because it's part of an MFD), since for this special
case IRQF_ONESHOT is not required to be specified when requesting the
IRQ.
This patch converts the drivers in drivers/input/* to use the
module_i2c_driver() macro which makes the code smaller and a bit
simpler.
A few new i2c-drivers came into the kernel which clear the clientdata
pointer on exit or error. This is not required anymore since the core
will do it for us.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
Adding the necessary MODULE_DEVICE_TABLE() information allows the
driver to be automatically loaded by udev
The AT42QT1070 QTouch sensor supports up to 7 keys.
The driver has been tested on Atmel AT91SAM9M10-G45-EK board, and it
should work fine on other platforms.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
