The caller of this function (parisc_driver_remove() in
arch/parisc/kernel/drivers.c) ignores the return value, so better don't
return any value at all to not wake wrong expectations in driver authors.
The only function that could return a non-zero value before was
ipmi_parisc_remove() which returns the return value of
ipmi_si_remove_by_dev(). Make this function return void, too, as for all
other callers the value is ignored, too.
Also fold in a small checkpatch fix for:
WARNING: Unnecessary space before function pointer arguments
+ void (*remove) (struct parisc_device *dev);
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> (for drivers/input)
Acked-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Acked-by: Jiri Slaby <jirislaby@kernel.org>
Signed-off-by: Helge Deller <deller@gmx.de>
Based on 1 normalized pattern(s):
this file is subject to the terms and conditions of the gnu general
public license version 2 see the file copying in the main directory
of this archive for more details
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 9 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531081036.888539456@linutronix.de
Redirect some older email addresses that are in the git logs.
Signed-off-by: Matthew Wilcox <willy@infradead.org>
Internally, hilkbd uses "unsigned long" I/O addresses everywhere.
This works fine as:
- On PA-RISC, hilkbd uses the gsc_{read,write}b() I/O accessors, which
take "unsigned long" addresses,
- On m68k, hilkbd uses {read,write}b(), which are currently mapped to
{in,out}_8(), and convert the passed addresses to pointers
internally.
However, the asm-generic version of {read,write}b() does not perform
such conversions, and requires passing pointers instead. Hence add
casts to prepare for switching m68k to the asm-generic version.
Acked-by: Greg Ungerer <gerg@linux-m68k.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
On parisc machines, which don't have HIL, removing the hilkbd module
panics the kernel. Fix this by adding proper implementations for the
probe and remove functions to the parisc_driver structure.
A few functions were renamed to clean up the code and make it easier
readable.
Disable the MODULE_DEVICE_TABLE() macro on parisc since the kernel
module autoloader should instead prefer the hp_sdc driver which takes
care of full HIL support, including HIL mouse and HIL tablets.
[dtor@mail.ru: fix some section markups]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Some input drivers do not check whether they're actually running on the
correct platform, causing multi-platform kernels to crash if they are not.
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits)
Input: gpio_keys - add support for switches (EV_SW)
Input: cobalt_btns - convert to use polldev library
Input: add skeleton for simple polled devices
Input: update some documentation
Input: wistron - fix typo in keymap for Acer TM610
Input: add input_set_capability() helper
Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs
Input: i8042 - add Panasonic CF-29 to nomux list
Input: lifebook - split into 2 devices
Input: lifebook - add signature of Panasonic CF-29
Input: lifebook - activate 6-byte protocol on select models
Input: lifebook - work properly on Panasonic CF-18
Input: cobalt buttons - separate device and driver registration
Input: ati_remote - make button repeat sensitivity configurable
Input: pxa27x - do not use deprecated SA_INTERRUPT flag
Input: ucb1400 - make delays configurable
Input: misc devices - switch to using input_dev->dev.parent
Input: joysticks - switch to using input_dev->dev.parent
Input: touchscreens - switch to using input_dev->dev.parent
Input: mice - switch to using input_dev->dev.parent
Fixed up conflicts with core device model removal of "struct subsystem" manually.
hilkbd: Kill compiler warning and fix comment dyslexia
Use input_get_drvdata() and input_set_drvdata() instead.
- mark some structures const or __read_mostly
- hilkbd.c: fix uninitialized spinlock in HIL keyboard driver
- hil_mlc.c: use USEC_PER_SEC instead of 1000000
- hp_sdc: bugfix for request_irq()/free_irq() parameters, this prevented
multiple load/unload cycles as module
Do not call release_region() if the code has been compiled
without CONFIG_HP300 support.
Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com>
Acked-by: Helge Deller <deller@gmx.de>
Also some whitespace cleanup.
Now that it's built on m68k too...
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
On Thu, Mar 30, 2006 at 08:31:02AM -0500, Dmitry Torokhov wrote:
> Don't do that, its double free. input_unregister_device() normally
> causes release() to be called and free the device. input_free_device
> is only to be called when input_register_device has not been called or
> failed.
> Plus you might want to unregister device after closing serio port,
> otherwise your interrupt routine might be referencing already freed
> memory.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Convert HIL drivers to use input_allocate_device() - avoids crashes.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Update drivers to new input layer changes.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Reorder code in gscps2_interrupt() and only enable ports when opened.
This fixes issues with hangs booting an SMP kernel on my C360.
Previously serio_interrupt() could be called before the lock in
struct serio was initialised.
Signed-off-by: Richard Hirst <rhirst@parisc-linux.org>
Convert pa_dev->hpa from an unsigned long to a struct resource.
Fix up users of ->hpa to use ->hpa.start instead.
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver
names.
infrastructure for it.
Let it rip!
