path: root/drivers/infiniband
2017-05-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "Things were a lot more calm than previously expected. It's primarily fixes in various areas, with most of the new functionality centering around TCMU backend driver work that Xiubo Li has been driving. Here's the summary on the feature side: - Make T10-PI verify configurable for emulated (FILEIO + RD) backends (Dmitry Monakhov) - Allow target-core/TCMU pass-through to use in-kernel SPC-PR logic (Bryant Ly + MNC) - Add TCMU support for growing ring buffer size (Xiubo Li + MNC) - Add TCMU support for global block data pool (Xiubo Li + MNC) and on the bug-fix side: - Fix COMPARE_AND_WRITE non GOOD status handling for READ phase failures (Gary Guo + nab) - Fix iscsi-target hang with explicitly changing per NodeACL CmdSN number depth with concurrent login driven session reinstatement. (Gary Guo + nab) - Fix ibmvscsis fabric driver ABORT task handling (Bryant Ly) - Fix target-core/FILEIO zero length handling (Bart Van Assche) Also, there was an OOPs introduced with the WRITE_VERIFY changes that I ended up reverting at the last minute, because as not unusual Bart and I could not agree on the fix in time for -rc1. Since it's specific to a conformance test, it's been reverted for now. There is a separate patch in the queue to address the underlying control CDB write overflow regression in >= v4.3 separate from the WRITE_VERIFY revert here, that will be pushed post -rc1" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (30 commits) Revert "target: Fix VERIFY and WRITE VERIFY command parsing" IB/srpt: Avoid that aborting a command triggers a kernel warning IB/srpt: Fix abort handling target/fileio: Fix zero-length READ and WRITE handling ibmvscsis: Do not send aborted task response tcmu: fix module removal due to stuck thread target: Don't force session reset if queue_depth does not change iscsi-target: Set session_fall_back_to_erl0 when forcing reinstatement target: Fix compare_and_write_callback handling for non GOOD status tcmu: Recalculate the tcmu_cmd size to save cmd area memories tcmu: Add global data block pool support tcmu: Add dynamic growing data area feature support target: fixup error message in target_tg_pt_gp_tg_pt_gp_id_store() target: fixup error message in target_tg_pt_gp_alua_access_type_store() target/user: PGR Support target: Add WRITE_VERIFY_16 Documentation/target: add an example script to configure an iSCSI target target: Use kmalloc_array() in transport_kmap_data_sg() target: Use kmalloc_array() in compare_and_write_callback() target: Improve size determinations in two functions ...
2017-05-09Merge tag 'iommu-updates-v4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: - code optimizations for the Intel VT-d driver - ability to switch off a previously enabled Intel IOMMU - support for 'struct iommu_device' for OMAP, Rockchip and Mediatek IOMMUs - header optimizations for IOMMU core code headers and a few fixes that became necessary in other parts of the kernel because of that - ACPI/IORT updates and fixes - Exynos IOMMU optimizations - updates for the IOMMU dma-api code to bring it closer to use per-cpu iova caches - new command-line option to set default domain type allocated by the iommu core code - another command line option to allow the Intel IOMMU switched off in a tboot environment - ARM/SMMU: TLB sync optimisations for SMMUv2, Support for using an IDENTITY domain in conjunction with DMA ops, Support for SMR masking, Support for 16-bit ASIDs (was previously broken) - various other small fixes and improvements * tag 'iommu-updates-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (63 commits) soc/qbman: Move dma-mapping.h include to qman_priv.h soc/qbman: Fix implicit header dependency now causing build fails iommu: Remove trace-events include from iommu.h iommu: Remove pci.h include from trace/events/iommu.h arm: dma-mapping: Don't override dma_ops in arch_setup_dma_ops() ACPI/IORT: Fix CONFIG_IOMMU_API dependency iommu/vt-d: Don't print the failure message when booting non-kdump kernel iommu: Move report_iommu_fault() to iommu.c iommu: Include device.h in iommu.h x86, iommu/vt-d: Add an option to disable Intel IOMMU force on iommu/arm-smmu: Return IOVA in iova_to_phys when SMMU is bypassed iommu/arm-smmu: Correct sid to mask iommu/amd: Fix incorrect error handling in amd_iommu_bind_pasid() iommu: Make iommu_bus_notifier return NOTIFY_DONE rather than error code omap3isp: Remove iommu_group related code iommu/omap: Add iommu-group support iommu/omap: Make use of 'struct iommu_device' iommu/omap: Store iommu_dev pointer in arch_data iommu/omap: Move data structures to omap-iommu.h iommu/omap: Drop legacy-style device support ...
2017-05-09Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted bits and pieces from various people. No common topic in this pile, sorry" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs/affs: add rename exchange fs/affs: add rename2 to prepare multiple methods Make stat/lstat/fstatat pass AT_NO_AUTOMOUNT to vfs_statx() fs: don't set *REFERENCED on single use objects fs: compat: Remove warning from COMPATIBLE_IOCTL remove pointless extern of atime_need_update_rcu() fs: completely ignore unknown open flags fs: add a VALID_OPEN_FLAGS fs: remove _submit_bh() fs: constify tree_descr arrays passed to simple_fill_super() fs: drop duplicate header percpu-rwsem.h fs/affs: bugfix: Write files greater than page size on OFS fs/affs: bugfix: enable writes on OFS disks fs/affs: remove node generation check fs/affs: import amigaffs.h fs/affs: bugfix: make symbolic links work again
2017-05-08Merge tags 'for-linus' and 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull more rdma updates from Doug Ledford: "As mentioned in my first pull request, this is the subsequent pull requests I had. This is all I have, and in fact this cleans out the RDMA subsystem's entire patchworks queue of kernel changes that are ready to go (well, it did for the weekend anyway, a few new patches are in, but they'll be coming during the -rc cycle). The first tag contains a single patch that would have conflicted if taken from my tree or DaveM's tree as it needed our trees merged to come cleanly. The second tag contains the patch series from Intel plus three other stragllers that came in late last week. I took them because it allowed me to legitimately claim that the RDMA patchworks queue was, for a short time, 100% cleared of all waiting kernel patches, woohoo! :-). I have it under my for-next tag, so it did get 0day and linux- next over the end of last week, and linux-next did show one minor conflict. Summary: 'for-linus' tag: - mlx5/IPoIB fixup patch 'for-next' tag: - the hfi1 15 patch set that landed late - IPoIB get_link_ksettings which landed late because I asked for a respin - one late rxe change - one -rc worthy fix that's in early" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: IB/mlx5: Enable IPoIB acceleration * tag 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: rxe: expose num_possible_cpus() cnum_comp_vectors IB/rxe: Update caller's CRC for RXE_MEM_TYPE_DMA memory type IB/hfi1: Clean up on context initialization failure IB/hfi1: Fix an assign/ordering issue with shared context IDs IB/hfi1: Clean up context initialization IB/hfi1: Correctly clear the pkey IB/hfi1: Search shared contexts on the opened device, not all devices IB/hfi1: Remove atomic operations for SDMA_REQ_HAVE_AHG bit IB/hfi1: Use filedata rather than filepointer IB/hfi1: Name function prototype parameters IB/hfi1: Fix a subcontext memory leak IB/hfi1: Return an error on memory allocation failure IB/hfi1: Adjust default eager_buffer_size to 8MB IB/hfi1: Get rid of divide when setting the tx request header IB/hfi1: Fix yield logic in send engine IB/hfi1, IB/rdmavt: Move r_adefered to r_lock cache line IB/hfi1: Fix checks for Offline transient state IB/ipoib: add get_link_ksettings in ethtool
2017-05-08Merge tag 'pci-v4.12-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - add framework for supporting PCIe devices in Endpoint mode (Kishon Vijay Abraham I) - use non-postable PCI config space mappings when possible (Lorenzo Pieralisi) - clean up and unify mmap of PCI BARs (David Woodhouse) - export and unify Function Level Reset support (Christoph Hellwig) - avoid FLR for Intel 82579 NICs (Sasha Neftin) - add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig) - short-circuit config access failures for disconnected devices (Keith Busch) - remove D3 sleep delay when possible (Adrian Hunter) - freeze PME scan before suspending devices (Lukas Wunner) - stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava) - disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann) - add arch-specific alignment control to improve device passthrough by avoiding multiple BARs in a page (Yongji Xie) - add sysfs sriov_drivers_autoprobe to control VF driver binding (Bodong Wang) - allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas) - fix crashes when unbinding host controllers that don't support removal (Brian Norris) - add driver for MicroSemi Switchtec management interface (Logan Gunthorpe) - add driver for Faraday Technology FTPCI100 host bridge (Linus Walleij) - add i.MX7D support (Andrey Smirnov) - use generic MSI support for Aardvark (Thomas Petazzoni) - make Rockchip driver modular (Brian Norris) - advertise 128-byte Read Completion Boundary support for Rockchip (Shawn Lin) - advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin) - convert atomic_t to refcount_t in HV driver (Elena Reshetova) - add CPU IRQ affinity in HV driver (K. Y. Srinivasan) - fix PCI bus removal in HV driver (Long Li) - add support for ThunderX2 DMA alias topology (Jayachandran C) - add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki) - add ITE 8893 bridge DMA alias quirk (Jarod Wilson) - restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices (Manish Jaggi) * tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits) PCI: Don't allow unbinding host controllers that aren't prepared ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP MAINTAINERS: Add PCI Endpoint maintainer Documentation: PCI: Add userguide for PCI endpoint test function tools: PCI: Add sample test script to invoke pcitest tools: PCI: Add a userspace tool to test PCI endpoint Documentation: misc-devices: Add Documentation for pci-endpoint-test driver misc: Add host side PCI driver for PCI test function device PCI: Add device IDs for DRA74x and DRA72x dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access PCI: dwc: dra7xx: Workaround for errata id i870 dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode PCI: dwc: dra7xx: Add EP mode support PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently dt-bindings: PCI: Add DT bindings for PCI designware EP mode PCI: dwc: designware: Add EP mode support Documentation: PCI: Add binding documentation for pci-test endpoint function ixgbe: Use pcie_flr() instead of duplicating it IB/hfi1: Use pcie_flr() instead of duplicating it PCI: imx6: Fix spelling mistake: "contol" -> "control" ...
2017-05-08scripts/spelling.txt: add regsiter -> register spelling mistakeStephen Boyd
This typo is quite common. Fix it and add it to the spelling file so that checkpatch catches it earlier. Link: http://lkml.kernel.org/r/20170317011131.6881-2-sboyd@codeaurora.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08scripts/spelling.txt: add "memory" pattern and fix typosStephen Boyd
Fix typos and add the following to the scripts/spelling.txt: momery||memory Link: http://lkml.kernel.org/r/20170317011131.6881-1-sboyd@codeaurora.org Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-07IB/srpt: Avoid that aborting a command triggers a kernel warningBart Van Assche
Avoid that the following warning is triggered: WARNING: CPU: 10 PID: 166 at ../drivers/infiniband/ulp/srpt/ib_srpt.c:2674 srpt_release_cmd+0x139/0x140 [ib_srpt] CPU: 10 PID: 166 Comm: kworker/u24:8 Not tainted 4.9.4-1-default #1 Workqueue: tmr-fileio target_tmr_work [target_core_mod] Call Trace: [<ffffffffaa3c4f70>] dump_stack+0x63/0x83 [<ffffffffaa0844eb>] __warn+0xcb/0xf0 [<ffffffffaa0845dd>] warn_slowpath_null+0x1d/0x20 [<ffffffffc06ba429>] srpt_release_cmd+0x139/0x140 [ib_srpt] [<ffffffffc06e4377>] target_release_cmd_kref+0xb7/0x120 [target_core_mod] [<ffffffffc06e4d7f>] target_put_sess_cmd+0x2f/0x60 [target_core_mod] [<ffffffffc06e15e0>] core_tmr_lun_reset+0x340/0x790 [target_core_mod] [<ffffffffc06e4816>] target_tmr_work+0xe6/0x140 [target_core_mod] [<ffffffffaa09e4d3>] process_one_work+0x1f3/0x4d0 [<ffffffffaa09e7f8>] worker_thread+0x48/0x4e0 [<ffffffffaa09e7b0>] ? process_one_work+0x4d0/0x4d0 [<ffffffffaa0a46da>] kthread+0xca/0xe0 [<ffffffffaa0a4610>] ? kthread_park+0x60/0x60 [<ffffffffaa71b775>] ret_from_fork+0x25/0x30 Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: David Disseldorp <ddiss@suse.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2017-05-07IB/srpt: Fix abort handlingBart Van Assche
Let the target core check the CMD_T_ABORTED flag instead of the SRP target driver. Hence remove the transport_check_aborted_status() call. Since state == SRPT_STATE_CMD_RSP_SENT is something that really should not happen, do not try to recover if srpt_queue_response() is called for an I/O context that is in that state. This patch is a bug fix because the srpt_abort_cmd() call is misplaced - if that function is called from srpt_queue_response() it should either be called before the command state is changed or after the response has been sent. Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andy Grover <agrover@redhat.com> Cc: David Disseldorp <ddiss@suse.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2017-05-04Merge tag 'char-misc-4.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big set of new char/misc driver drivers and features for 4.12-rc1. There's lots of new drivers added this time around, new firmware drivers from Google, more auxdisplay drivers, extcon drivers, fpga drivers, and a bunch of other driver updates. Nothing major, except if you happen to have the hardware for these drivers, and then you will be happy :) All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (136 commits) firmware: google memconsole: Fix return value check in platform_memconsole_init() firmware: Google VPD: Fix return value check in vpd_platform_init() goldfish_pipe: fix build warning about using too much stack. goldfish_pipe: An implementation of more parallel pipe fpga fr br: update supported version numbers fpga: region: release FPGA region reference in error path fpga altera-hps2fpga: disable/unprepare clock on error in alt_fpga_bridge_probe() mei: drop the TODO from samples firmware: Google VPD sysfs driver firmware: Google VPD: import lib_vpd source files misc: lkdtm: Add volatile to intentional NULL pointer reference eeprom: idt_89hpesx: Add OF device ID table misc: ds1682: Add OF device ID table misc: tsl2550: Add OF device ID table w1: Remove unneeded use of assert() and remove w1_log.h w1: Use kernel common min() implementation uio_mf624: Align memory regions to page size and set correct offsets uio_mf624: Refactor memory info initialization uio: Allow handling of non page-aligned memory regions hangcheck-timer: Fix typo in comment ...
2017-05-04rxe: expose num_possible_cpus() cnum_comp_vectorsSagi Grimberg
They're completely logical, so don't impose an artificial limitation. Signed-off-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Acked-by: Moni Shoua <monis@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/rxe: Update caller's CRC for RXE_MEM_TYPE_DMA memory typeLeon Romanovsky
Callers of rxe_mem_copy() provide pointer to store updated CRC value. That pointer was supposed to be updated, but the commit cee2688e3cd6 ("IB/rxe: Offload CRC calculation when possible") mistakenly removed that assignment for RXE_MEM_TYPE_DMA memory type. The code worked because there are no actual callers with RXE_MEM_TYPE_DMA, who are interested in returned value of crcp. The one caller in read_reply(), who uses the returned crcp didn't set RXE_MEM_TYPE_DMA as mem->type. Fixes: cee2688e3cd6 ("IB/rxe: Offload CRC calculation when possible") Reported-by: Andrew Boyer <andrew.boyer@dell.com> Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Acked-by: Moni Shoua <monis@mellanox.com> Reviewed-by: Andrew Boyer <andrew.boyer@dell.com> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Clean up on context initialization failureMichael J. Ruhl
The error path for context initialization is not consistent. Cleanup all resources on failure. Removed unused variable user_event_mask. Add the _BASE_FAILED bit to the event flags so that a base context can notify waiting sub contexts that they cannot continue. Running out of sub contexts is an EBUSY result, not EINVAL. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Fix an assign/ordering issue with shared context IDsMichael J. Ruhl
The current algorithm for generating sub-context IDs is FILO. If the contexts are not closed in that order, the uniqueness of the ID will be compromised. I.e. logging the creation/deletion of context IDs with an application that assigns and closes in a FIFO order reveals: cache_id: assign: uctxt: 3 sub_ctxt: 0 cache_id: assign: uctxt: 3 sub_ctxt: 1 cache_id: assign: uctxt: 3 sub_ctxt: 2 cache_id: close: uctxt: 3 sub_ctxt: 0 cache_id: assign: uctxt: 3 sub_ctxt: 2 <<< The sub_ctxt ID 2 is reused incorrectly. Update the sub-context ID assign algorithm to use a bitmask of in_use contexts. The new algorithm will allow the contexts to be closed in any order, and will only re-use unused contexts. Size subctxt and subctxt_cnt to match the user API size. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Clean up context initializationMichael J. Ruhl
Context initialization mixes base context init with sub context init. This is bad because contexts can be reused, and on reuse, reinit things that should not re-initialized. Normalize comments and function names to refer to base context and sub context (not main, shared or slaves). Separate the base context initialization from sub context initialization. hfi1_init_ctxt() cannot return an error so changed to a void and remove error message. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Correctly clear the pkeyMichael J. Ruhl
In the close path the context is removed from the device array, and then the clear pkey function is called. The pkey function trys to get the context from the device array, but because it was removed the clearing does not occur. Rework pkey clear function to work as expected. Update the function variable to reflect the correct size and name of the hw_context. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Search shared contexts on the opened device, not all devicesMichael J. Ruhl
The search for available shared contexts walks each registered hfi1 device. This search is too broad because other devices may not be on the same fabric, and using its contexts could cause unexpected behavior. Removed walking the list of devices, limiting the search to the opened device. With the device walk removed, the hfi1_devdata (dd) is not available. Added it to the hfi1_filedata for reference. With this change, hfi1_count_units() was rendered obsolete and was removed. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Remove atomic operations for SDMA_REQ_HAVE_AHG bitSebastian Sanchez
The AHG index is only accessed in the request call from user space, so there's no need for atomic semantics. Replace atomic operations for SDMA_REQ_HAVE_AHG bit with a test of the AHG index. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Use filedata rather than filepointerMichael J. Ruhl
Since almost all functions that use the hfi1_filedata get the pointer from the file pointer, simplify by only passing the hfi1_filedata pointer. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Name function prototype parametersMichael J. Ruhl
To improve the readability of function prototypes, give the parameters names. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Fix a subcontext memory leakMichael J. Ruhl
The only context that frees user_exp_rcv data structures is the last context closed (from a sub-context set). This leaks the allocations from the other sub-contexts. Separate the common frees from the specific frees and call them at the appropriate time. Using KEDR to check for memory leaks we get: Before test: [leak_check] Possible leaks: 25 After test: [leak_check] Possible leaks: 31 (6 leaked data structures) After patch applied (before and after test have the same value) [leak_check] Possible leaks: 25 Each leak is 192 + 13440 + 6720 = 20352 bytes per sub-context. Cc: stable@vger.kernel.org Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Return an error on memory allocation failureMichael J. Ruhl
If the eager buffer allocation fails, it is necessary to return an error code. Cc: stable@vger.kernel.org Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michael J. Ruhl <michael.j.ruhl@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Adjust default eager_buffer_size to 8MBTymoteusz Kielan
Performance analysis shows benefits for PSM2 in increasing eager buffer size from 2MB to 8MB. The change has neutral impact on verbs. Make change to the module parameter's default value. Allocation ring down was verified to work with the larger buffer size. Reviewed-by: Tadeusz Struk <tadeusz.struk@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Tymoteusz Kielan <tymoteusz.kielan@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Get rid of divide when setting the tx request headerSebastian Sanchez
Div instructions show costly in profiles when the tx request header is set. Using right shift instead of a divide operation reduces the cycles spent in the function that sets the tx request header as shown in the profile. Use right shift operation instead. Profile before change: 43.24% 009 | |--23.41%-- user_sdma_send_pkts | | | |--99.90%-- hfi1_user_sdma_process_requestAfter: Profile after change: 45.75% 009 | |--14.81%-- user_sdma_send_pkts | | | |--99.95%-- hfi1_user_sdma_process_request Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Fix yield logic in send engineMike Marciniszyn
When there are many RC QPs and an RDMA READ request is sent, timeouts occur on the requester side because of fairness among RC QPs on their relative SDMA engine on the responder side. This also hits write and send, but to a lesser extent. Complicating the issue is that the current code checks if workqueue is congested before scheduling other QPs, however, this check is based on the number of active entries in the workqueue, which was found to be too big to for workqueue_congested() to be effective. Fix by reducing the number of active entries as revealed by experimentation from the default of num_sdma to HFI1_MAX_ACTIVE_WORKQUEUE_ENTRIES. Retry counts were monitored to determine the correct value. Tracing to investigate any future issues is also added. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1, IB/rdmavt: Move r_adefered to r_lock cache lineMike Marciniszyn
This field is causing excessive cache line bouncing. There are spare bytes in the r_lock cache line so the best approach is to make an rvt QP field and remove from the hfi1 priv field. Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/hfi1: Fix checks for Offline transient stateJakub Byczkowski
In goto_offline() function pstate is masked by 0xff when compared to PLS_OFFLINE state. Mask should be 0xf0, since upper 4 bits specify the "major" state. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Easwar Hariharan <easwar.hariharan@intel.com> Signed-off-by: Jakub Byczkowski <jakub.byczkowski@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/ipoib: add get_link_ksettings in ethtoolZhu Yanjun
In order to let the bonding driver report the correct speed of the underlaying interfaces, when they are IPoIB, the ethtool function get_link_ksettings() in the IPoIB driver is implemented. Cc: Joe Jin <joe.jin@oracle.com> Cc: Junxiao Bi <junxiao.bi@oracle.com> Suggested-by: Håkon Bugge <Haakon.Bugge@oracle.com> Signed-off-by: Zhu Yanjun <yanjun.zhu@oracle.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04IB/mlx5: Enable IPoIB accelerationErez Shitrit
Enable mlx5 IPoIB acceleration by declaring mlx5_ib_{alloc,free}_rdma_netdev and assigning the mlx5 IPoIB rdma_netdev callbacks. In addition, this patch brings in sync mlx5's IPoIB parts for net and IB trees. As a precaution, we disabled IPoIB acceleration by default (in the mlx5_core Kconfig file). Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Erez Shitrit <erezsh@mellanox.com> Signed-off-by: Leon Romanovsky <leon@kernel.org> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-04Merge branches 'arm/exynos', 'arm/omap', 'arm/rockchip', 'arm/mediatek', ↵Joerg Roedel
'arm/smmu', 'arm/core', 'x86/vt-d', 'x86/amd' and 'core' into next
2017-05-02infiniband: avoid dereferencing uninitialized dst on error pathPaolo Abeni
With commit eea40b8f624f ("infiniband: call ipv6 route lookup via the stub interface"), if the route lookup fails due to ipv6 being disabled, the dst variable is left untouched, and the following dst_release() may access uninitialized memory. Since ipv6_dst_lookup() always sets dst to NULL in case of lookup failure with ipv6 enabled, fix the above just returning the error code if the lookup fails. Fixes: eea40b8f624 ("infiniband: call ipv6 route lookup via the stub interface") Reported-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Paolo Abeni <pabeni@redhat.com> Reviewed-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/mlx5: Add port_xmit_wait to counter registers readTim Wright
Add port_xmit_wait to the error counters read by mlx5_ib_process_mad to ensure sysfs port counter provides correct value for PortXmitWait. Otherwise the sysfs port_xmit_wait file always contains zero. The previous MAD_IFC implementation populated this counter, but it was removed during the migration to PPCNT for error counters (32-bit only). Signed-off-by: Tim Wright <tim@binbash.co.uk> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/ocrdma: fix out of bounds access to local bufferMichael Mera
In write to debugfs file 'resource_stats' the local buffer 'tmp_str' is written at index 'count-1' where 'count' is the size of the write, so potentially 0. This patch filters odd values for the write size/position to avoid this type of problem. Signed-off-by: Michael Mera <dev@michaelmera.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/mlx4: Fix incorrect order of formal and actual parametersHåkon Bugge
The last two actual parameters when calling id_map_find_by_sl_id() from id_map_get() are swapped. However, the same formal parameters to id_map_get() have them swapped as well, inverting the effect of the first error. This commit improves readability, but makes no functional change to the code. Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com> Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com> Reviewed-by: Knut Omang <knut.omang@oracle.com> Acked-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/mlx4: Change flush logic so it adheres to the variable nameHåkon Bugge
Change and simplify the code to match the variable name. This commit improves readability but makes no functional change to the code. Signed-off-by: Håkon Bugge <haakon.bugge@oracle.com> Suggested-by: Wengang Wang <wen.gang.wang@oracle.com> Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com> Reviewed-by: Knut Omang <knut.omang@oracle.com> Acked-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01mlx5: Fix mlx5_ib_map_mr_sg mr lengthSagi Grimberg
In case we got an initial sg_offset, we need to account for it in the mr length. Cc: stable@vger.kernel.org Fixes: ff2ba9936591 ("IB/core: Add passing an offset into the SG to ib_map_mr_sg") Signed-off-by: Sagi Grimberg <sagi@grimberg.me> Tested-by: Israel Rukshin <israelr@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/rxe: Don't clamp residual length to mtuJohannes Thumshirn
When reading a RDMA WRITE FIRST packet we copy the DMA length from the RDMA header into the qp->resp.resid variable for later use. Later in check_rkey() we clamp it to the MTU if the packet is an RDMA WRITE packet and has a residual length bigger than the MTU. Later in write_data_in() we subtract the payload of the packet from the residual length. If the packet happens to have a payload of exactly the MTU size we end up with a residual length of 0 despite the packet not being the last in the conversation. When the next packet in the conversation arrives, we don't have any residual length left and thus set the QP into an error state. This broke NVMe over Fabrics functionality over rdma_rxe.ko The patch was verified using the following test. # echo eth0 > /sys/module/rdma_rxe/parameters/add # nvme connect -t rdma -a 192.168.155.101 -s 1023 -n nvmf-test # mkfs.xfs -fK /dev/nvme0n1 meta-data=/dev/nvme0n1 isize=256 agcount=4, agsize=65536 blks = sectsz=4096 attr=2, projid32bit=1 = crc=0 finobt=0, sparse=0 data = bsize=4096 blocks=262144, imaxpct=25 = sunit=0 swidth=0 blks naming =version 2 bsize=4096 ascii-ci=0 ftype=1 log =internal log bsize=4096 blocks=2560, version=2 = sectsz=4096 sunit=1 blks, lazy-count=1 realtime =none extsz=4096 blocks=0, rtextents=0 # mount /dev/nvme0n1 /tmp/ [ 148.923263] XFS (nvme0n1): Mounting V4 Filesystem [ 148.961196] XFS (nvme0n1): Ending clean mount # dd if=/dev/urandom of=test.bin bs=1M count=128 128+0 records in 128+0 records out 134217728 bytes (134 MB, 128 MiB) copied, 0.437991 s, 306 MB/s # sha256sum test.bin cde42941f045efa8c4f0f157ab6f29741753cdd8d1cff93a6b03649d83c4129a test.bin # cp test.bin /tmp/ sha256sum /tmp/test.bin cde42941f045efa8c4f0f157ab6f29741753cdd8d1cff93a6b03649d83c4129a /tmp/test.bin Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Sagi Grimberg <sagi@grimberg.me> Cc: Max Gurtovoy <maxg@mellanox.com> Acked-by: Moni Shoua <monis@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/SA: Add support to query OPA path recordsDasaratharaman Chandramouli
When the bit 26 of capmask2 field in OPA classport info query is set, SA will query for OPA path records instead of querying for IB path records. Note that OPA path records can only be queried by kernel ULPs. Userspace clients continue to query IB path records. Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/SA: Add OPA path record typeDasaratharaman Chandramouli
Add opa_sa_path_rec to sa_path_rec data structure. The 'type' field in sa_path_rec identifies the type of the path record. Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/SA: Split struct sa_path_rec based on IB and ROCE specific fieldsDasaratharaman Chandramouli
sa_path_rec now contains a union of sa_path_rec_ib and sa_path_rec_roce based on the type of the path record. Note that fields applicable to path record type ROCE v1 and ROCE v2 fall under sa_path_rec_roce. Accessor functions are added to these fields so the caller doesn't have to know the type. Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/SA: Introduce path record specific typesDasaratharaman Chandramouli
struct sa_path_rec has a gid_type field. This patch introduces a more generic path record specific type 'rec_type' which is either IB, ROCE v1 or ROCE v2. The patch also provides conversion functions to get a gid type from a path record type and vice versa Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/SA: Rename ib_sa_path_rec to sa_path_recDasaratharaman Chandramouli
Rename ib_sa_path_rec to a more generic sa_path_rec. This is part of extending ib_sa to also support OPA path records in addition to the IB defined path records. Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/CM: Add braces when using sizeofDasaratharaman Chandramouli
This patch adds braces around parameters to sizeof as called out by checkpatch Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/core: Define 'ib' and 'roce' rdma_ah_attr typesDasaratharaman Chandramouli
rdma_ah_attr can now be either ib or roce allowing core components to use one type or the other and also to define attributes unique to a specific type. struct ib_ah is also initialized with the type when its first created. This ensures that calls such as modify_ah dont modify the type of the address handle attribute. Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Niranjana Vishwanathapura <niranjana.vishwanathapura@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/core: Use rdma_ah_attr accessor functionsDasaratharaman Chandramouli
Modify core and driver components to use accessor functions introduced to access individual fields of rdma_ah_attr Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Niranjana Vishwanathapura <niranjana.vishwanathapura@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/PVRDMA: Rename ib_ah_attr related functionsDasaratharaman Chandramouli
Functions pvrdma_ah_attr_to_ib and ib_ah_attr_to_pvrdma have been renamed so they are in sync wit the rename of the ib_ah_attr structure Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/mthca: Rename to_ib_ah_attr to to_rdma_ah_attrDasaratharaman Chandramouli
local function to_ib_ah_attr is renamed so it in sync with the rename of the ib_ah_attr structure Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-01IB/mlx5: Rename to_ib_ah_attr to to_rdma_ah_attrDasaratharaman Chandramouli
2017-05-01IB/mlx4: Rename to_ib_ah_attr to to_rdma_ah_attrDasaratharaman Chandramouli
2017-05-01IB/core: Rename ib_destroy_ah to rdma_destroy_ahDasaratharaman Chandramouli
Rename ib_destroy_ah to rdma_destroy_ah so its in sync with the rename of the ib address handle attribute Reviewed-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Don Hiatt <don.hiatt@intel.com> Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-by: Niranjana Vishwanathapura <niranjana.vishwanathapura@intel.com> Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
