Pull dma-mapping updates from Christoph Hellwig:
- make support for dma_ops optional
- move more code out of line
- add generic support for a dma_ops bypass mode
- misc cleanups
* tag 'dma-mapping-5.9' of git://git.infradead.org/users/hch/dma-mapping:
dma-contiguous: cleanup dma_alloc_contiguous
dma-debug: use named initializers for dir2name
powerpc: use the generic dma_ops_bypass mode
dma-mapping: add a dma_ops_bypass flag to struct device
dma-mapping: make support for dma ops optional
dma-mapping: inline the fast path dma-direct calls
dma-mapping: move the remaining DMA API calls out of line
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull uninitialized_var() macro removal from Kees Cook:
"This is long overdue, and has hidden too many bugs over the years. The
series has several "by hand" fixes, and then a trivial treewide
replacement.
- Clean up non-trivial uses of uninitialized_var()
- Update documentation and checkpatch for uninitialized_var() removal
- Treewide removal of uninitialized_var()"
* tag 'uninit-macro-v5.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
compiler: Remove uninitialized_var() macro
treewide: Remove uninitialized_var() usage
checkpatch: Remove awareness of uninitialized_var() macro
mm/debug_vm_pgtable: Remove uninitialized_var() usage
f2fs: Eliminate usage of uninitialized_var() macro
media: sur40: Remove uninitialized_var() usage
KVM: PPC: Book3S PR: Remove uninitialized_var() usage
clk: spear: Remove uninitialized_var() usage
clk: st: Remove uninitialized_var() usage
spi: davinci: Remove uninitialized_var() usage
rtlwifi: rtl8192cu: Remove uninitialized_var() usage
b43: Remove uninitialized_var() usage
drbd: Remove uninitialized_var() usage
x86/mm/numa: Remove uninitialized_var() usage
docs: deprecated.rst: Add uninitialized_var()
The memory allocated for the DIM wasn't freed in in error unwind path, fix
it by calling to rdma_dim_destroy().
Fixes: da6629793aa6 ("RDMA/core: Provide RDMA DIM support for ULPs")
Link: https://lore.kernel.org/r/20200730082719.1582397-4-leon@kernel.org
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Max Gurtovoy <maxg@mellanox.com <mailto:maxg@mellanox.com>>
Signed-off-by: Jason Gunthorpe <jgg@nvidia.com>
HW destroy operation should be last operation after all possible CQ users
completed their work, so move DIM work cancellation before such destroy
call.
Link: https://lore.kernel.org/r/20200730082719.1582397-3-leon@kernel.org
Reviewed-by: Max Gurtovoy <maxg@mellanox.com>
In DCT and RSS RAW QP creation flows, the QP mutex wasn't initialized and
the magic field inside lock was missing. This caused to the following
kernel warning for kernels build with CONFIG_DEBUG_MUTEXES.
DEBUG_LOCKS_WARN_ON(lock->magic != lock)
WARNING: CPU: 3 PID: 16261 at kernel/locking/mutex.c:938 __mutex_lock+0x60e/0x940
Modules linked in: bonding nf_tables ipip tunnel4 geneve ip6_udp_tunnel udp_tunnel ip6_gre ip6_tunnel tunnel6 ip_gre gre ip_tunnel mlx5_ib mlx5_core mlxfw ptp pps_core rdma_ucm ib_uverbs ib_ipoib ib_umad openvswitch nsh xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat xt_addrtype xt_conntrack nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 br_netfilter overlay ib_srp scsi_transport_srp rpcrdma ib_iser libiscsi scsi_transport_iscsi rdma_cm iw_cm ib_cm ib_core [last unloaded: mlxfw]
CPU: 3 PID: 16261 Comm: ib_send_bw Not tainted 5.8.0-rc4_for_upstream_min_debug_2020_07_08_22_04 #1
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
RIP: 0010:__mutex_lock+0x60e/0x940
Code: c0 0f 84 6d fa ff ff 44 8b 15 4e 9d ba 00 45 85 d2 0f 85 5d fa ff ff 48 c7 c6 f2 de 2b 82 48 c7 c7 f1 8a 2b 82 e8 d2 4d 72 ff <0f> 0b 4c 8b 4d 88 e9 3f fa ff ff f6 c2 04 0f 84 37 fe ff ff 48 89
RSP: 0018:ffff88810bb8b870 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: ffff88829f1dd880 RSI: 0000000000000000 RDI: ffffffff81192afa
RBP: ffff88810bb8b910 R08: 0000000000000000 R09: 0000000000000028
R10: 0000000000000000 R11: 0000000000003f85 R12: 0000000000000002
R13: ffff88827d8d3ce0 R14: ffffffffa059f615 R15: ffff8882a4d02610
FS: 00007f3f6988e740(0000) GS:ffff8882f5b80000(0000) knlGS:0000000000000000
CR2: 0000556556158000 CR3: 000000010a63c005 CR4: 0000000000360ea0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
? cmd_exec+0x947/0xe60 [mlx5_core]
? __mutex_lock+0x76/0x940
? mlx5_ib_qp_set_counter+0x25/0xa0 [mlx5_ib]
mlx5_ib_counter_bind_qp+0x9b/0xe0 [mlx5_ib]
__rdma_counter_bind_qp+0x6b/0xa0 [ib_core]
rdma_counter_bind_qp_auto+0x363/0x520 [ib_core]
_ib_modify_qp+0x316/0x580 [ib_core]
ib_modify_qp_with_udata+0x19/0x30 [ib_core]
modify_qp+0x4c4/0x600 [ib_uverbs]
ib_uverbs_ex_modify_qp+0x87/0xe0 [ib_uverbs]
ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0x129/0x1c0 [ib_uverbs]
ib_uverbs_cmd_verbs.isra.5+0x5d5/0x11f0 [ib_uverbs]
? ib_uverbs_handler_UVERBS_METHOD_QUERY_CONTEXT+0x120/0x120 [ib_uverbs]
? lock_acquire+0xb9/0x3a0
? ib_uverbs_ioctl+0xd0/0x210 [ib_uverbs]
? ib_uverbs_ioctl+0x175/0x210 [ib_uverbs]
ib_uverbs_ioctl+0x14b/0x210 [ib_uverbs]
ksys_ioctl+0x234/0x7d0
? exc_page_fault+0x202/0x640
? do_syscall_64+0x1f/0x2e0
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x59/0x2e0
? asm_exc_page_fault+0x8/0x30
? rcu_read_lock_sched_held+0x52/0x60
entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: b4aaa1f0b415 ("IB/mlx5: Handle type IB_QPT_DRIVER when creating a QP")
Link: https://lore.kernel.org/r/20200730082719.1582397-2-leon@kernel.org
Reviewed-by: Maor Gottlieb <maorg@mellanox.com>
The lookaside count is improperly initialized to the size of the
Receive Queue with the additional +1. In the traces below, the
RQ size is 384, so the count was set to 385.
The lookaside count is then rarely refreshed. Note the high and
incorrect count in the trace below:
rvt_get_rwqe: [hfi1_0] wqe ffffc900078e9008 wr_id 55c7206d75a0 qpn c
qpt 2 pid 3018 num_sge 1 head 1 tail 0, count 385
rvt_get_rwqe: (hfi1_rc_rcv+0x4eb/0x1480 [hfi1] <- rvt_get_rwqe) ret=0x1
The head,tail indicate there is only one RWQE posted although the count
says 385 and we correctly return the element 0.
The next call to rvt_get_rwqe with the decremented count:
rvt_get_rwqe: [hfi1_0] wqe ffffc900078e9058 wr_id 0 qpn c
qpt 2 pid 3018 num_sge 0 head 1 tail 1, count 384
Note that the RQ is empty (head == tail) yet we return the RWQE at tail 1,
which is not valid because of the bogus high count.
Best case, the RWQE has never been posted and the rc logic sees an RWQE
that is too small (all zeros) and puts the QP into an error state.
In the worst case, a server slow at posting receive buffers might fool
rvt_get_rwqe() into fetching an old RWQE and corrupt memory.
Fix by deleting the faulty initialization code and creating an
inline to fetch the posted count and convert all callers to use
new inline.
Fixes: f592ae3c999f ("IB/rdmavt: Fracture single lock used for posting and processing RWQEs")
Link: https://lore.kernel.org/r/20200728183848.22226.29132.stgit@awfm-01.aw.intel.com
Reported-by: Zhaojuan Guo <zguo@redhat.com>
Cc: <stable@vger.kernel.org> # 5.4.x
Reviewed-by: Kaike Wan <kaike.wan@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Tested-by: Honggang Li <honli@redhat.com>
Scatter CQE feature relies on two flags MLX5_QP_FLAG_SCATTER_CQE and
MLX5_QP_FLAG_ALLOW_SCATTER_CQE, both of them can be provided without
relation to device capability.
Relax global validity check to allow MLX5_QP_FLAG_ALLOW_SCATTER_CQE QP
flag.
Existing user applications are failing on this new validity check.
Fixes: 90ecb37a751b ("RDMA/mlx5: Change scatter CQE flag to be set like other vendor flags")
Fixes: 37518fa49f76 ("RDMA/mlx5: Process all vendor flags in one place")
Link: https://lore.kernel.org/r/20200728120255.805733-1-leon@kernel.org
Reviewed-by: Artemy Kovalyov <artemyko@mellanox.com>
destroy_prefetch_work() must always be called if the work is not going
to be queued. The num_sge also should have been set to i, not i-1
which avoids the condition where it shouldn't have been called in the
first place.
Cc: stable@vger.kernel.org
Fixes: fb985e278a30 ("RDMA/mlx5: Use SRCU properly in ODP prefetch")
Link: https://lore.kernel.org/r/20200727095712.495652-1-leon@kernel.org
These are missing throughout ucma, it harmlessly copies garbage from
userspace, but in this new code which uses min to compute the copy length
it can result in uninitialized stack memory. Check for minimum length at
the very start.
BUG: KMSAN: uninit-value in ucma_connect+0x2aa/0xab0 drivers/infiniband/core/ucma.c:1091
CPU: 0 PID: 8457 Comm: syz-executor069 Not tainted 5.8.0-rc5-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1df/0x240 lib/dump_stack.c:118
kmsan_report+0xf7/0x1e0 mm/kmsan/kmsan_report.c:121
__msan_warning+0x58/0xa0 mm/kmsan/kmsan_instr.c:215
ucma_write+0x5c5/0x630 drivers/infiniband/core/ucma.c:1764
do_loop_readv_writev fs/read_write.c:737 [inline]
do_iter_write+0x710/0xdc0 fs/read_write.c:1020
vfs_writev fs/read_write.c:1091 [inline]
do_writev+0x42d/0x8f0 fs/read_write.c:1134
__do_sys_writev fs/read_write.c:1207 [inline]
__se_sys_writev+0x9b/0xb0 fs/read_write.c:1204
__x64_sys_writev+0x4a/0x70 fs/read_write.c:1204
do_syscall_64+0xb0/0x150 arch/x86/entry/common.c:386
Fixes: 34e2ab57a911 ("RDMA/ucma: Extend ucma_connect to receive ECE parameters")
Fixes: 0cb15372a615 ("RDMA/cma: Connect ECE to rdma_accept")
Link: https://lore.kernel.org/r/0-v1-d5b86dab17dc+28c25-ucma_syz_min_jgg@nvidia.com
Reported-by: syzbot+086ab5ca9eafd2379aa6@syzkaller.appspotmail.com
Reported-by: syzbot+7446526858b83c8828b2@syzkaller.appspotmail.com
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Prefetch work in mlx5_ib_prefetch_mr_work can be queued and able to run
concurrently with destruction of the implicit MR. The num_deferred_work
was intended to serialize this, but there is a race:
CPU0 CPU1
mlx5_ib_free_implicit_mr()
xa_erase(odp_mkeys)
synchronize_srcu()
__xa_erase(implicit_children)
mlx5_ib_prefetch_mr_work()
pagefault_mr()
pagefault_implicit_mr()
implicit_get_child_mr()
xa_cmpxchg()
atomic_dec_and_test(num_deferred_mr)
wait_event(imr->q_deferred_work)
ib_umem_odp_release(odp_imr)
kfree(odp_imr)
At this point in mlx5_ib_free_implicit_mr() the implicit_children list is
supposed to be empty forever so that destroy_unused_implicit_child_mr()
and related are not and will not be running.
Since it is not empty the destroy_unused_implicit_child_mr() flow ends up
touching deallocated memory as mlx5_ib_free_implicit_mr() already tore down the
imr parent.
The solution is to flush out the prefetch wq by driving num_deferred_work
to zero after creation of new prefetch work is blocked.
Fixes: 5256edcb98a1 ("RDMA/mlx5: Rework implicit ODP destroy")
Link: https://lore.kernel.org/r/20200719065435.130722-1-leon@kernel.org
Avoid the overhead of the dma ops support for tiny builds that only
use the direct mapping.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Using uninitialized_var() is dangerous as it papers over real bugs[1]
(or can in the future), and suppresses unrelated compiler warnings
(e.g. "unused variable"). If the compiler thinks it is uninitialized,
either simply initialize the variable or make compiler changes.
In preparation for removing[2] the[3] macro[4], remove all remaining
needless uses with the following script:
git grep '\buninitialized_var\b' | cut -d: -f1 | sort -u | \
xargs perl -pi -e \
's/\buninitialized_var\(([^\)]+)\)/\1/g;
s:\s*/\* (GCC be quiet|to make compiler happy) \*/$::g;'
drivers/video/fbdev/riva/riva_hw.c was manually tweaked to avoid
pathological white-space.
No outstanding warnings were found building allmodconfig with GCC 9.3.0
for x86_64, i386, arm64, arm, powerpc, powerpc64le, s390x, mips, sparc64,
alpha, and m68k.
[1] https://lore.kernel.org/lkml/20200603174714.192027-1-glider@google.com/
[2] https://lore.kernel.org/lkml/CA+55aFw+Vbj0i=1TGqCR5vQkCzWJ0QxK6CernOU6eedsudAixw@mail.gmail.com/
[3] https://lore.kernel.org/lkml/CA+55aFwgbgqhbp1fkxvRKEpzyR5J8n1vKT1VZdz9knmPuXhOeg@mail.gmail.com/
[4] https://lore.kernel.org/lkml/CA+55aFz2500WfbKXAx8s67wrm9=yVJu65TpLgN_ybYNv0VEOKA@mail.gmail.com/
Reviewed-by: Leon Romanovsky <leonro@mellanox.com> # drivers/infiniband and mlx4/mlx5
Acked-by: Jason Gunthorpe <jgg@mellanox.com> # IB
Acked-by: Kalle Valo <kvalo@codeaurora.org> # wireless drivers
Reviewed-by: Chao Yu <yuchao0@huawei.com> # erofs
cm.lock must be held while accessing remote_sidr_table. This fixes the
below NULL pointer dereference.
BUG: kernel NULL pointer dereference, address: 0000000000000000
#PF: supervisor write access in kernel mode
#PF: error_code(0x0002) - not-present page
PGD 0 P4D 0
Oops: 0002 [#1] SMP PTI
CPU: 2 PID: 7288 Comm: udaddy Not tainted 5.7.0_for_upstream_perf_2020_06_09_15_14_20_38 #1
RIP: 0010:rb_erase+0x10d/0x360
Code: 00 00 00 48 89 c1 48 89 d0 48 8b 50 08 48 39 ca 74 48 f6 02 01 75 af 48 8b 7a 10 48 89 c1 48 83 c9 01 48 89 78 08 48 89 42 10 <48> 89 0f 48 8b 08 48 89 0a 48 83 e1 fc 48 89 10 0f 84 b1 00 00 00
RSP: 0018:ffffc90000f77c30 EFLAGS: 00010086
RAX: ffff8883df27d458 RBX: ffff8883df27da58 RCX: ffff8883df27d459
RDX: ffff8883d183fa58 RSI: ffffffffa01e8d00 RDI: 0000000000000000
RBP: ffff8883d62ac800 R08: 0000000000000000 R09: 00000000000000ce
R10: 000000000000000a R11: 0000000000000000 R12: ffff8883df27da00
R13: ffffc90000f77c98 R14: 0000000000000130 R15: 0000000000000000
FS: 00007f009f877740(0000) GS:ffff8883f1a00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000003d467e003 CR4: 0000000000160ee0
Call Trace:
cm_send_sidr_rep_locked+0x15a/0x1a0 [ib_cm]
ib_send_cm_sidr_rep+0x2b/0x50 [ib_cm]
cma_send_sidr_rep+0x8b/0xe0 [rdma_cm]
__rdma_accept+0x21d/0x2b0 [rdma_cm]
? ucma_get_ctx+0x2b/0xe0 [rdma_ucm]
? _copy_from_user+0x30/0x60
ucma_accept+0x13e/0x1e0 [rdma_ucm]
ucma_write+0xb4/0x130 [rdma_ucm]
vfs_write+0xad/0x1a0
ksys_write+0x9d/0xb0
do_syscall_64+0x48/0x130
RIP: 0033:0x7f009ef60924
Code: 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 80 00 00 00 00 8b 05 2a ef 2c 00 48 63 ff 85 c0 75 13 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 54 f3 c3 66 90 55 53 48 89 d5 48 89 f3 48 83
RSP: 002b:00007fff843edf38 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 000055743042e1d0 RCX: 00007f009ef60924
RDX: 0000000000000130 RSI: 00007fff843edf40 RDI: 0000000000000003
RBP: 00007fff843ee0e0 R08: 0000000000000000 R09: 0000557430433090
R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000000
R13: 00007fff843edf40 R14: 000000000000038c R15: 00000000ffffff00
Fixes: 6a8824a74bc9 ("RDMA/cm: Allow ib_send_cm_sidr_rep() to be done under lock")
Link: https://lore.kernel.org/r/20200716105519.1424266-1-leon@kernel.org
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
The FD should not be installed until all of the setup is completed as the
fd_install() transfers ownership of the kref to the FD table. A thread can
race a close() and trigger concurrent rdma_alloc_commit_uobject() and
uverbs_uobject_fd_release() which, at least, triggers a safety WARN_ON:
WARNING: CPU: 4 PID: 6913 at drivers/infiniband/core/rdma_core.c:768 uverbs_uobject_fd_release+0x202/0x230
Kernel panic - not syncing: panic_on_warn set ...
CPU: 4 PID: 6913 Comm: syz-executor.3 Not tainted 5.7.0-rc2 #22
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
RIP: 0010:uverbs_uobject_fd_release+0x202/0x230
Code: fe 4c 89 e7 e8 af 23 fe ff e9 2a ff ff ff e8 c5 fa 61 fe be 03 00 00 00 4c 89 e7 e8 68 eb f5 fe e9 13 ff ff ff e8 ae fa 61 fe <0f> 0b eb ac e8 e5 aa 3c fe e8 50 2b 86 fe e9 6a fe ff ff e8 46 2b
RSP: 0018:ffffc90008117d88 EFLAGS: 00010293
RAX: ffff88810e146580 RBX: 1ffff92001022fb1 RCX: ffffffff82d5b902
RDX: 0000000000000000 RSI: 0000000000000004 RDI: ffff88811951b040
RBP: ffff88811951b000 R08: ffffed10232a3609 R09: ffffed10232a3609
R10: ffff88811951b043 R11: 0000000000000001 R12: ffff888100a7c600
R13: ffff888100a7c650 R14: ffffc90008117da8 R15: ffffffff82d5b700
? __uverbs_cleanup_ufile+0x270/0x270
? uverbs_uobject_fd_release+0x202/0x230
? locks_remove_file+0x282/0x3d0
? security_file_free+0xaa/0xd0
__fput+0x2be/0x770
task_work_run+0x10e/0x1b0
exit_to_usermode_loop+0x145/0x170
do_syscall_64+0x2d0/0x390
? prepare_exit_to_usermode+0x17a/0x230
RIP: 0033:0x414da7
Code: 00 00 0f 05 48 3d 00 f0 ff ff 77 3f f3 c3 0f 1f 44 00 00 53 89 fb 48 83 ec 10 e8 f4 fb ff ff 89 df 89 c2 b8 03 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 2b 89 d7 89 44 24 0c e8 36 fc ff ff 8b 44 24
RSP: 002b:00007fff39d379d0 EFLAGS: 00000293 ORIG_RAX: 0000000000000003
RAX: 0000000000000000 RBX: 0000000000000003 RCX: 0000000000414da7
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000003
RBP: 00007fff39d37a3c R08: 0000000400000000 R09: 0000000400000000
R10: 00007fff39d37910 R11: 0000000000000293 R12: 0000000000000001
R13: 0000000000000001 R14: 0000000000000000 R15: 0000000000000003
Reorder so that fd_install() is the last thing done in
rdma_alloc_commit_uobject().
Fixes: aba94548c9e4 ("IB/uverbs: Move the FD uobj type struct file allocation to alloc_commit")
Link: https://lore.kernel.org/r/20200716102059.1420681-1-leon@kernel.org
ROCE uses "VA % buf_page_size" to caclulate the offset in the PBL's first
page, the actual PA corresponding to the MR's VA is equal to MR's PA plus
this offset. The first PA in PBL has already been aligned to PAGE_SIZE
after calling ib_umem_get(), but the MR's VA may not. If the buf_page_size
is smaller than the PAGE_SIZE, this will lead the HW to access the wrong
memory because the offset is smaller than expected.
Fixes: 9b2cf76c9f05 ("RDMA/hns: Optimize PBL buffer allocation process")
Link: https://lore.kernel.org/r/1594726935-45666-1-git-send-email-liweihang@huawei.com
Signed-off-by: Xi Wang <wangxi11@huawei.com>
Signed-off-by: Weihang Li <liweihang@huawei.com>
The RoCE Engine will schedule to another QP after one has sent
(2 ^ lp_pktn_ini) packets. lp_pktn_ini is set in QPC and should be
calculated from 2 factors:
1. current MTU as a integer
2. the RoCE Engine's maximum slice length 64KB
But the driver use MTU as a enum ib_mtu and the max inline capability, the
lp_pktn_ini will be much bigger than expected which may cause traffic of
some QPs to never get scheduled.
Fixes: b713128de7a1 ("RDMA/hns: Adjust lp_pktn_ini dynamically")
Link: https://lore.kernel.org/r/1594726138-49294-1-git-send-email-liweihang@huawei.com
SRQ table is accessed both from interrupt and process context,
therefore we must use xa_lock_irq.
inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage.
kworker/u17:9/8573 takes:
ffff8883e3503d30 (&xa->xa_lock#13){?...}-{2:2}, at: mlx5_cmd_get_srq+0x18/0x70 [mlx5_ib]
{IN-HARDIRQ-W} state was registered at:
_raw_spin_lock+0x25/0x30
srq_event_notifier+0x2b/0xc0 [mlx5_ib]
notifier_call_chain+0x45/0x70
__atomic_notifier_call_chain+0x69/0x100
forward_event+0x36/0xc0 [mlx5_core]
mlx5_eq_async_int+0xc5/0x160 [mlx5_core]
mlx5_irq_int_handler+0x19/0x30 [mlx5_core]
__handle_irq_event_percpu+0x43/0x2a0
handle_irq_event_percpu+0x30/0x70
handle_irq_event+0x34/0x60
handle_edge_irq+0x7c/0x1b0
do_IRQ+0x60/0x110
ret_from_intr+0x0/0x2a
default_idle+0x34/0x160
do_idle+0x1ec/0x220
cpu_startup_entry+0x19/0x20
start_secondary+0x153/0x1a0
secondary_startup_64+0xa4/0xb0
irq event stamp: 20907
hardirqs last enabled at (20907): _raw_spin_unlock_irq+0x24/0x30
hardirqs last disabled at (20906): _raw_spin_lock_irq+0xf/0x40
softirqs last enabled at (20746): __do_softirq+0x2c9/0x436
softirqs last disabled at (20681): irq_exit+0xb3/0xc0
Possible unsafe locking scenario:
CPU0
lock(&xa->xa_lock#13);
<Interrupt>
*** DEADLOCK ***
2 locks held by kworker/u17:9/8573:
#0: ffff888295218d38 ((wq_completion)mlx5_ib_page_fault){+.+.}-{0:0}, at: process_one_work+0x1f1/0x5f0
#1: ffff888401647e78 ((work_completion)(&pfault->work)){+.+.}-{0:0}, at: process_one_work+0x1f1/0x5f0
stack backtrace:
CPU: 0 PID: 8573 Comm: kworker/u17:9 Tainted: GO 5.7.0_for_upstream_min_debug_2020_06_14_11_31_46_41 #1
Workqueue: mlx5_ib_page_fault mlx5_ib_eqe_pf_action [mlx5_ib]
Call Trace:
dump_stack+0x71/0x9b
mark_lock+0x4f2/0x590
? print_shortest_lock_dependencies+0x200/0x200
__lock_acquire+0xa00/0x1eb0
? mlx5_cmd_get_srq+0x18/0x70 [mlx5_ib]
mlx5_ib_eqe_pf_action+0x257/0xa30 [mlx5_ib]
? process_one_work+0x209/0x5f0
process_one_work+0x27b/0x5f0
? __schedule+0x280/0x7e0
worker_thread+0x2d/0x3c0
? process_one_work+0x5f0/0x5f0
kthread+0x111/0x130
? kthread_park+0x90/0x90
ret_from_fork+0x24/0x30
Fixes: e126ba97dba9 ("mlx5: Add driver for Mellanox Connect-IB adapters")
Link: https://lore.kernel.org/r/20200712102641.15210-1-leon@kernel.org
ib_pd is accessed internally during destroy of the TIR/TIS, but PD
can be not set yet. This leading to the following kernel panic.
BUG: kernel NULL pointer dereference, address: 0000000000000074
PGD 8000000079eaa067 P4D 8000000079eaa067 PUD 7ae81067 PMD 0 Oops: 0000 [#1] SMP PTI
CPU: 1 PID: 709 Comm: syz-executor.0 Not tainted 5.8.0-rc3 #41 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
RIP: 0010:destroy_raw_packet_qp_tis drivers/infiniband/hw/mlx5/qp.c:1189 [inline]
RIP: 0010:destroy_raw_packet_qp drivers/infiniband/hw/mlx5/qp.c:1527 [inline]
RIP: 0010:destroy_qp_common+0x2ca/0x4f0 drivers/infiniband/hw/mlx5/qp.c:2397
Code: 00 85 c0 74 2e e8 56 18 55 ff 48 8d b3 28 01 00 00 48 89 ef e8 d7 d3 ff ff 48 8b 43 08 8b b3 c0 01 00 00 48 8b bd a8 0a 00 00 <0f> b7 50 74 e8 0d 6a fe ff e8 28 18 55 ff 49 8d 55 50 4c 89 f1 48
RSP: 0018:ffffc900007bbac8 EFLAGS: 00010293
RAX: 0000000000000000 RBX: ffff88807949e800 RCX: 0000000000000998
RDX: 0000000000000000 RSI: 0000000000000008 RDI: ffff88807c180140
RBP: ffff88807b50c000 R08: 000000000002d379 R09: ffffc900007bba00
R10: 0000000000000001 R11: 000000000002d358 R12: ffff888076f37000
R13: ffff88807949e9c8 R14: ffffc900007bbe08 R15: ffff888076f37000
FS: 00000000019bf940(0000) GS:ffff88807dd00000(0000) knlGS:0000000000000000
CR2: 0000000000000074 CR3: 0000000076d68004 CR4: 0000000000360ee0
Call Trace:
mlx5_ib_create_qp+0xf36/0xf90 drivers/infiniband/hw/mlx5/qp.c:3014
_ib_create_qp drivers/infiniband/core/core_priv.h:333 [inline]
create_qp+0x57f/0xd20 drivers/infiniband/core/uverbs_cmd.c:1443
ib_uverbs_create_qp+0xcf/0x100 drivers/infiniband/core/uverbs_cmd.c:1564
ib_uverbs_write+0x5fa/0x780 drivers/infiniband/core/uverbs_main.c:664
__vfs_write+0x3f/0x90 fs/read_write.c:495
vfs_write+0xc7/0x1f0 fs/read_write.c:559
ksys_write+0x5e/0x110 fs/read_write.c:612
do_syscall_64+0x3e/0x70 arch/x86/entry/common.c:359
RIP: 0033:0x466479
Code: Bad RIP value.
RSP: 002b:00007ffd057b62b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000466479
RDX: 0000000000000070 RSI: 0000000020000240 RDI: 0000000000000003
RBP: 00000000019bf8fc R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 0000000000000bf6 R14: 00000000004cb859 R15: 00000000006fefc0
Fixes: 6c41965d647a ("RDMA/mlx5: Don't access ib_qp fields in internal destroy QP path")
Link: https://lore.kernel.org/r/20200707110612.882962-4-leon@kernel.org
Some released FW versions mistakenly don't set the capability that 50G per
lane link-modes are supported for VFs (ptys_extended_ethernet capability
bit).
Use PTYS.ext_eth_proto_capability instead, as this indication is always
accurate. If PTYS.ext_eth_proto_capability is valid
(has a non-zero value) conclude that the HCA supports 50G per lane.
Otherwise, conclude that the HCA doesn't support 50G per lane.
Fixes: 08e8676f1607 ("IB/mlx5: Add support for 50Gbps per lane link modes")
Link: https://lore.kernel.org/r/20200707110612.882962-3-leon@kernel.org
Signed-off-by: Aya Levin <ayal@mellanox.com>
Reviewed-by: Eran Ben Elisha <eranbe@mellanox.com>
Reviewed-by: Saeed Mahameed <saeedm@mellanox.com>
Move the initialization of the vendor_part_id to be before calling
ib_register_device(), this is needed because the query_device() callback
is called from the context of ib_register_device() before initializing the
vendor_part_id, so the reported value is wrong.
Fixes: bdcf26bf9b3a ("rdma/siw: network and RDMA core interface")
Link: https://lore.kernel.org/r/20200707130931.444724-1-kamalheib1@gmail.com
Signed-off-by: Kamal Heib <kamalheib1@gmail.com>
Reviewed-by: Bernard Metzler <bmt@zurich.ibm.com>
There is a race condition where ib_nl_make_request() inserts the request
data into the linked list but the timer in ib_nl_request_timeout() can see
it and destroy it before ib_nl_send_msg() is done touching it. This could
happen, for instance, if there is a long delay allocating memory during
nlmsg_new()
This causes a use-after-free in the send_mad() thread:
[<ffffffffa02f43cb>] ? ib_pack+0x17b/0x240 [ib_core]
[ <ffffffffa032aef1>] ib_sa_path_rec_get+0x181/0x200 [ib_sa]
[<ffffffffa0379db0>] rdma_resolve_route+0x3c0/0x8d0 [rdma_cm]
[<ffffffffa0374450>] ? cma_bind_port+0xa0/0xa0 [rdma_cm]
[<ffffffffa040f850>] ? rds_rdma_cm_event_handler_cmn+0x850/0x850 [rds_rdma]
[<ffffffffa040f22c>] rds_rdma_cm_event_handler_cmn+0x22c/0x850 [rds_rdma]
[<ffffffffa040f860>] rds_rdma_cm_event_handler+0x10/0x20 [rds_rdma]
[<ffffffffa037778e>] addr_handler+0x9e/0x140 [rdma_cm]
[<ffffffffa026cdb4>] process_req+0x134/0x190 [ib_addr]
[<ffffffff810a02f9>] process_one_work+0x169/0x4a0
[<ffffffff810a0b2b>] worker_thread+0x5b/0x560
[<ffffffff810a0ad0>] ? flush_delayed_work+0x50/0x50
[<ffffffff810a68fb>] kthread+0xcb/0xf0
[<ffffffff816ec49a>] ? __schedule+0x24a/0x810
[<ffffffff810a6830>] ? kthread_create_on_node+0x180/0x180
[<ffffffff816f25a7>] ret_from_fork+0x47/0x90
The ownership rule is once the request is on the list, ownership transfers
to the list and the local thread can't touch it any more, just like for
the normal MAD case in send_mad().
Thus, instead of adding before send and then trying to delete after on
errors, move the entire thing under the spinlock so that the send and
update of the lists are atomic to the conurrent threads. Lightly reoganize
things so spinlock safe memory allocations are done in the final NL send
path and the rest of the setup work is done before and outside the lock.
Fixes: 3ebd2fd0d011 ("IB/sa: Put netlink request into the request list before sending")
Link: https://lore.kernel.org/r/1592964789-14533-1-git-send-email-divya.indi@oracle.com
Signed-off-by: Divya Indi <divya.indi@oracle.com>
The workqueue link_wq should only be destroyed when the hfi1 driver is
unloaded, not when the device is shut down.
Fixes: 71d47008ca1b ("IB/hfi1: Create workqueue for link events")
Link: https://lore.kernel.org/r/20200623204053.107638.70315.stgit@awfm-01.aw.intel.com
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Kaike Wan <kaike.wan@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
The workqueue hfi1_wq is destroyed in function shutdown_device(), which is
called by either shutdown_one() or remove_one(). The function
shutdown_one() is called when the kernel is rebooted while remove_one() is
called when the hfi1 driver is unloaded. When the kernel is rebooted,
hfi1_wq is destroyed while all qps are still active, leading to a kernel
crash:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000102
IP: [<ffffffff94cb7b02>] __queue_work+0x32/0x3e0
PGD 0
Oops: 0000 [#1] SMP
Modules linked in: dm_round_robin nvme_rdma(OE) nvme_fabrics(OE) nvme_core(OE) ib_isert iscsi_target_mod target_core_mod ib_ucm mlx4_ib iTCO_wdt iTCO_vendor_support mxm_wmi sb_edac intel_powerclamp coretemp intel_rapl iosf_mbi kvm rpcrdma sunrpc irqbypass crc32_pclmul ghash_clmulni_intel rdma_ucm aesni_intel ib_uverbs lrw gf128mul opa_vnic glue_helper ablk_helper ib_iser cryptd ib_umad rdma_cm iw_cm ses enclosure libiscsi scsi_transport_sas pcspkr joydev ib_ipoib(OE) scsi_transport_iscsi ib_cm sg ipmi_ssif mei_me lpc_ich i2c_i801 mei ioatdma ipmi_si dm_multipath ipmi_devintf ipmi_msghandler wmi acpi_pad acpi_power_meter hangcheck_timer ip_tables ext4 mbcache jbd2 mlx4_en sd_mod crc_t10dif crct10dif_generic mgag200 drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm hfi1(OE)
crct10dif_pclmul crct10dif_common crc32c_intel drm ahci mlx4_core libahci rdmavt(OE) igb megaraid_sas ib_core libata drm_panel_orientation_quirks ptp pps_core devlink dca i2c_algo_bit dm_mirror dm_region_hash dm_log dm_mod
CPU: 19 PID: 0 Comm: swapper/19 Kdump: loaded Tainted: G OE ------------ 3.10.0-957.el7.x86_64 #1
Hardware name: Phegda X2226A/S2600CW, BIOS SE5C610.86B.01.01.0024.021320181901 02/13/2018
task: ffff8a799ba0d140 ti: ffff8a799bad8000 task.ti: ffff8a799bad8000
RIP: 0010:[<ffffffff94cb7b02>] [<ffffffff94cb7b02>] __queue_work+0x32/0x3e0
RSP: 0018:ffff8a90dde43d80 EFLAGS: 00010046
RAX: 0000000000000082 RBX: 0000000000000086 RCX: 0000000000000000
RDX: ffff8a90b924fcb8 RSI: 0000000000000000 RDI: 000000000000001b
RBP: ffff8a90dde43db8 R08: ffff8a799ba0d6d8 R09: ffff8a90dde53900
R10: 0000000000000002 R11: ffff8a90dde43de8 R12: ffff8a90b924fcb8
R13: 000000000000001b R14: 0000000000000000 R15: ffff8a90d2890000
FS: 0000000000000000(0000) GS:ffff8a90dde40000(0000) knlGS:0000000000000000
CR2: 0000000000000102 CR3: 0000001a70410000 CR4: 00000000001607e0
Call Trace:
[<ffffffff94cb8105>] queue_work_on+0x45/0x50
[<ffffffffc03f781e>] _hfi1_schedule_send+0x6e/0xc0 [hfi1]
[<ffffffffc03f78a2>] hfi1_schedule_send+0x32/0x70 [hfi1]
[<ffffffffc02cf2d9>] rvt_rc_timeout+0xe9/0x130 [rdmavt]
[<ffffffff94ce563a>] ? trigger_load_balance+0x6a/0x280
[<ffffffffc02cf1f0>] ? rvt_free_qpn+0x40/0x40 [rdmavt]
[<ffffffff94ca7f58>] call_timer_fn+0x38/0x110
[<ffffffff94caa3bd>] run_timer_softirq+0x24d/0x300
[<ffffffff94ca0f05>] __do_softirq+0xf5/0x280
[<ffffffff9537832c>] call_softirq+0x1c/0x30
[<ffffffff94c2e675>] do_softirq+0x65/0xa0
[<ffffffff94ca1285>] irq_exit+0x105/0x110
[<ffffffff953796c8>] smp_apic_timer_interrupt+0x48/0x60
[<ffffffff95375df2>] apic_timer_interrupt+0x162/0x170
<EOI>
[<ffffffff951adfb7>] ? cpuidle_enter_state+0x57/0xd0
[<ffffffff951ae10e>] cpuidle_idle_call+0xde/0x230
[<ffffffff94c366de>] arch_cpu_idle+0xe/0xc0
[<ffffffff94cfc3ba>] cpu_startup_entry+0x14a/0x1e0
[<ffffffff94c57db7>] start_secondary+0x1f7/0x270
[<ffffffff94c000d5>] start_cpu+0x5/0x14
The solution is to destroy the workqueue only when the hfi1 driver is
unloaded, not when the device is shut down. In addition, when the device
is shut down, no more work should be scheduled on the workqueues and the
workqueues are flushed.
Fixes: 8d3e71136a08 ("IB/{hfi1, qib}: Add handling of kernel restart")
Link: https://lore.kernel.org/r/20200623204047.107638.77646.stgit@awfm-01.aw.intel.com
Legacy IPoIB sets IB_QP_CREATE_NETIF_QP QP create flag and because mlx5
doesn't use this flag, the process_create_flags() failed to create IPoIB
QPs.
Fixes: 2978975ce7f1 ("RDMA/mlx5: Process create QP flags in one place")
Link: https://lore.kernel.org/r/20200630122147.445847-1-leon@kernel.org
Clang warns:
drivers/infiniband/hw/hfi1/qp.c:198:9: warning: implicit conversion from enumeration type 'enum opa_mtu' to different enumeration type 'enum ib_mtu' [-Wenum-conversion]
mtu = OPA_MTU_8192;
enum opa_mtu extends enum ib_mtu. There are typically two ways to deal
with this:
* Remove the expected types and just use 'int' for all parameters and
types.
* Explicitly cast the enums between each other.
This driver chooses to do the later so do the same thing here.
Fixes: 6d72344cf6c4 ("IB/ipoib: Increase ipoib Datagram mode MTU's upper limit")
Link: https://lore.kernel.org/r/20200623005224.492239-1-natechancellor@gmail.com
Link: https://github.com/ClangBuiltLinux/linux/issues/1062
Link: https://lore.kernel.org/linux-rdma/20200527040350.GA3118979@ubuntu-s3-xlarge-x86/
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
When running iperf in a two host configuration the following trace can
occur:
[ 319.728730] NETDEV WATCHDOG: ib0 (hfi1): transmit queue 0 timed out
The issue happens because the current implementation relies on the netif
txq being stopped to control the flushing of the tx list.
There are two resources that the transmit logic can wait on and stop the
txq:
- SDMA descriptors
- Ring space to hold completions
The ring space is tested on the sending side and relieved when the ring is
consumed in the napi tx reaping.
Unfortunately, that reaping can run conncurrently with the workqueue
flushing of the txlist. If the txq is started just before the workitem
executes, the txlist will never be flushed, leading to the txq being
stuck.
Fix by:
- Adding sleep/wakeup wrappers
* Use an atomic to control the call to the netif routines inside the
wrappers
- Use another atomic to record ring space exhaustion
* Only wakeup when the a ring space exhaustion has happened and it
relieved
Add additional wrappers to clarify the ring space resource handling.
Fixes: d99dc602e2a5 ("IB/hfi1: Add functions to transmit datagram ipoib packets")
Link: https://lore.kernel.org/r/20200623204327.108092.4024.stgit@awfm-01.aw.intel.com
The current code mishandles -EBUSY in two ways:
- The flow change doesn't test the return from the flush and runs on to
process the current packet racing with the wakeup processing
- The -EBUSY handling for a single packet inserts the tx into the txlist
after the submit call, racing with the same wakeup processing
Fix the first by dropping the skb and returning NETDEV_TX_OK.
Fix the second by insuring the the list entry within the txreq is inited
when allocated. This enables the sleep routine to detect that the txreq
has used the non-list api and queue the packet to the txlist.
Both flaws can lead to having the flushing thread executing in causing two
threads to manipulate the txlist.
Link: https://lore.kernel.org/r/20200623204321.108092.83898.stgit@awfm-01.aw.intel.com
When the try_module_get calls were removed from opening and closing of the
i2c debugfs file, the corresponding module_put calls were missed. This
results in an inaccurate module use count that requires a power cycle to
fix.
Fixes: 09fbca8e6240 ("IB/hfi1: No need to use try_module_get for debugfs")
Link: https://lore.kernel.org/r/20200623203230.106975.76240.stgit@awfm-01.aw.intel.com
We need to do some rework on the dummy netdev. Calling the free_netdev()
would normally make sense, and that will be addressed in an upcoming
patch. For now just revert the behavior to what it was before keeping the
unused variable removal part of the patch.
The dd->dumm_netdev is mainly used for packet receiving through
alloc_netdev_mqs() for typical net devices. A a result, it should be freed
with kfree instead of free_netdev() that leads to a crash when unloading
the hfi1 module:
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 8000000855b54067 P4D 8000000855b54067 PUD 84a4f5067 PMD 0
CPU: 73 PID: 10299 Comm: modprobe Not tainted 5.6.0-rc5+ #1
Hardware name: Intel Corporation S2600WT2R/S2600WT2R, BIOS SE5C610.86B.01.01.0016.033120161139 03/31/2016
RIP: 0010:__hw_addr_flush+0x12/0x80
Code: 40 00 48 83 c4 08 4c 89 e7 5b 5d 41 5c e9 76 77 18 00 66 0f 1f 44 00 00 0f 1f 44 00 00 41 54 49 89 fc 55 53 48 8b 1f 48 39 df <48> 8b 2b 75 08 eb 4a 48 89 eb 48 89 c5 48 89 df e8 99 bf d0 ff 84
RSP: 0018:ffffb40e08783db8 EFLAGS: 00010282
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000002
RDX: ffffb40e00000000 RSI: 0000000000000246 RDI: ffff88ab13662298
RBP: ffff88ab13662000 R08: 0000000000001549 R09: 0000000000001549
R10: 0000000000000001 R11: 0000000000aaaaaa R12: ffff88ab13662298
R13: ffff88ab1b259e20 R14: ffff88ab1b259e42 R15: 0000000000000000
FS: 00007fb39b534740(0000) GS:ffff88b31f940000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000084d3ea004 CR4: 00000000003606e0
Call Trace:
dev_addr_flush+0x15/0x30
free_netdev+0x7e/0x130
hfi1_netdev_free+0x59/0x70 [hfi1]
remove_one+0x65/0x110 [hfi1]
pci_device_remove+0x3b/0xc0
device_release_driver_internal+0xec/0x1b0
driver_detach+0x46/0x90
bus_remove_driver+0x58/0xd0
pci_unregister_driver+0x26/0xa0
hfi1_mod_cleanup+0xc/0xd54 [hfi1]
__x64_sys_delete_module+0x16c/0x260
? exit_to_usermode_loop+0xa4/0xc0
do_syscall_64+0x5b/0x200
Fixes: 193ba03141bb ("IB/hfi1: Use free_netdev() in hfi1_netdev_free()")
Link: https://lore.kernel.org/r/20200623203224.106975.16926.stgit@awfm-01.aw.intel.com
Currently, when RMPP MADs are processed while the MAD agent is destroyed,
it could result in use after free of rmpp_recv, as decribed below:
cpu-0 cpu-1
ib_mad_recv_done()
ib_mad_complete_recv()
ib_process_rmpp_recv_wc()
unregister_mad_agent()
ib_cancel_rmpp_recvs()
cancel_delayed_work()
process_rmpp_data()
start_rmpp()
queue_delayed_work(rmpp_recv->cleanup_work)
destroy_rmpp_recv()
free_rmpp_recv()
cleanup_work()[1]
spin_lock_irqsave(&rmpp_recv->agent->lock) <-- use after free
[1] cleanup_work() == recv_cleanup_handler
Fix it by waiting for the MAD agent reference count becoming zero before
calling to ib_cancel_rmpp_recvs().
Fixes: 9a41e38a467c ("IB/mad: Use IDR for agent IDs")
Link: https://lore.kernel.org/r/20200621104738.54850-2-leon@kernel.org
Signed-off-by: Shay Drory <shayd@mellanox.com>
Don't deref udata if it is NULL
BUG: kernel NULL pointer dereference, address: 0000000000000030
PGD 0 P4D 0
Oops: 0000 SMP PTI
CPU: 2 PID: 1592 Comm: python3 Not tainted 5.7.0-rc6+ #1
RIP: 0010:create_qp+0x39e/0xae0 [mlx5_ib]
Code: c0 0d 00 00 bf 10 01 00 00 e8 be a9 e4 e0 48 85 c0 49 89 c2 0f 84 0c 07 00 00 41 8b 85 74 63 01 00 0f c8 a9 00 00 00 10 74 0a <41> 8b 46 30 0f c8 41 89 42 14 41 8b 52 18 41 0f b6 4a 1c 0f ca 89
RSP: 0018:ffffc9000067f8b0 EFLAGS: 00010206
RAX: 0000000010170000 RBX: ffff888441313000 RCX: 0000000000000000
RDX: 0000000000000200 RSI: 0000000000000000 RDI: ffff88845b1d4400
RBP: ffffc9000067fa60 R08: 0000000000000200 R09: ffff88845b1d4200
R10: ffff88845b1d4200 R11: ffff888441313000 R12: ffffc9000067f950
R13: ffff88846ac00140 R14: 0000000000000000 R15: ffff88846c2bc000
FS: 00007faa1a3c0540(0000) GS:ffff88846fd00000(0000) knlGS:0000000000000000
CR2: 0000000000000030 CR3: 0000000446dca003 CR4: 0000000000760ea0
PKRU: 55555554
Call Trace:
? __switch_to_asm+0x40/0x70
? __switch_to_asm+0x34/0x70
mlx5_ib_create_qp+0x897/0xfa0 [mlx5_ib]
ib_create_qp+0x9e/0x300 [ib_core]
create_qp+0x92d/0xb20 [ib_uverbs]
? ib_uverbs_cq_event_handler+0x30/0x30 [ib_uverbs]
? release_resource+0x30/0x30
ib_uverbs_create_qp+0xc4/0xe0 [ib_uverbs]
ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0xc8/0xf0 [ib_uverbs]
ib_uverbs_run_method+0x223/0x770 [ib_uverbs]
? track_pfn_remap+0xa7/0x100
? uverbs_disassociate_api+0xd0/0xd0 [ib_uverbs]
? remap_pfn_range+0x358/0x490
ib_uverbs_cmd_verbs.isra.6+0x19b/0x370 [ib_uverbs]
? rdma_umap_priv_init+0x82/0xe0 [ib_core]
? vm_mmap_pgoff+0xec/0x120
ib_uverbs_ioctl+0xc0/0x120 [ib_uverbs]
ksys_ioctl+0x92/0xb0
Fixes: e383085c2425 ("RDMA/mlx5: Set ECE options during QP create")
Link: https://lore.kernel.org/r/20200621115959.60126-1-leon@kernel.org
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Query a dynamically-allocated counter before release it, to update it's
hwcounters and log all of them into history data. Otherwise all values of
these hwcounters will be lost.
Fixes: f34a55e497e8 ("RDMA/core: Get sum value of all counters when perform a sysfs stat read")
Link: https://lore.kernel.org/r/20200621110000.56059-1-leon@kernel.org
Signed-off-by: Mark Zhang <markz@mellanox.com>
If ib_dma_mapping_error() returns non-zero value,
ib_mad_post_receive_mads() will jump out of loops and return -ENOMEM
without freeing mad_priv. Fix this memory-leak problem by freeing mad_priv
in this case.
Fixes: 2c34e68f4261 ("IB/mad: Check and handle potential DMA mapping errors")
Link: https://lore.kernel.org/r/20200612063824.180611-1-guofan5@huawei.com
Signed-off-by: Fan Guo <guofan5@huawei.com>
create_flags checks was refactored and broke the creation on integrity
enabled QPs and actually broke the NVMe/RDMA and iSER ULP's when using
mlx5 driven devices.
Link: https://lore.kernel.org/r/20200617130230.2846915-1-leon@kernel.org
Signed-off-by: Max Gurtovoy <maxg@mellanox.com>
Like any other QP type, rely on FW for the RAW_PACKET QPs to decide if ECE
is supported or not. This fixes an inability to create RAW_PACKET QPs with
latest rdma-core with the ECE support.
Link: https://lore.kernel.org/r/20200618112507.3453496-2-leon@kernel.org
Remote gid is not copied to the right address. Fix it by using
rdma_ah_set_dgid_raw to copy the remote gid value from the QP context on
query QP.
Fixes: 70bd7fb87625 ("RDMA/mlx5: Remove manually crafted QP context the query call")
Link: https://lore.kernel.org/r/20200618112507.3453496-3-leon@kernel.org
destroy_qp_common is called for flows where QP is already created by
HW. While it is called from IB/core, the ibqp.* fields will be fully
initialized, but it is not the case if this function is called during QP
creation.
Don't rely on ibqp fields as much as possible and initialize
send_cq/recv_cq as temporal solution till all drivers will be converted to
IB/core QP allocation scheme.
refcount_t: underflow; use-after-free.
WARNING: CPU: 1 PID: 5372 at lib/refcount.c:28 refcount_warn_saturate+0xfe/0x1a0
CPU: 1 PID: 5372 Comm: syz-executor.2 Not tainted 5.5.0-rc5 #2
Call Trace:
mlx5_core_put_rsc+0x70/0x80
destroy_resource_common+0x8e/0xb0
mlx5_core_destroy_qp+0xaf/0x1d0
mlx5_ib_destroy_qp+0xeb0/0x1460
ib_destroy_qp_user+0x2d5/0x7d0
create_qp+0xed3/0x2130
ib_uverbs_create_qp+0x13e/0x190
? ib_uverbs_ex_create_qp
ib_uverbs_write+0xaa5/0xdf0
__vfs_write+0x7c/0x100
ksys_write+0xc8/0x200
do_syscall_64+0x9c/0x390
Fixes: 08d53976609a ("RDMA/mlx5: Copy response to the user in one place")
Link: https://lore.kernel.org/r/20200617130148.2846643-1-leon@kernel.org
In disassociate flow, the type_attrs is set to be NULL, which is in an
implicit way is checked in alloc_uobj() by "if (!attrs->context)".
Change the logic to rely on that check, to be consistent with other
alloc_uobj() places that will fix the following kernel splat.
BUG: kernel NULL pointer dereference, address: 0000000000000018
PGD 0 P4D 0
CPU: 3 PID: 2743 Comm: python3 Not tainted 5.7.0-rc6-for-upstream-perf-2020-05-23_19-04-38-5 #1
RIP: 0010:alloc_begin_fd_uobject+0x18/0xf0 [ib_uverbs]
Code: 89 43 48 eb 97 66 66 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 41 55 49 89 f5 41 54 55 48 89 fd 53 48 83 ec 08 48 8b 1f <48> 8b 43 18 48 8b 80 80 00 00 00 48 3d 20 10 33 a0 74 1c 48 3d 30
RSP: 0018:ffffc90001127b70 EFLAGS: 00010282
RAX: ffffffffa0339fe0 RBX: 0000000000000000 RCX: 8000000000000007
RDX: fffffffffffffffb RSI: ffffc90001127d28 RDI: ffff88843fe1f600
RBP: ffff88843fe1f600 R08: ffff888461eb06d8 R09: ffff888461eb06f8
R10: ffff888461eb0700 R11: 0000000000000000 R12: ffff88846a5f6450
R13: ffffc90001127d28 R14: ffff88845d7d6ea0 R15: ffffc90001127cb8
FS: 00007f469bff1540(0000) GS:ffff88846f980000(0000) knlGS:0000000000000000
CR2: 0000000000000018 CR3: 0000000450018003 CR4: 0000000000760ee0
PKRU: 55555554
Call Trace:
? xa_store+0x28/0x40
rdma_alloc_begin_uobject+0x4f/0x90 [ib_uverbs]
ib_uverbs_create_comp_channel+0x87/0xf0 [ib_uverbs]
ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0xb1/0xf0 [ib_uverbs]
ib_uverbs_cmd_verbs.isra.8+0x96d/0xae0 [ib_uverbs]
? get_page_from_freelist+0x3bb/0xf70
? _copy_to_user+0x22/0x30
? __wake_up_common_lock+0x87/0xc0
ib_uverbs_ioctl+0xbc/0x130 [ib_uverbs]
ksys_ioctl+0x83/0xc0
? ksys_write+0x55/0xd0
RIP: 0033:0x7f469ac43267
Fixes: 849e149063bd ("RDMA/core: Do not allow alloc_commit to fail")
Link: https://lore.kernel.org/r/20200617061826.2625359-1-leon@kernel.org
If a IMP reset caused by some hardware errors and hns RoCE driver reset
occurred at the same time, there is a possiblity that the IMP will stop
dealing with command and users can't use the hardware. The logs are as
follows:
hns3 0000:fd:00.1: cleaned 0, need to clean 1
hns3 0000:fd:00.1: firmware version query failed -11
hns3 0000:fd:00.1: Cmd queue init failed
hns3 0000:fd:00.1: Upgrade reset level
hns3 0000:fd:00.1: global reset interrupt
The hns NIC driver divides the reset process into 3 status:
initialization, hardware resetting and softwaring restting. RoCE driver
gets reset status by interfaces provided by NIC driver and commands will
not be sent to the IMP if the driver is in any above status. The main
reason for this issue is that there is a time gap between status 1 and 2,
if the RoCE driver sends commands to the IMP during this gap, the IMP will
stop working because it is not ready.
To eliminate the time gap, the hns NIC driver has added a new interface in
commit a4de02287abb9 ("net: hns3: provide .get_cmdq_stat interface for the
client"), so RoCE driver can ensure that no commands will be sent during
resetting.
Link: https://lore.kernel.org/r/1592314778-52822-1-git-send-email-liweihang@huawei.com
Signed-off-by: Yangyang Li <liyangyang20@huawei.com>
ibmr.device is assigned after MR is successfully registered, but both
write_mtpt() and frmr_write_mtpt() accesses it during the mr registration
process, which may cause the following error when trying to register MR in
userspace and pbl_hop_num is set to 0.
pc : hns_roce_mtr_find+0xa0/0x200 [hns_roce]
lr : set_mtpt_pbl+0x54/0x118 [hns_roce_hw_v2]
sp : ffff00023e73ba20
x29: ffff00023e73ba20 x28: ffff00023e73bad8
x27: 0000000000000000 x26: 0000000000000000
x25: 0000000000000002 x24: 0000000000000000
x23: ffff00023e73bad0 x22: 0000000000000000
x21: ffff0000094d9000 x20: 0000000000000000
x19: ffff8020a6bdb2c0 x18: 0000000000000000
x17: 0000000000000000 x16: 0000000000000000
x15: 0000000000000000 x14: 0000000000000000
x13: 0140000000000000 x12: 0040000000000041
x11: ffff000240000000 x10: 0000000000001000
x9 : 0000000000000000 x8 : ffff802fb7558480
x7 : ffff802fb7558480 x6 : 000000000003483d
x5 : ffff00023e73bad0 x4 : 0000000000000002
x3 : ffff00023e73bad8 x2 : 0000000000000000
x1 : 0000000000000000 x0 : ffff0000094d9708
Call trace:
hns_roce_v2_write_mtpt+0x14c/0x168 [hns_roce_hw_v2]
hns_roce_mr_enable+0x6c/0x148 [hns_roce]
hns_roce_reg_user_mr+0xd8/0x130 [hns_roce]
ib_uverbs_reg_mr+0x14c/0x2e0 [ib_uverbs]
ib_uverbs_write+0x27c/0x3e8 [ib_uverbs]
__vfs_write+0x60/0x190
vfs_write+0xac/0x1c0
ksys_write+0x6c/0xd8
__arm64_sys_write+0x24/0x30
el0_svc_common+0x78/0x130
el0_svc_handler+0x38/0x78
el0_svc+0x8/0xc
Solve above issue by adding a pointer of structure hns_roce_dev as a
parameter of write_mtpt() and frmr_write_mtpt(), so that both of these
functions can access it before finishing MR's registration.
Link: https://lore.kernel.org/r/1592314629-51715-1-git-send-email-liweihang@huawei.com
Missed steps during ECE handshake left userspace application with less
options for the ECE handshake. Pass ECE options in the additional
transitions.
Fixes: 50aec2c3135e ("RDMA/mlx5: Return ECE data after modify QP")
Link: https://lore.kernel.org/r/20200616104536.2426384-1-leon@kernel.org
The bind_list and listen_list must be accessed under a lock, add the
missing locking around the access in cm_ib_id_from_event()
In addition add lockdep asserts to make it clearer what the locking
semantic is here.
general protection fault: 0000 [#1] SMP NOPTI
CPU: 226 PID: 126135 Comm: kworker/226:1 Tainted: G OE 4.12.14-150.47-default #1 SLE15
Hardware name: Cray Inc. Windom/Windom, BIOS 0.8.7 01-10-2020
Workqueue: ib_cm cm_work_handler [ib_cm]
task: ffff9c5a60a1d2c0 task.stack: ffffc1d91f554000
RIP: 0010:cma_ib_req_handler+0x3f1/0x11b0 [rdma_cm]
RSP: 0018:ffffc1d91f557b40 EFLAGS: 00010286
RAX: deacffffffffff30 RBX: 0000000000000001 RCX: ffff9c2af5bb6000
RDX: 00000000000000a9 RSI: ffff9c5aa4ed2f10 RDI: ffffc1d91f557b08
RBP: ffffc1d91f557d90 R08: ffff9c340cc80000 R09: ffff9c2c0f901900
R10: 0000000000000000 R11: 0000000000000001 R12: deacffffffffff30
R13: ffff9c5a48aeec00 R14: ffffc1d91f557c30 R15: ffff9c5c2eea3688
FS: 0000000000000000(0000) GS:ffff9c5c2fa80000(0000) knlGS:0000000000000000
CR2: 00002b5cc03fa320 CR3: 0000003f8500a000 CR4: 00000000003406e0
Call Trace:
? rdma_addr_cancel+0xa0/0xa0 [ib_core]
? cm_process_work+0x28/0x140 [ib_cm]
? cm_get_bth_pkey.isra.44+0x34/0xa0 [ib_cm]
cm_work_handler+0xa06/0x1a6f [ib_cm]
? __switch_to+0x7c/0x4b0
process_one_work+0x1da/0x400
worker_thread+0x2b/0x3f0
? process_one_work+0x400/0x400
kthread+0x118/0x140
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x22/0x40
Code: 00 66 83 f8 02 0f 84 ca 05 00 00 49 8b 84 24 d0 01 00 00 48 85 c0 0f 84 68 07 00 00 48 2d d0 01
00 00 49 89 c4 0f 84 59 07 00 00 <41> 0f b7 44 24 20 49 8b 77 50 66 83 f8 0a 75 9e 49 8b 7c 24 28
Fixes: 4c21b5bcef73 ("IB/cma: Add net_dev and private data checks to RDMA CM")
Link: https://lore.kernel.org/r/20200616104304.2426081-1-leon@kernel.org
Private data passed to iwarp_cm_handler is copied for connection request /
response, but ignored otherwise. If junk is passed, it is stored in the
event and used later in the event processing.
The driver passes an old junk pointer during connection close which leads
to a use-after-free on event processing. Set private data to NULL for
events that don 't have private data.
BUG: KASAN: use-after-free in ucma_event_handler+0x532/0x560 [rdma_ucm]
kernel: Read of size 4 at addr ffff8886caa71200 by task kworker/u128:1/5250
kernel:
kernel: Workqueue: iw_cm_wq cm_work_handler [iw_cm]
kernel: Call Trace:
kernel: dump_stack+0x8c/0xc0
kernel: print_address_description.constprop.0+0x1b/0x210
kernel: ? ucma_event_handler+0x532/0x560 [rdma_ucm]
kernel: __kasan_report.cold+0x1a/0x33
kernel: kasan_report+0xe/0x20
kernel: check_memory_region+0x130/0x1a0
kernel: memcpy+0x20/0x50
kernel: ucma_event_handler+0x532/0x560 [rdma_ucm]
kernel: ? __rpc_execute+0x608/0x620 [sunrpc]
kernel: cma_iw_handler+0x212/0x330 [rdma_cm]
kernel: ? iw_conn_req_handler+0x6e0/0x6e0 [rdma_cm]
kernel: ? enqueue_timer+0x86/0x140
kernel: ? _raw_write_lock_irq+0xd0/0xd0
kernel: cm_work_handler+0xd3d/0x1070 [iw_cm]
Fixes: e411e0587e0d ("RDMA/qedr: Add iWARP connection management functions")
Link: https://lore.kernel.org/r/20200616093408.17827-1-michal.kalderon@marvell.com
Signed-off-by: Ariel Elior <ariel.elior@marvell.com>
Signed-off-by: Michal Kalderon <michal.kalderon@marvell.com>
The max_pkeys device attribute was not set in query device verb, set it to
one in order to account for the default pkey (0xffff). This information is
exposed to userspace and can cause malfunction
Fixes: 40909f664d27 ("RDMA/efa: Add EFA verbs implementation")
Link: https://lore.kernel.org/r/20200614103534.88060-1-galpress@amazon.com
Reviewed-by: Firas JahJah <firasj@amazon.com>
Reviewed-by: Yossi Leybovich <sleybo@amazon.com>
Signed-off-by: Gal Pressman <galpress@amazon.com>
In case of failure of alloc_ud_wq_attr(), the memory allocated by
rvt_alloc_rq() is not freed. Fix it by calling rvt_free_rq() using the
existing clean-up code.
Fixes: d310c4bf8aea ("IB/{rdmavt, hfi1, qib}: Remove AH refcount for UD QPs")
Link: https://lore.kernel.org/r/20200614041148.131983-1-pakki001@umn.edu
Signed-off-by: Aditya Pakki <pakki001@umn.edu>
Fix the following sparse error by adding annotation to
cm_queue_work_unlock() that it releases cm_id_priv->lock lock.
drivers/infiniband/core/cm.c:936:24: warning: context imbalance in
'cm_queue_work_unlock' - unexpected unlock
Fixes: e83f195aa45c ("RDMA/cm: Pull duplicated code into cm_queue_work_unlock()")
Link: https://lore.kernel.org/r/20200611130045.1994026-1-leon@kernel.org
Reported-by: kernel test robot <lkp@intel.com>
The variable buf_addr is type dma_addr_t, which may not be the same size
as a pointer. To ensure it is the correct size, cast to a uintptr_t.
Fixes: c536277e0db1 ("RDMA/siw: Fix 64/32bit pointer inconsistency")
Link: https://lore.kernel.org/r/20200610174717.15932-1-tseewald@gmail.com
Signed-off-by: Tom Seewald <tseewald@gmail.com>
The word 'descriptor' is misspelled throughout the tree.
Fix it up accordingly:
decriptors -> descriptors
Link: https://lore.kernel.org/r/20200609124610.3445662-3-kieran.bingham+renesas@ideasonboard.com
Link: https://lore.kernel.org/r/20200609124610.3445662-12-kieran.bingham+renesas@ideasonboard.com
Signed-off-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Variables of type size_t should use %zu rather than %lu [1]. The variables
"inlen", "ucmd", "last", and "size" are all size_t, so use the correct
format specifiers.
[1] https://www.kernel.org/doc/html/latest/core-api/printk-formats.html
Link: https://lore.kernel.org/r/20200605023012.9527-1-tseewald@gmail.com
Acked-by: Leon Romanovsky <leonro@mellanox.com>
The assignment to resp.response_length is never read since it is being
updated again on the next statement. The assignment is redundant so
removed it.
Fixes: a645a89d9a78 ("RDMA/mlx5: Return ECE DC support")
Link: https://lore.kernel.org/r/20200604143902.56021-1-colin.king@canonical.com
Addresses-Coverity: ("Unused value")
