commit 1feb40067cf04ae48d65f728d62ca255c9449178 upstream.
The handling of IB_RDMA_WRITE_ONLY_WITH_IMMEDIATE will leak a memory
reference when a buffer cannot be allocated for returning the immediate
data.
The issue is that the rkey validation has already occurred and the RNR
nak fails to release the reference that was fruitlessly gotten. The
the peer will send the identical single packet request when its RNR
timer pops.
The fix is to release the held reference prior to the rnr nak exit.
This is the only sequence the requires both rkey validation and the
buffer allocation on the same packet.
Tested-by: Tadeusz Struk <tadeusz.struk@intel.com>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull main rdma updates from Doug Ledford:
"This is the main pull request for the rdma stack this release. The
code has been through 0day and I had it tagged for linux-next testing
for a couple days.
Summary:
- updates to mlx5
- updates to mlx4 (two conflicts, both minor and easily resolved)
- updates to iw_cxgb4 (one conflict, not so obvious to resolve,
proper resolution is to keep the code in cxgb4_main.c as it is in
Linus' tree as attach_uld was refactored and moved into
cxgb4_uld.c)
- improvements to uAPI (moved vendor specific API elements to uAPI
area)
- add hns-roce driver and hns and hns-roce ACPI reset support
- conversion of all rdma code away from deprecated
create_singlethread_workqueue
- security improvement: remove unsafe ib_get_dma_mr (breaks lustre in
staging)"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (75 commits)
staging/lustre: Disable InfiniBand support
iw_cxgb4: add fast-path for small REG_MR operations
cxgb4: advertise support for FR_NSMR_TPTE_WR
IB/core: correctly handle rdma_rw_init_mrs() failure
IB/srp: Fix infinite loop when FMR sg[0].offset != 0
IB/srp: Remove an unused argument
IB/core: Improve ib_map_mr_sg() documentation
IB/mlx4: Fix possible vl/sl field mismatch in LRH header in QP1 packets
IB/mthca: Move user vendor structures
IB/nes: Move user vendor structures
IB/ocrdma: Move user vendor structures
IB/mlx4: Move user vendor structures
IB/cxgb4: Move user vendor structures
IB/cxgb3: Move user vendor structures
IB/mlx5: Move and decouple user vendor structures
IB/{core,hw}: Add constant for node_desc
ipoib: Make ipoib_warn ratelimited
IB/mlx4/alias_GUID: Remove deprecated create_singlethread_workqueue
IB/ipoib_verbs: Remove deprecated create_singlethread_workqueue
IB/ipoib: Remove deprecated create_singlethread_workqueue
Signed-off-by: Yuval Shaia <yuval.shaia@oracle.com>
alloc_ordered_workqueue() with WQ_MEM_RECLAIM set, replaces
deprecated create_singlethread_workqueue(). This is the identity
conversion.
The workqueue "qib" queues work item &priv->s_work. It has been
identity converted.
WQ_MEM_RECLAIM has been set to ensure forward progress under
memory pressure.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Tested-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Acked-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
There is no need to have a global qpt_mask as that does not support the
multiple chip model which qib has. Instead rely on the value which
exists already in the device data (dd).
Fixes: 898fa52b4ac3 "IB/qib: Remove qpn, qp tables and related variables from qib"
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Use common header file structs, defines, and accessors
in the drivers. The old declarations are removed.
The repositioning of the includes allows for the removal
of hfi1_message_header and replaces its use with ib_header.
Also corrected are two issues with set_armed_to_active():
- The "packet" parameter is now a pointer as it should have been
- The etype is validated to insure that the header is correct
Reviewed-by: Don Hiatt <don.hiatt@intel.com>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
This improves readability and hides the reference count
mechanism from the client drivers.
Reuse existing functionality from memdup_user() instead of keeping
duplicate source code.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
The qp init function does a kzalloc() while holding the RCU
lock that encounters the following warning with a debug kernel
when a cat of the qp_stats is done:
[ 231.723948] rcu_scheduler_active = 1, debug_locks = 0
[ 231.731939] 3 locks held by cat/11355:
[ 231.736492] #0: (debugfs_srcu){......}, at: [<ffffffff813001a5>] debugfs_use_file_start+0x5/0x90
[ 231.746955] #1: (&p->lock){+.+.+.}, at: [<ffffffff81289a6c>] seq_read+0x4c/0x3c0
[ 231.755873] #2: (rcu_read_lock){......}, at: [<ffffffffa0a0c535>] _qp_stats_seq_start+0x5/0xd0 [hfi1]
[ 231.766862]
The init functions do an implicit next which requires the rcu read lock
before the kzalloc().
Fix for both drivers is to change the scope of the init function to only
do the allocation and the initialization of the just allocated iter.
The implict next is moved back into the respective start functions to fix
the issue.
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
CC: <stable@vger.kernel.org> # 4.6.x-
Instead of copying the actual GRH of type struct ib_grh, existing code
copies the struct ib_global_route into the sge. This patch fixes that
and constructs the actual GRH from ib_global_route and copies the GRH
into the sge.
Reviewed-by: Dean Luick <dean.luick@intel.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com>
Signed-off-by: Don Hiatt <don.hiatt@intel.com>
Add initial table for table driven post_send support.
Reviewed-by: Jianxin Xiong <jianxin.xiong@intel.com>
If a context has already been assigned to an FD, prevent
another assignment.
Pull more rdma updates from Doug Ledford:
"This is the second group of code for the 4.7 merge window. It looks
large, but only in one sense. I'll get to that in a minute. The list
of changes here breaks down as follows:
- Dynamic counter infrastructure in the IB drivers
This is a sysfs based code to allow free form access to the
hardware counters RDMA devices might support so drivers don't need
to code this up repeatedly themselves
- SendOnlyFullMember multicast support
- IB router support
- A couple misc fixes
- The big item on the list: hfi1 driver updates, plus moving the hfi1
driver out of staging
There was a group of 15 patches in the hfi1 list that I thought I had
in the first pull request but they weren't. So that added to the
length of the hfi1 section here.
As far as these go, everything but the hfi1 is pretty straight
forward.
The hfi1 is, if you recall, the driver that Al had complaints about
how it used the write/writev interfaces in an overloaded fashion. The
write portion of their interface behaved like the write handler in the
IB stack proper and did bi-directional communications. The writev
interface, on the other hand, only accepts SDMA request structures.
The completions for those structures are sent back via an entirely
different event mechanism.
With the security patch, we put security checks on the write
interface, however, we also knew they would be going away soon. Now,
we've converted the write handler in the hfi1 driver to use ioctls
from the IB reserved magic area for its bidirectional communications.
With that change, Intel has addressed all of the items originally on
their TODO when they went into staging (as well as many items added to
the list later).
As such, I moved them out, and since they were the last item in the
staging/rdma directory, and I don't have immediate plans to use the
staging area again, I removed the staging/rdma area.
Because of the move out of staging, as well as a series of 5 patches
in the hfi1 driver that removed code people thought should be done in
a different way and was optional to begin with (a snoop debug
interface, an eeprom driver for an eeprom connected directory to their
hfi1 chip and not via an i2c bus, and a few other things like that),
the line count, especially the removal count, is high"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (56 commits)
staging/rdma: Remove the entire rdma subdirectory of staging
IB/core: Make device counter infrastructure dynamic
IB/hfi1: Fix pio map initialization
IB/hfi1: Correct 8051 link parameter settings
IB/hfi1: Update pkey table properly after link down or FM start
IB/rdamvt: Fix rdmavt s_ack_queue sizing
IB/rdmavt: Max atomic value should be a u8
IB/hfi1: Fix hard lockup due to not using save/restore spin lock
IB/hfi1: Add tracing support for send with invalidate opcode
IB/hfi1, qib: Add ieth to the packet header definitions
IB/hfi1: Move driver out of staging
IB/hfi1: Do not free hfi1 cdev parent structure early
IB/hfi1: Add trace message in user IOCTL handling
IB/hfi1: Remove write(), use ioctl() for user cmds
IB/hfi1: Add ioctl() interface for user commands
IB/hfi1: Remove unused user command
IB/hfi1: Remove snoop/diag interface
IB/hfi1: Remove EPROM functionality from data device
IB/hfi1: Remove UI char device
IB/hfi1: Remove multiple device cdev
A new union member "ieth" (Invalidate Extended Transport Header) is
added to the packet header definition in preparation of supporting
the send with invalidate opcode.
Signed-off-by: Jianxin Xiong <jianxin.xiong@intel.com>
Building the qib driver with gcc version 6.1.0 raises the following
build warning:
drivers/infiniband/hw/qib/qib_iba7322.c:1311:39: warning:
'qib_7322_intr_msgs' defined but not used [-Wunused-const-variable=]
static const struct qib_hwerror_msgs qib_7322_intr_msgs[] = {
Remove the unused qib_7322_intr_msgs[]
Signed-off-by: Jubin John <jubin.john@intel.com>
Change struct ib_class_port_info to conform to IB Spec 1.3
That in order to get specific capability mask from ClassPortInfo mad.
>From the IB Spec, ClassPortInfo section:
"CapabilityMask2 Bits 0-26: Additional class-specific capabilities...
RespTimeValue the rest 5 bits"
The new struct now has one field for capabilitymask2 (previously was the
reserved field) and the resp_time field.
And it fixes up qib and srpt, use of the field repurposed to be used as
capabilitymask2:
IB/qib: Change pma_get_classportinfo
IB/srpt: Adjust the use of ib_class_port_info
Signed-off-by: Erez Shitrit <erezsh@mellanox.com>
Reviewed-by: Hal Rosenstock <hal@mellanox.com>
Pull rdma updates from Doug Ledford:
"Primary 4.7 merge window changes
- Updates to the new Intel X722 iWARP driver
- Updates to the hfi1 driver
- Fixes for the iw_cxgb4 driver
- Misc core fixes
- Generic RDMA READ/WRITE API addition
- SRP updates
- Misc ipoib updates
- Minor mlx5 updates"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (148 commits)
IB/mlx5: Fire the CQ completion handler from tasklet
net/mlx5_core: Use tasklet for user-space CQ completion events
IB/core: Do not require CAP_NET_ADMIN for packet sniffing
IB/mlx4: Fix unaligned access in send_reply_to_slave
IB/mlx5: Report Scatter FCS device capability when supported
IB/mlx5: Add Scatter FCS support for Raw Packet QP
IB/core: Add Scatter FCS create flag
IB/core: Add Raw Scatter FCS device capability
IB/core: Add extended device capability flags
i40iw: pass hw_stats by reference rather than by value
i40iw: Remove unnecessary synchronize_irq() before free_irq()
i40iw: constify i40iw_vf_cqp_ops structure
IB/mlx5: Add UARs write-combining and non-cached mapping
IB/mlx5: Allow mapping the free running counter on PROT_EXEC
IB/mlx4: Use list_for_each_entry_safe
IB/SA: Use correct free function
IB/core: Fix a potential array overrun in CMA and SA agent
IB/core: Remove unnecessary check in ibnl_rcv_msg
IB/IWPM: Fix a potential skb leak
RDMA/nes: replace custom print_hex_dump()
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Support for Power ISA 3.0 (Power9) Radix Tree MMU from Aneesh Kumar K.V
- Live patching support for ppc64le (also merged via livepatching.git)
Various cleanups & minor fixes from:
- Aaro Koskinen, Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V,
Chris Smart, Daniel Axtens, Frederic Barrat, Gavin Shan, Ian Munsie,
Lennart Sorensen, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring,
Michael Ellerman, Oliver O'Halloran, Paul Gortmaker, Paul Mackerras,
Rashmica Gupta, Russell Currey, Suraj Jitindar Singh, Thiago Jung
Bauermann, Valentin Rothberg, Vipin K Parashar.
General:
- Update LMB associativity index during DLPAR add/remove from Nathan
Fontenot
- Fix branching to OOL handlers in relocatable kernel from Hari Bathini
- Add support for userspace Power9 copy/paste from Chris Smart
- Always use STRICT_MM_TYPECHECKS from Michael Ellerman
- Add mask of possible MMU features from Michael Ellerman
PCI:
- Enable pass through of NVLink to guests from Alexey Kardashevskiy
- Cleanups in preparation for powernv PCI hotplug from Gavin Shan
- Don't report error in eeh_pe_reset_and_recover() from Gavin Shan
- Restore initial state in eeh_pe_reset_and_recover() from Gavin Shan
- Revert "powerpc/eeh: Fix crash in eeh_add_device_early() on Cell"
from Guilherme G Piccoli
- Remove the dependency on EEH struct in DDW mechanism from Guilherme
G Piccoli
selftests:
- Test cp_abort during context switch from Chris Smart
- Add several tests for transactional memory support from Rashmica
Gupta
perf:
- Add support for sampling interrupt register state from Anju T
- Add support for unwinding perf-stackdump from Chandan Kumar
cxl:
- Configure the PSL for two CAPI ports on POWER8NVL from Philippe
Bergheaud
- Allow initialization on timebase sync failures from Frederic Barrat
- Increase timeout for detection of AFU mmio hang from Frederic
Barrat
- Handle num_of_processes larger than can fit in the SPA from Ian
Munsie
- Ensure PSL interrupt is configured for contexts with no AFU IRQs
from Ian Munsie
- Add kernel API to allow a context to operate with relocate disabled
from Ian Munsie
- Check periodically the coherent platform function's state from
Christophe Lombard
Freescale:
- Updates from Scott: "Contains 86xx fixes, minor device tree fixes,
an erratum workaround, and a kconfig dependency fix."
* tag 'powerpc-4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (192 commits)
powerpc/86xx: Fix PCI interrupt map definition
powerpc/86xx: Move pci1 definition to the include file
powerpc/fsl: Fix build of the dtb embedded kernel images
powerpc/fsl: Fix rcpm compatible string
powerpc/fsl: Remove FSL_SOC dependency from FSL_LBC
powerpc/fsl-pci: Add a workaround for PCI 5 errata
powerpc/fsl: Fix SPI compatible on t208xrdb and t1040rdb
powerpc/powernv/npu: Add PE to PHB's list
powerpc/powernv: Fix insufficient memory allocation
powerpc/iommu: Remove the dependency on EEH struct in DDW mechanism
powerpc/eeh: Drop unnecessary label in eeh_pe_change_owner()
powerpc/eeh: Ignore handlers in eeh_pe_reset_and_recover()
powerpc/eeh: Restore initial state in eeh_pe_reset_and_recover()
powerpc/eeh: Don't report error in eeh_pe_reset_and_recover()
Revert "powerpc/powernv: Exclude root bus in pnv_pci_reset_secondary_bus()"
powerpc/powernv/npu: Enable NVLink pass through
powerpc/powernv/npu: Rework TCE Kill handling
powerpc/powernv/npu: Add set/unset window helpers
powerpc/powernv/ioda2: Export debug helper pe_level_printk()
The driver was requesting for a writethrough mapping. But with those
flags we will end up with an SAO mapping because we now have memory
conherence always enabled. ie, the existing mapping will end up with a
WIMG value 0b1110 which is Strong Access Order.
Update this to use cache inhibitted guarded mapping.
Cc: Doug Ledford <dledford@redhat.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: linux-rdma@vger.kernel.org
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
rdi->ports has memory allocated in rvt_alloc_device(), but does not get
freed because the hfi1 and qib drivers drivers call ib_dealloc_device()
directly instead of going through rdmavt. Add a rvt_dealloc_device()
that frees rdi->ports and then calls ib_dealloc_device(). Switch hfi1
and qib drivers to calling rvt_dealloc_device() instead of
ib_dealloc_device() directly.
Reviewed-by: Brian Welty <brian.welty@intel.com>
The dual lock patch moved locking around and missed an issue
with handling irq flags when processing UD loopback
packets. This issue was revealed by smatch.
Fix for both qib and hfi1 to pass the saved flags to the UD request
builder and handle the changes correctly.
Fixes: 46a80d62e6e0 ("IB/qib, staging/rdma/hfi1: add s_hlock for use in post send")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
The drivers/infiniband stack uses write() as a replacement for
bi-directional ioctl(). This is not safe. There are ways to
trigger write calls that result in the return structure that
is normally written to user space being shunted off to user
specified kernel memory instead.
For the immediate repair, detect and deny suspicious accesses to
the write API.
For long term, update the user space libraries and the kernel API
to something that doesn't present the same security vulnerabilities
(likely a structured ioctl() interface).
The impacted uAPI interfaces are generally only available if
hardware from drivers/infiniband is installed in the system.
Reported-by: Jann Horn <jann@thejh.net>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
[ Expanded check to all known write() entry points ]
Cc: stable@vger.kernel.org
"Round two of 4.6 merge window patches.
This is a monster pull request. I held off on the hfi1 driver updates
(the hfi1 driver is intimately tied to the qib driver and the new
rdmavt software library that was created to help both of them) in my
first pull request. The hfi1/qib/rdmavt update is probably 90% of
this pull request. The hfi1 driver is being left in staging so that
it can be fixed up in regards to the API that Al and yourself didn't
like. Intel has agreed to do the work, but in the meantime, this
clears out 300+ patches in the backlog queue and brings my tree and
their tree closer to sync.
This also includes about 10 patches to the core and a few to mlx5 to
create an infrastructure for configuring SRIOV ports on IB devices.
That series includes one patch to the net core that we sent to netdev@
and Dave Miller with each of the three revisions to the series. We
didn't get any response to the patch, so we took that as implicit
approval.
Finally, this series includes Intel's new iWARP driver for their x722
cards. It's not nearly the beast as the hfi1 driver. It also has a
linux-next merge issue, but that has been resolved and it now passes
just fine.
Summary:
- A few minor core fixups needed for the next patch series
- The IB SRIOV series. This has bounced around for several versions.
Of note is the fact that the first patch in this series effects the
net core. It was directed to netdev and DaveM for each iteration
of the series (three versions total). Dave did not object, but did
not respond either. I've taken this as permission to move forward
with the series.
- The new Intel X722 iWARP driver
- A huge set of updates to the Intel hfi1 driver. Of particular
interest here is that we have left the driver in staging since it
still has an API that people object to. Intel is working on a fix,
but getting these patches in now helps keep me sane as the upstream
and Intel's trees were over 300 patches apart"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (362 commits)
IB/ipoib: Allow mcast packets from other VFs
IB/mlx5: Implement callbacks for manipulating VFs
net/mlx5_core: Implement modify HCA vport command
net/mlx5_core: Add VF param when querying vport counter
IB/ipoib: Add ndo operations for configuring VFs
IB/core: Add interfaces to control VF attributes
IB/core: Support accessing SA in virtualized environment
IB/core: Add subnet prefix to port info
IB/mlx5: Fix decision on using MAD_IFC
net/core: Add support for configuring VF GUIDs
IB/{core, ulp} Support above 32 possible device capability flags
IB/core: Replace setting the zero values in ib_uverbs_ex_query_device
net/mlx5_core: Introduce offload arithmetic hardware capabilities
net/mlx5_core: Refactor device capability function
net/mlx5_core: Fix caching ATOMIC endian mode capability
ib_srpt: fix a WARN_ON() message
i40iw: Replace the obsolete crypto hash interface with shash
IB/hfi1: Add SDMA cache eviction algorithm
IB/hfi1: Switch to using the pin query function
IB/hfi1: Specify mm when releasing pages
The non-rdamvt versions of qib and hfi1 allow for a differing
heuristic to override a schedule progress in favor of a direct
call the the progress routine.
This patch adds that for both drivers and rdmavt.
If SMI AH is not destroyed before de-allocating the PD, it would result in
non-zero PD use count when de-allocating the PD, triggering a WARN_ON() at
drivers/infiniband/core/verbs.c:284 ib_dealloc_pd+0x69/0xb0 [ib_core]()
when unloading the qib driver on systems with dual-port card.
This problem has always been there in qib and was detected only after the
commit 7dd78647a2c2 ("IB/core: Make ib_dealloc_pd return void") introduced
a WARN_ON in ib_dealloc_pd() that triggers if a PD's use count is non-zero
before de-allocating the PD.
Below is the call trace from the dmesg log.
[ 7264.966129] Call Trace:
[ 7264.969652] [<ffffffff81338470>] dump_stack+0x44/0x64
[ 7264.976181] [<ffffffff81086bb6>] warn_slowpath_common+0x86/0xc0
[ 7264.983656] [<ffffffff81086cfa>] warn_slowpath_null+0x1a/0x20
[ 7264.990961] [<ffffffffa025c2d9>] ib_dealloc_pd+0x69/0xb0 [ib_core]
[ 7264.998717] [<ffffffffa0044de8>] ib_mad_port_close+0xb8/0x120 [ib_mad]
[ 7265.006866] [<ffffffffa0044ebf>] ib_mad_remove_device+0x6f/0xc0 [ib_mad]
[ 7265.015224] [<ffffffffa025fc87>] ib_unregister_device+0xa7/0x140 [ib_core]
[ 7265.023738] [<ffffffffa04b5b79>] rvt_unregister_device+0x29/0x80 [rdmavt]
[ 7265.032181] [<ffffffffa088d2a2>] qib_unregister_ib_device+0x22/0x210 [ib_qib]
[ 7265.040993] [<ffffffffa085f73f>] qib_remove_one+0x1f/0x250 [ib_qib]
[ 7265.048823] [<ffffffff8137a319>] pci_device_remove+0x39/0xc0
[ 7265.055984] [<ffffffff81466a1a>] __device_release_driver+0x9a/0x140
[ 7265.063821] [<ffffffff81466bc8>] driver_detach+0xb8/0xc0
[ 7265.070579] [<ffffffff81465a15>] bus_remove_driver+0x55/0xd0
[ 7265.077717] [<ffffffff8146732c>] driver_unregister+0x2c/0x50
[ 7265.084849] [<ffffffff813789ba>] pci_unregister_driver+0x2a/0x80
[ 7265.092366] [<ffffffffa08921bd>] qib_ib_cleanup+0x37/0x65 [ib_qib]
[ 7265.100068] [<ffffffff811096d0>] SyS_delete_module+0x190/0x220
[ 7265.107379] [<ffffffff816a7bae>] entry_SYSCALL_64_fastpath+0x12/0x71
Signed-off-by: Harish Chegondi <harish.chegondi@intel.com>
Rdmavt adopted an smi_ah from qib which is not needed by hfi1. Move this
back to qib and get it out of the common library.
Reviewed-by: Jubin John <jubin.john@intel.com>
Qib needs to be notified when mad agents are created and freed, there is
some counter maintenance that needs to be performed. Add those callbacks at
registration time with rdmavt.
This patch adds an additional lock to reduce contention on the s_lock.
This lock is used in post_send() so that the post_send is not
serialized with the send engine and other send related processing.
To do this the s_next_psn is now maintained on post_send() while
post_send() related fields are moved to a new cache line. There is
an s_avail maintained for the post_send() to mitigate trading cache
lines with the send engine. The lock is released/acquired around
releasing the just built packet to the egress mechanism.
Signed-off-by: Dean Luick <dean.luick@intel.com>
This would avoid conflict with the functions in hfi1 that have similar
names when both qib and hfi1 drivers are configured to be built into
the kernel. This issue came up in the 0-day build report.
Replace the timer API's to initialize a timer & then assign the callback
function by the setup_timer() API.
Signed-off-by: Hari Prasath Gujulan Elango <hgujulan@visteon.com>
This patch is a prerequisite for adding a separate lock
for post send.
The timing of updating s_last needs to be before returning
any send completion to avoid a race between a poll cq seeing
a completion and the post send checking for a full queue.
Use the new RNR timer for hfi1.
For qib, this timer doesn't exist, so exploit driver
callbacks to use the new timer as appropriate.
Delete code from query_port which has been moved into rvt_query_port
Create a call back function to shut down a port which may be called from
rvt_modify_port
Query gid is in rdmavt, but still relies on the driver to maintain the
guid table. Add the necessary driver call back and remove the existing
verb handler.
Reviewed-by: Harish Chegondi <harish.chegondi@intel.com>
Destroy QP functionality in rdmavt will be used instead.
Remove the remove_qp function being called exclusively by destroy qp code.
Modify queue pair functionality in rdmavt will be used instead.
Remove ancillary functions which are being used by modify QP code.
Add calls to rcu_read_lock()/rcu_read_unlock() as rvt_lookup_qpn callers
must hold the rcu_read_lock before calling and keep the lock until the
returned qp is no longer in use.
Remove lookaside qp and some qp refcount atomics in the sdma send code
that is redundant with the s_dma_busy refcount, which will also stall
the state processing to the reset state.
Change the qpn hash function to hash_32 which is hash function used
in rvt_lookup_qpn. qpn_hash function would be eliminated in later patches.
Remove some of the unnecessary code from qib_register_ib_device.
srq functionality is now in rdmavt. Remove it from the qib driver.
Rely on rvt_query_qp function defined in rdmavt
Multicast is now supported by rdmavt. Remove the verbs multicast functions
and use that.
This patch removes the simple post recv function in favor of using rdmavt.
The packet receive processing still lives in the driver though.
This patch removes the post_send and post_one_send from the qib driver.
The "posting" of sends will be done by rdmavt which will walk a WQE and
queue work. This patch will still provide the capability to schedule that
work as well as kick the progress. These are provided to the rdmavt layer.
Use the completion queue functionality provided by rdmavt.
Get rid of create and free mad agent from the driver and use rdmavt
version.
No longer do drivers need to call into the IB core to allocate the verbs
device. Use the functionality provided by rdmavt.
