This removes the 'write' and 'force' from get_user_pages() and replaces
them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers
as use of this flag can result in surprising behaviour (and hence bugs)
within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
We will soon modify the vanilla get_user_pages() so it can no
longer be used on mm/tasks other than 'current/current->mm',
which is by far the most common way it is called. For now,
we allow the old-style calls, but warn when they are used.
(implemented in previous patch)
This patch switches all callers of:
get_user_pages()
get_user_pages_unlocked()
get_user_pages_locked()
to stop passing tsk/mm so they will no longer see the warnings.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: jack@suse.cz
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20160212210156.113E9407@viggo.jf.intel.com
Instead of having firmware command functions return an error and also
a status, leading to code like:
err = mthca_FW_COMMAND(..., &status);
if (err)
goto out;
if (status) {
err = -E...;
goto out;
all over the place, just handle the FW status inside the FW command
handling code (the way mlx4 does it), so we can simply write:
err = mthca_FW_COMMAND(...);
if (err)
goto out;
In addition to simplifying the source code, this also saves a healthy
chunk of text:
add/remove: 0/0 grow/shrink: 10/88 up/down: 510/-3357 (-2847)
function old new delta
static.trans_table 324 584 +260
mthca_cmd_poll 352 477 +125
mthca_cmd_wait 511 567 +56
mthca_table_put 213 240 +27
mthca_cleanup_db_tab 372 387 +15
__mthca_remove_one 314 323 +9
mthca_cleanup_user_db_tab 275 283 +8
__mthca_init_one 1738 1746 +8
mthca_cleanup 20 21 +1
mthca_MAD_IFC 1081 1082 +1
mthca_MGID_HASH 43 40 -3
mthca_MAP_ICM_AUX 23 20 -3
mthca_MAP_ICM 19 16 -3
mthca_MAP_FA 23 20 -3
mthca_READ_MGM 43 38 -5
mthca_QUERY_SRQ 43 38 -5
mthca_QUERY_QP 59 54 -5
mthca_HW2SW_SRQ 43 38 -5
mthca_HW2SW_MPT 60 55 -5
mthca_HW2SW_EQ 43 38 -5
mthca_HW2SW_CQ 43 38 -5
mthca_free_icm_table 120 114 -6
mthca_query_srq 214 206 -8
mthca_free_qp 662 654 -8
mthca_cmd 38 28 -10
mthca_alloc_db 1321 1311 -10
mthca_setup_hca 1067 1055 -12
mthca_WRITE_MTT 35 22 -13
mthca_WRITE_MGM 40 27 -13
mthca_UNMAP_ICM_AUX 36 23 -13
mthca_UNMAP_FA 36 23 -13
mthca_SYS_DIS 36 23 -13
mthca_SYNC_TPT 36 23 -13
mthca_SW2HW_SRQ 35 22 -13
mthca_SW2HW_MPT 35 22 -13
mthca_SW2HW_EQ 35 22 -13
mthca_SW2HW_CQ 35 22 -13
mthca_RUN_FW 36 23 -13
mthca_DISABLE_LAM 36 23 -13
mthca_CLOSE_IB 36 23 -13
mthca_CLOSE_HCA 38 25 -13
mthca_ARM_SRQ 39 26 -13
mthca_free_icms 178 164 -14
mthca_QUERY_DDR 389 375 -14
mthca_resize_cq 1063 1048 -15
mthca_unmap_eq_icm 123 107 -16
mthca_map_eq_icm 396 380 -16
mthca_cmd_box 90 74 -16
mthca_SET_IB 433 417 -16
mthca_RESIZE_CQ 369 353 -16
mthca_MAP_ICM_page 240 224 -16
mthca_MAP_EQ 183 167 -16
mthca_INIT_IB 473 457 -16
mthca_INIT_HCA 745 729 -16
mthca_map_user_db 816 798 -18
mthca_SYS_EN 157 139 -18
mthca_cleanup_qp_table 78 59 -19
mthca_cleanup_eq_table 168 149 -19
mthca_UNMAP_ICM 143 121 -22
mthca_modify_srq 172 149 -23
mthca_unmap_fmr 198 174 -24
mthca_query_qp 814 790 -24
mthca_query_pkey 343 319 -24
mthca_SET_ICM_SIZE 34 10 -24
mthca_QUERY_DEV_LIM 1870 1846 -24
mthca_map_cmd 1130 1105 -25
mthca_ENABLE_LAM 401 375 -26
mthca_modify_port 247 220 -27
mthca_query_device 884 850 -34
mthca_NOP 75 41 -34
mthca_table_get 287 249 -38
mthca_init_qp_table 333 293 -40
mthca_MODIFY_QP 348 308 -40
mthca_close_hca 131 89 -42
mthca_free_eq 435 390 -45
mthca_query_port 755 705 -50
mthca_free_cq 581 528 -53
mthca_alloc_icm_table 578 524 -54
mthca_multicast_attach 1041 986 -55
mthca_init_hca 326 271 -55
mthca_query_gid 487 431 -56
mthca_free_srq 524 468 -56
mthca_free_mr 168 111 -57
mthca_create_eq 1560 1501 -59
mthca_multicast_detach 790 728 -62
mthca_write_mtt 918 854 -64
mthca_register_device 1406 1342 -64
mthca_fmr_alloc 947 883 -64
mthca_mr_alloc 652 582 -70
mthca_process_mad 1242 1164 -78
mthca_dev_lim 910 830 -80
find_mgm 482 400 -82
mthca_modify_qp 3852 3753 -99
mthca_init_cq 1281 1181 -100
mthca_alloc_srq 1719 1610 -109
mthca_init_eq_table 1807 1679 -128
mthca_init_tavor 761 491 -270
mthca_init_arbel 2617 2098 -519
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
They don't get updated by git and so they're worse than useless.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Current memfree FW has a bug which in some cases, assumes that ICM
pages passed to it are cleared. This patch uses __GFP_ZERO to
allocate all ICM pages passed to the FW. Once firmware with a fix is
released, we can make the workaround conditional on firmware version.
This fixes the bug reported by Arthur Kepner <akepner@sgi.com> here:
http://lists.openfabrics.org/pipermail/general/2008-May/050026.html
Cc: <stable@kernel.org>
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
[ Rewritten to be a one-liner using __GFP_ZERO instead of vmap()ing
ICM memory and memset()ing it to 0. - Roland ]
In mthca_alloc_icm_table(), the number of entries to allocate for the
table->icm array is computed by calculating obj_size * nobj and then
dividing by MTHCA_TABLE_CHUNK_SIZE. If nobj is really large, then
obj_size * nobj may overflow and the division may get the wrong value
(even a negative value). Fix this by calculating the number of
objects per chunk and then dividing nobj by this value instead.
This patch allows crazy configurations such as loading ib_mthca with
the module parameter num_mtt=33554432 to work properly.
Fix a few whitespace and other coding style problems.
Usually harmless, since the scatterlist is always hard-coded to a length
of 1, but it triggers a BUG() if CONFIG_DEBUG_SG=y, so we better fix it.
This fixes <http://bugzilla.kernel.org/show_bug.cgi?id=9934>.
Most drivers need to set length and offset as well, so may as well fold
those three lines into one.
Add sg_assign_page() for those two locations that only needed to set
the page, where the offset/length is set outside of the function context.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
The change to allow allocating ICM chunks from coherent memory did not
increment the count of sg entries properly, so a chunk that required
more than allocation would not be mapped properly by the HCA.
Fix this by adding the missing increment of chunk->nsg.
We allocate the MTT table with alloc_pages() and then do pci_map_sg(),
so we must call pci_dma_sync_sg() after the CPU writes to the MTT
table. This works since the device will never write MTTs on mem-free
HCAs, once we get rid of the use of the WRITE_MTT firmware command.
This change is needed to make that work, and is an improvement for
now, since it gives FMRs a chance at working.
For MPTs, both the device and CPU might write there, so we must
allocate DMA coherent memory for these.
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
mthca_table_find() will return the wrong address when the table entry
being searched for is exactly at the beginning of a sglist entry
(other than the first), because it uses >= when it should use >.
Example: assume we have 2 entries in scatterlist, 4K each, offset is
4K. The current code will return first entry + 4K when we really want
the second entry.
In particular this means mapping an FMR on a memfree HCA may end up
writing the page table into the wrong place, leading to memory
corruption and also causing the HCA to use an incorrect address
translation table.
Use a named enum for the HCA's internal page size, rather than having
magic values of 4096 and shifts by 12 all over the code. Also, fix
one minor bug in EQ handling: only one HCA page is mapped to the HCA
during initialization, but a full kernel page is unmapped during
cleanup. This might cause problems when PAGE_SIZE != 4096.
Signed-off-by: Ishai Rabinovitz <ishai@mellanox.co.il>
Convert semaphores to mutexes in mthca. Leave firmware command
interface poll_sem and event_sem as semaphores.
break only escapes from the innermost loop, and we want to escape both
loops and return an answer. Noticed by Ishai Rabinovitch.
Free the memory allocated in mthca_init_user_db_tab() when releasing
the db_tab in mthca_cleanup_user_db_tab().
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Make the type parameter of mthca_alloc_db() be an enum mthca_db_type
instead of an int. This doesn't have any practical effect but
documents the functions a little better.
When allocating a table for mem-free HCA context, don't assume that
obj_size * nobj is an even multiple of MTHCA_TABLE_CHUNK_SIZE. In
particular, make sure we allocate at least one slot even if the table
is smaller than MTHCA_TABLE_CHUNK_SIZE.
If we allocate a bunch of doorbell records and then free them, we'll
end up with completely empty pages, which we then free. However, when
we come back to allocate more doorbell pages, we have to reallocate
those empty pages rather than always trying to take a slot that we've
never used. If we don't, we eventually use up every slot and fail to
allocate a doorbell record, even though we have plenty of free space.
When creating a table in context memory where the table is smaller
than our chunk size, we don't want to allocate and map a full chunk.
Instead, allocate just enough memory to cover the table.
This can be pretty simple because all tables are a power-of-2 size, so
either the table is a multiple of the chunk size, or it's smaller than
one chunk.
Fix sparse warnings. Use __be* where appropriate.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Make some lawyers happy and add copyright notices for people who
forgot to include them when they actually touched the code.
Add support for userspace doorbell records to mthca.
Make mthca_table_put() and mthca_table_put_range() NOPs if the device is not
mem-free, so that we don't have to have "if (mthca_is_memfree())" tests in the
callers of these functions. This makes our code more readable and
maintainable, and saves a couple dozen bytes of text in ib_mthca.ko as well.
Signed-off-by: Roland Dreier <roland@topspin.com>
Fix order of #include lines in mthca_memfree.c
Missing include - usual portability problems...
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
Clean up mem-free mode support by introducing mthca_is_memfree() function,
which encapsulates the logic of deciding if a device is mem-free.
Add mthca_table_find() function, which returns the lowmem address of an entry
in a mem-free HCA's context tables. This will be used by the FMR
implementation.
Release mutex on error return path from mthca_alloc_db().
Doorbell record pages are allocated in HCA page size chunks (always 4096
bytes), so we need to divide by 4096 and not PAGE_SIZE when figuring out how
many pages we'll need space for.
In mem-free mode, when allocating memory regions, make sure that the HCA has
context memory mapped to cover the virtual space used for the MPT and MTTs
being used.
infrastructure for it.
Let it rip!
