Export the rdma cm interfaces to userspace via a misc device.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Allow the use of UD QPs through the rdma_cm, in order to provide
address translation services for resolving IB addresses for datagram
messages using SIDR.
During connection establishment, the passive side of a connection can
receive messages from the active side before the connection event has
been delivered to the user. Allow the passive side to send messages
in response to received data before the event is delivered. To handle
the case where the connection messages are lost, a new rdma_notify()
function is added that users may invoke to force a connection into the
established state.
Connection information was never given to the recipient of a
connection request or reply message. Only the event was delivered.
Report the connection data with the event to allows user to
reject the connection based on the requested parameters, or adjust
their resources to match the request.
The qp_type parameter into the rdma_cm is unneeded, and can be
misleading. The QP type should be determined from the port space.
ib_flush_fmr_pool() stashes away the request generation number
properly, but then goes ahead and rereads it every time it tests
whether the flush generation number has caught up. This means that
there is a theoretical possibility of livelock, if the request
generation number keeps getting bumped and the flush generation number
never catches up. The fix is simple: use the request generation
number read at the beginning of the function.
Also, atomic_inc() followed by atomic_read() can be replaced with
atomic_int_return(). There's no real requirement for atomicity here
but we might as well shrink the code.
This bug was discovered using David Binderman's list of "set but never
used" warnings from icc.
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/infiniband/core/iwcm.c
drivers/net/chelsio/cxgb2.c
drivers/net/wireless/bcm43xx/bcm43xx_main.c
drivers/net/wireless/prism54/islpci_eth.c
drivers/usb/core/hub.h
drivers/usb/input/hid-core.c
net/core/netpoll.c
Fix up merge failures with Linus's head and fix new compilation failures.
Signed-Off-By: David Howells <dhowells@redhat.com>
ib_ucm_cleanup_events() holds file_mutex while calling ib_destroy_cm_id().
This can deadlock since ib_destroy_cm_id() flushes event handlers, and
ib_ucm_event_handler() needs file_mutex, too. Therefore, drop the
file_mutex during the call to ib_destroy_cm_id().
Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il>
The ib_cm_establish() function is replaced with a more generic
ib_cm_notify(). This routine is used to notify the CM that failover
has occurred, so that future CM messages (LAP, DREQ) reach the remote
CM. (Currently, we continue to use the original path) This bumps the
userspace CM ABI.
New alternate path information is captured when a LAP message is sent
or received. This allows QP attributes to be initialized for the user
when a new path is loaded after failover occurs.
Replace a couple list_del()/list_add() combos with list_move().
Fix following problems in process_req() relating to cancellation:
- Function is wrongly doing another addr_remote() when cancelled,
which is not required.
- Make failure reporting immediate by using time_after_eq().
- On cancellation, -ETIMEDOUT was returned to the callback routine
instead of the more appropriate -ECANCELLED (users getting notified
may want to print/return this status, eg ucma_event_handler).
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
In iwcm_deref_id(), the comment says : "If the last reference is being
removed and iw_destroy_cm_id is waiting, wake up the waiting
thread". The second part of the comment, "and iw_destroy_cm_id is
waiting," is wrong, since this function either wakes the waiter
already waiting in iwcm_deref_id, or enables it (so that when
wait_for_completion() is performed later, it will immediately return).
Acked-by: Steve Wise <swise@opengridcomputing.com>
Remove unnecessary cm_id_priv argument to copy_private_data(), and
change text to reflect the code. Fix couple of typos in comments.
If we get IW_CM_EVENT_CONNECT_REQUEST message and encounter an error
(not in the LISTEN state, cannot create an id, cannot alloc
work_entry, etc), then the memory allocated by cm_event_handler() in
the event->private_data gets leaked. Since cm_work_handler has already
put the event on the work_free_list, this allocated memory is
leaked. High backlog value can allow DoS attacks.
Possible memory corruption scenario: after putting the work entry back
on the work_free_list, we call process_event() which dereferences
work->event, which could have been modified to another value
meanwhile.
The qp_access_flags are for remote access permissions only, so
IB_ACCESS_LOCAL_WRITE is an invalid value. Remove it from the values
set by cm_init_qp_init_attr() and cma_init_ib_qp().
Signed-off-by: Dotan Barak <dotanb@mellanox.co.il>
Replace open coded kmemdup() to save some screen space, and allow
inlining/not inlining to be triggered by gcc.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Rewrite cma_req_handler error handling case to encapsulate
common code.
Acked-by: Sean Hefty <sean.hefty@intel.com>
In queue_req(), use time_after_eq() instead of time_after()
for following reasons :
- Improves insert time if multiple entries with same time are
present.
- set_timeout need not be called if entry with same time
is added to the list (and that happens to be the entry
with the smallest time), saving atomic/locking operations.
- Earlier entries with same time are deleted first (fifo).
Remove redundant check of node_guid in cma_add_one().
Optimize to test for an empty list first. This ends up simplifying
the code too.
Fix up for make allyesconfig.
When ib_cancel_mad() is called, it puts the canceled send on a list
and schedules a "flushed" callback from process context. However,
this leaves a window where a receive completion could be processed
before the send is fully flushed.
This is fine, except that ib_find_send_mad() will find the MAD and
return it to the receive processing, which results in the sender
getting both a successful receive and a "flushed" send completion for
the same request. Understandably, this confuses the sender, which is
expecting only one of these two callbacks, and leads to grief such as
a use-after-free in IPoIB.
Fix this by changing ib_find_send_mad() to return a send struct only
if the status is still successful (and not "flushed"). The search of
the send_list already had this check, so this patch just adds the same
check to the search of the wait_list.
Require registration with ib_addr module to prevent caller from
unloading while a callback is in progress.
Return the sq_draining value back to user space for query_qp instead
of the en_sqd_async notify value, which is valid only for
modify_qp. For query_qp, the draining status should returned.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
rdma_bind_addr() leaks a cma_dev reference count in failure case.
Currently a DREP is only sent in response to a DREQ if a connection
has been found matching the DREQ, and it is in the proper state. Once
a DREP is sent, the local connection moves into timewait. Duplicate
DREQs received while in this state result in re-sending the DREP.
However, it's likely that the local connection will enter and exit
timewait before the remote side times out a lost DREP and resends a DREQ.
To handle this, we send a DREP in response to a DREQ, even if a local
connection is not found. This avoids maintaining disconnected
id's in timewait states for excessively long times, just to handle a
lost DREP.
If the ib_cm module is unloaded while id's are still in timewait, the
CM will destroy the work queue used to process timewait. Once the
id's exit timewait, their timers will fire, leading to a crash trying
to access the destroyed work queue.
We need to track id's that are in timewait, and cancel their deferred
work on module unload.
Reorganize code relating to cma_get_net_info() and rdam_create_id() to
optimize error case handling (no need to alloc memory/etc. as part of
rdma_create_id() if input parameters are wrong).
Eliminate remove_list by using list_del_init() instead during device
removal handling.
On reporting a route error, also include the status for the error,
rather than indicating a status of 0 when an error has occurred.
The race is as follows:
A process : cma_process_remove() calls cma_remove_id_dev(),
which sets id state to CMA_DEVICE_REMOVAL and
calls wait_event(dev_remove).
B process : cma_req_handler() had incremented dev_remove,
and calls cma_acquire_ib_dev() and on failure
calls cma_release_remove(), which does a
wake_up of cma_process_remove(). Then
cma_req_handler() calls rdma_destroy_id();
A Process : cma_remove_id_dev() gets woken and checks the
state of id, and since it is still (wrongly)
CMA_DEVICE_REMOVAL, it calls notify_user(id)
and if that fails, the caller - cma_process_remove()
calls rdma_destroy_id(id). Two processes can
call rdma_destroy_id(), resulting in one
de-referencing kfreed id_priv.
Fix is for process B to set CMA_DESTROYING in cma_req_handler()
so that process A will return instead of doing a rdma_destroy_id().
cma_connect_ib() and cma_connect_iw() leak cm_id's in failure cases.
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and
inet_ifa_match() annotated, along with inferred net-endian variables
* Rougly half of callers already do it by not checking return value
* Code in drivers/acpi/osl.c does the following to be sure:
(void)kmem_cache_destroy(cache);
* Those who check it printk something, however, slab_error already printed
the name of failed cache.
* XFS BUGs on failed kmem_cache_destroy which is not the decision
low-level filesystem driver should make. Converted to ignore.
indirect chains of includes are arch-specific and can't
be relied upon... (hell, even attempt to build it for
itanic would trigger vmalloc.h ones; err.h triggers
on e.g. alpha).
Do not track remote QPN in TimeWait state, since QP is not connected.
Require users to register with SA module, to prevent the sa_query
module text from going away while an SA query callback is still
running. Update all in-tree users for the new interface.
Closes a window where address resolution can attach an rdma_cm_id to a
device during destruction of the rdma_cm_id. This can result in the
rdma_cm_id remaining in the device list after its memory has been
freed.
Modifications to the existing rdma header files, core files, drivers,
and ulp files to support iWARP, including:
- Hook iWARP CM into the build system and use it in rdma_cm.
- Convert enum ib_node_type to enum rdma_node_type, which includes
the possibility of RDMA_NODE_RNIC, and update everything for this.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Add an iWARP Connection Manager (CM), which abstracts connection
management for iWARP devices (RNICs). It is a logical instance of the
xx_cm where xx is the transport type (ib or iw). The symbols exported
are used by the transport independent rdma_cm module, and are
available also for transport dependent ULPs.
Remove some trailing whitespace that has snuck in despite the best
efforts of whitespace=error-all. Also fix a few other whitespace
bogosities.
Randomize the starting local comm ID to avoid getting a rejected
connection due to a stale connection after a system reboot or
reloading of the ib_cm.
The ib_mad module does not use a kthread function, but mad_priv.h
includes <linux/kthread.h>. mad_rmpp.c does not do any DMA-related
stuff, but includes <linux/dma-mapping.h>. Remove the unused includes.
Signed-off-by: James Lentini <jlentini@netapp.com>
The implementation assumes that any RMPP request that requires a
response uses DS RMPP. Based on the RMPP start-up scenarios defined
by the spec, this should be a valid assumption. That is, there is no
start-up scenario defined where an RMPP request is followed by a
non-RMPP response. By having this assumption we avoid any API
changes.
In order for a node that supports DS RMPP to communicate with one that
does not, RMPP responses assume a new window size of 1 if a DS ACK has
not been received. (By DS ACK, I'm referring to the turn-around ACK
after the final ACK of the request.) This is a slight spec deviation,
but is necessary to allow communication with nodes that do not
generate the DS ACK. It also handles the case when a response is sent
after the request state has been discarded.
Set the reject code properly when rejecting a request that contains an
invalid GID. A suitable GID is returned by the IB CM in the
additional reject information (ARI). This is a spec compliancy issue.
