commit f794809a7259dfaa3d47d90ef5a86007cf48b1ce upstream.
The upstream kernel commit cited below modified the workqueue in the
new CQ API to be bound to a specific CPU (instead of being unbound).
This caused ALL users of the new CQ API to use the same bound WQ.
Specifically, MAD handling was severely delayed when the CPU bound
to the WQ was busy handling (higher priority) interrupts.
This caused a delay in the MAD "heartbeat" response handling,
which resulted in ports being incorrectly classified as "down".
To fix this, add a new "unbound" WQ type to the new CQ API, so that users
have the option to choose either a bound WQ or an unbound WQ.
For MADs, choose the new "unbound" WQ.
Fixes: b7363e67b23e ("IB/device: Convert ib-comp-wq to be CPU-bound")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.m>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 770b7d96cfff6a8bf6c9f261ba6f135dc9edf484 ]
We encountered a use-after-free bug when unloading the driver:
[ 3562.116059] BUG: KASAN: use-after-free in ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.117233] Read of size 4 at addr ffff8882ca5aa868 by task kworker/u13:2/23862
[ 3562.118385]
[ 3562.119519] CPU: 2 PID: 23862 Comm: kworker/u13:2 Tainted: G OE 5.1.0-for-upstream-dbg-2019-05-19_16-44-30-13 #1
[ 3562.121806] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu2 04/01/2014
[ 3562.123075] Workqueue: ib-comp-unb-wq ib_cq_poll_work [ib_core]
[ 3562.124383] Call Trace:
[ 3562.125640] dump_stack+0x9a/0xeb
[ 3562.126911] print_address_description+0xe3/0x2e0
[ 3562.128223] ? ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.129545] __kasan_report+0x15c/0x1df
[ 3562.130866] ? ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.132174] kasan_report+0xe/0x20
[ 3562.133514] ib_mad_post_receive_mads+0xddc/0xed0 [ib_core]
[ 3562.134835] ? find_mad_agent+0xa00/0xa00 [ib_core]
[ 3562.136158] ? qlist_free_all+0x51/0xb0
[ 3562.137498] ? mlx4_ib_sqp_comp_worker+0x1970/0x1970 [mlx4_ib]
[ 3562.138833] ? quarantine_reduce+0x1fa/0x270
[ 3562.140171] ? kasan_unpoison_shadow+0x30/0x40
[ 3562.141522] ib_mad_recv_done+0xdf6/0x3000 [ib_core]
[ 3562.142880] ? _raw_spin_unlock_irqrestore+0x46/0x70
[ 3562.144277] ? ib_mad_send_done+0x1810/0x1810 [ib_core]
[ 3562.145649] ? mlx4_ib_destroy_cq+0x2a0/0x2a0 [mlx4_ib]
[ 3562.147008] ? _raw_spin_unlock_irqrestore+0x46/0x70
[ 3562.148380] ? debug_object_deactivate+0x2b9/0x4a0
[ 3562.149814] __ib_process_cq+0xe2/0x1d0 [ib_core]
[ 3562.151195] ib_cq_poll_work+0x45/0xf0 [ib_core]
[ 3562.152577] process_one_work+0x90c/0x1860
[ 3562.153959] ? pwq_dec_nr_in_flight+0x320/0x320
[ 3562.155320] worker_thread+0x87/0xbb0
[ 3562.156687] ? __kthread_parkme+0xb6/0x180
[ 3562.158058] ? process_one_work+0x1860/0x1860
[ 3562.159429] kthread+0x320/0x3e0
[ 3562.161391] ? kthread_park+0x120/0x120
[ 3562.162744] ret_from_fork+0x24/0x30
[ 3562.187615] Freed by task 31682:
[ 3562.188602] save_stack+0x19/0x80
[ 3562.189586] __kasan_slab_free+0x11d/0x160
[ 3562.190571] kfree+0xf5/0x2f0
[ 3562.191552] ib_mad_port_close+0x200/0x380 [ib_core]
[ 3562.192538] ib_mad_remove_device+0xf0/0x230 [ib_core]
[ 3562.193538] remove_client_context+0xa6/0xe0 [ib_core]
[ 3562.194514] disable_device+0x14e/0x260 [ib_core]
[ 3562.195488] __ib_unregister_device+0x79/0x150 [ib_core]
[ 3562.196462] ib_unregister_device+0x21/0x30 [ib_core]
[ 3562.197439] mlx4_ib_remove+0x162/0x690 [mlx4_ib]
[ 3562.198408] mlx4_remove_device+0x204/0x2c0 [mlx4_core]
[ 3562.199381] mlx4_unregister_interface+0x49/0x1d0 [mlx4_core]
[ 3562.200356] mlx4_ib_cleanup+0xc/0x1d [mlx4_ib]
[ 3562.201329] __x64_sys_delete_module+0x2d2/0x400
[ 3562.202288] do_syscall_64+0x95/0x470
[ 3562.203277] entry_SYSCALL_64_after_hwframe+0x49/0xbe
The problem was that the MAD PD was deallocated before the MAD CQ.
There was completion work pending for the CQ when the PD got deallocated.
When the mad completion handling reached procedure
ib_mad_post_receive_mads(), we got a use-after-free bug in the following
line of code in that procedure:
sg_list.lkey = qp_info->port_priv->pd->local_dma_lkey;
(the pd pointer in the above line is no longer valid, because the
pd has been deallocated).
We fix this by allocating the PD before the CQ in procedure
ib_mad_port_open(), and deallocating the PD after freeing the CQ
in procedure ib_mad_port_close().
Since the CQ completion work queue is flushed during ib_free_cq(),
no completions will be pending for that CQ when the PD is later
deallocated.
Note that freeing the CQ before deallocating the PD is the practice
in the ULPs.
Fixes: 4be90bc60df4 ("IB/mad: Remove ib_get_dma_mr calls")
Link: https://lore.kernel.org/r/20190801121449.24973-1-leon@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 2468b82d69e3a53d024f28d79ba0fdb8bf43dfbf ]
Let's perform checks in-place instead of BUG_ONs.
commit 2fe2f378dd45847d2643638c07a7658822087836 upstream.
The array ib_mad_mgmt_class_table.method_table has MAX_MGMT_CLASS
(80) elements. Hence compare the array index with that value instead
of with IB_MGMT_MAX_METHODS (128). This patch avoids that Coverity
reports the following:
Overrunning array class->method_table of 80 8-byte elements at element index 127 (byte offset 1016) using index convert_mgmt_class(mad_hdr->mgmt_class) (which evaluates to 127).
Fixes: commit b7ab0b19a85f ("IB/mad: Verify mgmt class in received MADs")
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Reviewed-by: Hal Rosenstock <hal@mellanox.com>
The workqueue "ib_nl" queues work items &ib_nl_timed_work and
&mad_agent_priv->local_work. It has been identity converted.
WQ_MEM_RECLAIM has been set to ensure forward progress under
memory pressure.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Instead of exposing ib_get_dma_mr to ULPs and letting them use it more or
less unchecked, this moves the capability of creating a global rkey into
the RDMA core, where it can be easily audited. It also prints a warning
everytime this feature is used as well.
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Steve Wise <swise@opengridcomputing.com>
Make indentation consistent. Detected by smatch.
Cc: Hal Rosenstock <hal@mellanox.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Reviewed-By: Ira Weiny <ira.weiny@intel.com>
Consolidate ib_mad into ib_core, this commit eliminates
ib_mad.ko and makes it part of ib_core.ko
Signed-off-by: Mark Bloch <markb@mellanox.com>
Remove the local workqueue to process mad completions and use the CQ API
instead.
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Stop abusing wr_id and just pass the parameter explicitly.
It was found that when a process was rapidly sending MADs other processes could
be hung in their unregister calls.
This would happen when process A was injecting packets fast enough that the
single threaded workqueue was never exiting ib_mad_completion_handler.
Therefore when process B called flush_workqueue via the unregister call it
would hang until process A stopped sending MADs.
The fix is to periodically reschedule ib_mad_completion_handler after
processing a large number of completions. The number of completions chosen was
decided based on the defaults for the recv queue size. However, it was kept
fixed such that increasing those queue sizes would not adversely affect
fairness in the future.
Signed-off-by: Dean Luick <dean.luick@intel.com>
Receipt of CM MAD with other than the Send method for an attribute
other than the ClassPortInfo attribute is invalid.
CM attributes other than ClassPortInfo only use the send method.
The SRP initiator does not maintain a timeout policy for CM connect
requests relies on the CM layer to do that. The result was that
the SRP initiator hung as the connect request never completed.
A new SRP target has been observed to respond to Send CM REQ
with GetResp of CM REQ with bad status. This is non conformant
with IBA spec but exposes a vulnerability in the current MAD/CM
code which will respond to the incoming GetResp of CM REQ as if
it was a valid incoming Send of CM REQ rather than tossing
this on the floor. It also causes the MAD layer not to
retransmit the original REQ even though it has not received a REP.
Signed-off-by: Hal Rosenstock <hal@mellanox.com>
Adding an ability to query the IB cache by a netdev and get the
attributes of a GID. These parameters are necessary in order to
successfully resolve the required GID (when the netdevice is known)
and get the Ethernet L2 attributes from a GID.
Signed-off-by: Matan Barak <matanb@mellanox.com>
Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com>
This patch split up struct ib_send_wr so that all non-trivial verbs
use their own structure which embedds struct ib_send_wr. This dramaticly
shrinks the size of a WR for most common operations:
sizeof(struct ib_send_wr) (old): 96
sizeof(struct ib_send_wr): 48
sizeof(struct ib_rdma_wr): 64
sizeof(struct ib_atomic_wr): 96
sizeof(struct ib_ud_wr): 88
sizeof(struct ib_fast_reg_wr): 88
sizeof(struct ib_bind_mw_wr): 96
sizeof(struct ib_sig_handover_wr): 80
And with Sagi's pending MR rework the fast registration WR will also be
down to a reasonable size:
sizeof(struct ib_fastreg_wr): 64
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> [srp, srpt]
Reviewed-by: Chuck Lever <chuck.lever@oracle.com> [sunrpc]
Tested-by: Haggai Eran <haggaie@mellanox.com>
Tested-by: Sagi Grimberg <sagig@mellanox.com>
Tested-by: Steve Wise <swise@opengridcomputing.com>
The pd now has a local_dma_lkey member which completely replaces
ib_get_dma_mr, use it instead.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
An ib_client callback that is called with the lists_rwsem locked only for
read is protected from changes to the IB client lists, but not from
ib_unregister_device() freeing its client data. This is because
ib_unregister_device() will remove the device from the device list with
lists_rwsem locked for write, but perform the rest of the cleanup,
including the call to remove() without that lock.
Mark client data that is undergoing de-registration with a new going_down
flag in the client data context. Lock the client data list with lists_rwsem
for write in addition to using the spinlock, so that functions calling the
callback would be able to lock only lists_rwsem for read and let callbacks
sleep.
Since ib_unregister_client() now marks the client data context, no need for
remove() to search the context again, so pass the client data directly to
remove() callbacks.
Signed-off-by: Haggai Eran <haggaie@mellanox.com>
The define OPA_LID_PERMISSIVE is big endian and was compared to the
cpu endian variable opa_drslid.
Problem caught by 0-day build infrastructure.
Fixes: 8e4349d13f33 (IB/mad: Add final OPA MAD processing)
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Reviewed-by: John, Jubin <jubin.john@intel.com>
Persuant to Liran's comments on node_type on linux-rdma
mailing list:
In an effort to reform the RDMA core and ULPs to minimize use of
node_type in struct ib_device, an additional bit is added to
struct ib_device for is_switch (IB switch). This is needed
to be initialized by any IB switch device driver. This is a
NEW requirement on such device drivers which are all
"out of tree".
In addition, an ib_switch helper was added to ib_verbs.h
based on the is_switch device bit rather than node_type
(although those should be consistent).
The RDMA core (MAD, SMI, agent, sa_query, multicast, sysfs)
as well as (IPoIB and SRP) ULPs are updated where
appropriate to use this new helper. In some cases,
the helper is now used under the covers of using
rdma_[start end]_port rather than the open coding
previously used.
Reviewed-by: Sean Hefty <sean.hefty@intel.com>
Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Tested-by: Ira Weiny <ira.weiny@intel.com>
For devices which support OPA MADs
1) Use previously defined SMP support functions.
2) Pass correct base version to ib_create_send_mad when processing OPA MADs.
3) Process out_mad_key_index returned by agents for a response. This is
necessary because OPA SMP packets must carry a valid pkey.
4) Carry the correct segment size (OPA vs IBTA) of RMPP messages within
ib_mad_recv_wc.
5) Handle variable length OPA MADs by:
* Adjusting the 'fake' WC for locally routed SMP's to represent the
proper incoming byte_len
* out_mad_size is used from the local HCA agents
1) when sending agent responses on the wire
2) when passing responses through the local_completions
function
NOTE: wc.byte_len includes the GRH length and therefore is different
from the in_mad_size specified to the local HCA agents.
out_mad_size should _not_ include the GRH length as it is added
This patch is the first of 3 which adds processing of OPA MADs
1) Add Intel Omni-Path Architecture defines
2) Increase max management version to accommodate OPA
3) update ib_create_send_mad
If the device supports OPA MADs and the MAD being sent is the OPA base
version alter the MAD size and sg lengths as appropriate
In order to support alternate sized MADs (and variable sized MADs on OPA
devices) add in/out MAD size parameters to the process_mad core call.
In addition, add an out_mad_pkey_index to communicate the pkey index the driver
wishes the MAD stack to use when sending OPA MAD responses.
The out MAD size and the out MAD PKey index are required by the MAD
stack to generate responses on OPA devices.
Furthermore, the in and out MAD parameters are made generic by specifying them
as ib_mad_hdr rather than ib_mad.
Drivers are modified as needed and are protected by BUG_ON flags if the MAD
sizes passed to them is incorrect.
This patch implements allocating alternate receive MAD buffers within the MAD
stack. Support for OPA to send/recv variable sized MADs is implemented later.
1) Convert MAD allocations from kmem_cache to kzalloc
kzalloc is more flexible to support devices with different sized MADs
and research and testing showed that the current use of kmem_cache does
not provide performance benefits over kzalloc.
2) Change struct ib_mad_private to use a flex array for the mad data
3) Allocate ib_mad_private based on the size specified by devices in
rdma_max_mad_size.
4) Carry the allocated size in ib_mad_private to be used when processing
ib_mad_private objects.
5) Alter DMA mappings based on the mad_size of ib_mad_private.
6) Replace the use of sizeof and static defines as appropriate
7) Add appropriate casts for the MAD data when calling processing
functions.
Add max MAD size to the device immutable data set and have all drivers that
support MADs report the current IB MAD size (IB_MGMT_MAD_SIZE) to the core.
Verify MAD size data in both the MAD core and when reading the immutable data.
OPA drivers will report alternate MAD sizes in subsequent patches.
In preparation to support the new OPA MAD Base version, add a base version
parameter to ib_create_send_mad and set it to IB_MGMT_BASE_VERSION for current
users.
Definition of the new base version and it's processing will occur in later
patches.
Make a helper function to process Directed Route SMPs to be called by the IB
MAD Recv Handler, ib_mad_recv_done_handler.
This cleans up the MAD receive handler code a bit and allows for us to better
share the SMP processing code between IB and OPA SMPs.
IB and OPA SMPs share the same processing algorithm but have different header
formats and permissive LID detection. Therefore this and subsequent patches
split the common processing code from the IB specific code in anticipation of
sharing those algorithms with the OPA code.
ib_find_send_mad only needs access to the MAD header not the full IB MAD.
Change the local variable to ib_mad_hdr and change the corresponding cast.
This allows for clean usage of this function with both IB and OPA MADs because
OPA MADs carry the same header as IB MADs.
find_mad_agent only needs read only access to the MAD header. Update the
ib_mad pointer to be const ib_mad_hdr. Adjust call tree.
Currently, ib_create_cq uses cqe and comp_vecotr instead
of the extendible ib_cq_init_attr struct.
Earlier patches already changed the vendors to work with
ib_cq_init_attr. This patch changes the consumers too.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
into k.o/for-4.2
The following functions only need read access to the data passed to them.
ib_mad_kernel_rmpp_agent
is_rmpp_data_mad
rcv_has_same_gid
ib_find_send_mad
Clarify with const specifiers
rcv_has_same_class only needs access to the MAD header
specify WR and Receive WC as const
ib_response_mad only needs read access to the MAD header, not write access
to the entire mad struct, so replace struct ib_mad with const struct
ib_mad_hdr
validate_mad only needs read access to the MAD header, not write access
ib_mad_hdr
is_rmpp_data_mad is more descriptive for this function.
Introduce helper rdma_cap_ib_smi() to help us check if the port of an
IB device support Infiniband Subnet Management Interface.
Signed-off-by: Michael Wang <yun.wang@profitbricks.com>
Tested-by: Doug Ledford <dledford@redhat.com>
Introduce helper rdma_cap_ib_mad() to help us check if the port of an
IB device support Infiniband Management Datagrams.
Use raw management helpers to reform IB-core mad/agent/user_mad.
Using the new registration mechanism, define a flag that indicates the
user wishes to process RMPP messages in user space rather than have
the kernel process them.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Registrations options are specified through flags. Definitions of flags will
be in subsequent patches.
Registration failures can be difficult to debug from userspace. This
gives more visibility.
Use dev_* style print when struct device is available.
Also combine previously line broken user-visible strings as per
Documentation/CodingStyle:
"However, never break user-visible strings such as printk messages,
because that breaks the ability to grep for them."
[ Remove PFX so the patch actually builds. - Roland ]
Running with DMA_API_DEBUG enabled and not checking for DMA mapping
errors triggers a kernel stack trace with "DMA-API: device driver
failed to check map error" message. Add these checks to the MAD
module, both to be be more robust and also eliminate these
false-positive stack traces.
Signed-off-by: Yan Burman <yanb@mellanox.com>
Currently, QP1 is created using pkey index 0. This patch simply looks
for the index containing the default pkey, rather than hard-coding
pkey index 0.
This change will have no effect in native mode, since QP0 and QP1 are
created before the SM configures the port, so pkey table will still be
the default table defined by the IB Spec, in C10-123: "If non-volatile
storage is not used to hold P_Key Table contents, then if a PM
(Partition Manager) is not present, and prior to PM initialization of
the P_Key Table, the P_Key Table must act as if it contains a single
valid entry, at P_Key_ix = 0, containing the default partition
key. All other entries in the P_Key Table must be invalid."
Thus, in the native mode case, the driver will find the default pkey
at index 0 (so it will be no different than the hard-coding).
However, in SR-IOV mode, for VFs, the pkey table may be
paravirtualized, so that the VF's pkey index zero may not necessarily
be mapped to the real pkey index 0. For VFs, therefore, it is
important to find the virtual index which maps to the real default
pkey.
This commit does the following for QP1 creation:
1. Find the pkey index containing the default pkey, and use that index
if found. ib_find_pkey() returns the index of the
limited-membership default pkey (0x7FFF) if the full-member default
pkey is not in the table.
2. If neither form of the default pkey is found, use pkey index 0
(previous behavior).
Now that cancel_delayed_work() can be safely called from IRQ handlers,
there's no reason to use __cancel_delayed_work(). Use
cancel_delayed_work() instead of __cancel_delayed_work() and mark the
latter deprecated.
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Roland Dreier <roland@kernel.org>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Now that mod_delayed_work() is safe to call from IRQ handlers,
__cancel_delayed_work() followed by queue_delayed_work() can be
replaced with mod_delayed_work().
Most conversions are straight-forward except for the following.
* net/core/link_watch.c: linkwatch_schedule_work() was doing a quite
elaborate dancing around its delayed_work. Collapse it such that
linkwatch_work is queued for immediate execution if LW_URGENT and
existing timer is kept otherwise.
Commit 0b307043049f ("IB/mad: Return error response for unsupported
MADs") does not failed MADs (eg those that return
IB_MAD_RESULT_FAILURE) properly -- these MADs should be silently
discarded. (We should not force the lower-layer drivers to return
SUCCESS | CONSUMED in this case, since the MAD is NOT successful).
Unsupported MADs are not failures -- they return SUCCESS, but with an
"unsupported error" status value inside the response MAD.
MADs") does not handle directed-route MADs properly -- it fails to set
the 'D' bit in the response MAD status field. This is a problem for
SmInfo MADs when the receiver does not have an SM running.
Set up a response with appropriate error status and send it for MADs
that are not supported by a specific class/version.
Signed-off-by: Swapna Thete <swapna.thete@qlogic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
