Driver implementation for AMS/TAOS tsl2591 ambient light sensor.
This driver supports configuration via device tree and sysfs.
Supported channels for raw infrared light intensity,
raw combined light intensity and illuminance in lux.
The driver additionally supports iio events on lower and
upper thresholds.
This is a very-high sensitivity light-to-digital converter that
transforms light intensity into a digital signal.
Datasheet: https://ams.com/tsl25911#tab/documents
Signed-off-by: Joe Sandom <joe.g.sandom@gmail.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Link: https://lore.kernel.org/r/20210421221330.17007-1-joe.g.sandom@gmail.com
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Support for AMS AS73211 JENCOLOR(R) Digital XYZ Sensor.
This driver has no built-in trigger. In order for making triggered
measurements, an external (software) trigger driver like
iio-trig-hrtimer or iio-trig-sysfs is required.
The sensor supports single and continuous measurement modes. The latter
is not used by design as this would require tight timing synchronization
between hardware and driver without much benefit.
Datasheet: https://ams.com/documents/20143/36005/AS73211_DS000556_3-01.pdf
Signed-off-by: Christian Eggers <ceggers@arri.de>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull mfd updates from Lee Jones:
"New Drivers:
- Add support for IQS620A/621/622/624/625 Azoteq IQS62X Sensors
New Device Support:
- Add support for ADC, IRQ, Regulator, RTC and WDT to Ricoh RN5T618 PMIC
- Add support for Comet Lake to Intel LPSS
New Functionality:
- Add support for Charger Detection to Spreadtrum SC27xx PMICs
- Add support for Interrupt Polarity to Dialog Semi DA9062/61 PMIC
- Add ACPI enumeration support to Diolan DLN2 USB Adaptor
Fix-ups:
- Device Tree; iqs62x, rn5t618, cros_ec_dev, stm32-lptimer, rohm,bd71837, rohm,bd71847
- I2C registration; rn5t618
- Kconfig; MFD_CPCAP, AB8500_CORE, MFD_WM8994, MFD_WM97xx, MFD_STPMIC1
- Use flexible-array members; omap-usb-tll, qcom-pm8xxx
- Remove unnecessary casts; omap-usb-host, omap-usb-tll
- Power (suspend/resume/poweroff) enhancements; rk808
- Improve error/sanity checking; dln2
- Use snprintf(); aat2870-core
Bug Fixes:
- Fix PCI IDs in intel-lpss-pci"
* tag 'mfd-next-5.7' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (33 commits)
mfd: intel-lpss: Fix Intel Elkhart Lake LPSS I2C input clock
mfd: aat2870: Use scnprintf() for avoiding potential buffer overflow
mfd: dln2: Allow to be enumerated via ACPI
mfd: da9062: Add support for interrupt polarity defined in device tree
dt-bindings: bd718x7: Yamlify and add BD71850
mfd: dln2: Fix sanity checking for endpoints
mfd: intel-lpss: Add Intel Comet Lake PCH-V PCI IDs
mfd: sc27xx: Add USB charger type detection support
dt-bindings: mfd: Document STM32 low power timer bindings
mfd: rk808: Convert RK805 to shutdown/suspend hooks
mfd: rk808: Reduce shutdown duplication
mfd: rk808: Stop using syscore ops
mfd: rk808: Ensure suspend/resume hooks always work
mfd: rk808: Always use poweroff when requested
mfd: omap: Remove useless cast for driver.name
mfd: Kconfig: Fix some misspelling of the word functionality
mfd: pm8xxx: Replace zero-length array with flexible-array member
mfd: omap-usb-tll: Replace zero-length array with flexible-array member
mfd: cpcap: Fix compile if MFD_CORE is not selected
mfd: cros_ec: Check DT node for usbpd-notify add
This patch adds support for the Azoteq IQS621 and IQS622 ambient light
sensors, both of which can report a four-bit representation of ambient
light intensity.
The IQS621 can additionally report illuminace directly in units of lux,
while the IQS622 can report a four-bit representation of infrared light
intensity. Furthermore, the IQS622 can report a unitless measurement of
a target's proximity to the device.
Signed-off-by: Jeff LaBundy <jeff@labundy.com>
Reviewed-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Based on:
- 3320A in-kernel driver
- https://www.spinics.net/lists/linux-iio/msg25145.html
- https://lore.kernel.org/patchwork/patch/684179/
I decided to keep it aside of AL3320A due to different approach and much
simpler design of 3010.
Tested on Nexus 7 2012 (grouper/tilapia).
Tested-by: David Heidelberg <david@ixit.cz>
Tested-by: Dmitry Osipenko <digetx@gmail.com>
Tested-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: David Heidelberg <david@ixit.cz>
This driver handles two different Sharp sensors that have been
proposed for merging to the mainline kernel over the years, and
already has a limited proximity-only driver in the input
subsystem.
These components are completely different from the confusingly
similarly named Sharp GP2AP020A00F, for which we have a driver
in drivers/iio/light/gp2ap020a00f.c
The two components GP2AP002A00F and GP2AP002S00F are
distinctively different but similar: they share the same set of
registers but differ slightly in the I2C protocol.
Instead of the approach by the previous input driver, we create
a combined IIO proximity and light sensor driver.
The plan is to merge this driver and delete the input driver.
The pieces for the driver are picked all over the place after
researching and grepping through a few different vendor trees
and driver submissions.
We merge it under the light sensors because:
- It has similarities with the Capella CM3605 light sensor and
proximity driver which is there.
- It is related to the GP2AP020A00F driver which is also there.
This driver was tested with the Samsung GT-S7710 mobile phone
which has the GP2AP002S00F proximity sensor mounted.
The suspend/resume cycle will disable the interrupt from the
sensor. If someone would desire to use this interrupt for
wakeup, the driver will need modifications.
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com>
Cc: Jonathan Bakker <xc-racer2@live.ca>
Cc: Oskar Andero <oskar.andero@gmail.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Tested-by: Jonathan Bakker <xc-racer2@live.ca>
veml6030 is an ambient light sensor from Vishay semiconductors.
It has 16-bit resolution, supports both ambient light measurement
and white channel which is more responsive to wider wavelength
spectrum. It has flexible power saving, integration time and
gain options. Communication with host is over I2C.
Signed-off-by: Rishi Gupta <gupt21@gmail.com>
Add initial support for Analog Devices ADUX1020 Photometric sensor.
Only proximity mode has been enabled for now.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
This driver adds the initial support for the ON Semiconductor
NOA1305 Ambient Light Sensor.
Originally written by Sergei Miroshnichenko. Found here:
https://github.com/EmcraftSystems/linux-upstream/commit/196d6cf897e632d2cb82d45484bd7a1bfdd5b6d9
Signed-off-by: Sergei M <fizik1@yandex.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.com>
The MAX44009 is a low-power ambient light sensor from Maxim
Integrated. It differs from the MAX44000 in that it doesn't have
proximity sensing and that it requires far less current (1 micro-amp
vs 5 micro-amps). The register mapping and feature set between the
two are different enough to require a new driver for the MAX44009.
Developed and tested with a BeagleBone Black and UDOO Neo (i.MX6SX)
Supported features:
* Reading lux (processed value)
* Rising and falling illuminance threshold
events
* Configuring integration time
https://datasheets.maximintegrated.com/en/ds/MAX44009.pdf
Signed-off-by: Robert Eshleman <bobbyeshleman@gmail.com>
Add support for VCNL4035, which is capable of Ambient light
sensing (ALS) and proximity function. This patch adds support
only for ALS function
Signed-off-by: Parthiban Nallathambi <pn@denx.de>
e-mail received from Silicon Lab to confirm that the licensing
isn't a problem.
Dear Maxime Roussin-Belanger,
The LUX calculation code only works with Si1133.
As long as the software is used with Silicon Lab's sensor product,
I don't see any problem.
Regards,
Tony
Signed-off-by: Maxime Roussin-Bélanger <maxime.roussinbelanger@gmail.com>
Reviewed-by: Jean-Francois Dagenais <jeff.dagenais@gmail.com>
Move the tsl2772 driver out of staging and into mainline.
Signed-off-by: Brian Masney <masneyb@onstation.org>
This patch adds support for the On Semiconductor LV0104CS ambient
light sensor.
add support for STMicroelectronics UVIS25 uv sensor
http://www.st.com/resource/en/datasheet/uvis25.pdf
- continuos mode support
- i2c support
- spi support
- trigger mode support
- system PM support
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi83@gmail.com>
Driver for 20-bit ALS and UV B sensor with I2C interface exposing
the following API:
in_uvindex_input
in_illuminance_raw
in_illuminance_scale
in_illuminance_scale_available
in_intensity_uv_raw
in_intensity_uv_scale
in_intensity_uv_scale_available
integration_time
integration_time_available
Signed-off-by: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Move ISL29028 ALS / Proximity Sensor out of staging and into mainline.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch adds support for STMicro VL6180 - ALS, range and proximity sensor. Sensor is capable of measuring the light
intensity as well as object distance using TOF (Time of Flight) technology.
Signed-off-by: Manivannan Sadhasivam <manivannanece23@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Handle Light and Proximity sensors presented by the ChromeOS EC Sensor hub.
Creates an IIO device for each functions.
Signed-off-by: Gwendal Grignou <gwendal@chromium.org>
Signed-off-by: Guenter Roeck <groeck@chromium.org>
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
This adds a driver for the Capella Microsystems CM3605 Ambient
Light Sensor and proximity sensor. This is a pretty simple entirely
analog device that is interfaced with the target system using
the POUT (proximity out) and AOUT (ambient light out) signals.
The POUT signal is a simple high/low signal that indicates whether
an object is in proximity, most typically used to detect a face
in front of a mobile device. The signal requires that an infrared
LED is mounted next to the device, making IR light reflect off
the object in proximity and triggering the POUT signal. We grab
a GPIO pin to handle the POUT signal as an interrupt line and
register this as an event channel for the sensor.
Since the proximity sensor requires an IR LED, we add a LED trigger
named "cm3605" so that the infrared LED can just associate with
this trigger to be sure it is always on when the proximity sensor
needs it.
The AOUT is an analog voltage between 0 and 1550 mV that indicate
the LUX value in the ambient light: this is orthogonal to the
proximity sensor functionality. Since this analog voltage needs
to be converted into a digital value, the driver grabs an IIO
channel named "aout" associated with the device.
This patch created a combined ALS and proximity sensor driver.
The former supports raw reads of the LUX value and the latter
will generate proximity events.
To integrate this properly with Linux we also add a supply
regulator for the VDD pin (driving both functions) and add device
tree bindings to define the RSET resistor that in turn configures
the luminosity range of the ALS sensor.
Since the sensor needs to be on more or less constantly, we
restrict the power management to system suspend/resume: we
disable the IR LED and disable the regulator for VDD on suspend
and take them back up on resume.
Tests:
cd /sys/bus/iio/devices/iio:device1
cat in_illuminance_raw
304
(hold hand over sensor)
17
iio_event_monitor cm3605
Found IIO device with name cm3605 with device number 1
Event: time: 2444842301447, type: proximity, channel: 0,
evtype: thresh, direction: falling
(remove hand over sensor)
Event: time: 2445583440706, type: proximity, channel: 0,
evtype: thresh, direction: rising
Cc: Capella Microsystems <capellamicro@gmail.com>
Cc: Kevin Tsai <ktsai@capellamicro.com>
Move tsl2580, tsl2581, tsl2583 driver out of staging into mainline.
Move ISL29018/ISL29023/ISL29035 driver out of staging into mainline.
light, uv index and proximity sensors
The si114x supports x=1,2,3 IR LEDs for proximity sensing together with
visible and IR ambient light sensing (ALS).
Newer parts (si1132, si1145/6/7) can measure UV light and compute an UV
index
This was tested on si1143 and si1145
Signed-off-by: Crestez Dan Leonard <leonard.crestez@intel.com>
This just adds support for reporting illuminance with default settings.
Important default registers are written on probe because the device
otherwise lacks a reset function.
ultraviolet (UV) light sensor with I2C interface with a peak
sensitivity at 355 nm
strangely, chip uses two addresses 0x38 and 0x39 for LSB and
MSB data, resp.
datasheet: http://www.vishay.com/docs/84277/veml6070.pdf
This is a reimplementation of the old misc device driver for the
ROHM BH1780 ambient light sensor (drivers/misc/bh1780gli.c).
Differences from the old driver:
- Uses the IIO framework
- Uses runtime PM to idle the hardware after 5 seconds
- No weird custom power management from userspace
- No homebrewn values in sysfs
This uses the same (undocumented) device tree compatible-string
as the old driver ("rohm,bh1780gli").
Cc: Ulf Hansson <ulf.hansson@linaro.org>
Cc: Daniel Mack <daniel@caiaq.de>
Cc: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Add support for UPISEMI us5182d als and proximity sensor.
Supports raw readings.
Data sheet for this device can be found here:
http://www.upi-semi.com/temp/uS5182D-DS-P0103-temp.pdf
Signed-off-by: Adriana Reus <adriana.reus@intel.com>
APDS9960 is a combination of ALS, proximity, and gesture sensors.
This patch adds support for these functions along with gain control,
integration time, and event thresholds.
Signed-off-by: Matt Ranostay <mranostay@gmail.com>
Add support for TXC PA12203001 als and proximity sensor.
Support for raw illuminance and proximity readings.
TI's opt3001 light sensor is a simple and yet powerful
little device. The device provides 99% IR rejection,
automatic full-scale, very low power consumption and
measurements from 0.01 to 83k lux.
This patch adds support for that device using the IIO
framework.
See http://www.ti.com/product/opt3001 for more information.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
This patch adds support for ROHM RPR0521 ambient light and proximity
sensor. It offers raw readings for intensity and proximity.
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
This driver adds the initial support for the ACPI Ambient Light Sensor
as defined in Section 9.2 of the ACPI specification (Revision 5.0) [1].
Sensors complying with the standard are exposed as ACPI devices with
ACPI0008 as hardware ID and provide standard methods by which the OS
can query properties of the ambient light environment the system is
currently operating in.
This driver currently allows only to get the current ambient light
illuminance reading through the _ALI method, but is ready to be
extended extended to handle _ALC, _ALT and _ALP as well.
[1] http://www.acpi.info/DOWNLOADS/ACPIspec50.pdf
Signed-off-by: Martin Liska <marxin.liska@gmail.com>
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
Cc: Zhang Rui <rui.zhang@intel.com>
light sensors
Add support for ROHM BH1710/BH1715/BH1721/BH1750/BH1751 ambient light
sensors.
Signed-off-by: Tomasz Duszynski <tduszyns@gmail.com>
Minimal implementation of an IIO driver for the Sensortek
STK3310 ambient light and proximity sensor. The STK3311
model is also supported.
Includes:
- ACPI support;
- read_raw and write_raw;
- reading and setting configuration parameters for gain/scale
and integration time for both ALS and PS.
- power management
Signed-off-by: Tiberiu Breana <tiberiu.a.breana@intel.com>
Minimal implementation providing raw light intensity
and integration time attribute.
Userspace applications can use GREEN channel for raw
illuminance readings following this table:
Integration Time | G Sensitivity
40 ms | 0.18
80 ms | 0.09
160 ms | 0.045
320 ms | 0.0225
640 ms | 0.01125
1280 ms | 0.005625
CM3232 is an advanced ambient light sensor with I2C protocol interface.
The I2C slave address is internally hardwired as 0x10 (7-bit). Writing
to configure register is byte mode, but reading ALS register requests to
use word mode for 16-bit resolution.
Signed-off-by: Kevin Tsai <ktsai@capellamicro.com>
This patch adds a new driver for solteam opto JSA1212 proximity and
Basic details of the chip can be found here.
http://www.solteamopto.com.tw/detail.php?ms=3&po_unit=2&pt_unit=29&p_unit=120
Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com>
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Minimal implementation. This driver provides raw illuminance readings.
This is based on drivers/hwmon/al3320.c (*) driver from msm tree written
by Tsechih Lin <Tsechih_Lin@asus.com>
* https://android.googlesource.com/kernel/msm.git
Reviewed-by: Hartmut Knaack <knaack.h@gmx.de>
16-bit digital color sensor with red, green, blue and clear channel
datasheet: http://ams.com/eng/content/download/250258/975997/TCS3414_Datasheet_EN_v1.pdf
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
datasheet: http://www.intersil.com/content/dam/Intersil/documents/isl2/isl29125.pdf
Added usage id processing for Proximity (Human Presence).
This uses IIO interfaces for triggered buffer to present data
to user mode. This uses HID sensor framework for registering
callback events from the sensor hub.
Signed-off-by: Archana Patni <archana.patni@intel.com>
combined ambient light (two channels) and proximity sensor with I2C
interface; the ALS channels are visible+IR and IR
datasheet is here
http://optoelectronics.liteon.com/upload/download/DS86-2012-0006/P_100_LTR-501ALS-01_PrelimDS_ver1.1.pdf
v3:
* fix use of sizeof in _read_als()
v2: (thanks to Lars-Peter Clausen)
* cannot use devm_iio_device_register() due to cleanup order in _remove()
* mutex around data wait/read
* turn info message in _probe() into check for part number
* change copyright year to 2014
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
Add Capella Microsystem CM32181 Ambient Light Sensor IIO driver.
This driver will convert raw data to lux value under open-air
condition. Change the calibscale based on the cover material.
This patch adds a new driver for Capella CM36651 proximity and RGB sensor.
Signed-off-by: Beomho Seo <beomho.seo@samsung.com>
Add a new driver for the ambient light/proximity sensor
device. The driver exposes three channels: light_clear
light_ir and proximity. It also supports triggered buffer,
high and low ambient light threshold event and proximity
detection events.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
chip has four 16-bit channels for red, green, blue, clear color
intensity; driver supports the TCS3x7x family of devices and was
tested with a TCS34725 chip; further information here:
http://www.ams.com/eng/Products/Light-Sensors/Color-Sensor/TCS34725
v2 (thanks to Jonathan Cameron):
* drop dynamic buffer allocation, buffer is in tcs3472_data
* limit sysfs output to PAGE_SIZE
* check val2 == 0 when writing CALIBSCALE
Cc: Jon Brenner <jon.brenner@ams.com>
driver for the TSL4531 family of 16-bit I2C ambient light
sensors; information is here:
http://www.ams.com/eng/Products/Light-Sensors/Ambient-Light-Sensor-ALS/TSL45315
the chip offers simple lux output
v3 (thanks Lars-Peter Clausen):
* add mutex to when updating integration time
* fix chip ID checking
* code cleanups
v2:
* rename to tsl4351
* use INT_TIME
This patch adds IIO driver for APDS9300 ambient light sensor (ALS).
http://www.avagotech.com/docs/AV02-1077EN
The driver allows to read raw data from ADC registers or calculate
lux value. It also can handle threshold interrupt.
Signed-off-by: Oleksandr Kravchenko <o.v.kravchenko@globallogic.com>
Keeping Makefile and Kconfig entries in alphabetical order usually works better
than just appending new entries at the end, since it reduces the amount of
conflicts. This patch adds a comment to the IIO Kconfig and Makefile files to
document that the entries should be kept in alphabetical order.
Also reorder those entries which weren't in alphabetical order yet.
