Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
This patch separates the core driver using regmap and the i2c driver
which creates the i2c regmap. Also in the Kconfig file BMG160 and
BMG160_I2C are separate now.
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
This patch introduces regmap usage into the driver. This is done to
later easily support the SPI interface of this chip.
This patch adds selects for IIO_BUFFER and IIO_TRIGGERED_BUFFER. Without
IIO_BUFFER, the driver does not compile.
Cc: <Stable@vger.kernel.org>
Add support for the BMI055 gyroscope sensor. BMI055 is a package
consisting of an acceleration sensor and a gyroscope. This patch
adds support for the gyroscope only.
Spec downloaded from:
http://ae-bst.resource.bosch.com/media/products/dokumente/bmi055/BST-BMI055-DS000-06.pdf
The BMI055 gyroscope uses the same register definition as BMG160,
but does not specify a temp register. However, the temp register
seems to be working in the same way as for BMG160, so this patch
does not remove the temp channel for BMI055.
Signed-off-by: Irina Tirdea <irina.tirdea@intel.com>
This change implements support for BMG160 Gyro sensor. Although chip
has several advanced features, this change implements minimum set
required for using gyro sensor.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
The driver was not able to manage the sensor: during probe function
and wai check, the driver stops and writes: "device name and WhoAmI mismatch."
The correct value of L3GD20H wai is 0xd7 instead of 0xd4.
Dropped support for the sensor.
Signed-off-by: Denis Ciocca <denis.ciocca@st.com>
Cc: stable@vger.kernel.org
The drivers is in more or less good shape, conforms to the IIO ABI and none of
the default static code checker report any problems, so move it out of staging.
Keeping Makefile and Kconfig entries in alphabetical order usually works better
than just appending new entries at the end, since it reduces the amount of
conflicts. This patch adds a comment to the IIO Kconfig and Makefile files to
document that the entries should be kept in alphabetical order.
Also reorder those entries which weren't in alphabetical order yet.
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Acked-by: "Denis Ciocca" <denis.ciocca@st.com>
The adis16130 driver is fairly simple and it a good shape now, so move it out of
staging. Remove an outdated FIXME along the way.
Drivers for STMicroelectronics accelerometers, gyroscopes, and
magnetometers were added in v3.9. They all have a (similar) select
statement in their Kconfig files for a non-existant Kconfig symbol.
These select statements can safely be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Denis Ciocca <denis.ciocca@st.com>
This patch adds support for the InvenSense itg3200.
The itg3200 is a three-axis gyro with 16-bit ADC and
I2C interface.
Signed-off-by: Manuel Stahl <manuel.stahl@iis.fraunhofer.de>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
The adxrs450 is in a reasonable shape now. It follows the IIO ABI and non of the
standard code checker tools report any issue, so move it out of staging.
This patch adds a generic gyroscope driver for STMicroelectronics
gyroscopes, currently it supports:
L3G4200D, LSM330DL, L3GD20, L3GD20H, LSM330DLC, L3G4IS, LSM330.
The driver is rather simple and in a good shape. It follows the IIO ABI and the
standard codechecker tools do not report any issues, so move it out of staging.
While moving it also remove one outdated 'fixme' comment.
Not much to say, without that change, hid-sensor-trigger will be
always compiled if HID_SENSOR_IIO_COMMON is selected which fails if
CONFIG_IIO_TRIGGER is not set because CONFIG_IIO_CONSUMERS_PER_TRIGGER
will not be defined.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
This patch adds support for the ADIS16133, ADIS16135, ADIS16136 single channel
gyroscopes. The main difference between them is the sensor precision.
Added usage id processing for Gyroscope 3D. This uses IIO
interfaces for triggered buffer to present data to user
mode.This uses HID sensor framework for registering callback
events from the sensor hub.
Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com>
