path: root/drivers/iio/Makefile
2013-06-05iio:pressure: Add STMicroelectronics pressures driverDenis CIOCCA
This patch adds a generic pressure driver for STMicroelectronics pressure sensors, currently it supports: LPS331AP. Signed-off-by: Denis Ciocca <denis.ciocca@st.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2013-05-22iio:trigger:sysfs Move out of staging.Jonathan Cameron
This simple driver is rather useful. No issues about its interface have been raised for some time hence the proposal to move it out of staging. Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-19staging:iio: Move adis library out of stagingLars-Peter Clausen
Now that the adis library no longer depends on the sw_ring buffer implementation we can move it out of staging. While we are at it also sort the entries in the iio Kconfig and Makefile to be in alphabetical order. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-11-10staging:iio: add a callback buffer for in kernel push interfaceJonathan Cameron
This callback buffer is meant to be opaque to users, but basically adds a very simple pass through buffer to which data may be pushed when it is inserted into the buffer list. Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-10-19iio: Remove duplicates for light/ in Kconfig and Makefileiio-fixes-for-3.7aAndreas Larsson
Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: hid-sensors: Added ALSsrinivas pandruvada
Added usage id processing for ALS. This uses IIO interfaces for triggered buffer to present data to user mode.This uses HID sensor framework for registering callback events from the sensor hub. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: hid-sensors: Added Compass/Magnetometer 3Dsrinivas pandruvada
Added usage id processing for Compass 3D. This uses IIO interfaces for triggered buffer to present data to user mode.This uses HID sensor framework for registering callback events from the sensor hub. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: hid-sensors: Added Gyroscope 3Dsrinivas pandruvada
Added usage id processing for Gyroscope 3D. This uses IIO interfaces for triggered buffer to present data to user mode.This uses HID sensor framework for registering callback events from the sensor hub. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: hid-sensors: Added accelerometer 3Dsrinivas pandruvada
Added usage id processing for Accelerometer 3D.This uses IIO interfaces for triggered buffer to present data to user mode.This uses HID sensor framework for registering callback events from the sensor hub. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-09-06iio: hid-sensors: Common attribute and triggersrinivas pandruvada
This patch contains the common code, which is used by all HID sensors. There are some common set of attributes, which every hid sensor needs it. This patch contains all such attributes processing. Also the trigger interface is common among all HID sensors. This patch contains common trigger functions utilized by all HID sensors. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-06-18iio: Add helper function for initializing triggered buffersLars-Peter Clausen
Add a helper function for executing the common tasks which are usually involved in setting up a simple software ringbuffer. It will allocate the buffer, allocate the pollfunc and register the buffer. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-05staging:iio: Move DAC drivers out of stagingLars-Peter Clausen
The IIO DAC drivers are in a reasonably good shape. They all make use of channel spec and non of them provides non-documented sysfs attributes. Code style should be OK as well, both checkpatch and coccicheck only report trivial issues. So lets move the whole folder out of staging. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-04iio: frequency: New driver for AD9523 SPI Low Jitter Clock GeneratorMichael Hennerich
Changes since V1: Apply Jonathan's review feedback: Revise device status attribute names, and split documentation into two sections. Add additional comments, and fix indention issues. Remove pointless zero initializations. Revise return value handling. Simplify some code sections. Split store_eeprom and sync handling into separate functions. Use strtobool where applicable. Document platform data structures using kernel-doc style. Use dev_to_iio_dev write_raw IIO_CHAN_INFO_FREQUENCY: Reject values <= 0 Make patch target drivers/iio Changes since V2: Use for_each_clear_bit() and __set_bit() where applicable. Add descriptive comment. Avoid temporary for struct regulator. spi_device_id name use ad9523-1, ad9523 will be added later. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-04iio: add LM3533 ambient-light-sensor driverJohan Hovold
Add sub-driver for the ambient-light-sensor interface on National Semiconductor / TI LM3533 lighting power chips. The sensor interface can be used to control the LEDs and backlights of the chip through defining five light zones and three sets of corresponding output-current values. The driver provides raw and mean adc readings along with the current light zone through sysfs. A threshold event can be generated on zone changes. The ALS-control output values can be set per zone for the three current output channels. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14ARM: AT91: IIO: Add AT91 ADC driver.Maxime Ripard
Add the ADC driver for Atmel's AT91SAM9G20-EK, AT91SAM9M10G45-EK and AT91SAM9X5 family boards. It has support for both software and hardware triggers. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14iio: amplifiers: New driver for AD8366 Dual-Digital Variable Gain AmplifierMichael Hennerich
Changes since V1: Apply review feedback: Introduce and use IIO_CHAN_INFO_HARDWAREGAIN Introduce and use Use IIO_VAL_INT_PLUS_MICRO_DB Modify out of staging include paths. Convert to new iio core API naming. Changes since V2: more sanity checking in write_raw Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-25IIO: Move the core files to drivers/iioJonathan Cameron
Take the core support + the kfifo buffer implentation out of staging. Whilst we are far from done in improving this subsystem it is now at a stage where the userspae interfaces (provided by the core) can be considered stable. Drivers will follow over a longer time scale. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
