path: root/drivers/ieee1394
2005-09-05[PATCH] I2C: Drop debug eeprom dump code in pcilynxJean Delvare
The pcilynx driver includes code to dump the contents of an i2c eeprom for debugging purposes. The same can be done from userspace using the i2cdump tool (part of the lm_sensors project) instead, in a more efficient and flexible way. Thus I would suggest that this functionality be simply dropped from the pcilynx driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-08-26[PATCH] late spinlock initialization in ieee1394/ohciAl Viro
spinlock used in irq handler should be initialized before registering irq, even if we know that our device has interrupts disabled; handler is registered shared and taking spinlock is done unconditionally. As it is, we can and do get oopsen on boot for some configuration, depending on irq routing - I've got a reproducer. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Ben Collins <bcollins@debian.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] ratelimit the ieee1394 IR legacy activated messagesOlaf Hering
running coriander1 with an Apple iSight produces lots of dmesg output. Jul 13 22:14:17 ibook kernel: ieee1394: raw1394: /dev/raw1394 device initialized Jul 13 22:15:28 ibook kernel: ohci1394: fw-host0: IR legacy activated Jul 13 22:15:59 ibook last message repeated 208 times Jul 13 22:17:00 ibook last message repeated 762 times Jul 13 22:18:01 ibook last message repeated 914 times Jul 13 22:18:17 ibook last message repeated 238 times Jul 13 22:18:17 ibook kernel: ieee1394: unsolicited response packet received - no tlabel match Jul 13 22:18:17 ibook kernel: ohci1394: fw-host0: IR legacy activated its less noisy with the patch: Jul 14 08:03:08 ibook kernel: ieee1394: raw1394: /dev/raw1394 device initialized Jul 14 08:03:26 ibook kernel: ohci1394: fw-host0: IR legacy activated Jul 14 08:03:42 ibook last message repeated 10 times Jul 14 08:03:47 ibook kernel: printk: 63 messages suppressed. Jul 14 08:03:47 ibook kernel: ohci1394: fw-host0: IR legacy activated Jul 14 08:03:52 ibook kernel: printk: 74 messages suppressed. Signed-off-by: Olaf Hering <olh@suse.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-10[PATCH] Sync up ieee-1394Ben Collins
Lots of this patch is trivial code cleanups (static vars were being intialized to 0, etc). There's also some fixes for ISO transmits (max buffer handling). Aswell, we have a few fixes to disable IRM capabilites correctly. We've also disabled, by default some generally unused EXPORT symbols for the sake of cleanliness in the kernel. However, instead of removing them completely, we felt it necessary to have a config option that allowed them to be enabled for the many projects outside of the main kernel tree that use our API for driver development. The primary reason for this patch is to revert a MODE6->MODE10 RBC conversion patch from the SCSI maintainers. The new conversions handled directly in the scsi layer do not seem to work for SBP2. This patch reverts to our old working code so that users can enjoy using Firewire disks and dvd drives again. We are working with the SCSI maintainers to resolve this issue outside of the main kernel tree. We'll merge the patch once the SCSI layer's handling of the MODE10 conversion is working for us. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06ieee1394: fix broken signed char assumption.Linus Torvalds
"ack_code" is assigned (and tested against) negative numbers, but was declared as "char". Which only works if "char" is signed - which it necessarily isn't. So make that signedness assumption specific.
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/i2c/chips/w83781d.c - ↵Yani Ioannou
drivers/s390/block/dcssblk.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] Use device_for_each_child() to unregister devices in ↵gregkh@suse.de
nodemgr_remove_host_dev() Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -Nru a/drivers/ieee1394/nodemgr.c b/drivers/ieee1394/nodemgr.c
2005-06-20[PATCH] class: convert drivers/ieee1394/* to use the new class api instead ↵gregkh@suse.de
of class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-17merge by hand (fix up qla_os.c merge error)James Bottomley
2005-06-17[SCSI] allow sleeping in ->eh_device_reset_handler()Jeff Garzik
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-17[SCSI] Remove unnecessary locking around completion function callsJeff Garzik
The SCSI ->done() hook should not be called from inside a spinlock. Drivers that do this are mostly cut-n-paste from 2.2.x-era. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-16[PATCH] sbp2 slab corruption fixAlexandre Oliva
This fixed a problem that showed up in the Fedora development tree a few weeks before the Fedora Core 4 release, initially as slab corruption, later as hard crashes on boot up, when slab debugging was disabled for the release. More details on the history at https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=158424 The problem is caused by sbp2's use of scsi_host->hostdata[0] to hold a scsi_id, without explicitly requesting space for it. Since hostdata is declared as a zero-sized array, we don't get any such space by default, so it must be explicitly requested. The patch below implements just that. Signed-off-by: Alexandre Oliva <aoliva@redhat.com> Cc: Jody McIntyre <scjody@modernduck.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-26Automatic merge of ../scsi-misc-2.6-old/James Bottomley
2005-05-26[SCSI] git-scsi-misc-sbp2-warning-fixAndrew Morton
drivers/ieee1394/sbp2.c: In function `sbp2_check_sbp2_response': drivers/ieee1394/sbp2.c:2154: warning: unused variable `device_type' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-26[SCSI] TYPE_RBC cache fixes (sbp2.c affected)Al Viro
a) TYPE_SDAD renamed to TYPE_RBC and taken to scsi.h b) in sbp2.c remapping of TYPE_RPB to TYPE_DISK turned off c) relevant places in midlayer and sd.c taught to accept TYPE_RBC d) sd.c::sd_read_cache_type() looks into page 6 when dealing with TYPE_RBC - these guys have writeback cache flag there and are not guaranteed to have page 8 at all. e) sd_read_cache_type() got an extra sanity check - it checks that it got the page it asked for before using its contents. And screams if mismatch had happened. Rationale: there are broken devices out there that are "helpful" enough to go for "I don't have a page you've asked for, here, have another one". For example, PL3507 had been caught doing just that... f) sbp2 sets sdev->use_10_for_rw and sdev->use_10_for_ms instead of bothering to remap READ6/WRITE6/MOD_SENSE, so most of the conversions in there are gone now. Incidentally, I wonder if USB storage devices that have no mode page 8 are simply RBC ones. I haven't touched that, but it might be interesting to check... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-17[PATCH] ieee1394: fix premature expiry of async packetsJody McIntyre
Set the initial sendtime to be 10 seconds in the future, to avoid the packet timing out while it's still queued to be sent. This fixes furthur "no tlabel match" problems caused by premature expiry. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: fix cross_bound check for null ISO packetsJody McIntyre
Fix cross_bound to not return 1 for zero-length regions. Fixes regression when sending null ISO packets. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: single buffer fixes to video1394Jody McIntyre
Apply and fixup patch from Markus Tavenrath <speedygoo@speedygoo.de> for video1394 to allow only a single buffer on receive and two buffers on transmit. Tested with libdc1394 and dvconnect (libdv). Signed-off-by: Dan Dennedy <dan@dennedy.org> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: drivers/ieee1394/pcilynx.c: Use the DMA_32BIT_MASK constantJody McIntyre
Use the DMA_32BIT_MASK constant from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() These patches include dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: remove NULL checks for kfreeJody McIntyre
This patch removes redundant NULL pointer checks before kfree() in all of drivers/ieee1394/ Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: drivers/ieee1394/ieee1394_transactions.c: possible cleanupsJody McIntyre
This patch contains the following possible cleanups: - #if 0 the following unused global functions: - hpsb_lock - hpsb_send_gasp - ieee1394_transactions.h: remove the stale hpsb_lock64 prototype Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] ieee1394: drivers/ieee1394/pcilynx.c: remove dead optionsJody McIntyre
The options CONFIG_IEEE1394_PCILYNX_LOCALRAM and CONFIG_IEEE1394_PCILYNX_PORTS are not available for some time. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-21[PATCH] Fix non-legacy ISO receive regressionJody McIntyre
Fix non-legacy multichannel ISO receive, broken by Parag Wardukar's allocation fix. Multichannel ISO receive still sucks; it should be possible to use both legacy and non-legacy modes at the same time, but with this patch, things are no worse than they were in 2.6.11 and allocation is still done at the correct time. Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-21[PATCH] ohci1394: tlabels misprinted in DBGMSGJody McIntyre
- Print the correct value in the DBGMSG in dma_rcv_tasklet(). See OHCI 1.1 section 8.7, page 103 ff. - Print tlabels as %d everywhere. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jody McIntyre <scjody@steamballoon.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
