path: root/drivers/ieee1394/iso.h
2007-04-30ieee1394: move some comments from declaration to definitionStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2006-07-03[PATCH] ieee1394: update #include directives in midlayer header filesStefan Richter
Remove unnecessary includes, add missing includes. Use forward type declarations for some structs. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2006-07-03[PATCH] ieee1394: coding style and comment fixes in midlayer header filesStefan Richter
Adjust tabulators, line wraps, empty lines, and comment style. Update comments in ieee1394_transactions.h and highlevel.h. Fix typo in comment in csr.h. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com>
2005-07-10[PATCH] Sync up ieee-1394Ben Collins
Lots of this patch is trivial code cleanups (static vars were being intialized to 0, etc). There's also some fixes for ISO transmits (max buffer handling). Aswell, we have a few fixes to disable IRM capabilites correctly. We've also disabled, by default some generally unused EXPORT symbols for the sake of cleanliness in the kernel. However, instead of removing them completely, we felt it necessary to have a config option that allowed them to be enabled for the many projects outside of the main kernel tree that use our API for driver development. The primary reason for this patch is to revert a MODE6->MODE10 RBC conversion patch from the SCSI maintainers. The new conversions handled directly in the scsi layer do not seem to work for SBP2. This patch reverts to our old working code so that users can enjoy using Firewire disks and dvd drives again. We are working with the SCSI maintainers to resolve this issue outside of the main kernel tree. We'll merge the patch once the SCSI layer's handling of the MODE10 conversion is working for us. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
