path: root/drivers/ide
2009-06-21ide cmd64x: Remove serialize setting.David S. Miller
This begins to fix regressions reported by Frans Pop on his Ultra-10. There are still some funnies left that we are investigating. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-20Merge branch 'for-2.6.31' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-2.6.31' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (34 commits) ide-cd: prevent null pointer deref via cdrom_newpc_intr ide: BUG() on unknown requests ide: filter out invalid DMA xfer mode changes in HDIO_DRIVE_CMD ioctl handler ide: do not access ide_drive_t 'drive_data' field directly sl82c105: implement test_irq() method siimage: implement test_irq() method pdc202xx_old: implement test_irq() method (take 2) cmd64x: implement test_irq() method cmd640: implement test_irq() method ide: move ack_intr() method into 'struct ide_port_ops' (take 2) ide: move IRQ clearing from ack_intr() method to clear_irq() method (take 2) siimage: use ide_dma_test_irq() (take 2) cmd64x: implement clear_irq() method (take 2) ide: call clear_irq() method in ide_timer_expiry() sgiioc4: coding style cleanup ide: don't enable IORDY at a probe time ide: IORDY handling fixes ata: add ata_id_pio_need_iordy() helper (v2) ide-tape: fix build issue ide: unify interrupt reason checking ...
2009-06-20ide-cd: prevent null pointer deref via cdrom_newpc_intrRainer Weikusat
With 2.6.30, the error handling code in cdrom_newpc_intr was changed to deal with partial request failures by normally completing the 'good' parts of a request and only 'error' the last (and presumably, incompletely transferred) bio associated with a particular request. In order to do this, ide_complete_rq is called over ide_cd_error_cmd() to partially complete the rq. The block layer does partial completion only for requests with bio's and if the rq doesn't have one (eg 'GPCMD_READ_DISC_INFO') the request is completed as a whole and the drive->hwif->rq pointer set to NULL afterwards. When calling ide_complete_rq again to report the error, this null pointer is derefenced, resulting in a kernel crash. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=13399. Signed-off-by: Rainer Weikusat <rweikusat@mssgmbh.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: linux-ide@vger.kernel.org Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15ide: BUG() on unknown requestsBartlomiej Zolnierkiewicz
Unsupported requests should be never handed down to device drivers and the best thing we can do upon discovering such request inside driver's ->do_request method is to just BUG(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: filter out invalid DMA xfer mode changes in HDIO_DRIVE_CMD ioctl handlerBartlomiej Zolnierkiewicz
2009-06-15ide: do not access ide_drive_t 'drive_data' field directlyJoao Ramos
Change ide_drive_t 'drive_data' field from 'unsigned int' type to 'void *' type, allowing a wider range of values/types to be stored in this field. Added 'ide_get_drivedata' and 'ide_set_drivedata' helpers to get and set the 'drive_data' field. Fixed all host drivers to maintain coherency with the change in the 'drive_data' field type. Signed-off-by: Joao Ramos <joao.ramos@inov.pt> [bart: fix qd65xx build, cast to 'unsigned long', minor Coding Style fixups] Acked-by: Sergei Shtylyov <sshtylyov@ru.montavista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15sl82c105: implement test_irq() methodSergei Shtylyov
Implement test_irq() method. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15siimage: implement test_irq() methodSergei Shtylyov
Implement test_irq() method based on the driver's former dma_test_irq() methods. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15pdc202xx_old: implement test_irq() method (take 2)Sergei Shtylyov
Implement test_irq() method based on the driver's former dma_test_irq() method. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15cmd64x: implement test_irq() methodSergei Shtylyov
Convert the driver's two dma_test_irq() methods into test_irq() methods. The driver will now use the standard dma_test_irq() method implementation which allows to remove 'cmd54x_dma_ops' and 'cmd648_dma_ops' that become identical to 'sff_dma_ops'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15cmd640: implement test_irq() methodSergei Shtylyov
Implement test_irq() method, adding the drive 2/3 interrupt bit definition. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: move ack_intr() method into 'struct ide_port_ops' (take 2)Sergei Shtylyov
Move the ack_intr() method into 'struct ide_port_ops', also renaming it to test_irq() while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: move IRQ clearing from ack_intr() method to clear_irq() method (take 2)Sergei Shtylyov
There are now two methods that clear the port interrupt: ack_intr() method, implemented only on M680x0 machines, that is called at the start of ide_intr(), and clear_irq() method, that is called somewhat later in this function. In order to stop this duplication, delegate the task of clearing the interrupt to clear_irq() method, only leaving to ack_intr() the task of testing for the port interrupt. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15siimage: use ide_dma_test_irq() (take 2)Sergei Shtylyov
Remove interrupt bit test (not trusted anyway) from siimage_io_dma_test_irq() and siimage_mmio_dma_test_irq() -- this allows to replace the former function with now identical ide_dma_test_irq()... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15cmd64x: implement clear_irq() method (take 2)Sergei Shtylyov
Convert the driver's two dma_end() methods into clear_irq() methods -- the driver will now use the standard dma_end() method implementation, ide_dma_end(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: call clear_irq() method in ide_timer_expiry()Sergei Shtylyov
Now the clear_irq() method is called only from ide_intr() but ide_timer_expiry() also should call this method in case when drive_is_ready() succeeds... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15sgiioc4: coding style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space between the asterisk and parameter name; - inconsistent spacing between operator and operands; - space between *sizeof* and open parenthesis; - #include <asm/io.h> instead of #include <linux/io.h> - use of *typedef* instead of a structure tag; - line over 80 characters. In addition to these changes, also do the following: - indent with tabs instead of spaces; - put the function's result type and name/parameters on the same line; - join back the needlessly broken lines; - get rid of needless type cast in sgiioc4_checkirq(); - remove space between the type cast and the variable name; - remove commented out field initializer; - uppercase the acronyms, lowercase the normal words in the comments; - fix up the multi-line comment style... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: don't enable IORDY at a probe timeBartlomiej Zolnierkiewicz
* Add 'unsigned long port_flags' field to ide_hwif_t. * Add IDE_PFLAG_PROBING port flag and keep it set during probing. * Fix ide_pio_need_iordy() to not enable IORDY at a probe time (IORDY may lead to controller lock up on certain controllers if the port is not occupied). Loosely based on the recent libata's fix by Tejun, thanks to Alan for the hint that IDE may also need it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide: IORDY handling fixesBartlomiej Zolnierkiewicz
Add ide_pio_need_iordy() helper and convert host drivers to use it. This fixes it8172, it8213, pdc202xx_old, piix, slc90e66 and siimage host drivers to handle IORDY correctly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-15ide-tape: fix build issueBorislav Petkov
This fixes drivers/ide/ide-tape.c: In function `idetape_chrdev_open': drivers/ide/ide-tape.c:1515: error: implicit declaration of function `idetape_read_position' make[1]: *** [drivers/ide/ide-tape.o] Error 1 Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-13Merge branch 'bp-remove-pc-buf' into for-nextBartlomiej Zolnierkiewicz
Conflicts: drivers/ide/ide-tape.c
2009-06-12Merge branch 'for-2.6.31' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-2.6.31' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (29 commits) ide: re-implement ide_pci_init_one() on top of ide_pci_init_two() ide: unexport ide_find_dma_mode() ide: fix PowerMac bootup oops ide: skip probe if there are no devices on the port (v2) sl82c105: add printk() logging facility ide-tape: fix proc warning ide: add IDE_DFLAG_NIEN_QUIRK device flag ide: respect quirk_drives[] list on all controllers hpt366: enable all quirks for devices on quirk_drives[] list hpt366: sync quirk_drives[] list with pdc202xx_{new,old}.c ide: remove superfluous SELECT_MASK() call from do_rw_taskfile() ide: remove superfluous SELECT_MASK() call from ide_driveid_update() icside: remove superfluous ->maskproc method ide-tape: fix IDE_AFLAG_* atomic accesses ide-tape: change IDE_AFLAG_IGNORE_DSC non-atomically pdc202xx_old: kill resetproc() method pdc202xx_old: don't call pdc202xx_reset() on IRQ timeout pdc202xx_old: use ide_dma_test_irq() ide: preserve Host Protected Area by default (v2) ide-gd: implement block device ->set_capacity method (v2) ...
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: fix typo milisecond/millisecond for documentation and source comments.Martin Olsson
Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-11Merge branch 'for-2.6.31' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-2.6.31' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (28 commits) ide-tape: fix debug call alim15x3: Remove historical hacks, re-enable init_hwif for PowerPC ide-dma: don't reset request fields on dma_timeout_retry() ide: drop rq->data handling from ide_map_sg() ide-atapi: kill unused fields and callbacks ide-tape: simplify read/write functions ide-tape: use byte size instead of sectors on rw issue functions ide-tape: unify r/w init paths ide-tape: kill idetape_bh ide-tape: use standard data transfer mechanism ide-tape: use single continuous buffer ide-atapi,tape,floppy: allow ->pc_callback() to change rq->data_len ide-tape,floppy: fix failed command completion after request sense ide-pm: don't abuse rq->data ide-cd,atapi: use bio for internal commands ide-atapi: convert ide-{floppy,tape} to using preallocated sense buffer ide-cd: convert to using generic sense request ide: add helpers for preparing sense requests ide-cd: don't abuse rq->buffer ide-atapi: don't abuse rq->buffer ...
2009-06-10ide: re-implement ide_pci_init_one() on top of ide_pci_init_two()Bartlomiej Zolnierkiewicz
There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-10ide: unexport ide_find_dma_mode()Bartlomiej Zolnierkiewicz
2009-06-10ide: fix PowerMac bootup oopsHugh Dickins
PowerMac bootup with CONFIG_IDE=y oopses in ide_pio_cycle_time(): because "ide: try to use PIO Mode 0 during probe if possible" causes pmac_ide_set_pio_mode() to be called before drive->id has been set. Bart points out other places which now need drive->id set earlier, so follow his advice to allocate it in ide_port_alloc_devices() (using kzalloc_node, without error message, as when allocating drive) and memset it for reuse in ide_port_init_devices_data(). Fixed in passing: ide_host_alloc() was missing ide_port_free_devices() from an error path. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Joao Ramos <joao.ramos@inov.pt> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-08ide: skip probe if there are no devices on the port (v2)Bartlomiej Zolnierkiewicz
In ide_probe_port() skip probe if ide_port_wait_ready() returns -ENODEV and print error message instead of debug one if it returns -EBUSY. v2: Fix the default 'rc' value. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-08sl82c105: add printk() logging facilitySergei Shtylyov
Add missing printk() logging facility in sl82c105_dma_lost_irq(). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-08ide-tape: fix proc warningBorislav Petkov
ide_tape_chrdev_get() was missing an ide_device_get() refcount increment which lead to the following warning: [ 278.147906] ------------[ cut here ]------------ [ 278.152685] WARNING: at fs/proc/generic.c:847 remove_proc_entry+0x199/0x1b8() [ 278.160070] Hardware name: P4I45PE 1.00 [ 278.160076] remove_proc_entry: removing non-empty directory 'ide0/hdb', leaking at least 'name' [ 278.160080] Modules linked in: rtc intel_agp pcspkr thermal processor thermal_sys parport_pc parport agpgart button [ 278.160100] Pid: 2312, comm: mt Not tainted 2.6.30-rc2 #3 [ 278.160105] Call Trace: [ 278.160117] [<c012141d>] warn_slowpath+0x71/0xa0 [ 278.160126] [<c035f219>] ? _spin_unlock_irqrestore+0x29/0x2c [ 278.160132] [<c011c686>] ? try_to_wake_up+0x1b6/0x1c0 [ 278.160141] [<c011c69b>] ? default_wake_function+0xb/0xd [ 278.160149] [<c0177ead>] ? pollwake+0x4a/0x55 [ 278.160156] [<c035f240>] ? _spin_unlock+0x24/0x26 [ 278.160163] [<c0165d38>] ? add_partial+0x44/0x49 [ 278.160169] [<c01669e8>] ? __slab_free+0xba/0x29c [ 278.160177] [<c01a13d8>] ? sysfs_delete_inode+0x0/0x3c [ 278.160184] [<c019ca92>] remove_proc_entry+0x199/0x1b8 [ 278.160191] [<c01a297e>] ? remove_dir+0x27/0x2e [ 278.160199] [<c025f3ab>] ide_proc_unregister_device+0x40/0x4c [ 278.160207] [<c02599cd>] drive_release_dev+0x14/0x47 [ 278.160214] [<c0250538>] device_release+0x35/0x5a [ 278.160221] [<c01f8bed>] kobject_release+0x40/0x50 [ 278.160226] [<c01f8bad>] ? kobject_release+0x0/0x50 [ 278.160232] [<c01f96ac>] kref_put+0x3c/0x4a [ 278.160238] [<c01f8b29>] kobject_put+0x37/0x3c [ 278.160243] [<c025020c>] put_device+0xf/0x11 [ 278.160249] [<c025789f>] ide_device_put+0x2d/0x30 [ 278.160255] [<c02658da>] ide_tape_put+0x24/0x32 [ 278.160261] [<c0266e0c>] idetape_chrdev_release+0x17f/0x18e [ 278.160269] [<c016c4f5>] __fput+0xca/0x175 [ 278.160275] [<c016c5b9>] fput+0x19/0x1b [ 278.160280] [<c0169d19>] filp_close+0x51/0x5b [ 278.160286] [<c0169d96>] sys_close+0x73/0xad [ 278.160293] [<c0102a61>] syscall_call+0x7/0xb [ 278.160298] ---[ end trace f16d907ea1f89336 ]--- Instead of trivially fixing it by adding the missing call, ide_tape_chrdev_get() and ide_tape_get() were merged into one function since both were almost identical. The only difference was that ide_tape_chrdev_get() was accessing the ide-tape reference through the idetape_devs[] array of minors instead of through the gendisk. Accomodate that by adding two additional parameters to ide_tape_get() to annotate the call site and invoke the proper behavior. As a result, remove ide_tape_chrdev_get(). Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide: add IDE_DFLAG_NIEN_QUIRK device flagBartlomiej Zolnierkiewicz
Add IDE_DFLAG_NIEN_QUIRK device flag and use it instead of drive->quirk_list. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide: respect quirk_drives[] list on all controllersBartlomiej Zolnierkiewicz
* Add ide_check_nien_quirk_list() helper to the core code and then use it in ide_port_tune_devices(). * Remove no longer needed ->quirkproc methods from hpt366.c and pdc202xx_{new,old}.c. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07hpt366: enable all quirks for devices on quirk_drives[] listBartlomiej Zolnierkiewicz
Enable also quirks in do_reset1() and ide_config_drive_speed() for devices on quirk_drives[] list. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07hpt366: sync quirk_drives[] list with pdc202xx_{new,old}.cBartlomiej Zolnierkiewicz
2009-06-07ide: remove superfluous SELECT_MASK() call from do_rw_taskfile()Bartlomiej Zolnierkiewicz
With ->write_devctl method call (which unmasks drive IRQ) preceding SELECT_MASK() call there is really no need for the latter. Moreover with the combination of HPT36x controller and the drive on the quirk_drives[] list this can result in superfluous enable_irq() call which in turn will trigger WARN() in __enable_irq(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide: remove superfluous SELECT_MASK() call from ide_driveid_update()Bartlomiej Zolnierkiewicz
We always call SELECT_MASK(drive, 0) after ide_dev_read_id() call so there is no need to do it again in the error path. Moreover with the combination of HPT36x controller and the drive on the quirk_drives[] list this can result in superfluous enable_irq() call which in turn will trigger WARN() in __enable_irq(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07icside: remove superfluous ->maskproc methodBartlomiej Zolnierkiewicz
[inspired by pata_icside] Enabling/disabling of card IRQs is handled fine by IRQ and IDE subsystems so there is no need for custom ->maskproc method. Moreover icside_maskproc() would enable IRQ only if it was already enabled [because of 'if (state->enabled && !mask)' check]. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide-tape: fix IDE_AFLAG_* atomic accessesBorislav Petkov
These flags used to be bit numbers and now are single bits in the ->atapi_flags vector. Use them properly. Spotted-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide-tape: change IDE_AFLAG_IGNORE_DSC non-atomicallyBorislav Petkov
There are two sites where the flag is being changed: ide_retry_pc and idetape_do_request. Both codepaths are protected by hwif->busy (ide_lock_port) and therefore we shouldn't need the atomic accesses. Spotted-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07pdc202xx_old: kill resetproc() methodSergei Shtylyov
The driver's resetproc() method resets both channels at once -- most probably by driving RESET- on them. Not only such reset can severely disturb concurrent operations on another channel, it also ensues 2-second delay, while there's no apparent reason why SRST reset being performed prior to resetproc() call needs to be followed up by another reset. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07pdc202xx_old: don't call pdc202xx_reset() on IRQ timeoutSergei Shtylyov
The driver's dma_lost_irq() and dma_clear() methods call pdc202xx_reset() which resets both channels at once -- most probably by driving RESET- on them. Not only such reset can severely disturb concurrent operations on another channel, it is also a clear overkill (especially in the first case) and is completely unexpected and thus not properly handled by the IDE core in this context (in the second case the usual SRST reset would most probably ensue anyway though); it also causes quite arbitrary 2-second delay. Hence, use the standard ide_dma_lost_irq() method and don't install the optional dma_clear() method at all -- the driver should do well without this age-old cruft... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07pdc202xx_old: use ide_dma_test_irq()Sergei Shtylyov
The driver's dma_test_irq() method, although tests some chip specific interrupt bits, finally always relies on the SFF-8038i standard interrupt bit. I see no point in testing the bits that are not trusted anyway -- the driver should be fully able to use the standard method implemetation, ide_dma_test_irq(). With this change 'pdc202xx_dma_ops' finally becomes identical to 'sff_dma_ops', and we can get rid of it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07Merge branch 'for-linus' into for-nextBartlomiej Zolnierkiewicz
2009-06-07ide: preserve Host Protected Area by default (v2)Bartlomiej Zolnierkiewicz
From the perspective of most users of recent systems, disabling Host Protected Area (HPA) can break vendor RAID formats, GPT partitions and risks corrupting firmware or overwriting vendor system recovery tools. Unfortunately the original (kernels < 2.6.30) behavior (unconditionally disabling HPA and using full disk capacity) was introduced at the time when the main use of HPA was to make the drive look small enough for the BIOS to allow the system to boot with large capacity drives. Thus to allow the maximum compatibility with the existing setups (using HPA and partitioned with HPA disabled) we automically disable HPA if any partitions overlapping HPA are detected. Additionally HPA can also be disabled using the "nohpa" module parameter (i.e. "ide_core.nohpa=0.0" to disable HPA on /dev/hda). v2: Fix ->resume HPA support. While at it: - remove stale "idebus=" entry from Documentation/kernel-parameters.txt Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [patch description was based on input from Alan Cox and Frans Pop] Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07ide-gd: implement block device ->set_capacity method (v2)Bartlomiej Zolnierkiewicz
* Use ->probed_capacity to store native device capacity for ATA disks. * Add ->set_capacity method to struct ide_disk_ops. * Implement disk device ->set_capacity method for ATA disks. * Implement block device ->set_capacity method. v2: * Check if LBA and HPA are supported in ide_disk_set_capacity(). * According to the spec the SET MAX ADDRESS command shall be immediately preceded by a READ NATIVE MAX ADDRESS command. * Add ide_disk_hpa_{get_native,set}_capacity() helpers. Together with the previous patch adding ->set_capacity block device method this allows automatic disabling of Host Protected Area (HPA) if any partitions overlapping HPA are detected. Cc: Robert Hancock <hancockrwd@gmail.com> Cc: Frans Pop <elendil@planet.nl> Cc: "Andries E. Brouwer" <Andries.Brouwer@cwi.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Emphatically-Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07pdc202xx_old: fix resetproc() methodSergei Shtylyov
pdc202xx_reset() calls pdc202xx_reset_host() twice, for both channels, while that function actually twiddles the single, shared software reset bit -- the net effect is a duplicated reset and horrendous 4 second delay happening not only on a channel reset but also when dma_lost_irq() and dma_clear() methods are called. Fold pdc202xx_reset_host() into pdc202xx_reset(), fix printk(), and move it before the actual reset... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
