path: root/drivers/ide/ppc
2008-04-28ide: add IDE_HFLAG_MMIO host flag (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_MMIO host flag and set it for hosts which use default_hwif_mmiops(). v2: * Fix kernel panic in pmac host driver (',' should be '|'). Thanks to Kamalesh for reporting it + testing the fix and to Andrew for hinting me about the source of the issue. Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27mpc8xx-ide: use ide_find_port()Bartlomiej Zolnierkiewicz
2008-04-26ide: constify struct ide_dma_opsBartlomiej Zolnierkiewicz
* Export ide_dma_exec_cmd() and __ide_dma_test_irq(). * Constify struct ide_dma_ops. * Always set hwif->dma_ops to &sff_dma_ops in ide_setup_dma() (it is later overriden by ide_init_port() if needed) and drop 'const struct ide_port_info *d' argument. While at it: * Rename __ide_dma_test_irq() to ide_dma_test_irq(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_dma_ops (take 3)Bartlomiej Zolnierkiewicz
Add struct ide_dma_ops and convert core code + drivers to use it. While at it: * Drop "ide_" prefix from ->ide_dma_end and ->ide_dma_test_irq methods. * Drop "ide_" "infixes" from DMA methods. * au1xxx-ide.c: - use auide_dma_{test_irq,end}() directly in auide_dma_timeout() * pdc202xx_old.c: - drop "old_" "infixes" from DMA methods * siimage.c: - add siimage_dma_test_irq() helper - print SATA warning in siimage_init_one() * Remove no longer needed ->init_hwif implementations. v2: * Changes based on review from Sergei: - s/siimage_ide_dma_test_irq/siimage_dma_test_irq/ - s/drive->hwif/hwif/ in idefloppy_pc_intr(). - fix patch description w.r.t. au1xxx-ide changes - fix au1xxx-ide build - fix naming for cmd64*_dma_ops - drop "ide_" and "old_" infixes - s/hpt3xxx_dma_ops/hpt37x_dma_ops/ - s/hpt370x_dma_ops/hpt370_dma_ops/ - use correct DMA ops for HPT302/N, HPT371/N and HPT374 - s/it821x_smart_dma_ops/it821x_pass_through_dma_ops/ v3: * Two bugs slipped in v2 (noticed by Sergei): - use correct DMA ops for HPT374 (for real this time) - handle HPT370/HPT370A properly Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-pmac: use ->init_dma methodBartlomiej Zolnierkiewicz
* Move pmif->dma_regs check from pmac_ide_setup_device() to pmac_ide_init_dma(). * Get 'pmif' from 'hwif->hwif_data' in pmac_ide_init_dma() and replace 'pmac_ide_hwif_t *pmif' argument by 'const struct ide_port_info *d'. * Add pmac_ide_init_dma() implementation for CONFIG_BLK_DEV_IDEDMA_PMAC=n case and convert the driver to use ->init_dma method. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: cleanup setting hwif->mmio flagBartlomiej Zolnierkiewicz
It is no longer needed to set hwif->mmio flag to tell IDE layer to not manage resources so cleanup host drivers that used hwif->mmio flag only for this purpose. Ditto for ide_legacy_init_one(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove ->noprobe field from ide_hwif_tBartlomiej Zolnierkiewicz
Update IDE PMAC host driver to use drive->noprobe instead of hwif->noprobe and remove hwif->noprobe completely (it is always set to zero now). There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_port_ops (take 2)Bartlomiej Zolnierkiewicz
* Move hooks for port/host specific methods from ide_hwif_t to 'struct ide_port_ops'. * Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info' and ide_hwif_t. * Update host drivers and core code accordingly. While at it: * Rename ata66_*() cable detect functions to *_cable_detect() to match the standard naming. (Suggested by Sergei Shtylyov) v2: * Fix build for bast-ide. (Noticed by Andrew Morton) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-mpc8xx: fix resources reservationBartlomiej Zolnierkiewicz
* Tell IDE layer to not manage resources by setting hwif->mmio flag and request resources in m8xx_ide_init_ports(). * Use request_mem_region() for resources reservation. * Use driver name for resources reservation. Cc: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-mpc8xx: make m8xx_ide_init_ports() return an error valueBartlomiej Zolnierkiewicz
* Make m8xx_ide_init_ports() return an error value. * Update mpc8xx_ide_probe() to setup/probe only ports for which m8xx_ide_init_ports() succedded. Cc: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: remove PIO "downgrade" quirkBartlomiej Zolnierkiewicz
No need for it nowadays so remove quirk code from ide_get_best_pio_mode() and IDE_HFLAG_PIO_DOWNGRADE host flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide-pmac: use ide_find_port()Bartlomiej Zolnierkiewicz
2008-04-26ide-pmac: dynamically allocate struct pmac_ide_hwif instances (take 2)Bartlomiej Zolnierkiewicz
* Dynamically allocate struct pmac_ide_hwif instances in pmac_ide_macio_attach() and pmac_ide_pci_attach(), then remove no longer needed pmac_ide[]. v2: * Build fix from Kamalesh Babulal. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/mpc8xx: remove ppc_ide_md hooksBartlomiej Zolnierkiewicz
* Initialize IDE ports in mpc8xx_ide_probe(). * Remove m8xx_ide_init() and ppc_ide_md hooks - no need for them (IDE mpc8xx host driver takes care of all this setup). * Remove needless 'if (irq)' and 'if (data_port >= MAX_HWIFS)' checks from m8xx_ide_init_hwif_ports(). * Remove 'ctrl_port' and 'irq' arguments from m8xx_ide_init_hwif_ports(). * Rename m8xx_ide_init_hwif_ports() to m8xx_ide_init_ports(). * Add __init tag to m8xx_ide_init_ports(). This patch fixes hwif->irq always being overriden to 0 (== auto-probe, is this even working on PPC?) because of ide_init_default_irq() call in ide.c. There should be no other functional changes. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ppc/pmac: remove ppc_ide_md hooksBartlomiej Zolnierkiewicz
* Add pmac_ide_init_ports() helper and use it instead of pmac_ide_init_hwif_ports(). * Remove ppc_ide_md hooks - no need for them (IDE pmac host driver takes care of all this setup). * Then remove no longer needed <linux/ide.h> include from arch/powerpc/platforms/powermac/pmac.h. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide-pmac: remove dead codeBartlomiej Zolnierkiewicz
Remove unused pmac_ide_{check_base,get_irq}() and pmac_find_ide_boot(), then remove no longer needed ide_majors[] and pmac_ide_count. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE_*_REG macrosBartlomiej Zolnierkiewicz
* Add IDE_{ALTSTATUS,IREASON,BCOUNTL,BCOUNTH}_OFFSET defines. * Remove IDE_*_REG macros - this results in more readable and slightly smaller code. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ->hold field from ide_hwif_t (take 2)Bartlomiej Zolnierkiewicz
->hold is write-only now, remove it. v2: * v1 missed bast-ide, palm_bk3710, ide-cs and delkin_cb host drivers. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: rework PowerMac media-bay support (take 2)Bartlomiej Zolnierkiewicz
Rework PowerMac media-bay support in such way that instead of un/registering the IDE interface we un/register IDE devices: * Add ide_port_scan() helper for probing+registerering devices on a port. * Rename ide_port_unregister_devices() to __ide_port_unregister_devices(). * Add ide_port_unregister_devices() helper for unregistering devices on a port. * Add 'ide_hwif_t *cd_port' to 'struct media_bay_info', pass 'hwif' instead of hwif->index to media_bay_set_ide_infos() and use it to setup 'cd_port'. * Use ide_port_unregister_devices() instead of ide_unregister() and ide_port_scan() instead of ide_register_hw() in media_bay_step(). * Unexport ide_register_hw() and make it static. v2: * Fix build by adding <linux/ide.h> include to <asm-powerpc/mediabay.h>. (Reported by Michael/Kamalesh/Andrew). Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-02ide/ppc/pmac.c: add MODULE_LICENSEAdrian Bunk
Now that it can be built modular it needs a MODULE_LICENSE. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-02ide/ppc/mpc8xx.c: add MODULE_LICENSEAdrian Bunk
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: remove unnecessary inclusions of {asm, linux}/a.out.hDavid Howells
Remove now unnecessary inclusions of {asm,linux}/a.out.h. [akpm@linux-foundation.org: fix alpha build] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-02ide: add struct ide_port_info instances to legacy host driversBartlomiej Zolnierkiewicz
* Remove 'struct pci_dev *dev' argument from ide_hwif_setup_dma(). * Un-static ide_hwif_setup_dma() and add CONFIG_BLK_DEV_IDEDMA_PCI=n version. * Add 'const struct ide_port_info *d' argument to ide_device_add[_all](). * Factor out generic ports init from ide_pci_setup_ports() to ide_init_port(), move it to ide-probe.c and call it in in ide_device_add_all() instead of ide_pci_setup_ports(). * Move ->mate setup to ide_device_add_all() from ide_port_init(). * Add IDE_HFLAG_NO_AUTOTUNE host flag for host drivers that don't enable ->autotune currently. * Setup hwif->chipset in ide_init_port() but iff pi->chipset is set (to not override setup done by ide_hwif_configure()). * Add ETRAX host handling to ide_device_add_all(). * cmd640.c: set IDE_HFLAG_ABUSE_* also for CONFIG_BLK_DEV_CMD640_ENHANCED=n. * pmac.c: make pmac_ide_setup_dma() return an error value and move DMA masks setup to pmac_ide_setup_device(). * Add 'struct ide_port_info' instances to legacy host drivers, pass them to ide_device_add() calls and then remove open-coded ports initialization. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-pmac: macio resource freeing bugfixBartlomiej Zolnierkiewicz
Release DMA resource before zeroing pmif. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: keep pointer to struct device instead of struct pci_dev in ide_hwif_tBartlomiej Zolnierkiewicz
Keep pointer to struct device instead of struct pci_dev in ide_hwif_t. While on it: * Use *dev->dma_mask instead of pci_dev->dma_mask in ide_toggle_bounce(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: use ide_destroy_dmatable() instead of pci_unmap_sg() (take 2)Bartlomiej Zolnierkiewicz
Use ide_destroy_dmatable() in: * ide-dma.c::ide_build_dmatable() * sgiioc4.c::sgiioc4_build_dma_table() * pmac.c::pmac_ide_{build,destroy}_dmatable() There should be no functionality changes caused by this patch. v2: * pmac.c build fix from Andrew Morton. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide/ppc/pmac.c section fixesAdrian Bunk
This patch fixes the following section mismatch: <-- snip --> ... WARNING: vmlinux.o(.text+0x3b641c): Section mismatch in reference from the function .pmac_ide_setup_device() to the function .init.text:.pmac_ide_setup_dma() ... <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide-pmac: use custom hwif->sg_max_nents only if DMA support is enabledBartlomiej Zolnierkiewicz
Move setting hwif->sg_max_nents from pmac_ide_setup_device() to pmac_ide_setup_dma(). Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: make remaining built-in only IDE host drivers modular (take 2)Bartlomiej Zolnierkiewicz
* Make remaining built-in only IDE host drivers modular, add ide-scan-pci.c file for probing PCI host drivers registered with IDE core (special case for built-in IDE and CONFIG_IDEPCI_PCIBUS_ORDER=y) and then take care of the ordering in which all IDE host drivers are probed when IDE is built-in during link time. * Move probing of gayle, falconide, macide, q40ide and buddha (m68k arch specific) host drivers, before PCI ones (no PCI on m68k), ide-cris (cris arch specific), cmd640 (x86 arch specific) and pmac (ppc arch specific). * Move probing of ide-cris (cris arch specific) host driver before cmd640 (x86 arch specific). * Move probing of mpc8xx (ppc specific) host driver before ide-pnp (depends on ISA and none of ppc platform that use mpc8xx supports ISA) and ide-h8300 (h8300 arch specific). * Add "probe_vlb" kernel parameter to cmd640 host driver and update Documentation/ide.txt accordingly. * Make IDE_ARM config option visible so it can also be disabled if needed. * Remove bogus comment from ide.c while at it. v2: * Fix two issues spotted by Sergei: - replace ENOMEM error value by ENOENT in ide-h8300 host driver - fix MODULE_PARM_DESC() in cmd640 host driver Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: fix host drivers depending on ide_generic to probe for interfaces (take 2)Bartlomiej Zolnierkiewicz
* Add mpc8xx_ide_probe() to mpc8xx.c and call it from probe_for_hwifs(). * Convert ide_arm, ide-cris, ide-h8300, ide-pnp, buddha, falconide, gayle, macide, q40ide, cmd640 and mpc8xx host drivers to use ide_device_add(). This removes dependency on ide_generic for these drivers so update ide/Kconfig accordingly. v2: * ide_arm build fix (s/ide_device_idx/ide_device_add/) (Thanks to Christoph Lameter <clameter@sgi.com> for reporting the problem). Cc: Mikael Starvik <starvik@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: add ide_init_port_hw() helperBartlomiej Zolnierkiewicz
* Add ide_init_port_hw() helper. * rapide.c: convert rapide_locate_hwif() to rapide_setup_ports() and use ide_init_port_hw(). * ide_platform.c: convert plat_ide_locate_hwif() to plat_ide_setup_ports() and use ide_init_port_hw(). * sgiioc4.c: use ide_init_port_hw(). * pmac.c: add 'hw_regs_t *hw' argument to pmac_ide_setup_device(), setup 'hw' in pmac_ide_{macio,pci}_attach() and use ide_init_port_hw() in pmac_ide_setup_device(). This patch is a preparation for the future changes in the IDE probing code. There should be no functionality changes caused by this patch. Cc: Russell King <rmk@arm.linux.org.uk> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Jeremy Higdon <jeremy@sgi.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: merge ->dma_host_{on,off} methods into ->dma_host_set methodBartlomiej Zolnierkiewicz
Merge ->dma_host_{on,off} methods into ->dma_host_set method which takes 'int on' argument. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: remove ->ide_dma_on and ->dma_off_quietly methods from ide_hwif_tBartlomiej Zolnierkiewicz
* Make ide_dma_off_quietly() and __ide_dma_on() always available. * Drop "__" prefix from __ide_dma_on(). * Check for presence of ->dma_host_on instead of ->ide_dma_on. * Convert all users of ->ide_dma_on and ->dma_off_quietly methods to use ide_dma_on() and ide_dma_off_quietly() instead. * Remove no longer needed ->ide_dma_on and ->dma_off_quietly methods from ide_hwif_t. * Make ide_dma_on() void. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add IDE_HFLAG_ABUSE_SET_DMA_MODE host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_SET_DMA_MODE host flag and use it to decide what to do with transfer modes < XFER_PIO_0 in ide_set_xfer_rate(). * Set IDE_HFLAG_ABUSE_SET_DMA_MODE in host drivers that need it (aec62xx, amd74xx, cs5520, cs5535, hpt34x, hpt366, pdc202xx_old, serverworks, tc86c001 and via82cxxx) and cleanup ->set_dma_mode methods in host drivers that don't (IDE core code guarantees that ->set_dma_mode will be called only for modes which are present in SWDMA/MWDMA/UDMA masks). While at it: * Add IDE_HFLAGS_HPT34X/HPT3XX/PDC202XX/SVWKS define in hpt34x/hpt366/pdc202xx_old/serverworks host driver. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide-pmac: fix pmac_ide_init_hwif_ports()Bartlomiej Zolnierkiewicz
* pmac_ide_init_hwif_ports() can be called by ide_init_hwif_ports() (through ppc_ide_md.ide_init_hwif hook) for non IDE PMAC interfaces. If this is the case the hw->io_ports[] should be already setup by ide_init_hwif_ports()->ide_std_init_ports() so remove redundant code from pmac_ide_init_hwif_ports(). As side-effect this change fixes ctl_addr == 0 special handling in ide_init_hwif_ports(). * Fix misleading comment while at it. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-27drivers/ide: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-13ide-pmac: skip conservative PIO "downgrade"Bartlomiej Zolnierkiewicz
We can skip conservative PIO "downgrade" (PIO3 becomes PIO2 etc.) on PMAC. Problem reported by Mikael. Cc: Mikael Pettersson <mikpe@it.uu.se> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: remove write-only hwif->hwBartlomiej Zolnierkiewicz
2007-10-20ide: add hwif->ack_intr hookBartlomiej Zolnierkiewicz
* Add hwif->ack_intr hook and use it instead of hwif->hw.ack_intr. * Add missing brackets to cris-v32 and powerpc ide_ack_intr() macros. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: add ide_device_add()Bartlomiej Zolnierkiewicz
* Add ide_device_add() helper and convert host drivers to use it instead of open-coded variants. * Make ide_pci_setup_ports() and do_ide_setup_pci_device() take 'u8 *idx' argument instead of 'ata_index_t *index'. * Remove no longer needed ata_index_t. * Unexport probe_hwif_init() and make it static. * Unexport ide_proc_register_port(). There should be no functionality changes caused by this patch (sgiioc4.c: ide_proc_register_port() requires hwif->present to be set and it won't be set if probe_hwif_init() fails). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_ATAPI_DMA host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_ATAPI_DMA host flag and set it in host drivers which don't support ATAPI DMA. Then remove no longer needed hwif->atapi_dma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove hwif->autodma and drive->autodmaBartlomiej Zolnierkiewicz
* hpt34x.c: disable DMA masks for HPT345 (hwif->autodma is zero so DMA won't be enabled anyway). * trm290.c: disable IDE_HFLAG_TRUST_BIOS_FOR_DMA flag (hwif->autodma is zero so DMA won't be enabled anyway). * Check noautodma global variable instead of drive->autodma in ide_tune_dma(). This fixes handling of "ide=nodma" kernel parameter for icside, ide-cris, au1xxx-ide, pmac, it821x, jmicron, sgiioc4 and siimage host drivers. * Remove hwif->autodma (it was not checked by IDE core code anyway) and drive->autodma (was set by all host drivers - except HPT345/TRM290 special cases - unless "ide=nodma" was used). While at it: - remove needless printk() from icside.c - remove stale FIXME/comment from ide-probe.c - don't force DMA off if PCI bus-mastering had to be enabled in setup-pci.c (this setting was always later over-ridden by host drivers anyway) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: use PCI_VDEVICE() macroBartlomiej Zolnierkiewicz
While at it: - make struct pci_device_id tables const - use PCI_DEVICE_ID_ITE_8213 define in it8213.c - fix comment in generic.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove ->ide_dma_check (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_TRUST_BIOS_FOR_DMA host flag for host drivers that depend on BIOS for programming device/controller for DMA. Set it in cy82c693, generic, ns87415, opti621 and trm290 host drivers. * Add IDE_HFLAG_VDMA host flag for host drivers using VDMA. Set it in cs5520 host driver. * Teach ide_tune_dma() about IDE_HFLAG_TRUST_BIOS_FOR_DMA flag. * Add generic ide_dma_check() helper and remove all open coded ->ide_dma_check implementations. Fix all places checking for presence of ->ide_dma_check hook to check for ->ide_dma_on instead. * Remove no longer needed code from config_drive_for_dma(). * Make ide_tune_dma() static. v2: * Fix config_drive_for_dma() return values. * Fix ide-dma.c build for CONFIG_BLK_DEV_IDEDMA_PCI=n by adding dummy config_drive_for_dma() inline. * Fix IDE_HFLAG_TRUST_BIOS_FOR_DMA handling in ide_dma_check(). * Fix init_hwif_it8213() comment. There should be no functionality changes caused by this patch. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide-pmac: add PIO autotune fallback to ->ide_dma_checkBartlomiej Zolnierkiewicz
Since ide-pmac allows separate PIO and DMA timings, and ide-pmac always sets ->autotune this change shouldn't have any other effect than bringing ide-pmac driver in-line with other host drivers wrt ->ide_dma_check implementation. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16IDE: sg chaining supportJens Axboe
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
