The SiS966 has one additional PCI-ID 1180.
If the chipset is using this PCI-ID, the primary channel is connected to the
first PATA-port. The secondary channel is connected to SATA-ports in IDE
emulation mode. The legacy IO-ports are used.
The including of the PCI-ID into pata_sis is not sufficient, because the legacy
driver in drivers/ide is initialized before pata_sis.
Signed-off-by: Uwe Koziolek <uwe.koziolek@gmx.net>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Recently the PLL input clock of Promise 2027x is sometimes detected
higher than expected (e.g. 20.027 MHz compared to 16.714 MHz).
It seems sometimes the mdelay() function is not as precise as it
used to be. Per Alan's advice, HT or power management might affect
the precision of mdelay().
This patch calls gettimeofday() to measure the time elapsed and
calculate the PLL input clock accordingly.
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Bahadir Balban <bahadir.balban@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
SWDMA modes are unsupported by it821x. Attempts to tune SWDMA modes always
fail (due to sanity check in ->speedproc) and result in PIO being tuned.
* Fix incorrect SWDMA mask so core code won't try these modes and will just
tune PIO if no other DMA modes are available.
* Bump driver version.
* Driver can't skip programming transfer mode on the device in amd_set_drive()
(similar fix has been applied to via82cxxx driver ages ago).
* While at it remove redundant warning (ide_config_drive_speed() already
produces more valuable one).
The HPT36x chips finally turned out to have the channel enable bits -- however,
badly implemented. Make use of them despite it's probably only going to burden
the driver's code -- assuming both channels are always enabled by the HighPoint
BIOS anyway...
Acked-by: Linas Vepstas <linas@austin.ibm.com>
Cc: michal.kepien@poczta.onet.pl
Add the MAXTOR STM3320620A drive into the UltraDMA/66 mode blacklist
for the HPT36x chips.
Add the MCP73/MCP77 support to PATA driver.
bart: Added amd74xx_chipsets[] and amd_pci_tbl[] entries.
bart: Bumped driver version.
Signed-off-by: Peer Chen <peerchen@gmail.com>
Cc: Alan Cox <alan@redhat.com>,
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Tejun Heo <htejun@gmail.com>
Eliminate UltraATA/133 support for HPT374 -- the chip isn't capable of this mode
according to the manual, and doesn't even seem to tolerate 66 MHz DPLL clock...
Cc: Geller Sandor <wildy@petra.hos.u-szeged.hu>
generic IDE PCI driver, add another device exception
This device is char device and is grabbed by generic ide driver:
00:0b.0 Class ffff: National Semiconductor Corporation 87410 IDE (rev ff) (prog-if ff)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Disallow generic IDE PCI driver to grab it by adding next condition. Also
consolidate exceptions to one bigger 'switch (dev->vendor)'.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Ingo Korb <ml@akana.de>
The DMA support for RAID mode broke after:
commit 71ef51cc1756d1c56b57c70e7cc27a3559c81ee6
Author: Jens Axboe <axboe@suse.de>
Date: Â Fri Jul 28 09:02:17 2006 +0200
  [PATCH] it821x: fix ide dma setup bug
  Only enable dma for a valid speed setting.
  Signed-off-by: Jens Axboe <axboe@suse.de>
commit 0a8348d08677ad77ee353f96eb8745c693a05a13
Date: Â Fri Jul 28 08:58:26 2006 +0200
  [PATCH] ide: if the id fields looks screwy, disable DMA
  It's the safer choice. Originally due to a bug in itx821x, but a
  generally sound thing to do.
However it worked by pure luck before Jens' fixes: bogus ide_dma_enable()
usage in it821x driver combined with loosy check in ide_dma_verbose() allowed
the hardware to operate in DMA mode. When these problems were fixed the DMA
support broke...
The source root for the regression turned out to be that the it821x.c code
was clearing too much of id->field_valid. The IDE core code was using the
original value of id->field_valid to do the tuning but later DMA got disabled
in ide_dma_verbose() because of the incorrect id->field_valid fixup. Fix it.
While at it:
* Do fixup() after probing the drives but before tuning them (which is also
OK w.r.t. ide_undecoded_slave() fixup). This change fixes device IDENTIFY
data to be consistent before/after the tuning and allows us to remove extra
re-tuning of drives from it821x_fixups().
* Fake MWDMA0 enabled/supported bits in IDENTIFY data if the device has
DMA capable bit set (this is just to tell the IDE core that DMA is
supported since it821x firmware takes care of DMA mode programming).
* Don't touch timing registers and don't program transfer modes on devices
et all when in RAID mode - depend solely on firmware to do the tuning
(as suggested by Alan Cox and done in libata pata_it821x driver).
Thanks for testing the patch goes out to Thomas Kuther.
Cc: Thomas Kuther <gimpel@sonnenkinder.org>
Cc: Jens Axboe <axboe@suse.de>
Problem noticed by Joe Zbiciak, see
http://kerneltrap.org/node/8252
for details.
On CSB6 the driver is using BIOS settings and not programming DMA/PIO timings
itself. However the logic was completely broken and resulted in wrong timings
being silently allowed (instead of being corrected by the driver).
This bug would explain some data corruption/timeout issues with Serverworks
MegaIDE in RAID mode that Alan Cox has fixed recently with:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=2074a106f52b6371885afbd714e929d60d0e3f64
For 2.6.23 we may be better off with completely switching the driver to always
programming timings (libata pata_serverworks.c driver is doing things this way
and there were no problems reported so far) but for 2.6.22 lets fix the bug
in the simplest and the least intrusive way.
Remove crappy code noticed by Linus, see
http://lkml.org/lkml/2007/5/23/476
for details.
While at it simplify logic a bit.
There should be no functionality changes caused by this patch.
gcc-4.3:
drivers/ide/pci/serverworks.c: In function 'svwks_tune_chipset':
drivers/ide/pci/serverworks.c:176: warning: overflow in implicit constant conversion
drivers/ide/pci/serverworks.c:190: warning: overflow in implicit constant conversion
drivers/ide/pci/serverworks.c:211: warning: overflow in implicit constant conversion
drivers/ide/pci/serverworks.c:212: warning: overflow in implicit constant conversion
It turns out from customer reports to Red Hat and some PCI dumps that the
MegaIDE in RAID mode doesn't provide the drive tuning data that the
serverworks driver expects but sometimes does provide something that
fools the code.
For the RAID class case skip the oem setup and don't trust the BIOS data.
We then tune from scratch and this sorts it out. (This has been confirmed
on an afflicted IBM blade)
[libata serverworks.c never trusts the BIOS in the first place so is
accidentally immune]
Signed-off-by: Alan Cox <alan@redhat.com>
Add the IDE device ID to atiixp_pci_tbl struct in atiixp.c for ATI SB700.
Signed-off-by: Luugi Marsan <luugi.marsan@amd.com>
Not sure how this one got missed in the great purge some time ago but it did.
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
* check ->speedproc return value in ide_tune_dma()
* use ide_tune_dma() in cmd64x/cs5530/sc1200/siimage/sl82c105/scc_pata drivers
* remove no longer needed ide_dma_enable()
Add the speedproc() method for setting transfer modes, modify config_for_dma()
to call it and use ide_max_dma_mode() to select the best DMA mode.
Add support for the multiword DMA modes 0 and 1, using the upper half of the
'drive_data' field to store the DMA timings to program into the drive control
register when DMA is turned on for real.
* add {cs5530,sc1200}_tunepio() for programming PIO timings
* add {cs5530,sc1200}_tune_chipset() (->speedproc method) for setting
transfer mode and convert {cs5530,sc1200}_config_dma() to use it
* bump driver version
sc1200.c:
* remove open-coded variant of ide_dma_host_off() (== ->dma_host_off),
it is not needed because ->dma_off_quietly calls ->dma_host_off
* use ->dma_host_on (== ide_dma_host_on() for this driver) instead of
open-coded variant, call it from the users of sc1200_config_dma2()
[ there is no need to call ->dma_host_on in sc1200_config_dma() because
core code takes care of calling ->ide_dma_on on successful execution
of ->ide_dma_check ]
* add comment about ->tuneproc interface abuse
cs5530.c/sc1200.c:
* core code takes care of calling ->dma_off_quietly before calling
->ide_dma_check so there is no need to call it in ->ide_dma_check methods
Use ide_tune_dma() in ide-cris/it821x/pdc202xx_old/serverworks drivers.
CS5530/SC1200 specifies that two drives on the same cable cannot mix
UDMA/MDMA. Add {cs5530,sc1200}_udma_filter() to handle this. This also
makes it possible to remove open-coded best DMA mode selection and use
standard ide_use_dma()/ide_max_dma_mode() helpers. While at it bump
version numbers.
* remove code enabling IORDY and prefetch from config_chipset_for_dma(),
as the comment states it has no real effect because these settings are
overriden when the PIO mode is set (and for this driver ->autotune == 1
so PIO mode is always programmed)
* use ide_tune_dma() in pdcnew_config_drive_xfer_rate() and remove no longer
needed config_chipset_for_dma()
Use ide_tune_dma() in ali15x3_config_drive_for_dma() and remove all the open
coded DMA tuning code and also config_chipset_for_dma(). Set ->atapi_dma flag
correctly in init_hwif_common_ali15x3() so ide_tune_dma() can take care of
checking if ATAPI DMA is allowed and remove open coded ATAPI DMA check from
ali15x3_config_drive_for_dma().
* limit max PIO mode to PIO4, this driver doesn't support PIO5 and attempt
to program PIO5 by config_art_rwp_pio() could result in incorrect PIO
timings being programmed and possibly the data corruption (for < ATA100
family chipsets PIO0 timings were used, for ATA100 and ATA100a - the random
content of test1 variable was used, for ATA133 - MWDMA0 timings were used)
* BUG() in sis5513_tune_chipset() if somebody tries to force unsupported PIO5,
also cleanup this function a bit while at it
* add comment about PIO0 timings for < ATA100 family chipsets
* remove open-coded best PIO mode selection from config_art_rwp_pio(),
it contained numerous bugs:
- it didn't check for validity of id->eide_pio_modes and id->eide_pio_iordy
before using them
- it tried to found out maximum PIO mode basing on minimum IORDY cycle time
(moreover wrong cycle times were used for PIO1/5)
- it was overriding PIO blacklist and conservative PIO "downgrade" done
by ide_get_best_pio_mode()
* use sis5513_tune_drive() instead of config_art_rwp_pio()
in sis5513_config_xfer_rate() so the correct PIO mode is also set
on drive even if the device is not IORDY/DMA capable
* config_art_rwp_pio() was always setting the best possible mode and not
the wanted one - fix it and move ide_get_best_pio_mode() call to
config_chipset_for_pio()
* don't use ide_find_best_mode() in config_chipset_for_pio(), it was being
overriden by config_art_rwp_pio() for the host timings anyway + we need to
set the same PIO mode on the device and the host
* pass correct "pio" argument (255 instead of 5) to sis5513_tune_drive() call
in sis5513_config_xfer_rate() so the best PIO mode is set on the drive
and not PIO4
* rename sis5513_tune_drive() to sis5513_tuneproc()
and config_chipset_for_pio() to sis5513_tune_driver()
to program PIO5 by svwks_tune_chipset() could result in incorrect PIO
timings being programmed and possibly the data corruption (it seems that
the minimum possible values were used but I lack the datasheets to be sure)
* select best PIO mode in svwks_tune_drive() and not in svwks_tune_chipset()
when doing PIO autotuning (pio == 255)
* don't try to tune PIO in config_chipset_for_dma() as ide_dma_enable() could
return 1 if DMA was previously enabled (svwks_config_drive_xfer_rate()
takes care of PIO tuning if no suitable DMA mode is found)
* remove config_chipset_for_pio() and use svwks_tune_drive() instead,
config_chipset_for_pio() contained numerous bugs when selecting PIO mode
(luckily it was only used for devices limited to PIO by capabilities/BIOS):
before using them
(moreover wrong cycle times were used for PIO0/1/5)
- if the max drive PIO was PIO5 then XFER_PIO_0/XFER_PIO_SLOW was selected
(XFER_PIO_SLOW is not supported by svwks_tune_chipset() so the result
was the same as if using XFER_PIO_5 => wrong PIO timings were set)
- it was overriding drive->current_speed
This patch is based on the documentation (I would like to thank Promise
for it) and also partially on the older vendor driver.
Rewrite mode programming code:
* disable 66MHz clock in pdc202xx_tune_chipset() so it is correctly disabled
even if both devices on the channel are not DMA capable and after reset
* enable/disable IORDY and PREFETCH bits in pdc202xx_tune_chipset()
as they need to be setup correctly also for PIO only devices, plus IORDY
wasn't disabled for non-IORDY devices and PREFETCH wasn't disabled for
ATAPI devices
* remove dead code for setting SYNC_ERDDY_EN bits from config_chipset_for_dma()
(driver sets ->autotune to 1 so PIO modes are always programmed => lower
nibble of register A never equals 4 => "chipset_is_set" is always true)
* enable PIO mode programming for all ATAPI devices
(it was limited to ->media == ide_cdrom devices)
* remove extra reads of registers A/B/C, don't read register D et all
* do clearing / programming of registers A/B/C in one go
(gets rid of extra PCI config space read/write cycle)
* set initial values of drive_conf/AP/BP/CP variables to zero
(paranoia for the case when PCI reads fail)
* remove XFER_UDMA6 to XFER_UDMA5 remapping case - it can't happen
(ide_rate_filter() takes care of it)
* fix XFER_MW_DMA0 timings (they were overclocked, use the official ones)
* fix bitmasks for clearing bits of register B:
- when programming DMA mode bit 0x10 of register B was cleared which
resulted in overclocked PIO timing setting (iff PIO0 was used)
- when programming PIO mode bits 0x18 weren't cleared so suboptimal
timings were used for PIO1-4 if PIO0 was previously set (bit 0x10)
and for PIO0/3/4 if PIO1/2 was previously set (bit 0x08)
* add FIXME comment about missing locking for 66MHz clock register
Also while at it:
* remove unused defines
* do a few cosmetic / CodingStyle fixes
v2:
* in pdc202xx_tune_chipset() the old content of drive configuration
registers is used only by the debugging code so cover "drive_conf"
PCI registers read by #if PDC202XX_DEBUG_DRIVE_INFO
(Noticed by Sergei Shtylyov)
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: fix PIO setup on resume for ATAPI devices
ide: legacy PCI bus order probing fixes
ide: add ide_proc_register_port()
ide: add "initializing" argument to ide_register_hw()
ide: cable detection fixes (take 2)
ide: move IDE settings handling to ide-proc.c
ide: split off ioctl handling from IDE settings (v2)
ide: make /proc/ide/ optional
ide: add ide_tune_dma() helper
ide: rework the code for selecting the best DMA transfer mode (v3)
ide: fix UDMA/MWDMA/SWDMA masks (v3)
* create_proc_ide_interfaces() tries to add /proc entries for every probed
and initialized IDE port, replace it by ide_proc_register_port() which does
it only for the given port (also rename destroy_proc_ide_interface() to
ide_proc_unregister_port() for consistency)
* convert {create,destroy}_proc_ide_interface[s]() users to use new functions
* pmac driver depended on proc_ide_create() to add /proc port entries, fix it
* au1xxx-ide, swarm and cs5520 drivers depended indirectly on ide-generic
driver (CONFIG_IDE_GENERIC=y) to add port /proc entries, fix them
* there is now no need to add /proc entries for IDE ports in proc_ide_create()
so don't do it
* proc_ide_create() needs now to be called before drivers are probed - fix it,
while at it make proc_ide_create() create /proc "ide" directory
Add "initializing" argument to ide_register_hw() and use it instead of ide.c
wide variable of the same name. Update all users of ide_register_hw()
accordingly.
Tejun's recent eighty_ninty_three() fix has inspired me to do more thorough
review of the cable detection code...
* print user-friendly warning about limiting the maximum transfer speed
to UDMA33 (and the reason behind it) when 80-wire cable is not detected,
also while at it cleanup eighty_ninty_three() a bit
* use eighty_ninty_three() in ide_ata66_check(), this actually fixes 3 bugs:
- bit 14 (word 93 validity check) == 1 && bit 13 (80-wire cable test) == 1
were used as 80-wire cable present test for CONFIG_IDEDMA_IVB=n case
(please see FIXME comment in eighty_ninty_three() for more details)
- CONFIG_IDEDMA_IVB=y/n cases were interchanged
- check for SATA devices was missing
* remove private cable warnings from pdc_202xx{old,new} drivers now that core
code provides this functionality (plus, in pdc202xx_new case the test could
give false warnings for ATAPI devices because pdc202xx_new driver doesn't
even support ATAPI DMA)
All important information/features should be already available through
sysfs and ioctl interfaces.
Add CONFIG_IDE_PROC_FS (CONFIG_SCSI_PROC_FS rip-off) config option,
disabling it makes IDE driver ~5 kB smaller (on x86-32).
While at it add CONFIG_PROC_FS=n versions of proc_ide_{create,destroy}()
and remove no longer needed #ifdefs.
After reworking the code responsible for selecting the best DMA
transfer mode it is now possible to add generic ide_tune_dma() helper.
Convert some IDE PCI host drivers to use it (the ones left need more work).
Depends on the "ide: fix UDMA/MWDMA/SWDMA masks" patch.
* add ide_hwif_t.udma_filter hook for filtering UDMA mask
(use it in alim15x3, hpt366, siimage and serverworks drivers)
* add ide_max_dma_mode() for finding best DMA mode for the device
(loosely based on some older libata-core.c code)
* convert ide_dma_speed() users to use ide_max_dma_mode()
* make ide_rate_filter() take "ide_drive_t *drive" as an argument instead
of "u8 mode" and teach it to how to use UDMA mask to do filtering
* use ide_rate_filter() in hpt366 driver
* remove no longer needed ide_dma_speed() and *_ratemask()
* unexport eighty_ninty_three()
v2:
* rename ->filter_udma_mask to ->udma_filter
[ Suggested by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ]
v3:
* updated for scc_pata driver (fixes XFER_UDMA_6 filtering for user-space
originated transfer mode change requests when 100MHz clock is used)
* use 0x00 instead of 0x80 to disable ->{ultra,mwdma,swdma}_mask
* add udma_mask field to ide_pci_device_t and use it to initialize
->ultra_mask in aec62xx, cmd64x, pdc202xx_{new,old} and piix drivers
* fix UDMA masks to match with chipset specific *_ratemask()
(alim15x3, hpt366, serverworks and siimage drivers need UDMA mask
filtering method - done in the next patch)
v2:
* piix: fix cable detection for 82801AA_1 and 82372FB_1
[ Noticed by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ]
* cmd64x: use hwif->cds->udma_mask
* aec62xx: fix newly introduced bug - check DMA status not command register
v3:
* piix: use hwif->cds->udma_mask
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
for consistency with other Open Firmware interfaces (and Sparc).
This is just a straight replacement.
This leaves the compatibility define in place.
HPT36x chip don't seem to have the channel enable bits, so prevent the IDE core
from checking them...
Cc: Michal Kepien <michal.kepien@poczta.onet.pl>
This driver doesn't support SWDMA so use the correct ->swdma_mask.
While at it:
* no need to call config_chipset_for_pio() in config_chipset_for_dma(),
if DMA is not available config_chipset_for_pio() will be called
by siimage_config_drive_for_dma() and if DMA is available
config_siimage_chipset_for_pio() will be called by siimage_tune_chipset()
* remove needless config_chipset_for_pio() wrapper
to setup PIO5 by it821x_tuneproc() could result in incorrect PIO timings
+ incorrect base clock being set for controller in the passthrough mode
* move code limiting max PIO according to the pair device capabilities from
config_it821x_chipset_for_pio() to it821x_tuneproc() so the check is also
applied for mode change requests coming through ->tuneproc and ->speedproc
interfaces
* set device speed in it821x_tuneproc()
* in it821x_tune_chipset() call it821x_tuneproc() also if the controller is
in the smart mode (so the check for pair device max PIO is done)
* rename it821x_tuneproc() to it821x_tune_pio(), then add it821x_tuneproc()
wrapper which does the max PIO mode check; it worked by the pure luck
previously, pio[4] and pio_want[4] arrays were used with index == 255
so random PIO timings and base clock were set for the controller in the
passthrough mode, thankfully PIO timings and base clock were corrected
later by config_it821x_chipset_for_pio() call (but it was not called for
PIO-only devices during resume and for user requested PIO autotuning)
* remove config_it821x_chipset_for_pio() call from config_chipset_for_dma()
as the driver sets ->autotune to 1 and ->tuneproc does the proper job now
* convert the last user of config_it821x_chipset_for_pio() to use
it821x_tuneproc(drive, 255) and remove no longer needed function
While at it:
* fix few comments
There is no reason to limit DMA to ide_cdrom type devices.
If DMA tuning fails always set the best PIO mode.
Teach the driver's tuneproc() method to do PIO auto-runing properly since it
treated 5 instead of 255 as auto-tune request, and also passed the mode limit
of PIO5 to ide_get_best_pio_mode() despite supporting up to PIO4 only.
While at it, also:
- remove the driver's wrong claim about supporting SWDMA modes;
- stop hooking ide_dma_timeout() method as the handler clearly doesn't fit for
the task...
Fold the parts of the ide_dma_end() methods identical to __ide_dma_end() into a
mere call to it.
Start using faster versions of the ide_dma_end() and ide_dma_test_irq() methods
for the PCI0646U and newer chips that have the duplicate interrupt status bits
in the I/O mapped MRDMODE register, determing what methods to use at the driver
load time. Do some cleanup/renaming in the "old" ide_dma_test_irq() method too.
Fix several issues with the driver's procfs output:
- when testing if channel is enabled, the code looks at the "simplex" bits, not
at the real enable bits -- add #define for the primary channel enable bit;
- UltraDMA modes 0, 1, 3 for slave drive reported incorrectly due to using the
master drive's clock cycle resolution bit.
While at it, also perform the following cleanups:
- don't print extra newline before the first controller's dump;
- correct the chipset names (from CMDxxx to PCI-xxx)
- don't read from the registers which aren't used for dump;
- better align the table column sizes;
- rework UltraDMA mode dump code;
- remove PIO mode dump code that has never been finished;
- remove the duplicate interrupt status (the MRDMODE register bits mirror those
those in the CFR and ARTTIM23 registers) and fold the dump into single line;
- correct the style of the ?: operators...
The IDE core looks at the wrong bit when checking if the secondary channel is
enabled on PCI0646 -- CNTRL register bit 7 is read-ahead disable, bit 3 is the
correct one.
Starting with PCI0646U chip, the primary channel can also be enabled/disabled --
so, add 'enablebits' initializers to each 'ide_pci_device_t' structure, handling
the original PCI0646 via adding the init_setup() method and clearing the 'reg'
field there if necessary...
The driver's ide_dma_test_irq() method was reading the MRDMODE register even on
PCI0643/6 where it was write-only -- fix this by always reading the "backward-
compatible" interrupt bits, renaming dma_alt_stat to irq_stat as the interrupt
status bits are not coupled to DMA.
In addition, wrong interrupt bit was tested/cleared for the primary channel --
it's bit 2 in all the chip specs and the driver used bit 1... :-/
Fix the multiword DMA and drop the single-word DMA support (which nobody will
miss, I think). In order to do it, a number of changes was necessary:
- rename program_drive_counts() to program_cycle_times(), pass to it cycle's
total/active times instead of the clock counts, and convert them into the
active/recovery clocks there instead of cmd64x_tune_pio() -- this causes
quantize_timing() to also move;
- contrarywise, move all the code handling the address setup timing into
cmd64x_tune_pio(), so that setting MWDMA mode wouldn't change address setup;
- remove from the speedproc() method the bogus code pretending to set the DMA
timings by twiddling bits in the BMIDE status register, handle setting MWDMA
by just calling program_cycle_times(); while at it, improve the style of that
whole switch statement;
- stop fiddling with the DMA capable bits in the speedproc() method -- they do
not enable DMA, and are properly dealt with by the dma_host_{on,off} methods;
- don't set hwif->swdma_mask in the init_hwif() method anymore.
In addition to those changes, do the following:
- in cmd64x_tune_pio(), when writing to ARTTIM23 register preserve the interrupt
status bit, eliminate local_irq_{save|restore}() around this code as there's
*no* actual race with the interrupt handler, and move cmdprintk() to a more
fitting place -- after ide_get_best_pio_mode() call;
- make {arttim|drwtim}_regs arrays single-dimensional, indexed with drive->dn;
- rename {setup|recovery}_counts[] into more fitting {setup|recovery}_values[];
- in the speedproc() method, get rid of the duplicate reads/writes from/to the
UDIDETCRx registers and of the extra variable used to store the transfer mode
value after filtering, use another method of determining master/slave drive,
and cleanup useless parens;
- beautify cmdprintk() output here and there.
While at it, remove meaningless comment about the driver being used only on
UltraSPARC and long non-relevant RCS tag. :-)
Fold the now equivalent code in the ide_dma_check() method into a mere call to
ide_use_dma(). Make config_for_dma() return non-zero if DMA mode has been set
and call it from the ide_dma_check() method instead of ide_dma_on().
Defer writing the DMA timings to the chip registers until DMA is really turned
on (and do not enable IORDY for DMA).
Remove unneeded code from the init_hwif() method, improve its overall looks.
Rename the dma_start(), ide_dma_check(), and ide_dma_lostirq() methods, and
also use more proper hwif->dma_command, fix printk() and comment in the latter
one as well. While at it, cleanup style in several places.
