path: root/drivers/ide/pci/sl82c105.c
2007-01-27ide: add missing __init tags to IDE PCI host driversBartlomiej Zolnierkiewicz
also change __devinit tag for sgiioc4.c:ioc4_ide_init() to __init Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2006-12-08[PATCH] sl82c105: straighten up IDE control/status register cachingSergei Shtylyov
Straighten up the IDE control/status register caching -- you *really* can't cache the shared register per-channel and hope that it won't get out ouf sync. Set the PIO fallback mode to PIO0 for the slave drive as well as master -- there was no point in having them different (most probably a resutl of typo). Do a bit of reformat and cleanup while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] ide: housekeeping on IDE driversAlan Cox
Move auto arrays to static (const). Clean up using PCI_DEVICE in places, remove unreachable junk and dead code. Fix the serverworks cable detect logic (if ordering is wrong). Backport from libata. Plenty of scope for more cleanup left. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-12[ARM] Ensure sl82c105 IDE interfaces are serialized when using DMARussell King
We don't want to reset the DMA state machine while the other channel is in use. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] Fix broken sl82c105 DMA preventionRussell King
We must _never_ _ever_ on pain of death enable IDE DMA on SL82C105 chipsets where the southbridge revision is <= 5, otherwise data corruption will occur. Strangely this used to work, but something has changed in the upper echelons of the IDE layer to break the hosts decision to deny DMA. Let's make it crystal clear to the IDE layer that we know best. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ide: hotplug mark __devinit sl82c105.cHerbert Xu
From: Herbert Xu <herbert@gondor.apana.org.au> mark the __init section __devinit. Splitted up from the Debian kernel patch. Signed-off-by: maximilian attems <janitor@sternwelten.at> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
