path: root/drivers/ide/pci/cs5535.c
2008-04-26ide: add struct ide_port_ops (take 2)Bartlomiej Zolnierkiewicz
* Move hooks for port/host specific methods from ide_hwif_t to 'struct ide_port_ops'. * Add 'const struct ide_port_ops *port_ops' to 'struct ide_port_info' and ide_hwif_t. * Update host drivers and core code accordingly. While at it: * Rename ata66_*() cable detect functions to *_cable_detect() to match the standard naming. (Suggested by Sergei Shtylyov) v2: * Fix build for bast-ide. (Noticed by Andrew Morton) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: IDE_HFLAG_BOOTABLE -> IDE_HFLAG_NON_BOOTABLEBartlomiej Zolnierkiewicz
"bootable" should be the default behavior so replace IDE_HFLAG_BOOTABLE host flag with IDE_HFLAG_NON_BOOTABLE. There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: add ->cable_detect method to ide_hwif_tBartlomiej Zolnierkiewicz
* Add ->cable_detect method to ide_hwif_t. * Call the new method in ide_init_port() if: - the host supports UDMA modes > UDMA2 ('hwif->ultra_mask & 78') - DMA initialization was successful (if hwif->dma_base is not set ide_init_port() sets hwif->ultra_mask to zero) - "idex=ata66" is not used ('hwif->cbl != ATA_CBL_PATA40_SHORT') * Convert PCI host drivers to use ->cable_detect method. While at it: * Factor out cable detection to separate functions (if not already done). * hpt366.c/it8213.c/slc90e66.c: - don't check cable type if "idex=ata66" is used * pdc202xx_new.c: - add __devinit tag to pdcnew_cable_detect() * pdc202xx_old.c: - rename pdc202xx_old_cable_detect() to pdc2026x_old_cable_detect() - add __devinit tag to pdc2026x_old_cable_detect() Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02atiixp/cs5535/scc_pata: fix "idex=ata66" parameter handlingBartlomiej Zolnierkiewicz
Don't override the cable type if the "idex=ata66" parameter was used. While at it: * atiixp.c: factor out cable detection to atiixp_cable_detect() from init_hwif_atiixp(). * cs5535.c: pass 'ide_hwif_t *hwif' instead of 'struct pci_dev *dev' to cs5535_cable_detect(). * scc_pata.c: factor out cable detection to scc_cable_detect() from init_hwif_scc() and remove incorrect comment. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: keep pointer to struct device instead of struct pci_dev in ide_hwif_tBartlomiej Zolnierkiewicz
Keep pointer to struct device instead of struct pci_dev in ide_hwif_t. While on it: * Use *dev->dma_mask instead of pci_dev->dma_mask in ide_toggle_bounce(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add IDE_HFLAG_ABUSE_SET_DMA_MODE host flagBartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_SET_DMA_MODE host flag and use it to decide what to do with transfer modes < XFER_PIO_0 in ide_set_xfer_rate(). * Set IDE_HFLAG_ABUSE_SET_DMA_MODE in host drivers that need it (aec62xx, amd74xx, cs5520, cs5535, hpt34x, hpt366, pdc202xx_old, serverworks, tc86c001 and via82cxxx) and cleanup ->set_dma_mode methods in host drivers that don't (IDE core code guarantees that ->set_dma_mode will be called only for modes which are present in SWDMA/MWDMA/UDMA masks). While at it: * Add IDE_HFLAGS_HPT34X/HPT3XX/PDC202XX/SVWKS define in hpt34x/hpt366/pdc202xx_old/serverworks host driver. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-12-24drivers/ide/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Andrew Morton <akpm@linux-foundation.org>, Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-20ide: constify struct ide_port_infoBartlomiej Zolnierkiewicz
2007-10-20ide: replace ide_pci_device_t by struct ide_port_infoBartlomiej Zolnierkiewicz
* Rename struct ide_pci_device_s to struct ide_port_info. * Remove ide_pci_device_t typedef. While at it: * Fix __ide_pci_register_driver() comment. * Fix aec62xx_init_one() comment. * Remove unused 'cds' field from ide_hwgroup_t. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: set drive->autotune in ide_pci_setup_ports()Bartlomiej Zolnierkiewicz
Majority of host drivers using IDE PCI layer set drive->autotune, the only exceptions are: generic.c ns87415.c rz1000.c trm290.c * no ->set_pio_mode method it821x.c: * if memory allocation fails drive->autotune won't be set (but there also won't be ->set_pio_mode method in such case) piix.c: * MPIIX controller (no ->init_hwif method so also no ->set_pio_mode method) However if there is no ->set_pio_mode method there are no changes in behavior w.r.t. PIO tuning so always set drive->autotune in ide_pci_setup_ports(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add ->mwdma_mask and ->swdma_mask to ide_pci_device_t (take 2)Bartlomiej Zolnierkiewicz
* Add ->mwdma_mask and ->swdma_mask to ide_pci_device_t. * Set ide_hwif_t DMA masks using DMA masks from ide_pci_device_t in setup-pci.c::ide_pci_setup_ports() (iff DMA base is valid and ->init_hwif method may still override them). * Convert IDE PCI host drivers to use ide_pci_device_t DMA masks. While at it: * Use ATA_{UDMA,MWDMA,SWDMA}* defines. * hpt34x.c: add separate ide_pci_device_t instances for HPT343 and HPT345. * serverworks.c: fix DMA masks being set before checking DMA base. v2: * Add missing masks to DECLARE_GENERIC_PCI_DEV() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_{DMA,AUTODMA} host flagsBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_{DMA,AUTODMA} host flags. Convert all host drivers using ide_pci_device_t to use these flags instead of d->autodma and then remove no longer needed d->autodma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_BOOTABLE host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_BOOTABLE host flag and IDE_HFLAG_OFF_BOARD define. Convert all host drivers using ide_pci_device_t to use IDE_HFLAG_{BOOTABLE,OFF_BOARD} instead of d->bootable and then remove no longer needed d->bootable. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: add IDE_HFLAG_NO_ATAPI_DMA host flagBartlomiej Zolnierkiewicz
Add IDE_HFLAG_NO_ATAPI_DMA host flag and set it in host drivers which don't support ATAPI DMA. Then remove no longer needed hwif->atapi_dma. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-19ide: Fix cs5535 driver accessing beyond array boundaryBenjamin Herrenschmidt
The cs5535 uses an incorrect construct to access the other drive of a pair, causing it to access beyond an array boundary on the secondary interface. This fixes it by using the new ide_get_paired_drive() helper instead. Bart: patch description fixes Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@osdl.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove hwif->autodma and drive->autodmaBartlomiej Zolnierkiewicz
* hpt34x.c: disable DMA masks for HPT345 (hwif->autodma is zero so DMA won't be enabled anyway). * trm290.c: disable IDE_HFLAG_TRUST_BIOS_FOR_DMA flag (hwif->autodma is zero so DMA won't be enabled anyway). * Check noautodma global variable instead of drive->autodma in ide_tune_dma(). This fixes handling of "ide=nodma" kernel parameter for icside, ide-cris, au1xxx-ide, pmac, it821x, jmicron, sgiioc4 and siimage host drivers. * Remove hwif->autodma (it was not checked by IDE core code anyway) and drive->autodma (was set by all host drivers - except HPT345/TRM290 special cases - unless "ide=nodma" was used). While at it: - remove needless printk() from icside.c - remove stale FIXME/comment from ide-probe.c - don't force DMA off if PCI bus-mastering had to be enabled in setup-pci.c (this setting was always later over-ridden by host drivers anyway) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: use PCI_VDEVICE() macroBartlomiej Zolnierkiewicz
While at it: - make struct pci_device_id tables const - use PCI_DEVICE_ID_ITE_8213 define in it8213.c - fix comment in generic.c Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove ->ide_dma_check (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_TRUST_BIOS_FOR_DMA host flag for host drivers that depend on BIOS for programming device/controller for DMA. Set it in cy82c693, generic, ns87415, opti621 and trm290 host drivers. * Add IDE_HFLAG_VDMA host flag for host drivers using VDMA. Set it in cs5520 host driver. * Teach ide_tune_dma() about IDE_HFLAG_TRUST_BIOS_FOR_DMA flag. * Add generic ide_dma_check() helper and remove all open coded ->ide_dma_check implementations. Fix all places checking for presence of ->ide_dma_check hook to check for ->ide_dma_on instead. * Remove no longer needed code from config_drive_for_dma(). * Make ide_tune_dma() static. v2: * Fix config_drive_for_dma() return values. * Fix ide-dma.c build for CONFIG_BLK_DEV_IDEDMA_PCI=n by adding dummy config_drive_for_dma() inline. * Fix IDE_HFLAG_TRUST_BIOS_FOR_DMA handling in ide_dma_check(). * Fix init_hwif_it8213() comment. There should be no functionality changes caused by this patch. Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove ide_use_fast_pio()Bartlomiej Zolnierkiewicz
Remove ide_use_fast_pio() and just re-tune PIO unconditionally if DMA tuning has failed in ->ide_dma_check. All host drivers using ide_use_fast_pio() set drive->autotune so PIO is always tuned anyway and in some cases we _really_ need to re-tune PIO because PIO and DMA timings are shared. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-16ide: remove drive->init_speed zeroingBartlomiej Zolnierkiewicz
Several host drivers used to reset drive->init_speed in their ->ide_dma_check implementations which resulted in incorrect init speed being reported to the user, fix it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-13cs5535: add missing ->dma_base checkBartlomiej Zolnierkiewicz
If ->dma_base is not set (== PCI BAR4 cannot be reserved) then DMA hooks shouldn't be initialized or bad things will happen. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-13ide: move ide_config_drive_speed() calls to upper layers (take 2)Bartlomiej Zolnierkiewicz
* Convert {ide_hwif_t,ide_pci_device_t}->host_flag to be u16. * Add IDE_HFLAG_POST_SET_MODE host flag to indicate the need to program the host for the transfer mode after programming the device. Set it in au1xxx-ide, amd74xx, cs5530, cs5535, pdc202xx_new, sc1200, pmac and via82cxxx host drivers. * Add IDE_HFLAG_NO_SET_MODE host flag to indicate the need to completely skip programming of host/device for the transfer mode ("smart" hosts). Set it in it821x host driver and check it in ide_tune_dma(). * Add ide_set_pio_mode()/ide_set_dma_mode() helpers and convert all direct ->set_pio_mode/->speedproc users to use these helpers. * Move ide_config_drive_speed() calls from ->set_pio_mode/->speedproc methods to callers. * Rename ->speedproc method to ->set_dma_mode, make it void and update all implementations accordingly. * Update ide_set_xfer_rate() comments. * Unexport ide_config_drive_speed(). v2: * Fix issues noticed by Sergei: - export ide_set_dma_mode() instead of moving ->set_pio_mode abuse wrt to setting DMA modes from sc1200_set_pio_mode() to do_special() - check IDE_HFLAG_NO_SET_MODE in ide_tune_dma() - check for (hwif->set_pio_mode) == NULL in ide_set_pio_mode() - check for (hwif->set_dma_mode) == NULL in ide_set_dma_mode() - return -1 from ide_set_{pio,dma}_mode() if ->set_{pio,dma}_mode == NULL - don't set ->set_{pio,dma}_mode on it821x in "smart" mode - fix build problem in pmac.c - minor fixes in au1xxx-ide.c/cs5530.c/siimage.c - improve patch description Changes in behavior caused by this patch: - HDIO_SET_PIO_MODE ioctl would now return -ENOSYS for attempts to change PIO mode if it821x controller is in "smart" mode - removal of two debugging printk-s (from cs5530.c and sc1200.c) - transfer modes 0x00-0x07 passed from user space may be programmed twice on the device (not really an issue since 0x00 is not supported correctly by any host driver ATM, 0x01 is not supported at all and 0x02-0x07 are invalid) Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-13cs5535: check ide_config_drive_speed() return valueBartlomiej Zolnierkiewicz
2007-10-11ide: add ide_set{_max}_pio() (take 4)Bartlomiej Zolnierkiewicz
* Add IDE_HFLAG_ABUSE_{PREFETCH,FAST_DEVSEL,DMA_MODES} flags and set them in ht6560, cmd640, cmd64x and sc1200 host drivers. * Add set_pio_mode_abuse() for checking if host driver has a non-standard ->tuneproc() implementation and use it in do_special(). * Add ide_set_pio() for setting PIO mode (it uses hwif->pio_mask to find the maximum PIO mode supported by the host), also add ide_set_max_pio() wrapper for ide_set_pio() to use for auto-tuning. Convert users of ->tuneproc to use ide_set{_max}_pio() where possible. This leaves only do_special(), set_using_pio(), ide_hwif_restore() and ide_set_pio() as a direct users of ->tuneproc. * Remove no longer needed ide_get_best_pio_mode() calls and printk-s reporting PIO mode selected from ->tuneproc implementations. * Rename ->tuneproc hook to ->set_pio_mode and make 'pio' argument const. * Remove stale comment from ide_config_drive_speed(). v2: * Fix "ata_" prefix (Noticed by Jeff). v3: * Minor cleanups/fixups per Sergei's suggestions. v4: * Fix compile problem in drivers/ide/pci/cmd640.c (Noticed by Andrew Morton). * Improve some ->set_pio_mode comments. Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11ide: move ide_rate_filter() calls to the upper layer (take 2)Bartlomiej Zolnierkiewicz
* Move ide_rate_filter() calls from host drivers to IDE core. * Make ide_rate_filter() static. * Make 'speed' argument of ->speedproc const. v2: * Fix it8213_tune_chipset() comment. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01cs5535: PIO fixesBartlomiej Zolnierkiewicz
* Fix cs5535_tuneproc() to pass PIO transfer mode value instead of PIO mode number to cs5535_set_speed() (fixes random PIO timings being programmed and a possible OOPS). Do a little cleanup while at it. * Fix cs5535_set_speed() to check if the mate device is present (fixes PIO0 taskfile timings being used if there is no other device on the cable). * Use cs5535_tuneproc() in cs5535_dma_check(). The old code had the same issue as cs5535_tuneproc() and add additionally caused 0x00-0x04 transfer mode values (== default PIO, default PIO w/ IORDY + two invalid values) being set on the device instead of values 0x08-0x0c (XFER_PIO_[0,4]). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-08-01ide: Fix an overrun found in the CS5535 IDE driverJordan Crouse
As found by the Coverity checker, and reported by Adrian Bunk, this fixes a overrun error in the CS5535 IDE driver. Somebody got a little excited with the if() statement - the CS5535 only supports UDMA 0-4. Bart: Not a bug per se since the upper layer will never feed this function with speed > XFER_UDMA_4 (thanks to ->ultra_mask being set to 0x1f). Worth fixing anyway. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add PIO masksBartlomiej Zolnierkiewicz
* Add ATA_PIO[0-6] defines to <linux/ata.h>. * Add ->pio_mask field to ide_pci_device_t and ide_hwif_t. * Add PIO masks to host drivers. <linux/ata.h> change ACK-ed by Jeff Garzik <jeff@garzik.org>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: drop "PIO data" argument from ide_get_best_pio_mode()Bartlomiej Zolnierkiewicz
* Drop no longer needed "PIO data" argument from ide_get_best_pio_mode() and convert all users accordingly. * Remove no longer needed ide_pio_data_t. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-20ide: add ide_pci_device_t.host_flags (take 2)Bartlomiej Zolnierkiewicz
* Rename ide_pci_device_t.flags to ide_pci_device_t.host_flags and IDEPCI_FLAG_ISA_PORTS flag to IDE_HFLAG_ISA_PORTS. * Add IDE_HFLAG_SINGLE flag for single channel devices. * Convert core code and all IDE PCI drivers to use IDE_HFLAG_SINGLE and remove no longer needed ide_pci_device_t.channels field. v2: * Fix issues noticed by Sergei: - correct code alignment in scc_pata.c - s/IDE_HFLAG_SINGLE/~IDE_HFLAG_SINGLE/ in serverworks.c Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide: add short cables supportBartlomiej Zolnierkiewicz
This patch allows users to override both host and device side cable detection with "ideX=ata66" kernel parameter. Thanks to this it should be now possible to use UDMA > 2 modes on systems (laptops mainly) which use short 40-pin cable instead of 80-pin one. Next patches add automatic detection of some systems using short cables. Changes: * Rename hwif->udma_four to hwif->cbl and make it u8. * Convert all existing users accordingly (use ATA_CBL_* defines while at it). * Add ATA_CBL_PATA40_SHORT support to ide-iops.c:eighty_ninty_three(). * Use ATA_CBL_PATA40_SHORT for "ideX=ata66" kernel parameter. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Reviewed-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
2007-05-10ide: add ide_tune_dma() helperBartlomiej Zolnierkiewicz
After reworking the code responsible for selecting the best DMA transfer mode it is now possible to add generic ide_tune_dma() helper. Convert some IDE PCI host drivers to use it (the ones left need more work). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: rework the code for selecting the best DMA transfer mode (v3)Bartlomiej Zolnierkiewicz
Depends on the "ide: fix UDMA/MWDMA/SWDMA masks" patch. * add ide_hwif_t.udma_filter hook for filtering UDMA mask (use it in alim15x3, hpt366, siimage and serverworks drivers) * add ide_max_dma_mode() for finding best DMA mode for the device (loosely based on some older libata-core.c code) * convert ide_dma_speed() users to use ide_max_dma_mode() * make ide_rate_filter() take "ide_drive_t *drive" as an argument instead of "u8 mode" and teach it to how to use UDMA mask to do filtering * use ide_rate_filter() in hpt366 driver * remove no longer needed ide_dma_speed() and *_ratemask() * unexport eighty_ninty_three() v2: * rename ->filter_udma_mask to ->udma_filter [ Suggested by Sergei Shtylyov <sshtylyov@ru.mvista.com>. ] v3: * updated for scc_pata driver (fixes XFER_UDMA_6 filtering for user-space originated transfer mode change requests when 100MHz clock is used) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: add ide_set_dma() helper (v2)Bartlomiej Zolnierkiewicz
* add ide_set_dma() helper and make ide_hwif_t.ide_dma_check return -1 when DMA needs to be disabled (== need to call ->ide_dma_off_quietly) 0 when DMA needs to be enabled (== need to call ->ide_dma_on) 1 when DMA setting shouldn't be changed * fix IDE code to use ide_set_dma() instead if using ->ide_dma_check directly v2: * updated for scc_pata Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: disable DMA in ->ide_dma_check for "no IORDY" case (v2)Bartlomiej Zolnierkiewicz
If DMA is unsupported ->ide_dma_check should disable DMA. v2: * updated for scc_pata Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17ide: add ide_use_fast_pio() helper (v3)Bartlomiej Zolnierkiewicz
* add ide_use_fast_pio() helper for use by host drivers * add DMA capability and hwif->autodma checks to ide_use_dma() - au1xxx-ide/it8213/it821x drivers didn't check for (id->capability & 1) [ for the IT8211/2 in SMART mode this check shouldn't be made but since in it821x_fixups() we set DMA bit explicitly: if(strstr(id->model, "Integrated Technology Express")) { /* In raid mode the ident block is slightly buggy We need to set the bits so that the IDE layer knows LBA28. LBA48 and DMA ar valid */ id->capability |= 3; /* LBA28, DMA */ we are better off using generic helper if we can ] - ide-cris driver didn't set ->autodma [ before the patch hwif->autodma was only checked in the chipset specific hwif->ide_dma_check implementations, for ide-cris it is cris_dma_check() function so there no behavior change here ] v2: * updated patch description (thanks to Alan Cox for the feedback) v3: * updated for scc_pata driver Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-09[PATCH] ide: CS5535 driverJaya Kumar
Signed-off-by: Jaya Kumar <jayakumar.ide@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
