path: root/drivers/ide/ide-taskfile.c
2008-04-29ide: use blk_rq_init() to initialize the requestFUJITA Tomonori
This converts ide to use blk_rq_init to initialize the request. This is a preparation for large command support, which needs to initialize the request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-28ide: add ->tf_load and ->tf_read methodsBartlomiej Zolnierkiewicz
* Add ->tf_load and ->tf_read methods to ide_hwif_t and set the default methods in default_hwif_transport(). * Use ->tf_{load,read} instead o calling ide_tf_{load,read}() directly. * Make ide_tf_{load,read}() static. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: move ide_tf_{load,read} to ide-iops.cBartlomiej Zolnierkiewicz
2008-04-28ide: factor out debugging code from ide_tf_load()Bartlomiej Zolnierkiewicz
Factor out debugging code from ide_tf_load() to ide_tf_dump() helper and update ide_tf_load() users accordingly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: merge ->atapi_*put_bytes and ->ata_*put_data methodsBartlomiej Zolnierkiewicz
* Merge ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods into new ->{in,out}put_data methods which take number of bytes to transfer as an argument and always do padding. While at it: * Use 'hwif' or 'drive->hwif' instead of 'HWIF(drive)'. There should be no functional changes caused by this patch (all users of ->ata_{in,out}put_data methods were using multiply-of-4 word counts). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28falconide/q40ide: add ->atapi_*put_bytes and ->ata_*put_data methods (take 2)Bartlomiej Zolnierkiewicz
* Add ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods to falconide and q40ide host drivers (->ata_* methods are implemented on top of ->atapi_* methods so they also do byte-swapping now). * Cleanup atapi_{in,out}put_bytes(). v2: * Add 'struct request *rq' argument to ->ata_{in,out}put_data methods and don't byte-swap disk fs requests (we shouldn't un-swap fs requests because fs itself is stored byte-swapped on the disk) - this is how things were done before the patch (ideally device mapper should be used instead but it would break existing setups and would have some performance impact). Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michael Schmitz <schmitz@debian.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Zidlicky <rz@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27ide: add struct ide_io_ports (take 3)Bartlomiej Zolnierkiewicz
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]` in ide_hwif_t. * Rename io_ports[] in hw_regs_t to io_ports_array[]. * Use un-named union for 'unsigned long io_ports_array[]' and 'struct ide_io_ports io_ports' in hw_regs_t. * Remove IDE_*_OFFSET defines. v2: * scc_pata.c build fix from Stephen Rothwell. v3: * Fix ctl_adrr typo in Sparc-specific part of ns87415.c. (Noticed by Andrew Morton) Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: constify struct ide_dma_opsBartlomiej Zolnierkiewicz
* Export ide_dma_exec_cmd() and __ide_dma_test_irq(). * Constify struct ide_dma_ops. * Always set hwif->dma_ops to &sff_dma_ops in ide_setup_dma() (it is later overriden by ide_init_port() if needed) and drop 'const struct ide_port_info *d' argument. While at it: * Rename __ide_dma_test_irq() to ide_dma_test_irq(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: add struct ide_dma_ops (take 3)Bartlomiej Zolnierkiewicz
Add struct ide_dma_ops and convert core code + drivers to use it. While at it: * Drop "ide_" prefix from ->ide_dma_end and ->ide_dma_test_irq methods. * Drop "ide_" "infixes" from DMA methods. * au1xxx-ide.c: - use auide_dma_{test_irq,end}() directly in auide_dma_timeout() * pdc202xx_old.c: - drop "old_" "infixes" from DMA methods * siimage.c: - add siimage_dma_test_irq() helper - print SATA warning in siimage_init_one() * Remove no longer needed ->init_hwif implementations. v2: * Changes based on review from Sergei: - s/siimage_ide_dma_test_irq/siimage_dma_test_irq/ - s/drive->hwif/hwif/ in idefloppy_pc_intr(). - fix patch description w.r.t. au1xxx-ide changes - fix au1xxx-ide build - fix naming for cmd64*_dma_ops - drop "ide_" and "old_" infixes - s/hpt3xxx_dma_ops/hpt37x_dma_ops/ - s/hpt370x_dma_ops/hpt370_dma_ops/ - use correct DMA ops for HPT302/N, HPT371/N and HPT374 - s/it821x_smart_dma_ops/it821x_pass_through_dma_ops/ v3: * Two bugs slipped in v2 (noticed by Sergei): - use correct DMA ops for HPT374 (for real this time) - handle HPT370/HPT370A properly Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26ide: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ [bart: fix checkpatch.pl errors in ide-lib.c and ppc/mpc8xx.c while at it] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove IDE_*_REG macrosBartlomiej Zolnierkiewicz
* Add IDE_{ALTSTATUS,IREASON,BCOUNTL,BCOUNTH}_OFFSET defines. * Remove IDE_*_REG macros - this results in more readable and slightly smaller code. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-03-18IDE: Make taskfile interface more robust wrt unexpected end-of-commandLinus Torvalds
Now that we handle all the special commands using REQ_TYPE_ATA_TASKFILE rather than using the old REQ_TYPE_ATA_CMD model, we need to also emulate the lack of full taskfile data that comes with the old command model (ie when commands are generated with the HDIO_DRIVE_CMD ioctl rather than using the HDIO_DRIVE_TASK[FILE] ioctls). In particular, this means that we should handle command completion the more relaxed way that the old drive_cmd_intr() code did. It allows commands to finish early even if they don't use up all the data that we thought we had for them. This fixes a regression seen by Anders Eriksson where some SMART commands sent by smartd would cause a boot-time system hang on his machine because the IDE command handling code didn't realize that the command had completed. Tested-by: Anders Eriksson <aeriksson@fastmail.fm> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ide: add ide_read_error() inline helperBartlomiej Zolnierkiewicz
2008-02-06ide: add ide_read_[alt]status() inline helpersBartlomiej Zolnierkiewicz
2008-02-02ide: remove ide_ata66_check()Bartlomiej Zolnierkiewicz
2008-02-02ide: remove set_transfer()Bartlomiej Zolnierkiewicz
2008-02-01ide: update/add my CopyrightsBartlomiej Zolnierkiewicz
The last years stuff and a trip down memory lane... Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide: make wait_drive_not_busy() static againAdrian Bunk
After commit 7267c3377443322588cddaf457cf106839a60463 wait_drive_not_busy() can become static again. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: switch ide_cmd_ioctl() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. Switch set_xfer_rate() to use REQ_TYPE_ATA_TASKFILE requests and make ide_wait_cmd() static. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: convert "empty" REQ_TYPE_ATA_CMD requests to use REQ_TYPE_ATA_TASKFILEBartlomiej Zolnierkiewicz
Based on the previous work by Tejun Heo. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: initialize rq->cmd_type in ide_init_drive_cmd() callersBartlomiej Zolnierkiewicz
* Initialize rq->cmd_type in ide_wait_cmd(), ide_cmd_ioctl() and set_pio_mode() (other callers were aleady over-riding rq->cmd_type). * Remove no longer needed rq->cmd_type setup from ide_init_drive_cmd(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: use wait_drive_not_busy() in drive_cmd_intr() (take 2)Bartlomiej Zolnierkiewicz
Use wait_drive_not_busy() in drive_cmd_intr(). v2: * Fix wait_drive_not_busy() comment (noticed by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: kill DATA_READY defineBartlomiej Zolnierkiewicz
2008-01-26ide: task_end_request() fixTejun Heo
task_end_request() modified to always call ide_end_drive_cmd() for taskfile requests. Previously, ide_end_drive_cmd() was called only when IDE_TFLAG_FLAGGED was set. Also, ide_dma_intr() is modified to use task_end_request(). Enables TASKFILE ioctls to get valid register outputs on successful completion. Bart: - ported it over recent IDE changes Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: use rq->nr_sectors in task_end_request()Bartlomiej Zolnierkiewicz
2008-01-26ide: remove needless ->cursg clearing from task_end_request()Bartlomiej Zolnierkiewicz
2008-01-26ide: set IDE_TFLAG_IN_* flags before queuing/executing commandBartlomiej Zolnierkiewicz
* Add IDE_TFLAG_{HOB,TF,DEVICE} defines. * Set IDE_TFLAG_IN_* flags in {do_rw,ide_no_data,ide_raw}_taskfile() users. * Remove no longer needed ->tf_flags setup from ide_end_drive_cmd(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: fix final status check in task_in_intr()Bartlomiej Zolnierkiewicz
Check for DRQ bit being cleared on the final status check. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: fix ->io_32bit race in ide_taskfile_ioctl()Tejun Heo
In ide_taskfile_ioctl(), there was a race condition involving drive->io_32bit. It was cleared and restored during ioctl requests but there was no synchronization with other requests. So, other requests could execute with the altered ->io_32bit setting or updated drive->io_32bit could be overwritten by ide_taskfile_ioctl(). This patch adds IDE_TFLAG_IO_16BIT flag to indicate to ide_pio_datablock() that 16-bit I/O is needed regardless of drive->io_32bit settting. Bart: - ported it over recent IDE changes Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: remove broken disk byte-swapping supportBartlomiej Zolnierkiewicz
Remove broken disk byte-swapping support: - it can cause a data corruption on SMP (or if using PREEMPT on UP) - all data coming from disk are byte-swapped by taskfile_*_data() which results in incorrect identify data being reported by /proc/ide/ and IOCTLs - "hdx=bswap/byteswap" kernel parameter has been broken on m68k host drivers (including Atari/Q40 ones) since 2.5.x days (because of 'hwif' zero-ing) - byte-swapping is limited to PIO transfers (for working with TiVo disks on x86 machines using user-space solutions or dm-byteswap should result in much better performance because DMA can be used) For previous discussions please see: http://www.ussg.iu.edu/hypermail/linux/kernel/0201.0/0768.html http://lkml.org/lkml/2004/2/28/111 [ I have dm-byteswap device mapper target if somebody is interested (patch is for 2.6.4 though but I'll dust it off if needed). ] Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: add ide_set_irq() inline helperBartlomiej Zolnierkiewicz
2008-01-26ide: dump taskfile HOB registers in ide_tf_load() (if DEBUG is defined)Bartlomiej Zolnierkiewicz
* Dump taskfile HOB registers in ide_tf_load() (if DEBUG is defined). * Remove no longer needed DEBUG code from __ide_do_rw_disk(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide-disk: use do_rw_taskfile() (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_TFLAG_DMA_PIO_FALLBACK taskfile flag to indicate the need to skip loading taskfile registers in do_rw_taskfile(). * Export do_rw_taskfile(). * Convert __ide_do_rw_disk() to use do_rw_taskfile(). * Unexport ide_tf_load(). * Unexport {pre_task_out,task_in}_intr() and make it static. * Remove incorrect comment about do_rw_taskfile() from <linux/ide.h>. There should be no functionality changes caused by this patch. v2: * Add missing blk_fs_request() check to task_dma_ok() (for VDMA). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove 'handler' field from ide_task_t (take 2)Bartlomiej Zolnierkiewicz
* Add IDE_TFLAG_CUSTOM_HANDLER taskfile flag and use it for internal requests which require custom handlers. Check the flag in do_rw_taskfile() and set handler accordingly. * Cleanup ide_init_{specify,restore,setmult}_cmd() and rename it to ide_tf_set_{specify,restore,setmult}_cmd(). * Make {set_geometry,recal,set_multmode}_intr() static. * Remove no longer needed 'handler' field from ide_task_t. v2: * 'handler' in do_rw_taskfile() must be set to NULL initially. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: use ->data_phase to set ->handler in do_rw_taskfile()Bartlomiej Zolnierkiewicz
* Use ->data_phase to set ->handler in do_rw_taskfile() instead of setting ->handler in callers of ide_raw_taskfile()/do_rw_taskfile(). * Unexport task_no_data_intr() and make it static. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: convert do_rw_taskfile() to use ->data_phaseBartlomiej Zolnierkiewicz
* Use task->data_phase in do_rw_taskfile() to decide what to do. * task->prehandler is only used by TASKFILE[_MULTI]_OUT so just use pre_task_out_intr() directly and remove no longer needed 'prehandler' field from ide_task_t. * Remove no longer needed ide_pre_handler_t type. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: merge flagged_taskfile() into do_rw_taskfile()Bartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. task->data_phase == TASKFILE_MULTI_{IN,OUT} vs drive->mult_count == 0 check is needed also for ide_taskfile_ioctl() requests that don't have IDE_TFLAG_FLAGGED taskfile flag set. Cc: Tejun Heo <htejun@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove 'tf_in_flags' field from ide_task_tBartlomiej Zolnierkiewicz
* Add IDE_TFLAG_IN_DATA taskfile flag to indicate the need of reading IDE_DATA_REG in ide_end_drive_cmd(). Set the new flag in ide_taskfile_ioctl() if ->in_flags.b.data is set. * Add IDE_TFLAG_FLAGGED_SET_IN_FLAGS taskfile flag to indicate the need of modifying ->in_flags in ide_taskfile_ioctl(). Set the new flag in flagged_taskfile() and move the code modifying ->tf_in_flags to ide_taskfile_ioctl(). While at it remove the bogus comment: ->tf_in_flags (except .b.data) have no effect on selection of registers to read. * Remove no longer needed 'tf_in_flags' field from ide_task_t. As the result we finally have the internals of HDIO_DRIVE_TASKFILE ioctl separated from the core IDE code. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove 'command_type' field from ide_task_tBartlomiej Zolnierkiewicz
* Add 'data_buf' and 'nsect' variables in ide_taskfile_ioctl() to cache data buffer pointer and number of sectors to transfer (this allows us to have only one ide_diag_taskfile() call). * Add IDE_TFLAG_WRITE taskfile flag and use it to check whether the REQ_RW request flag should be set. * Move ->command_type handling from ide_diag_taskfile() to ide_taskfile_ioctl() and use ->req_cmd instead of ->command_type. * Add 'nsect' parameter to ide_raw_taskfile(). * Merge ide_diag_taskfile() into ide_raw_taskfile(). * Initialize ->data_phase explicitly in idedisk_prepare_flush(), ide_start_power_step() and ide_disk_special(). * Remove no longer needed 'command_type' field from ide_task_t. * Add #ifndef/#endif __KERNEL__ to <linux/hdreg.h> around no longer used by kernel IDE_DRIVE_TASK_* and TASKFILE_* defines. There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: switch ide_task_ioctl() to use REQ_TYPE_ATA_TASKFILE requestsBartlomiej Zolnierkiewicz
2008-01-25ide: remove unnecessary writes to HOB taskfile registersBartlomiej Zolnierkiewicz
* Set taskfile flags for REQ_TYPE_ATA_TASKFILE requests before adding the request to the queue. * Cleanup execute_drive_cmd(). * Remove unnecessary writes to HOB taskfile registers when using LBA48 disk for the following cases: - Power Management requests (WIN_FLUSH_CACHE[_EXT], WIN_STANDBYNOW1, WIN_IDLEIMMEDIATE commands) - special commands (WIN_SPECIFY, WIN_RESTORE, WIN_SETMULT) - Host Protected Area support (WIN_READ_NATIVE_MAX, WIN_SET_MAX) - /proc/ide/ SMART support (WIN_SMART with SMART_ENABLE, SMART_READ_VALUES and SMART_READ_THRESHOLDS subcommands) - write cache enabling/disabling in ide-disk (WIN_SETFEATURES with SETFEATURES_{EN,DIS}_WCACHE) - write cache flushing in ide-disk (WIN_FLUSH_CACHE[_EXT]) - acoustic management in ide-disk (WIN_SETFEATURES with SETFEATURES_{EN,DIS}_AAM) - door (un)locking in ide-disk (WIN_DOORLOCK, WIN_DOORUNLOCK) - /proc/ide/hd?/identify support (WIN_IDENTIFY) - ACPI _GTF taskfiles Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: use ide_tf_load() in execute_drive_cmd()Bartlomiej Zolnierkiewicz
* Add IDE_TFLAG_OUT_DEVICE taskfile flag to indicate the need of writing the Device register and handle it in ide_tf_load(). Update ide_tf_load() and {do_rw,flagged}_taskfile() users accordingly. * Use struct ide_taskfile and ide_tf_load() in execute_drive_cmd(). * Make the debugging code dump all taskfile registers for both REQ_ATA_TYPE_{CMD,TASK} requests and move it to ide_tf_load() so it also covers REQ_ATA_TYPE_TASKFILE requests. There should be no functionality changes caused by this patch (unless DEBUG is defined). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: use do_rw_taskfile() in flagged_taskfile()Bartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. * Move setting IDE_TFLAG_LBA48 taskfile flag from do_rw_taskfile() function to the callers. * Add IDE_TFLAG_FLAGGED taskfile flag for flagged taskfiles coming from ide_taskfile_ioctl(). Check it instead of ->tf_out_flags.all. * Add IDE_TFLAG_OUT_DATA taskfile flag to indicate the need to load IDE data register in ide_tf_load(). * Add IDE_TFLAG_OUT_* taskfile flags to indicate the need to load particular IDE taskfile registers in ide_tf_load(). * Update do_rw_taskfile() and ide_tf_load() users to set respective IDE_TFLAG_OUT_* taksfile flags. * Add task_dma_ok() helper. * Use IDE_TFLAG_FLAGGED taskfile flag to select HIHI mask in ide_tf_load(). * Use do_rw_taskfile() in flagged_taskfile(). * Remove no longer needed 'tf_out_flags' field from ide_task_t. There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add ide_no_data_taskfile() helperBartlomiej Zolnierkiewicz
* Add ide_no_data_taskfile() helper and convert ide_raw_taskfile() w/ NO DATA protocol users to use it instead. * Set ->data_phase explicitly in ide_no_data_taskfile() (TASKFILE_NO_DATA is defined as 0x0000). * Unexport task_no_data_intr(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add ide_tf_load() helperBartlomiej Zolnierkiewicz
Based on the earlier work by Tejun Heo. * Add 'tf_flags' field (for taskfile flags) to ide_task_t. * Add IDE_TFLAG_LBA48 taskfile flag for LBA48 taskfiles. * Add IDE_TFLAG_NO_SELECT_MASK taskfile flag for __ide_do_rw_disk() which doesn't use SELECT_MASK() (looks like a bug but it requires some more investigation). * Split off ide_tf_load() helper from do_rw_taskfile(). * Convert __ide_do_rw_disk() to use ide_tf_load(). There should be no functionality changes caused by this patch. Cc: Tejun Heo <htejun@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: add struct ide_taskfile (take 2)Bartlomiej Zolnierkiewicz
* Don't set write-only ide_task_t.hobRegister[6] and ide_task_t.hobRegister[7] in idedisk_set_max_address_ext(). * Add struct ide_taskfile and use it in ide_task_t instead of tfRegister[] and hobRegister[]. * Remove no longer needed IDE_CONTROL_OFFSET_HOB define. * Add #ifndef/#endif __KERNEL__ around definitions of {task,hob}_struct_t. While at it: * Use ATA_LBA define for LBA bit (0x40) as suggested by Tejun Heo. v2: * Add missing newlines. (Noticed by Sergei) * Use ~ATA_LBA instead of 0xBF. (Noticed by Sergei) * Use unnamed unions for error/feature and status/command. (Suggested by Sergei). There should be no functionality changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-25ide: remove task_ioreg_t typedef (take 2)Bartlomiej Zolnierkiewicz
Remove task_ioreg_t typedef from the kernel code (but leave it in <linux/hdreg.h> for #ifndef/#endif __KERNEL__ case). While at it also move sata_ioreg_t typedef under #ifndef/#endif __KERNEL__. v2: Remove name of the second parameter from ide_execute_command() declaration. (Noticed by Sergei). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-05ide: add missing #ifdef/#endif CONFIG_IDE_TASK_IOCTLBartlomiej Zolnierkiewicz
