path: root/drivers/ide/ide-floppy.c
2006-01-04[PATCH] ide: MODALIAS support for autoloading of ide-cd, ide-disk, ...Kay Sievers
IDE: MODALIAS support for autoloading of ide-cd, ide-disk, ... Add MODULE_ALIAS to IDE midlayer modules: ide-disk, ide-cd, ide-floppy and ide-tape, to autoload these modules depending on the probed media type of the IDE device. It is used by udev and replaces the former agent shell script of the hotplug package, which was required to lookup the media type in the proc filesystem. Using proc was racy, cause the media file is created after the hotplug event is sent out. The module autoloading does not take any effect, until something like the following udev rule is configured: SUBSYSTEM=="ide", ACTION=="add", ENV{MODALIAS}=="?*", RUN+="/sbin/modprobe $env{MODALIAS}" The module ide-scsi will not be autoloaded, cause it requires manual configuration. It can't be, and never was supported for automatic setup in the hotplug package. Adding a MODULE_ALIAS to ide-scsi for all supported media types, would just lead to a default blacklist entry anyway. $ modinfo ide-disk filename: /lib/modules/2.6.15-rc4-g1b0997f5/kernel/drivers/ide/ide-disk.ko description: ATA DISK Driver alias: ide:*m-disk* license: GPL ... $ modprobe -vn ide:m-disk insmod /lib/modules/2.6.15-rc4-g1b0997f5/kernel/drivers/ide/ide-disk.ko $ cat /sys/bus/ide/devices/0.0/modalias ide:m-disk It also adds attributes to the IDE device: $ tree /sys/bus/ide/devices/0.0/ /sys/bus/ide/devices/0.0/ |-- bus -> ../../../../../../../bus/ide |-- drivename |-- media |-- modalias |-- power | |-- state | `-- wakeup `-- uevent $ cat /sys/bus/ide/devices/0.0/{modalias,drivename,media} ide:m-disk hda disk Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-19[PATCH] ide: add missing __init tags to device driversBartlomiej Zolnierkiewicz
Also remove bogus comments for idefloppy_init() and idetape_init(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-18[PATCH] ide: remove ide_driver_t.owner fieldLaurent Riffard
The structure ide_driver_t have a .owner field which is a duplicate of .gendriver.owner field (.gen_driver is a struct device_driver). This patch removes ide_driver_t's owner field. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-10[PATCH] ide-floppy: software eject not working with LS-120 driveOndrej Zary
The problem (eject not working on ATAPI LS-120 drive) is caused by idefloppy_ioctl() function which *first* tries generic_ide_ioctl() and *only* if it fails with -EINVAL, proceeds with the specific ioctls. The generic eject command fails with something other than -EINVAL and the specific one is never executed. This patch fixes it by first going through the internal ioctls and only trying generic_ide_ioctl() if none of them matches. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-07[PATCH] ide: kmalloc + memset -> kzalloc conversionDeepak Saxena
Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] ide-floppy: fix IDEFLOPPY_TICKS_DELAYBartlomiej Zolnierkiewicz
* IDEFLOPPY_TICKS_DELAY assumed HZ == 100, fix it * increase the delay to 50ms (to match comment in the code) Thanks to Manfred Scherer <manfred.scherer.mhm@t-online.de> for reporting the problem and testing the patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-06-23[PATCH] ide-floppy adjustmentsJan Beulich
Fix a build problem when IDEFLOPPY_DEBUG_BUGS is turned off, and eliminate an access to memory that is no longer allocated (causing systems to fail booting when CONFIG_DEBUG_PAGEALLOC is turned on). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-26[PATCH] convert IDE device drivers to driver-modelBartlomiej Zolnierkiewicz
* add ide_bus_match() and export ide_bus_type * split ide_remove_driver_from_hwgroup() out of ide_unregister() * move device cleanup from ide_unregister() to drive_release_dev() * convert ide_driver_t->name to driver->name * convert ide_driver_t->{attach,cleanup} to driver->{probe,remove} * remove ide_driver_t->busy as ide_bus_type->subsys.rwsem protects against concurrent ->{probe,remove} calls * make ide_{un}register_driver() void as it cannot fail now * use driver_{un}register() directly, remove ide_{un}register_driver() * use device_register() instead of ata_attach(), remove ata_attach() * add proc_print_driver() and ide_drivers_show(), remove ide_drivers_op * fix ide_replace_subdriver() and move it to ide-proc.c * remove ide_driver_t->drives, ide_drives and drives_lock * remove ide_driver_t->drivers, drivers and drivers_lock * remove ide_drive_t->driver and DRIVER() macro Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
