path: root/drivers/ide/ide-cd.h
2008-02-01ide: delete filenames/versions from commentsBartlomiej Zolnierkiewicz
Delete filenames/versions from comments. I'm leaving decisions about adding DRV_VERSION defines and MODULE_VERSION()-s to maintainers of the respective drivers. While at it: * Remove unused VERSION define from ide.c. * Remove unused/stale DRV_VERSION define from au1xxx-ide.c. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move the remaining cdrom.c ioctl handling code to ide-cd_ioctl.cBorislav Petkov
There should be no functional changes from this. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move code handling cdrom.c IOCTLs to ide-cd_ioctl.cBartlomiej Zolnierkiewicz
There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move VERBOSE_IDE_CD_ERRORS code to ide-cd_verbose.cBartlomiej Zolnierkiewicz
* Rename ide-cd kernel module to ide-cd_mod in preparation to moving code out from ide-cd.[c,h]. Add MODULE_ALIAS("ide-cd") to preserve compatibility. * Move VERBOSE_IDE_CD_ERRORS code from ide-cd.[c,h] to ide-cd_verbose.c. ide-cd_verbose.c is IDE subsystem independent and may be easily converted into generic library usable by other drivers (i.e. libata) if needed. * Add CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS config option to drivers/ide/Kconfig replacing VERBOSE_IDE_CD_ERRORS define. Make this config option enabled by default and visible only if CONFIG_EMBEDDED is defined. before the patch: text data bss dec hex filename 22841 360 1056 24257 5ec1 drivers/ide/ide-cd.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=y: text data bss dec hex filename 22857 360 1056 24273 5ed1 drivers/ide/ide-cd_mod.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=n: text data bss dec hex filename 15091 360 1056 16507 407b drivers/ide/ide-cd_mod.o Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: coding style fixes for VERBOSE_IDE_CD_ERRORS codeBartlomiej Zolnierkiewicz
* Coding style fixes for VERBOSE_IDE_CD_ERRORS code. * Add KERN_{ERR,CONT} printk() levels where needed. This is a preparation for moving this code out of ide-cd.[c,h]. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove duplicate sense keys definitions from ide-cd.hBartlomiej Zolnierkiewicz
ide-cd.c already uses sense keys definitions from <scsi/scsi.h>. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: re-organize handling of quirky devicesBartlomiej Zolnierkiewicz
Re-organize handling of quirky devices: * Add struct cd_list_entry, ide_cd_quirks_list[] and ide_cd_flags() helper. * Set flags returned by ide_cd_flags() in ide_cdrom_setup(). * Add IDE_CD_FLAG_VERTOS_{300_SDD,600_ESD} and IDE_CD_FLAG_SANYO_3CD flags. * Move device quirks from ide_cdrom_setup() to ide_cd_quirks_list[]. * Rename IDE_CD_FLAG_NEC260 to IDE_CD_FLAG_PRE_ATAPI12 and handle quirky Stingray 8X CD-ROM using ide_cd_quirks_list[]. * Add IDE_CD_FLAG_FULL_CAPS_PAGE flag and handle quirky ACER 50X CD-ROM / WPI 32X CD-ROM using ide_cd_quirk_list[]. * Add IDE_CD_FLAG_PLAY_AUDIO_OK flag and handle quirky MATSHITA DVD-ROMs using ide_cd_quirks_list[]. * Add IDE_CD_FLAG_LE_SPEED_FIELDS flag and handle quirky ACER/AOpen 24X CD-ROM using ide_cd_quirk_list[]. * Fix some comments about quirky devices while at it. There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove STANDARD_ATAPI defineBartlomiej Zolnierkiewicz
Remove STANDARD_ATAPI define + drive-by coding style fixes. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove NO_DOOR_LOCKING defineBartlomiej Zolnierkiewicz
2008-02-01ide-cd: remove struct ide_cd_{config,state}_flagsBartlomiej Zolnierkiewicz
* Remove unused ->{writing,reserved} fields from struct ide_cd_config_flags. * Move ->max_speed from struct ide_cd_config_flags to struct cdrom_info. * Move ->current_speed from struct ide_cd_state_flags to struct cdrom_info. * Add defines for config and state flags. * Add 'unsigned int cd_flags' to struct cdrom_info and use ->cd_flags instead of ->{config,state}_flags. * Remove no longer needed struct ide_cd_{config,state}_flags. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove struct atapi_capabilities_page (take 2)Bartlomiej Zolnierkiewicz
* Remove struct atapi_capabilities_page. * Add ATAPI_CAPABILITIES_PAGE[_PAD]_SIZE define. v2: * The buf[] array access indexes were swapped between 'curspeed'/'maxspeed'. (Noticed by Borislav Petkov). Cc: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: kill CDROM_STATE_FLAGS() macroBartlomiej Zolnierkiewicz
While at it rename 'info' variable to 'cd' in cdrom_saw_media_change(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: kill CDROM_CONFIG_FLAGS() macroBartlomiej Zolnierkiewicz
While at it rename 'info' variable to 'cd' in ide_cdrom_probe_capabilities() and ide_cdrom_setup(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove redundant config flagsBartlomiej Zolnierkiewicz
* Use CDC_* flags directly and remove redundant flags from ->config_flags. While at it: * Add KERN_CONT to printk()-s in ide_cdrom_probe_capabilities(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove struct atapi_{mechstat_header,changer_info,slot}Bartlomiej Zolnierkiewicz
* Remove ->changer_info from struct cdrom_info (it is never allocated). * Remove unused struct atapi_{mechstat_header,changer_info,slot}. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove unused and write-only struct ide_cd_config_flags fieldsBartlomiej Zolnierkiewicz
unused fields: * ->writing * ->reserved write-only fields: * ->playmsf_as_bcd * ->subchan_as_bcd * ->test_write * ->supp_disc_present Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: remove unused struct atapi_cdrom_subchnlBartlomiej Zolnierkiewicz
2008-02-01ide-cd: remove unused defines from ide-cd.hBartlomiej Zolnierkiewicz
2007-12-24ide-cd: fix SAMSUNG CD-ROM SCR-3231 quirkBartlomiej Zolnierkiewicz
cdi->mask is cleared by ide_cdrom_register() which is called after the quirk. Fix it by adding new ->no_speed_select flag to struct ide_cd_config_flags and using it in ide_cdrom_register() to set CDC_SELECT_SPEED flag. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-07-09ide-cd: replace C code with call to ARRAY_SIZE() macroRobert P. J. Day
Delete the unnecessary macro ARY_LEN and use ARRAY_SIZE directly. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-12-15[PATCH] ide-cd: remove write-only cmd field from struct cdrom_infoBartlomiej Zolnierkiewicz
