path: root/drivers/ide/Makefile
2013-09-16ide: Drop H8/300 driverGuenter Roeck
Architecture is gone, so there is no need to keep its ide driver around. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-02-13ARM: at91: drop ide driver in favor of the pata oneJean-Christophe PLAGNIOL-VILLARD
Driver at91_ide is broken and should not be fixed: remove it. Modification of device files that where making use of it. The PATA driver (pata_at91) is able to replace at91_ide. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-03-17ide: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-03-31ide: merge ide_arm and ide_generic host driversBartlomiej Zolnierkiewicz
There is no need for a separate ide_arm host driver nowadays so merge it into ide_generic one. While at it: - return -EBUSY from ide_generic_init() if I/O resources are busy - scale down ide_generic_check_pci_legacy_iobases() for CONFIG_PCI=n Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move error handling code to ide-eh.c (v2)Bartlomiej Zolnierkiewicz
Do some CodingStyle fixups in <linux/ide.h> while at it. v2: Add missing <linux/delay.h> include (reported by Stephen Rothwell). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move standard I/O code to ide-io-std.cBartlomiej Zolnierkiewicz
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move xfer mode tuning code to ide-xfer-mode.cBartlomiej Zolnierkiewicz
* Move xfer mode tuning code to ide-xfer-mode.c. * Add CONFIG_IDE_XFER_MODE config option to be selected by host drivers that support xfer mode tuning. * Add CONFIG_IDE_XFER_MODE=n static inline versions of ide_set_pio() and ide_set_xfer_rate(). * Make IDE_TIMINGS and BLK_DEV_IDEDMA config options select IDE_XFER_MODE, also add explicit selects for few host drivers that need it. * Build/link ide-xfer-mode.o and ide-pio-blacklist.o (it is needed only by ide-xfer-mode.o) only if CONFIG_IDE_XFER_MODE=y. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-24ide: move device settings code to ide-devsets.cBartlomiej Zolnierkiewicz
Remove stale comment from ide.c while at it. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-03-05ide: add at91_ide driverStanislaw Gruszka
This is IDE host driver for AT91 (SAM9, CAP9, AT572D940HF) Static Memory Controller with Compact Flash True IDE Mode logic. Driver have to switch 8/16 bit bus width when accessing Task Tile or Data Register. Moreover some extra things need to be done when setting PIO mode. Only PIO mode is used, hardware have no DMA support. If interrupt line is connected through GPIO extra quirk is needed to cope with fake interrupts. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Andrew Victor <avictor.za@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-02ide: add CS5536 host driver (v3)Bartlomiej Zolnierkiewicz
This is a port of libata's pata_cs5536.c (written by Martin K. Petersen) to IDE subsystem. Changes done while at it: * Reprogram PIO/MWDMA timings if needed before and after DMA transfer (chipset uses shared PIO/MWDMA timings). * Fix cable detection to report 80-wires cable if BIOS set it for any device on a port (IDE core will do drive-side cable detection later). * Don't disable UDMA while programming PIO timings. * Simplify PCI/MSR support. Pros of having IDE host driver in addition to libata's one: * IDE is much lighter than SCSI+libata, the host driver itself is also a bit smaller: text data bss dec hex filename 1261 496 4 1761 6e1 drivers/ata/pata_cs5536.o 1242 128 4 1374 55e drivers/ide/cs5536.o * This allows use of IDE features which are unavailable under libata. v2: * Fixes per review from Sergei: - simplify dependency check in Kconfig - use IDE_DRV_MASK also for ->drive_data - disable UDMA when programming MWDMA - program new DTC timings only when necessary - fix printk() level in cs5536_init_one() * Fix patch description according to comments from Alan and Sergei. v3: * Smarter masking of UDMA bits per Sergei's suggestion. Cc: Martin K. Petersen <mkp@mkp.net> Cc: Karl Auerbach <karl@iwl.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-06Resurrect IT8172 IDE controller driverShane McDonald
Support for the IT8172 IDE controller was removed from the kernel sometime after 2.6.18. Support for the only boards that used the IT8172 was removed from the kernel after 2.6.18, as they had never compiled since 2.6.0. However, there are a couple of platforms that use this chip: the PMC-Sierra Xiao Hu thin-client computer, which is no longer in production, and the Linksys NSS4000 Network Attached Storage box, which is based on the Xiao Hu board. I am attempting to add support for the Xiao Hu to the kernel, and this IT8172 IDE controller is the first bit of code in this effort. This patch resurrects the IT8172 IDE controller code. I began with the 2.6.18 version of the it8172.c file, and have moved it forward so that it works with the latest version of the kernel. I have run this driver on a PMC-Sierra Xiao Hu board with the 2.6.28 kernel, and I have had no problems with it in my configuration. The attached patch applies cleanly against 2.6.28. Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: alan@lxorguk.ukuu.org.uk [bart: s/HWIF(drive)/drive->hwif/] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-01-02ide: move sysfs support to ide-sysfs.cBartlomiej Zolnierkiewicz
While at it: - media_string() -> ide_media_string() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: move legacy ISA/VLB ports handling to ide-legacy.c (v2)Bartlomiej Zolnierkiewicz
* Move legacy ISA/VLB ports handling from ide-probe.c to ide-legacy.c. * Add CONFIG_IDE_LEGACY config option to be selected by host drivers needing ide-legacy.c. v2: Fix CONFIG_IDE_LEGACY not being defined in Kconfig. (from Takashi Iwai <tiwai@suse.de>) There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-12-29ide: move Power Management support to ide-pm.cBartlomiej Zolnierkiewicz
2008-10-23ide: drivers/ide/generic.c -> drivers/ide/ide-pci-generic.cBartlomiej Zolnierkiewicz
Suggested-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-23ide: Add tx4938ide driver (v2)Atsushi Nemoto
This is the driver for the Toshiba TX4938 SoC EBUS controller ATA mode. It has custom set_pio_mode and some hacks for big endian. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: ralf@linux-mips.org Cc: sshtylyov@ru.mvista.com Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-23ide: Add tx4939ide driver (v6)Atsushi Nemoto
This is the driver for the Toshiba TX4939 SoC ATA controller. This controller has standard ATA taskfile registers and DMA command/status registers, but the register layout is swapped on big endian. There are some other endian issue and some special registers which requires many custom dma_ops/tp_ops routines and build_dmatable. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: ralf@linux-mips.org Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21ide: remove useless subdirs from drivers/ide/Bartlomiej Zolnierkiewicz
Suggested-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: add generic ATA/ATAPI disk driverBartlomiej Zolnierkiewicz
* Add struct ide_disk_ops containing protocol specific methods. * Add 'struct ide_disk_ops *' to ide_drive_t. * Convert ide-{disk,floppy} drivers to use struct ide_disk_ops. * Merge ide-{disk,floppy} drivers into generic ide-gd driver. While at it: - ide_disk_init_capacity() -> ide_disk_get_capacity() Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide-floppy: factor out generic disk handling code to ide-gd-floppy.cBartlomiej Zolnierkiewicz
While at it: - idefloppy_do_request() -> ide_floppy_do_request() - idefloppy_end_request() -> ide_floppy_end_request() - idefloppy_setup() -> ide_floppy_setup() There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide-disk: factor out generic disk handling code to ide-gd.cBartlomiej Zolnierkiewicz
While at it: - IDEDISK_VERSION -> IDE_GD_VERSION - ide_cacheflush_p() -> ide_disk_flush() - init_idedisk_capacity() -> ide_disk_init_capacity() - idedisk_set_doorlock() -> ide_disk_set_doorlock() - idedisk_setup() -> ide_disk_setup() - ide_disk_capacity() -> ide_gd_capacity() - ide_disk_remove() -> ide_gd_remove() - ide_disk_probe() -> ide_gd_probe() - ide_disk_resume() -> ide_gd_resume() - ide_device_shutdown() -> ide_gd_shutdown() - idedisk_driver -> ide_gd_driver - idedisk_open() -> ide_gd_open() - idedisk_release() -> ide_gd_release() - idedisk_getgeo() -> ide_gd_getgeo() - idedisk_media_changed() -> ide_gd_media_changed() - idedisk_revalidate_disk() -> ide_gd_revalidate_disk() - idedisk_ops -> ide_gd_ops - idedisk_init() -> ide_gd_init() - idedisk_exit() -> ide_gd_exit() There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: Implement disk shock protection support (v4)Elias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). Port resets are deferred whenever a device on that port is in the parked state. v3: Elias Oltmanns <eo@nebensachen.de> wrote: [...] > >> 1. Make sure that no negative value is being passed to > >> jiffies_to_msecs() in ide_park_show(). > >> 2. Drop the superfluous variable hwif in ide_special_rq(). > >> 3. Skip initialisation of task and tf in ide_special_rq() if we are not > >> handling a (un)park request. > > > > Well, #3 should have been done differently because we donn't want to > > check for REQ_(UN)?PARK_HEADS more often than is necessary. > > While preparing the backport to 2.6.27, it has just occurred to me that > we need to clear the IDE_DFLAG_PARKED flag in ide_disk_pre_reset() > because this flag must not be set after *any* sort of access to the > device. v4: Fix a memory leak due to a missing blk_put_request() in issue_park_cmd(). Additionally, we should plug the queue when enqueueing the unpark request because there is no guarantee that the park timeout has not expired by then. Even though the chance for that to happen is very slim, the request might end up hanging in the queue until the next I/O operation is queued up. While at it, clean up the code a little: - make issue_park_cmd() a function of type void since nobody cares for the return value anyway; - use blk_start_queueing() instead of __blk_run_queue() since we don't have to worry about recursion; - remove a superfluous pointer deference in task_no_data_intr(). Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Cc: Jeff Garzik <jeff@garzik.org>, Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: move SFF DMA code to ide-dma-sff.cBartlomiej Zolnierkiewicz
2008-10-13ide-disk: move /proc handling to ide-disk_proc.c (take 3)Bartlomiej Zolnierkiewicz
While at it: - idedisk_capacity() -> ide_disk_capacity() - idedisk_proc[] -> ide_disk_proc[] - idedisk_settings[] -> ide_disk_settings[] v2/3: Build fix for CONFIG_IDE_PROC_FS=n from Elias Oltmanns. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-disk: move all ioctl handling to ide-disk_ioctl.cBartlomiej Zolnierkiewicz
While at it: - idedisk_ioctl() -> ide_disk_ioctl() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-floppy: move /proc handling to ide-floppy_proc.c (take 2)Bartlomiej Zolnierkiewicz
While at it: - idefloppy_capacity() -> ide_floppy_capacity() - idefloppy_proc[] -> ide_floppy_proc[] - idefloppy_settings[] -> ide_floppy_settings[] v2: Build fix for CONFIG_IDE_PROC_FS=n from Elias Oltmanns. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove CONFIG_BLK_DEV_IDE config option (take 2)Bartlomiej Zolnierkiewicz
Because hd.c was moved to drivers/block/ this config option is superfluous now and may be removed. v2: Fix drivers/ide/Makefile (noticed by Adrian Bunk). Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-floppy: move floppy ioctls handling to ide-floppy_ioctl.cBartlomiej Zolnierkiewicz
While at it: - idefloppy_create_read_capacity_cmd() -> ide_floppy_create_read_capacity_cmd() - idefloppy_create_mode_sense_cmd() -> ide_floppy_create_mode_sense_cmd() - idefloppy_create_request_sense_cmd() -> ide_floppy_create_request_sense_cmd() - idefloppy_create_format_unit_cmd() -> ide_floppy_create_format_unit_cmd() - idefloppy_get_sfrp_bit() -> ide_floppy_get_sfrp_bit() Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: move ioctls handling to ide-ioctls.cBartlomiej Zolnierkiewicz
* Move ioctls handling to ide-ioctls.c (except HDIO_DRIVE_TASKFILE for now). * Make ide_{cmd,task}() static. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: remove stale comments from drivers/ide/MakefileBartlomiej Zolnierkiewicz
2008-07-16move ide/legacy/hd.c to drivers/block/Adrian Bunk
This patch moves hd.c to drivers/block/ Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: rmk@arm.linux.org.uk Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide/legacy/hd.c: use late_initcall()Adrian Bunk
Since the later move to drivers/block/ will break the link order, the module_init() has to become a late_initcall(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: rmk@arm.linux.org.uk Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: move PIO blacklist to ide-pio-blacklist.cBartlomiej Zolnierkiewicz
Move PIO blacklist to ide-pio-blacklist.c. While at it: - fix comment - fix whitespace damage There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-16ide: convert ide-timing.h to ide-timings.c library (take 2)Bartlomiej Zolnierkiewicz
* Don't include ide-timing.h in cs5535 and sis5513 host drivers (they don't need it currently). * Convert ide-timing.h to ide-timings.c library and add CONFIG_IDE_TIMINGS config option to be selected by host drivers using the library. While at it: - fix ide_timing_find_mode() placement v2: * Add missing EXPORT_SYMBOLs. (Stephen Rothwell <sfr@canb.auug.org.au>) There should be no functional changes caused by this patch. Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15ide: add ide_transfer_pc() helperBartlomiej Zolnierkiewicz
* Add ide-atapi.c file for generic ATAPI support together with CONFIG_IDE_ATAPI config option. * Add generic ide_transfer_pc() helper to ide-atapi.c and then convert ide-{floppy,tape,scsi} device drivers to use it. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28remove the broken ETRAX_IDE driverAdrian Bunk
ETRAX_IDE was marked as broken last year with the comment "it doesn't even compile currently". Remove it since it won't get fixed in the near future. On Mon, Apr 14, 2008 at 02:50:19PM +0200, Mikael Starvik wrote: > You can remove it for now and we will resubmit a new if/when we get around > to fix it. [bart: ported it over IDE tree] Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <Jesper.Nilsson@axis.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: fix ide_find_port()Bartlomiej Zolnierkiewicz
* Instead of checking for '->io_ports[IDE_DATA_OFFSET] == 0' check for '->chipset == ide_unknown' when looking for an empty ide_hwifs[] slot. * Do ide-pnp initialization after ide-generic when IDE is built-in (ide-pnp is the only user of ide_find_port() which needs such fixup). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move code handling cdrom.c IOCTLs to ide-cd_ioctl.cBartlomiej Zolnierkiewicz
There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01ide-cd: move VERBOSE_IDE_CD_ERRORS code to ide-cd_verbose.cBartlomiej Zolnierkiewicz
* Rename ide-cd kernel module to ide-cd_mod in preparation to moving code out from ide-cd.[c,h]. Add MODULE_ALIAS("ide-cd") to preserve compatibility. * Move VERBOSE_IDE_CD_ERRORS code from ide-cd.[c,h] to ide-cd_verbose.c. ide-cd_verbose.c is IDE subsystem independent and may be easily converted into generic library usable by other drivers (i.e. libata) if needed. * Add CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS config option to drivers/ide/Kconfig replacing VERBOSE_IDE_CD_ERRORS define. Make this config option enabled by default and visible only if CONFIG_EMBEDDED is defined. before the patch: text data bss dec hex filename 22841 360 1056 24257 5ec1 drivers/ide/ide-cd.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=y: text data bss dec hex filename 22857 360 1056 24273 5ed1 drivers/ide/ide-cd_mod.o after the patch w/ CONFIG_BLK_DEV_IDECD_VERBOSE_ERRORS=n: text data bss dec hex filename 15091 360 1056 16507 407b drivers/ide/ide-cd_mod.o Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-26ide: make remaining built-in only IDE host drivers modular (take 2)Bartlomiej Zolnierkiewicz
* Make remaining built-in only IDE host drivers modular, add ide-scan-pci.c file for probing PCI host drivers registered with IDE core (special case for built-in IDE and CONFIG_IDEPCI_PCIBUS_ORDER=y) and then take care of the ordering in which all IDE host drivers are probed when IDE is built-in during link time. * Move probing of gayle, falconide, macide, q40ide and buddha (m68k arch specific) host drivers, before PCI ones (no PCI on m68k), ide-cris (cris arch specific), cmd640 (x86 arch specific) and pmac (ppc arch specific). * Move probing of ide-cris (cris arch specific) host driver before cmd640 (x86 arch specific). * Move probing of mpc8xx (ppc specific) host driver before ide-pnp (depends on ISA and none of ppc platform that use mpc8xx supports ISA) and ide-h8300 (h8300 arch specific). * Add "probe_vlb" kernel parameter to cmd640 host driver and update Documentation/ide.txt accordingly. * Make IDE_ARM config option visible so it can also be disabled if needed. * Remove bogus comment from ide.c while at it. v2: * Fix two issues spotted by Sergei: - replace ENOMEM error value by ENOENT in ide-h8300 host driver - fix MODULE_PARM_DESC() in cmd640 host driver Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-11-27ide: add CONFIG_IDE_H8300 config optionBartlomiej Zolnierkiewicz
Add a separate config option for ide-8300 host driver instead of depending on CONFIG_H8300. This change is a preparation for the future changes and also allows ide-h8300 to be disabled if needed. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: make /proc/ide/ optionalBartlomiej Zolnierkiewicz
All important information/features should be already available through sysfs and ioctl interfaces. Add CONFIG_IDE_PROC_FS (CONFIG_SCSI_PROC_FS rip-off) config option, disabling it makes IDE driver ~5 kB smaller (on x86-32). While at it add CONFIG_PROC_FS=n versions of proc_ide_{create,destroy}() and remove no longer needed #ifdefs. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-03-17scc_pata: dependency fixKou Ishizaki
This patch fixes: * the dependency of scc_pata on BLK_DEV_IDEDMA_PCI * incorrect link to ide-core * move scc_pata from ide/ppc to ide/pci Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi@toshiba.co.jp> Cc: Al Viro <viro@ftp.linux.org.uk>, Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-17drivers/ide: PATA driver for CellebKou Ishizaki
This is the patch (based on 2.6.19-rc4) for PATA controller of Toshiba Cell reference set(Celleb). The reference set consists of Cell, 512MB memory, Super Companion Chip(SCC) and some peripherals such as HDD, GbE, etc. You can see brief explanation and picture of Cell reference set at following URLs. http://www.toshiba.co.jp/about/press/2005_09/pr2001.htm http://cell-industries.com/toshiba_announces.php We use a drivers/ide driver because its design is more suitable for SCC IDE controller than libata driver. Since SCC supports only 32bit read/write, we must override many callbacks of ata_port_operations by modifying generic helpers. Each time the libata common code is updated, we must update those modified helpers. It is very hard for us. But we will try to implement the libata driver as needed. Signed-off-by: Kou Ishizaki <kou.ishizaki at toshiba.co.jp> Signed-off-by: Akira Iguchi <akira2.iguchi at toshiba.co.jp> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-02-07ACPI support for IDE devicesHannes Reinecke
This patch implements ACPI integration for generic IDE devices. The ACPI spec mandates that some methods are called during suspend and resume. And consequently there most modern Laptops cannot resume properly without it. According to the spec, we should call '_GTM' (Get Timing) upon suspend to store the current IDE adapter settings. Upon resume we should call '_STM' (Set Timing) to initialize the adapter with the stored settings; afterwards '_GTF' (Get Taskfile) should be called which returns a buffer with some IDE initialisation commands. Those commands should be passed to the drive. There are two module params which control the behaviour of this patch: 'ide=noacpi' Do not call any ACPI methods (Disables any ACPI method calls) 'ide=acpigtf' Enable execution of _GTF methods upon resume. Has no effect if 'ide=noacpi' is set. 'ide=acpionboot' Enable execution of ACPI methods during boot. This might be required on some machines if 'ide=acpigtf' is selected as some machines modify the _GTF information depending on the drive identification passed down with _STM. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-11-17[IDE] Add driver for Sibyte Swarm evaluation boardRalf Baechle
This driver supports the IDE port on the Sibyte Swarm evaluation boards and it's relatives for the BCM1250 family of systems on a chip. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2005-07-03[PATCH] drivers/ide/Makefile: kill dead CONFIG_BLK_DEV_IDE_TCQ entryAdrian Bunk
This patch kills the dead CONFIG_BLK_DEV_IDE_TCQ entry. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
