Propagate the error values returned by i2c_wait() instead of overriding
them with a meaningless -1.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
This adds a i2c_new_dummy() primitive to help work with devices
that consume multiple addresses, which include many I2C eeproms
and at least one RTC.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
It is no longer required to hold adapter->clist_lock to call
i2c_check_addr.
Cc: David Brownell <david-b@pacbell.net>
We only need to hold adapter->clist_lock when we touch the client list.
This goes on top of the patch removing most i2c_adapter.clients usage,
updating i2c_attach_client:
- Don't call device_register() while holding clist_lock. This
removes a self-deadlock when on the i2c_driver.probe() path,
for drivers that need to attach new devices (e.g. dummies).
- Remove a redundant address check. The driver model core does
this as a consequence of guaranteeing unique names.
- Move the "device registered" diagnostic so that it never lies;
previously, on error paths it would falsely report success.
The i2c_adapter.clients list of i2c_client nodes duplicates driver
model state. This patch starts removing that list, letting us remove
most existing users of those i2c-core lists.
* The core I2C code now iterates over the driver model's list instead
of the i2c-internal one in some places where it's safe:
- Passing a command/ioctl to each client, a mechanims
used almost exclusively by DVB adapters;
- Device address checking, in both i2c-core and i2c-dev.
* Provide i2c_verify_client() to use with driver model iterators.
* Flag the relevant i2c_adapter and i2c_client fields as deprecated,
to help prevent new users from appearing.
For the moment the list needs to stick around, since some issues show
up when deleting devices created by legacy I2C drivers. (They don't
follow standard driver model rules. Removing those devices can cause
self-deadlocks.)
Add support for another variant of the VT8237. I couldn't test
I2C block support but I assume it is present as well.
Checking the PCI function number doesn't add any value, and it makes
adding dynamic IDs to the driver more difficult. Drop this check.
The i2c-amd756 and i2c-viapro drivers make use of the driver_data
field of the PCI device ID. When adding device IDs dynamically (by
writing to the new_id sysfs file) you cannot set the value of this
field by default. It has to be allowed explicitly. Do that, and
check the value so that the user can't crash the kernel accidentally.
Add polling I2C transfer implementation for PXA I2C. This is needed
for cases where I2C transactions have to occur at times interrups are
disabled.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: eric miao <eric.miao@marvell.com>
Allow i2c_transfer to be called in contexts where sleeping is not allowed.
It is the reponsability of the caller to ensure that the underlying i2c bus
driver will not sleep either.
The implementation is unsafe, and anyway one can achieve the same from
userspace using i2c-dev + i2cdetect.
Also tag i2c_sibyte_add_bus __init.
I2C block read is supported since the ICH5. I couldn't get it to work
using the block buffer, so it's using the old-style byte-by-byte mode
for now.
Note: I'm also updating the driver author... The i2c-i801 driver was
really written by Mark Studebaker, even though he based his work on
the i2c-piix4 driver which was written by Philip Edelbrock.
Clear special mode bits (PEC, block buffer) at driver load time,
you never know in which state the device was left by its last user.
Also make sure that we reset the block buffer mode at the end of every
transaction, not only when PEC was used.
Use separate flags with explicit names to describe the features of
the ICH chip.
Provide a clearer documentation of which additional features each
ICH chip support, and which of these the driver supports.
Move the tps65010 header file from the OMAP arch directory to the
more generic <linux/i2c/...> directory, and remove the spurious
dependency of this driver on OMAP.
Rename the main mutex in i2c-core from core_lists to core_lock. This
makes more sense now that the redundant lists are gone.
i2c_driver.list is superfluous, this list duplicates the one
maintained by the driver core. Drop it.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
i2c_adapter.list is superfluous, this list duplicates the one
Use more standard prototypes for i2c_use_client() and
i2c_release_client(). The former now returns a pointer to the client,
and the latter no longer returns anything. This matches what all other
subsystems do.
Don't implement our own reference counting mechanism for i2c clients
when the driver model already has one.
The framebuffer drivers for these pieces of hardware include support
for the DDC/I2C buses, so there is no need for separate drivers.
I2C adapter drivers are supposed to handle retries on nack by themselves
if they do, so there's no point in setting .retries if they don't.
As this retry mechanism is going away (at least in its current form),
clean this up now so that we don't get build failures later.
This patch allows much of the I2C client address data to move from initdata
into text.
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
The 10-bit address support in i2c-algo-pcf is so heavily broken that
it can't have ever been used. Nobody ever complained, so I'll take it
that nobody needs it. Let's just delete it.
Update comments and logging on return path for byte writes. NAK is
an error, to be reported or optionally ignored. Timeouts are always
errors. Lost arbitration is not currently handled, so don't even list
it as an option in the error message.
Don't return bogus EFAULT code for inappropriate NAK; EIO is better,
there is no bad userspace address in question.
Fix *LOTS* of whitespace goofs and checkpatch.pl warnings, strangely
parenthesized ternary expressions, and other CodingStyle glitches.
remove #ifdef CONFIG_PXA27x .. #endif and use cpu_is_pxaXXXX() macros
so that a single binary can support PXA25x/PXA27x/PXA3xx at run-time.
Signed-off-by: eric miao <eric.miao@marvell.com>
This patch contains the overdue removal of three I2C drivers.
[JD: In fact only i2c-ixp4xx can be removed at the moment, the other two
platforms don't implement the generic GPIO layer yet.]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch contains the scheduled removal of legacy I2C RTC drivers with
replacement drivers.
This mimics the behavior of actual SMBus chips better.
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com>
Use numbered adapter registration to always have the same hardware bus
show up at the same number.
PWRficient 1682M has three buses, they are all on the same PCI device but
different functions. So do the simple thing and register them based on
function number. Future products, if having a different number of busses,
are expected to have similar behaviour w.r.t. device/function layout.
My guess is that all the chips supported by this driver support block
transactions and reset, but for now we play it safe and only list the
ones for which this was actually tested.
Cc: Oleg Ryjkov <olegr@olegr.ca>
Removed duplicates defined elsewhere
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
If the registration of the second I2C channel fails, we really want to
unregister the first one before we return with an error.
While we're here, fix the printk right above so that it displays the
real driver name.
[JD: One more fix in i2c-dev.]
This patch fixes bug #9581 reported by Marcio Buss. If kzalloc fails,
omap_i2c_write_reg() tries to reset an unallocated I2C controller.
Cc: Marcio Buss <marciobuss@gmail.com>
Build fix to the isp1301_omap driver ... this driver gets built
more often in the OMAP tree than in mainline, partly because the
defconfig for H2 (plus probably H3 and H4) needs updating.
This is required to let hwmon drivers attach to the adapter.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Recent (i.e. 2005 and later) Sony Vaio laptops have names beginning
with VGN rather than PCG. Update the eeprom driver so that it
recognizes these.
The sysfs interface to DMI data takes care to not make the system
serial number and UUID world-readable, presumably due to privacy
concerns. For consistency, we should not let the eeprom driver
export these same strings to the world on Sony Vaio laptops.
Instead, only make them readable by root, as we already do for BIOS
passwords.
Turns out we don't actually check the status to see if there was a
device out there to talk to, just if we had a timeout when doing so.
Add the proper check, so we don't falsly think there are devices
on the bus that are not there, etc.
i2c_check_addr is only used inside i2c-core now, so we can make it
static and stop exporting it. Thanks to David Brownell for noticing.
