This is the 4.4.167 stable release
commit 08d9db00fe0e300d6df976e6c294f974988226dd upstream.
The i2c-scmi driver crashes when the SMBus Write Block transaction is
executed:
WARNING: CPU: 9 PID: 2194 at mm/page_alloc.c:3931 __alloc_pages_slowpath+0x9db/0xec0
Call Trace:
? get_page_from_freelist+0x49d/0x11f0
? alloc_pages_current+0x6a/0xe0
? new_slab+0x499/0x690
__alloc_pages_nodemask+0x265/0x280
kmalloc_order+0x18/0x40
kmalloc_order_trace+0x24/0xb0
? acpi_ut_allocate_object_desc_dbg+0x62/0x10c
__kmalloc+0x203/0x220
acpi_os_allocate_zeroed+0x34/0x36
acpi_ut_copy_eobject_to_iobject+0x266/0x31e
acpi_evaluate_object+0x166/0x3b2
acpi_smbus_cmi_access+0x144/0x530 [i2c_scmi]
i2c_smbus_xfer+0xda/0x370
i2cdev_ioctl_smbus+0x1bd/0x270
i2cdev_ioctl+0xaa/0x250
do_vfs_ioctl+0xa4/0x600
SyS_ioctl+0x79/0x90
do_syscall_64+0x73/0x130
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
ACPI Error: Evaluating _SBW: 4 (20170831/smbus_cmi-185)
This problem occurs because the length of ACPI Buffer object is not
defined/initialized in the code before a corresponding ACPI method is
called. The obvious patch below fixes this issue.
Signed-off-by: Edgar Cherkasov <echerkasov@dev.rtsoft.ru>
Acked-by: Viktor Krasnov <vkrasnov@dev.rtsoft.ru>
Acked-by: Michael Brunner <Michael.Brunner@kontron.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 4c85609b08c4761eca0a40fd7beb06bc650f252d ]
This driver currently emits a STOP if the next message is not
I2C_MD_RD. It should not do it because it disturbs the I2C_RDWR
ioctl, where read/write transactions are combined without STOP
between.
Issue STOP only when the message is the last one _or_ flagged with
I2C_M_STOP.
Fixes: 6a62974b667f ("i2c: uniphier_f: add UniPhier FIFO-builtin I2C driver")
[ Upstream commit 38f5d8d8cbb2ffa2b54315118185332329ec891c ]
between.
I2C_M_STOP.
Fixes: dd6fd4a32793 ("i2c: uniphier: add UniPhier FIFO-less I2C driver")
[ Upstream commit 7fd6d98b89f382d414e1db528e29a67bbd749457 ]
Commit 7ae81952cda ("i2c: i801: Allow ACPI SystemIO OpRegion to conflict
with PCI BAR") made it possible for AML code to access SMBus I/O ports
by installing custom SystemIO OpRegion handler and blocking i80i driver
access upon first AML read/write to this OpRegion.
However, while ThinkPad T560 does have SystemIO OpRegion declared under
the SMBus device, it does not access any of the SMBus registers:
Device (SMBU)
OperationRegion (SMBP, PCI_Config, 0x50, 0x04)
Field (SMBP, DWordAcc, NoLock, Preserve)
, 5,
TCOB, 11,
Offset (0x04)
Name (TCBV, 0x00)
Method (TCBS, 0, NotSerialized)
If ((TCBV == 0x00))
TCBV = (\_SB.PCI0.SMBU.TCOB << 0x05)
Return (TCBV) /* \_SB_.PCI0.SMBU.TCBV */
OperationRegion (TCBA, SystemIO, TCBS (), 0x10)
Field (TCBA, ByteAcc, NoLock, Preserve)
Offset (0x04),
, 9,
CPSC, 1
Problem with the current approach is that it blocks all I/O port access
and because this system has touchpad connected to the SMBus controller
after first AML access (happens during suspend/resume cycle) the
touchpad fails to work anymore.
Fix this so that we allow ACPI AML I/O port access if it does not touch
the region reserved for the SMBus.
Fixes: 7ae81952cda ("i2c: i801: Allow ACPI SystemIO OpRegion to conflict with PCI BAR")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=200737
Reported-by: Yussuf Khalil <dev@pp3345.net>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
This is the 4.4.158 stable release
commit 851a15114895c5bce163a6f2d57e0aa4658a1be4 upstream.
DNV's iTCO is slightly different with SMBCTRL sitting at a different
offset when compared to all other devices. Let's fix so that we can
properly use iTCO watchdog.
Fixes: 84d7f2ebd70d ("i2c: i801: Add support for Intel DNV")
Cc: <stable@vger.kernel.org> # v4.4+
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit ae7304c3ea28a3ba47a7a8312c76c654ef24967e upstream.
Disable interrupts while configuring the transfer and enable them back.
We have below as the programming sequence
1. start and slave address
2. byte count and stop
In some customer platform there was a lot of interrupts between 1 and 2
and after slave address (around 7 clock cyles) if 2 is not executed
then the transaction is nacked.
To fix this case make the 2 writes atomic.
Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com>
[wsa: added a newline for better readability]
Cc: stable@kernel.org
[ Upstream commit cc8de9a68599b261244ea453b38678229f06ada7 ]
If CLKH is set to 0 I2C clock is not generated at all, so avoid this value
and stretch the clock in this case.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
commit bed4ff1ed4d8f2ef5007c5c6ae1b29c5677a3632 upstream.
This fixes a race condition, where the DMAEN bit ends up being set after
I2C slave has transmitted a byte following the dummy read. When that
happens, an interrupt is generated instead, and no DMA request is generated
to kickstart the DMA read, and a timeout happens after DMA_TIMEOUT (1 sec).
Fixed by setting the DMAEN bit before the dummy read.
Signed-off-by: Esben Haabendal <eha@deif.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit 17e83549e199d89aace7788a9f11c108671eecf5 upstream.
Fix the following kernel bug:
kernel BUG at drivers/iommu/intel-iommu.c:3260!
invalid opcode: 0000 [#5] PREEMPT SMP
Hardware name: Intel Corp. Harcuvar/Server, BIOS HAVLCRB0.X64.0013.D39.1608311820 08/31/2016
task: ffff880175389950 ti: ffff880176bec000 task.ti: ffff880176bec000
RIP: 0010:[<ffffffff8150a83b>] [<ffffffff8150a83b>] intel_unmap+0x25b/0x260
RSP: 0018:ffff880176bef5e8 EFLAGS: 00010296
RAX: 0000000000000024 RBX: ffff8800773c7c88 RCX: 000000000000ce04
RDX: 0000000080000000 RSI: 0000000000000000 RDI: 0000000000000009
RBP: ffff880176bef638 R08: 0000000000000010 R09: 0000000000000004
R10: ffff880175389c78 R11: 0000000000000a4f R12: ffff8800773c7868
R13: 00000000ffffac88 R14: ffff8800773c7818 R15: 0000000000000001
FS: 00007fef21258700(0000) GS:ffff88017b5c0000(0000) knlGS:0000000000000000
CR2: 000000000066d6d8 CR3: 000000007118c000 CR4: 00000000003406e0
Stack:
00000000ffffac88 ffffffff8199867f ffff880176bef5f8 ffff880100000030
ffff880176bef668 ffff8800773c7c88 ffff880178288098 ffff8800772c0010
ffff8800773c7818 0000000000000001 ffff880176bef648 ffffffff8150a86e
Call Trace:
[<ffffffff8199867f>] ? printk+0x46/0x48
[<ffffffff8150a86e>] intel_unmap_page+0xe/0x10
[<ffffffffa039d99b>] ismt_access+0x27b/0x8fa [i2c_ismt]
[<ffffffff81554420>] ? __pm_runtime_suspend+0xa0/0xa0
[<ffffffff815544a0>] ? pm_suspend_timer_fn+0x80/0x80
[<ffffffff8143dfd0>] ? pci_bus_read_dev_vendor_id+0xf0/0xf0
[<ffffffff8172b36c>] i2c_smbus_xfer+0xec/0x4b0
[<ffffffff810aa4d5>] ? vprintk_emit+0x345/0x530
[<ffffffffa038936b>] i2cdev_ioctl_smbus+0x12b/0x240 [i2c_dev]
[<ffffffff810aa829>] ? vprintk_default+0x29/0x40
[<ffffffffa0389b33>] i2cdev_ioctl+0x63/0x1ec [i2c_dev]
[<ffffffff811b04c8>] do_vfs_ioctl+0x328/0x5d0
[<ffffffff8119d8ec>] ? vfs_write+0x11c/0x190
[<ffffffff8109d449>] ? rt_up_read+0x19/0x20
[<ffffffff811b07f1>] SyS_ioctl+0x81/0xa0
[<ffffffff819a351b>] system_call_fastpath+0x16/0x6e
This happen When run "i2cdetect -y 0" detect SMBus iSMT adapter.
After finished I2C block read/write, when unmap the data buffer,
a wrong device address was pass to dma_unmap_single().
To fix this, give dma_unmap_single() the "dev" parameter, just like
what dma_map_single() does, then unmap can find the right devices.
Fixes: 13f35ac14cd0 ("i2c: Adding support for Intel iSMT SMBus 2.0 host controller")
Signed-off-by: Liwei Song <liwei.song@windriver.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit 9f9e3e0d4dd3338b3f3dde080789f71901e1e4ff upstream.
Make sure to call reinit_completion() before dma is started to avoid race
condition where reinit_completion() is called after complete() and before
wait_for_completion_timeout().
Fixes: ce1a78840ff7 ("i2c: imx: add DMA support for freescale i2c driver")
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit ae481cc139658e89eb3ea671dd00b67bd87f01a3 upstream.
Resume failed because of uninitialized registers. Instead of adding a
resume callback, we simply initialize registers before every transfer.
This lightweight change is more robust and will keep us safe if we ever
need support for power domains or dynamic frequency changes.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
This is the 4.4.138 stable release
commit 52df445f29b79006d8b2dcd129152987c0d3bd64 upstream.
If we don't clear START generation as soon as possible, it may cause
another message to be generated, e.g. when receiving NACK in address
phase. To keep the race window as small as possible, we clear it right
at the beginning of the interrupt. We don't need any checks since we
always want to stop START and STOP generation on the next occasion after
we started it.
This patch improves the situation but sadly does not completely fix it.
It is still to be researched if we can do better given this HW design.
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Reviewed-by: Biju Das <biju.das@bp.renesas.com>
commit c3be0af15959e11fa535d5332ab3d7cf34abd09b upstream.
Due to the HW design, master IRQs are timing critical, so give them
precedence over slave IRQ.
commit d89667b14f9d13b684287f6189ca209af5feee43 upstream.
The manual says (55.4.8.6) that HW does automatically send STOP after
NACK was received. My measuerments confirm that.
commit cc21d0b4b62e41e5013d763adade5ea4462c33a4 upstream.
Setting up new messages was done in process context while handling a
message was in interrupt context. Because of the HW design, this IP core
is sensitive to timing, so the context switches were too expensive. Move
this setup to interrupt context as well.
In my test setup, this fixed the occasional 'data byte sent twice' issue
which a number of people have seen. It also fixes to send REP_START
after a read message which was wrongly send as a STOP + START sequence
before.
Reviewed-by: Chris Paterson <Chris.Paterson2@renesas.com>
commit b9d0684c79c4b9d30ce0d47d3270493dd0e76e59 upstream.
We want to reuse this function later.
commit ff2316b87a336bff940939cd9fc56287ed48e578 upstream.
After making sure to reinit the HW and clear interrupts in the timeout
case, we know that interrupts are always disabled in the sections
protected by the spinlock. Thus, we can simply remove it which is a
preparation for further refactoring. While here, rename the timeout
variable to time_left which is way more readable.
commit 90f779e565bdc18dd4f79d81cf11f43a7266010b upstream.
commit 2c78cdc1c06308a59d6ed4145cdba73fdeff8c0d upstream.
We don't need to init HW before every transfer since we know the HW
state then. HW init at probe time is enough. While here, add setting the
clock register which belongs to init HW. Also, set MDBS bit since not
setting it is prohibited according to the manual.
commit e43e0df13f8528ca55ed79f469c4b2af897fa796 upstream.
When calculating the bus speed, the clock should be on, of course. Most
bootloaders left them on, so this went unnoticed so far.
Move the ioremapping out of this clock-enabled-block and prepare for
adding hw initialization there, too.
Reported-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[ Upstream commit 31184d8c6ea49ea0676d100cdd7e1f102ad025b5 ]
The errata FE-8471889 description has been updated. There is still a
timing violation for repeated start. But the errata now states that it
was only the case for the Standard mode (100 kHz), in Fast mode (400 kHz)
there is no issue.
This patch limit the errata fix to the Standard mode.
It has been tesed successfully on the clearfog (Aramda 388 based board).
[ Upstream commit e058e7a4bc89104540a8a303682248614b5df6f1 ]
Description of the problem:
- i2c-scmi driver contains only two identifiers "SMBUS01" and "SMBUSIBM";
- the fist HID (SMBUS01) is clearly defined in "SMBus Control Method
Interface Specification, version 1.0": "Each device must specify
'SMBUS01' as its _HID and use a unique _UID value";
- unfortunately, BIOS vendors (like AMI) seem to ignore this requirement
and implement "SMB0001" HID instead of "SMBUS01";
- I speculate that they do this because only "SMB0001" is hard coded in
Windows SMBus driver produced by Microsoft.
This leads to following situation:
- SMBus works out of box in Windows but not in Linux;
- board vendors are forced to add correct "SMBUS01" HID to BIOS to make
SMBus work in Linux. Moreover the same board vendors complain that
tools (3-rd party ASL compiler) do not like the "SMBUS01" identifier
and produce errors. So they need to constantly patch the compiler for
each new version of BIOS.
As it is very unlikely that BIOS vendors implement a correct HID in
future, I would propose to consider whether it is possible to work around
the problem by adding MS HID to the Linux i2c-scmi driver.
v2: move the definition of the new HID to the driver itself.
Signed-off-by: Michael Brunner <Michael.Brunner@kontron.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
This is the 4.4.121 stable release
commit 5abe9b26847c65a698f38744a52635b287514294 upstream.
As of next-20160607 with allyesconfig we get this linker failure:
MODPOST vmlinux.o
WARNING: vmlinux.o(.text+0x21bc0d): Section mismatch in reference from
the function intel_scu_devices_create() to the function
.init.text:i2c_register_board_info()
This is caused by the fact that intel_scu_devices_create() calls
i2c_register_board_info() and intel_scu_devices_create() is not
annotated with __init. This typically involves manual code
inspection and if one is certain this is correct we would
just peg intel_scu_devices_create() with a __ref annotation.
In this case this would be wrong though as the
intel_scu_devices_create() call is exported, and used in
the ipc_probe() on drivers/platform/x86/intel_scu_ipc.c.
The issue is that even though builtin_pci_driver(ipc_driver)
is used this just exposes the probe routine, which can occur
at any point in time if this bus supports hotplug. A race
can happen between kernel_init_freeable() that calls the init
calls (in this case registeres the intel_scu_ipc.c driver, and
later free_initmem(), which would free the i2c_register_board_info().
If a probe happens later in boot i2c_register_board_info() would
not be present and we should get a page fault.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
[wsa: made function declaration a one-liner]
This is the 4.4.107 stable release
[ Upstream commit 2501c1bb054290679baad0ff7f4f07c714251f4c ]
While modifying the driver to use the STOP interrupt, the completion of the
intermediate transfers need to wake the driver back up in order to initiate
the next transfer (restart condition). Otherwise you get never ending
interrupts and only the first transfer sent.
Fixes: 71ccea095ea1 ("i2c: riic: correctly finish transfers")
Reported-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit 71ccea095ea1d4efd004dab971be6d599e06fc3f ]
This fixes the condition where the controller has not fully completed its
final transfer and leaves the bus and controller in a undesirable state.
At the end of the last transmitted byte, the existing driver would just
signal for a STOP condition to be transmitted then immediately signal
completion. However, the full STOP procedure might not have fully taken
place by the time the runtime PM shuts off the peripheral clock, leaving
the bus in a suspended state.
Alternatively, the STOP condition on the bus may have completed, but when
the next transaction is requested by the upper layer, not all the
necessary register cleanup was finished from the last transfer which made
the driver return BUS BUSY when it really wasn't.
This patch now makes all transmit and receive transactions wait for the
STOP condition to fully complete before signaling a completed transaction.
With this new method, runtime PM no longer seems to be an issue.
Fixes: 310c18a41450 ("i2c: riic: add driver")
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
commit c6ebcedbab7ca78984959386012a17b21183e1a3 upstream.
Commit b6c159a9cb69 ("i2c: ismt: Don't duplicate the receive length for
block reads") broke I2C block reads. It aimed to fix normal SMBus block
read, but changed the correct behavior of I2C block read in the process.
According to Documentation/i2c/smbus-protocol, one vital difference
between normal SMBus block read and I2C block read is that there is no
byte count prefixed in the data sent on the wire:
SMBus Block Read: i2c_smbus_read_block_data()
S Addr Wr [A] Comm [A]
S Addr Rd [A] [Count] A [Data] A [Data] A ... A [Data] NA P
I2C Block Read: i2c_smbus_read_i2c_block_data()
S Addr Rd [A] [Data] A [Data] A ... A [Data] NA P
Therefore the two transaction types need to be processed differently in
the driver by copying of the dma_buffer as done previously for the
I2C_SMBUS_I2C_BLOCK_DATA case.
Fixes: b6c159a9cb69 ("i2c: ismt: Don't duplicate the receive length for block reads")
Signed-off-by: Pontus Andersson <epontan@gmail.com>
Tested-by: Stephen Douthit <stephend@adiengineering.com>
[ Upstream commit e3ccc921b7d8fd1fcd10a00720e09823d8078666 ]
When going to suspend, the I2C registers may be lost because the power to
VDDcore is cut. Restore them when resuming.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit 3b0277f198ac928f323c42e180680d2f79aa980d ]
Most likely a copy & paste error.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Acked-by: Jerome Brunet <jbrunet@baylibre.com>
Fixes: 30021e3707a7 ("i2c: add support for Amlogic Meson I2C controller")
This is the 4.4.88 stable release
commit ba201c4f5ebe13d7819081756378777d8153f23e upstream.
Compare the number of bytes actually seen on the wire to the byte
count field returned by the slave device.
Previously we just overwrote the byte count returned by the slave
with the real byte count and let the caller figure out if the
message was sane.
Signed-off-by: Stephen Douthit <stephend@adiengineering.com>
Tested-by: Dan Priamo <danp@adiengineering.com>
commit b6c159a9cb69c2cf0bf59d4e12c3a2da77e4d994 upstream.
According to Table 15-14 of the C2000 EDS (Intel doc #510524) the
rx data pointed to by the descriptor dptr contains the byte count.
desc->rxbytes reports all bytes read on the wire, including the
"byte count" byte. So if a device sends 4 bytes in response to a
block read, on the wire and in the DMA buffer we see:
count data1 data2 data3 data4
0x04 0xde 0xad 0xbe 0xef
That's what we want to return in data->block to the next level.
Instead we were actually prefixing that with desc->rxbytes:
bad
count count data1 data2 data3 data4
0x05 0x04 0xde 0xad 0xbe 0xef
This was discovered while developing a BMC solution relying on the
ipmi_ssif.c driver which was trying to interpret the bogus length
field as part of the IPMI response.
commit 27bfeb5a0619554d9734fb39e14f0e80fa7c342c upstream.
David reported that the length for memset was incorrect (element sizes
were not taken into account). Then I saw that we are clearing kzalloced
memory, so we can simply drop this code.
Reported-by: David Binderman <dcb314@hotmail.com>
Reviewed-by: Axel Lin <axel.lin@ingics.com>
commit a23318feeff662c8d25d21623daebdd2e55ec221 upstream.
The commit 8503ff166504 ("i2c: designware: Avoid unnecessary resuming
during system suspend"), may suggest to the PM core to try out the so
called direct_complete path for system sleep. In this path, the PM core
treats a runtime suspended device as it's already in a proper low power
state for system sleep, which makes it skip calling the system sleep
callbacks for the device, except for the ->prepare() and the ->complete()
callbacks.
However, the PM core may unset the direct_complete flag for a parent
device, in case its child device are being system suspended before. In this
scenario, the PM core invokes the system sleep callbacks, no matter if the
device is runtime suspended or not.
Particularly in cases of an existing i2c slave device, the above path is
triggered, which breaks the assumption that the i2c device is always
runtime resumed whenever the dw_i2c_plat_suspend() is being called.
More precisely, dw_i2c_plat_suspend() calls clk_core_disable() and
clk_core_unprepare(), for an already disabled/unprepared clock, leading to
a splat in the log about clocks calls being wrongly balanced and breaking
system sleep.
To still allow the direct_complete path in cases when it's possible, but
also to keep the fix simple, let's runtime resume the i2c device in the
->suspend() callback, before continuing to put the device into low power
state.
Note, in cases when the i2c device is attached to the ACPI PM domain, this
problem doesn't occur, because ACPI's ->suspend() callback, assigned to
acpi_subsys_suspend(), already calls pm_runtime_resume() for the device.
It should also be noted that this change does not fix commit 8503ff166504
("i2c: designware: Avoid unnecessary resuming during system suspend").
Because for the non-ACPI case, the system sleep support was already broken
prior that point.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Tested-by: John Stultz <john.stultz@linaro.org>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
This is the 4.4.73 stable release
[ Upstream commit f43128c75202f29ee71aa83e6c320a911137c189 ]
Since '701dc207bf55 ("i2c: piix4: Avoid race conditions with IMC")' we
are using the SMBSLVCNT register at offset 0x8. We need to request it.
Fixes: 701dc207bf55 ("i2c: piix4: Avoid race conditions with IMC")
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
commit 5165da5923d6c7df6f2927b0113b2e4d9288661e upstream.
Since v4.9 i2c-tiny-usb generates the below call trace
and longer works, since it can't communicate with the
USB device. The reason is, that since v4.9 the USB
stack checks, that the buffer it should transfer is DMA
capable. This was a requirement since v2.2 days, but it
usually worked nevertheless.
[ 17.504959] ------------[ cut here ]------------
[ 17.505488] WARNING: CPU: 0 PID: 93 at drivers/usb/core/hcd.c:1587 usb_hcd_map_urb_for_dma+0x37c/0x570
[ 17.506545] transfer buffer not dma capable
[ 17.507022] Modules linked in:
[ 17.507370] CPU: 0 PID: 93 Comm: i2cdetect Not tainted 4.11.0-rc8+ #10
[ 17.508103] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1 04/01/2014
[ 17.509039] Call Trace:
[ 17.509320] ? dump_stack+0x5c/0x78
[ 17.509714] ? __warn+0xbe/0xe0
[ 17.510073] ? warn_slowpath_fmt+0x5a/0x80
[ 17.510532] ? nommu_map_sg+0xb0/0xb0
[ 17.510949] ? usb_hcd_map_urb_for_dma+0x37c/0x570
[ 17.511482] ? usb_hcd_submit_urb+0x336/0xab0
[ 17.511976] ? wait_for_completion_timeout+0x12f/0x1a0
[ 17.512549] ? wait_for_completion_timeout+0x65/0x1a0
[ 17.513125] ? usb_start_wait_urb+0x65/0x160
[ 17.513604] ? usb_control_msg+0xdc/0x130
[ 17.514061] ? usb_xfer+0xa4/0x2a0
[ 17.514445] ? __i2c_transfer+0x108/0x3c0
[ 17.514899] ? i2c_transfer+0x57/0xb0
[ 17.515310] ? i2c_smbus_xfer_emulated+0x12f/0x590
[ 17.515851] ? _raw_spin_unlock_irqrestore+0x11/0x20
[ 17.516408] ? i2c_smbus_xfer+0x125/0x330
[ 17.516876] ? i2c_smbus_xfer+0x125/0x330
[ 17.517329] ? i2cdev_ioctl_smbus+0x1c1/0x2b0
[ 17.517824] ? i2cdev_ioctl+0x75/0x1c0
[ 17.518248] ? do_vfs_ioctl+0x9f/0x600
[ 17.518671] ? vfs_write+0x144/0x190
[ 17.519078] ? SyS_ioctl+0x74/0x80
[ 17.519463] ? entry_SYSCALL_64_fastpath+0x1e/0xad
[ 17.519959] ---[ end trace d047c04982f5ac50 ]---
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Till Harbaum <till@harbaum.org>
This is the 4.4.59 stable release
commit 30f939feaeee23e21391cfc7b484f012eb189c3c upstream.
i2c_smbus_xfer() does not always fill an entire block, allowing
kernel stack memory disclosure through the temp variable. Clear
it before it's read to.
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
commit 6f724fb3039522486fce2e32e4c0fbe238a6ab02 upstream.
In of_i2c_register_device(), when the check for
device address validity fails we print the info.addr,
which has not been assigned properly.
Fix this by printing the actual invalid address.
Signed-off-by: John Garry <john.garry@huawei.com>
Reviewed-by: Vladimir Zapolskiy <vz@mleia.com>
Fixes: b4e2f6ac1281 ("i2c: apply DT flags when probing")
This is the 4.4.39 stable release
commit 93d710a65ef02fb7fd48ae207e78f460bd7a6089 upstream.
We get the following build error from UM Linux after adding
an entry to drivers/iio/gyro/Kconfig that issues "select I2C_MUX":
ERROR: "devm_ioremap_resource"
[drivers/i2c/muxes/i2c-mux-reg.ko] undefined!
ERROR: "of_address_to_resource"
It appears that the I2C mux core code depends on HAS_IOMEM
for historical reasons, while CONFIG_I2C_MUX_REG does *not*
have a direct dependency on HAS_IOMEM.
This creates a situation where a allyesconfig or allmodconfig
for UM Linux will select I2C_MUX, and will implicitly enable
I2C_MUX_REG as well, and the compilation will fail for the
register driver.
Fix this up by making I2C_MUX_REG depend on HAS_IOMEM and
removing the dependency from I2C_MUX.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Reported-by: Jonathan Cameron <jic23@jic23.retrosnub.co.uk>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Acked-by: Peter Rosin <peda@axentia.se>
commit 147b36d5b70c083cc76770c47d60b347e8eaf231 upstream.
Race condition between registering an I2C device driver and
deregistering an I2C adapter device which is assumed to manage that
I2C device may lead to a NULL pointer dereference due to the
uninitialized list head of driver clients.
The root cause of the issue is that the I2C bus may know about the
registered device driver and thus it is matched by bus_for_each_drv(),
but the list of clients is not initialized and commonly it is NULL,
because I2C device drivers define struct i2c_driver as static and
clients field is expected to be initialized by I2C core:
i2c_register_driver() i2c_del_adapter()
driver_register() ...
bus_add_driver() ...
... bus_for_each_drv(..., __process_removed_adapter)
... i2c_do_del_adapter()
... list_for_each_entry_safe(..., &driver->clients, ...)
INIT_LIST_HEAD(&driver->clients);
To solve the problem it is sufficient to do clients list head
initialization before calling driver_register().
The problem was found while using an I2C device driver with a sluggish
registration routine on a bus provided by a physically detachable I2C
master controller, but practically the oops may be reproduced under
the race between arbitraty I2C device driver registration and managing
I2C bus device removal e.g. by unbinding the latter over sysfs:
% echo 21a4000.i2c > /sys/bus/platform/drivers/imx-i2c/unbind
Unable to handle kernel NULL pointer dereference at virtual address 00000000
Internal error: Oops: 17 [#1] SMP ARM
CPU: 2 PID: 533 Comm: sh Not tainted 4.9.0-rc3+ #61
Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
task: e5ada400 task.stack: e4936000
PC is at i2c_do_del_adapter+0x20/0xcc
LR is at __process_removed_adapter+0x14/0x1c
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 10c5387d Table: 35bd004a DAC: 00000051
Process sh (pid: 533, stack limit = 0xe4936210)
Stack: (0xe4937d28 to 0xe4938000)
Backtrace:
[<c0667be0>] (i2c_do_del_adapter) from [<c0667cc0>] (__process_removed_adapter+0x14/0x1c)
[<c0667cac>] (__process_removed_adapter) from [<c0516998>] (bus_for_each_drv+0x6c/0xa0)
[<c051692c>] (bus_for_each_drv) from [<c06685ec>] (i2c_del_adapter+0xbc/0x284)
[<c0668530>] (i2c_del_adapter) from [<bf0110ec>] (i2c_imx_remove+0x44/0x164 [i2c_imx])
[<bf0110a8>] (i2c_imx_remove [i2c_imx]) from [<c051a838>] (platform_drv_remove+0x2c/0x44)
[<c051a80c>] (platform_drv_remove) from [<c05183d8>] (__device_release_driver+0x90/0x12c)
[<c0518348>] (__device_release_driver) from [<c051849c>] (device_release_driver+0x28/0x34)
[<c0518474>] (device_release_driver) from [<c0517150>] (unbind_store+0x80/0x104)
[<c05170d0>] (unbind_store) from [<c0516520>] (drv_attr_store+0x28/0x34)
[<c05164f8>] (drv_attr_store) from [<c0298acc>] (sysfs_kf_write+0x50/0x54)
[<c0298a7c>] (sysfs_kf_write) from [<c029801c>] (kernfs_fop_write+0x100/0x214)
[<c0297f1c>] (kernfs_fop_write) from [<c0220130>] (__vfs_write+0x34/0x120)
[<c02200fc>] (__vfs_write) from [<c0221088>] (vfs_write+0xa8/0x170)
[<c0220fe0>] (vfs_write) from [<c0221e74>] (SyS_write+0x4c/0xa8)
[<c0221e28>] (SyS_write) from [<c0108a20>] (ret_fast_syscall+0x0/0x1c)
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
commit 603616017c35f4d0fbdbcace72adf9bf949c4a65 upstream.
SMBus block command uses the first byte of buffer for the data length.
The dma_buffer should be increased by 1 to avoid the overrun issue.
Reported-by: Phil Endecott <phil_gjouf_endecott@chezphil.org>
Signed-off-by: Hoan Tran <hotran@apm.com>
commit 331dcf421c34d227784d07943eb01e4023a42b0a upstream.
If the i2c device is already runtime suspended, if qup_i2c_suspend is
executed during suspend-to-idle or suspend-to-ram it will result in the
following splat:
WARNING: CPU: 3 PID: 1593 at drivers/clk/clk.c:476 clk_core_unprepare+0x80/0x90
Modules linked in:
CPU: 3 PID: 1593 Comm: bash Tainted: G W 4.8.0-rc3 #14
Hardware name: Qualcomm Technologies, Inc. APQ 8016 SBC (DT)
PC is at clk_core_unprepare+0x80/0x90
LR is at clk_unprepare+0x28/0x40
pc : [<ffff0000086eecf0>] lr : [<ffff0000086f0c58>] pstate: 60000145
Call trace:
qup_i2c_disable_clocks+0x2c/0x68
qup_i2c_suspend+0x10/0x20
platform_pm_suspend+0x24/0x68
This patch fixes the issue by executing qup_i2c_pm_suspend_runtime
conditionally in qup_i2c_suspend.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
commit 371a015344b6e270e7e3632107d9554ec6d27a6b upstream.
the eg20t driver call request_irq() function before the pch_base_address,
base address of i2c controller's register, is assigned an effective value.
there is one possible scenario that an interrupt which isn't inside eg20t
arrives immediately after request_irq() is executed when i2c controller
shares an interrupt number with others. since the interrupt handler
pch_i2c_handler() has already active as shared action, it will be called
and read its own register to determine if this interrupt is from itself.
At that moment, since base address of i2c registers is not remapped
in kernel space yet,so the INT handler will access an illegal address
and then a error occurs.
Signed-off-by: Yadi.hu <yadi.hu@windriver.com>
