Proposed cleanups to the i2c-amd8111 SMBus driver:
* Fold long lines.
* Add an explicit mask when writing the low byte of a word.
* Use I2C_SMBUS_BLOCK_MAX instead of hardcoding 32.
* Discard extra blank lines.
* Use boolean not instead of bitwise not for bit tests, it's clearer.
* Return -EBUSY rather than -1 on I/O resource conflict.
* Fix a race on device registration, initialization should be done
before the bus is registered.
This simple patch adds support to i2c-parport for the One For All remote
JP1 parallel port interfaces which can be found detailed at:
http://www.hifi-remote.com/jp1/hardware.shtml
These allow access to the internal configuration EEPROM on various
remote controls and there are a variety of Windows tools that make use
of this hardware. I have tested this patch with the "simple" parallel
port device and a One For All URC-7562 and confirmed that the data read
using the eeprom i2c driver matches that returned by the Windows "IR"
JP1 tool.
Signed-off-by: Jonathan McDowell <noodles@earth.li>
We do not have any documentation for the CX700, but it was reported
to work fine. Thanks to Claas Langbehn for testing.
IDs have been defined but not used by most of the I2C adapters.
By having a unique ID, clients can check for correct connection
during probe.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Driver model updates for the I2C core:
- Add new suspend(), resume(), and shutdown() methods. Use them in the
standard driver model style; document them.
- Minor doc updates to highlight zero-initialized fields in drivers, and
the driver model accessors for "clientdata".
If any i2c drivers were previously using the old suspend/resume calls
in "struct driver", they were getting warning messages ... and will
now no longer work. Other than that, this patch changes no behaviors;
and it lets I2C drivers use conventional PM and shutdown support.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
i2c-core and i2c-isa use completions without including
<linux/completion.h>. Fix it.
i2c-powermac includes <linux/completion.h> but doesn't use any
completion. Fix it.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: David Brownell <david-b@pacbell.net>
Add support for the ATI SB600 SMBus controller.
Cc: Hans-Frieder Vogt <hfvogt@gmx.net>
The i2c-ali1563 initialization looks quite broken to me:
* If the I/O space isn't enabled, we forcibly set 3 bits in
the PCI configuration space instead of just the one enabling
the I/O space.
* After that we pretend to check if the write worked, but we
don't actually read the new value from the register.
* It's probably not a good idea to enable the I/O space if no
base address has been set.
So I propose the following changes to that part of the driver:
* Merge ali1563_enable() into ali1563_setup().
* Check the base address before the I/O space enabled bit.
Acked-by: Rudolf Marek <r.marek@assembler.cz>
Improve the status messages printed by the i2c-ali1563 driver.
Cc: Rudolf Marek <r.marek@assembler.cz>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This moves <linux/usb_ch9.h> to <linux/usb/ch9.h> to reduce some of the
clutter of usb header files.
m41t00.c forgets to set the year field in set_rtc_time; fix that.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Acked-by: Mark A. Greer <mgreer@mvista.com>
I have a Marvell board which has the same i2c hw block than mv64xxx, so
I'm trying to use i2c-mv64xxx driver.
But I get the following random oops at boot:
Unable to handle kernel NULL pointer dereference at virtual address 00000002
Backtrace:
[<c0397e4c>] (mv64xxx_i2c_intr+0x0/0x2b8) from [<c02879c4>] (__do_irq+0x4c/0x8c)
[<c0287978>] (__do_irq+0x0/0x8c) from [<c0287c0c>] (do_level_IRQ+0x68/0xc0)
r8 = C0501E08 r7 = 00000005 r6 = C0501E08 r5 = 00000005
r4 = C048BB78
[<c0287ba4>] (do_level_IRQ+0x0/0xc0) from [<c02885f8>] (asm_do_IRQ+0x50/0x134)
r6 = C0449C78 r5 = F1020000 r4 = FFFFFFFF
[<c02885a8>] (asm_do_IRQ+0x0/0x134) from [<c02869c4>] (__irq_svc+0x24/0x100)
r8 = C1CAC400 r7 = 00000005 r6 = 00000002 r5 = F1020000
r4 = FFFFFFFF
[<c0287efc>] (setup_irq+0x0/0x124) from [<c02880d0>] (request_irq+0xb0/0xd0)
r7 = C041B2AC r6 = C0397E4C r5 = 00000000 r4 = 00000005
[<c0288020>] (request_irq+0x0/0xd0) from [<c03985f4>] (mv64xxx_i2c_probe+0x148/0x244)
[<c03984ac>] (mv64xxx_i2c_probe+0x0/0x244) from [<c038bedc>] (platform_drv_probe+0x20/0x24)
The oops is caused by a spurious interrupt that occurs when request_irq
is called. mv64xxx_i2c_fsm() tries to read drv_data->msg, which is NULL.
I noticed that hardware init is done after requesting irq. Thus any
pending irq from previous hardware usage may cause this.
The following patch fixes it:
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
Flag i2c_adapter.dev for removal after userspace tools get upgraded, and
include a near-term code migration aid to facilitate this:
- The class device gets the name attribute it should have had. This
was previously (wrongly) associated with the i2c_adapter.dev node.
Sysfs based tools and libraries can start converting right away.
- Issue a warning for legacy adapter drivers that don't provide any
physical device node; so systems with those drivers will know to
fix this problem earlier.
This is one of a series of patches to help the I2C stack become a better
citizen of the Linux Driver Model world.
This fixes two issues raised by David Brownell on the i2c list:
<< Someone needs to update i2c-pnx.c to handle the IRQ handler doesn't
expect pt_regs (gone now for a while), and so it doesn't try to
reference "mudule_init()" if I2C isn't initialized "early". For
that matter, to get rid of that _option_ to initialize then, and
always init that driver with subsystem_init() ... it's common with
embedded systems to need I2C access to tweak a GPIO expander or
do some other work when bringing up drivers, that's not specific
to USB stacks. >>
Signed-off-by: Vitaly Wool <vitalywool@gmail.com>
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6:
hwmon: Add MAINTAINERS entry for new ams driver
hwmon: New AMS hardware monitoring driver
hwmon/w83793: Add documentation and maintainer
hwmon: New Winbond W83793 hardware monitoring driver
hwmon: Update Rudolf Marek's e-mail address
hwmon/f71805f: Fix the device address decoding
hwmon/f71805f: Always create all fan inputs
hwmon/f71805f: Add support for the Fintek F71872F/FG chip
hwmon: New PC87427 hardware monitoring driver
hwmon/it87: Remove the SMBus interface support
hwmon/hdaps: Update the list of supported devices
hwmon/hdaps: Move the DMI detection data to .data
hwmon/pc87360: Autodetect the VRM version
hwmon/f71805f: Document the fan control features
hwmon/f71805f: Add support for "speed mode" fan speed control
hwmon/f71805f: Support DC fan speed control mode
hwmon/f71805f: Let the user adjust the PWM base frequency
hwmon/f71805f: Add manual fan speed control
hwmon/f71805f: Store the fan control registers
More fixes to build breakage from the work_struct changes ... this updates
the tps65010 driver. Plus, fix some dependencies related to the way it's
used on the OMAP OSK: force static linking there, since the resulting
kernel can't link.
NOTE that until the i2c core gets fixed to work without SMBUS_QUICK,
kernels needing this driver must still use "tps65010.force=0,0x48" on the
command line.
Cc: Jean Delvare <khali@linux-fr.org>
The Silicon Hill club is not what it used to be.
Signed-off-by: Rudolf Marek <r.marek@assembler.cz>
Refactor kfree(i2c_dev) into return_i2c_dev(). This saves some
code and makes more sense, as the memory is allocated in
get_free_i2c_dev().
Cc: Greg Kroah-Hartman <gregkh@suse.de>
device_create() returns error code as pointer on failures.
This patch checks the return value of device_create() by using IS_ERR().
Enable PEC on recent Intel SMBus controllers (ICH6, ICH7, ICH8, ICH9
and ESB2.)
Acked-by: Jason Gaston <jason.d.gaston@intel.com>
They are all only calling i2c_del_adapter, so we may as well do
it directly.
Add support for the I2C bus found on the ARM Versatile and Realview
platforms. The I2C bus has a RTC and optionally some EEPROMs attached.
On a custom board with ds1337 RTC I found that upgrade from 2.6.15 to
2.6.18 broke RTC support.
The main problem are changes to ds1337_init_client().
When a ds1337 recognizes a problem (e.g. power or clock failure) bit 7
in status register is set. This has to be reset by writing 0 to status
register. But since there are only 16 byte written to the chip and the
first byte is interpreted as an address, the status register (which is
the 16th) is never written.
The other problem is, that initializing all registers to zero is not
valid for day, date and month register. Funny enough this is checked by
ds1337_detect(), which depends on this values not being zero. So then
treated by ds1337_init_client() the ds1337 is not detected anymore,
whereas the failure bit in the status register is still set.
Signed-off-by: Dirk Stieler <stieler@gdsys.de>
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Remove extraneous whitespace from various i2c headers and core files,
like space-before-tab and whitespace at end of line.
This speeds up the I2C_FUNCS ioctl by 5 to 8% in my tests.
Laughed-at-by: Mark M. Hoffman <mhoffman@lightlink.com>
Add support for the I2C (Two-wire interface) controller integrated in
the Atmel AT91RM9200 processor. This driver should also be usable on
the Atmel AT91SAM9261 and AT91SAM9260 processors.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
This patch adds the 'level' field into the i2c_adapter structure, which is
used to represent the 'logical' level of nesting for the purposes of
lockdep. This field is then used in the i2c_transfer() function, to
acquire the per-adapter bus_lock with correct nesting level.
Signed-off-by: Jiri Kosina <jikos@jikos.cz>
Summary of changes:
- fixes:
o legacy I/O region size is 64 bytes, not 8 bytes
- general cleanup:
o removed code for the unsupported I2C block data, block data,
proc call and block proc call transfer modes
o removed detail warnings about unsupported modes that are
covered in a general warning (unsupported transaction...)
anyway
o removed necessity of a definition of struct i2c_adapter
o moved definition of struct i2c_algorithm, making forward
declarations of nforce2_access and nforce2_func unnecessary
- minor changes:
o in the description mention the nForce 5xx chipsets
o changes my e-mail address in MODULE_AUTHOR
Theses cleanups shrink the driver binary size from 4.0 kB to 2.7 kB
on i386.
Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net>
Reserving I/O memory for a driver with request_mem_region is necessary to
avoid memory access conflicts. Even if it's never going to happen, it is
cleaner and it allows to monitor I/O memory used in /proc/iomem.
Signed-off-by: Jean-Baptiste Maneyrol <jean-baptiste.maneyrol@teamlog.com>
New I2C bus driver for Philips ARM boards (Philips IP3204 I2C IP
block). This I2C controller can be found on (at least) PNX010x,
PNX52xx and PNX4008 Philips boards.
The rest of the ITE8172 support was already removed from MIPS tree.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (76 commits)
[ARM] 4002/1: S3C24XX: leave parent IRQs unmasked
[ARM] 4001/1: S3C24XX: shorten reboot time
[ARM] 3983/2: remove unused argument to __bug()
[ARM] 4000/1: Osiris: add third serial port in
[ARM] 3999/1: RX3715: suspend to RAM support
[ARM] 3998/1: VR1000: LED platform devices
[ARM] 3995/1: iop13xx: add iop13xx support
[ARM] 3968/1: iop13xx: add iop13xx_defconfig
[ARM] Update mach-types
[ARM] Allow gcc to optimise arm_add_memory a little more
[ARM] 3991/1: i.MX/MX1 high resolution time source
[ARM] 3990/1: i.MX/MX1 more precise PLL decode
[ARM] 3986/1: H1940: suspend to RAM support
[ARM] 3985/1: ixp4xx clocksource cleanup
[ARM] 3984/1: ixp4xx/nslu2: Fix disk LED numbering (take 2)
[ARM] 3994/1: ixp23xx: fix handling of pci master aborts
[ARM] 3981/1: sched_clock for PXA2xx
[ARM] 3980/1: extend the ARM Versatile sched_clock implementation from 32 to 63 bit
[ARM] 3979/1: extend the SA11x0 sched_clock implementation from 32 to 63 bit period
[ARM] 3978/1: macro to provide a 63-bit value from a 32-bit hardware counter
Merge:
Atmel AT91RM9200 and AT91SAM9260 changes
General ARM developments
Disconfiguous memory cleanups
64-bit/32-bit division and sched_clock extension patches
EP93xx support changes
IOP support changes
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a
Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory
controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz
PCI-X interface, a x8 PCI-Express interface, and other peripherals to form
a system-on-a-chip RAID subsystem engine.
The iop342 processor replaces the SAS controller with a second Xscale core
for dual core embedded applications.
The iop341 processor is the single core version of iop342.
This patch supports the two Intel customer reference platforms iq81340mc
for external storage and iq81340sc for direct attach (HBA) development.
The developer's manual is available here:
ftp://download.intel.com/design/iio/docs/31503701.pdf
Changelog:
* removed virtual addresses from resource definitions
* cleaned up some unnecessary #include's
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/infiniband/core/iwcm.c
drivers/net/chelsio/cxgb2.c
drivers/net/wireless/bcm43xx/bcm43xx_main.c
drivers/net/wireless/prism54/islpci_eth.c
drivers/usb/core/hub.h
drivers/usb/input/hid-core.c
net/core/netpoll.c
Fix up merge failures with Linus's head and fix new compilation failures.
Signed-Off-By: David Howells <dhowells@redhat.com>
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (28 commits)
PCI: make arch/i386/pci/common.c:pci_bf_sort static
PCI: ibmphp_pci.c: fix NULL dereference
pciehp: remove unnecessary pci_disable_msi
pciehp: remove unnecessary free_irq
PCI: rpaphp: change device tree examination
PCI: Change memory allocation for acpiphp slots
i2c-i801: SMBus patch for Intel ICH9
PCI: irq: irq and pci_ids patch for Intel ICH9
PCI: pci_{enable,disable}_device() nestable ports
PCI: switch pci_{enable,disable}_device() to be nestable
PCI: arch/i386/kernel/pci-dma.c: ioremap balanced with iounmap
pci/i386: style cleanups
PCI: Block on access to temporarily unavailable pci device
pci: fix __pci_register_driver error handling
pci: clear osc support flags if no _OSC method
acpiphp: fix missing acpiphp_glue_exit()
acpiphp: fix use of list_for_each macro
Altix: Initial ACPI support - ROM shadowing.
Altix: SN ACPI hotplug support.
Altix: Add initial ACPI IO support
As class_device is going away eventually...
This updated patch adds the Intel ICH9 LPC and SMBus Controller DID's. Thi=
s patch relies on the irq ICH9 patch to pci_ids.h.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
The i2c-pxa driver should not contain EEPROM slave-mode emulation;
this is something the platform should provide where required. Remove
it.
Fix recent i2c-ixp4xx compilation breakage. Sorry for overlooking it.
Fix up for make allyesconfig.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
i2c_bit_add_bus() returns -E;
-E != 0 => err = 1
probe fails with positive error code
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Deepak Saxena <dsaxena@mvista.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
