path: root/drivers/i2c/i2c-dev.c
2009-12-06i2c: Remove big kernel lock from i2cdev_openVincent Sanders
The BKL is held over a kmalloc so cannot protect anything beyond that. The two calls before the kmalloc have their own locking. Improve device open function by removing the now unnecessary ret variable Signed-off-by: Vincent Sanders <vince@simtec.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-02-24i2c-dev: Clarify the unit of ioctl I2C_TIMEOUTJean Delvare
The unit in which user-space can set the bus timeout value is jiffies for historical reasons (back when HZ was always 100.) This is however not good because user-space doesn't know how long a jiffy lasts. The timeout value should instead be set in a fixed time unit. Given the original value of HZ, this unit should be 10 ms, for compatibility. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-24i2c-dev: Return correct error code on class_create() failureSven Wegener
We need to convert the error pointer from class_create(), else we'll return the successful return code from register_chrdev() on failure. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-08-10i2c: correct some size_t printk formatsDavid Brownell
Fix various printk format strings where %zd was passed a size_t; those should be %zu instead. (Courtesy of a version of GCC which warns when these details are wrong.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-21device create: i2c: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: (56 commits) i2c: Add detection capability to new-style drivers i2c: Call client_unregister for new-style devices too i2c: Clean up old chip drivers i2c-ibm_iic: Register child nodes i2c: New-style EEPROM driver using device IDs i2c: Export the i2c_bus_type symbol i2c-au1550: Fix PM support i2c-dev: Delete empty detach_client callback i2c: Drop stray references to lm_sensors i2c: Check for ACPI resource conflicts i2c-ocores: basic PM support i2c-sibyte: SWARM I2C board initialization i2c-i801: Fix handling of error conditions i2c-i801: Rename local variable temp to status i2c-i801: Properly report bus arbitration loss i2c-i801: Remove verbose debugging messages i2c-algo-pcf: Drop unused struct members i2c-algo-pcf: Multi-master lost-arbitration improvement i2c: Deprecate the legacy gpio drivers i2c-pxa: Initialize early ...
2008-07-14i2c-dev: Delete empty detach_client callbackJean Delvare
Implementing detach_client is optional, so there is no point in an empty implementation. Likewise, i2c driver IDs are optional, and we don't need one. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Push ioctl BKL down into the i2c codeAlan Cox
This is part of the effort to get rid of the BKL. [JD: In fact i2c-dev doesn't need more locking than is already done for the other i2c drivers, so we can simply switch to unlocked_ioctl.] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-18i2c: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-22i2c-dev: Split i2cdev_ioctlJean Delvare
Split the handling of the I2C_RDWR and I2C_SMBUS ioctls to their own functions. This limits the stack usage, saves one level of indentation and makes the code more readable. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c: Stop using the redundant client listDavid Brownell
The i2c_adapter.clients list of i2c_client nodes duplicates driver model state. This patch starts removing that list, letting us remove most existing users of those i2c-core lists. * The core I2C code now iterates over the driver model's list instead of the i2c-internal one in some places where it's safe: - Passing a command/ioctl to each client, a mechanims used almost exclusively by DVB adapters; - Device address checking, in both i2c-core and i2c-dev. * Provide i2c_verify_client() to use with driver model iterators. * Flag the relevant i2c_adapter and i2c_client fields as deprecated, to help prevent new users from appearing. For the moment the list needs to stick around, since some issues show up when deleting devices created by legacy I2C drivers. (They don't follow standard driver model rules. Removing those devices can cause self-deadlocks.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-14i2c: Spelling fixesJoe Perches
[JD: One more fix in i2c-dev.] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-11-15i2c-dev: Unbound new-style i2c clients aren't busyJean Delvare
Let i2c-dev deal properly with new-style i2c clients. Instead of considering them always busy, it needs to check wether a driver is bound to them or not. This is still not completely correct, as the client could become busy later, but the same problem already existed before new-style clients were introduced. We'll want to fix it someday. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net>
2007-11-15i2c-dev: "how does it work" commentsDavid Brownell
This adds some "how does this work" comments to the i2c-dev driver, plus separators between the three main components: - The parallel list of i2c_adapters ("i2c_dev_list"), each of which gets a "struct i2c_dev" and a /dev/i2c-X character special file. - An i2cdev_driver gets adapter add/remove notifications, which are used to maintain that list of adapters. - Special file operations, which let userspace talk either directly to the adapter (for i2c_msg operations) or through cached addressing info using an anonymous i2c_client (never registered anywhere). Plus there's the usual module load/unload record keeping. After making sense of this code, I think that the anonymous i2c_client is pretty shady. But since it's never registered, using this code with a system set up for "new style" I2C drivers is no more complicated than always using the I2C_SLAVE_FORCE ioctl (instead of I2C_SLAVE). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c: Remove i2c_algorithm.algo_control()David Brownell
This removes: - An effectively unused hook: i2c_algorithm.algo_control. - The i2c_control() call, used only by i2c-dev to call that unused hook or set two barely supported adapter params. (That param setting moves into i2c-dev.c ... still iffy due to lack of locking, but no other changes.) As shown by diffstat, this is a net code shrink. It also reduces the complexity of the I2C adapter and /dev interfaces. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-13i2c-dev: Reject I2C_M_RECV_LENDavid Brownell
The I2C_M_RECV_LEN calling convention for i2c_mesg.flags involves playing games with reported buffer lengths. (They start out less than their actual size, and the length is then modified to reflect how many bytes were delivered ... which one hopes is less than the presumed actual size.) Refuse to play such error prone games across the boundary between userspace and kernel. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c: Fix the i2c_smbus_read_i2c_block_data() prototypeJean Delvare
Let the drivers specify how many bytes they want to read with i2c_smbus_read_i2c_block_data(). So far, the block count was hard-coded to I2C_SMBUS_BLOCK_MAX (32), which did not make much sense. Many driver authors complained about this before, and I believe it's about time to fix it. Right now, authors have to do technically stupid things, such as individual byte reads or full-fledged I2C messaging, to work around the problem. We do not want to encourage that. I even found that some bus drivers (e.g. i2c-amd8111) already implemented I2C block read the "right" way, that is, they didn't follow the old, broken standard. The fact that it was never noticed before just shows how little i2c_smbus_read_i2c_block_data() was used, which isn't that surprising given how broken its prototype was so far. There are some obvious compatiblity considerations: * This changes the i2c_smbus_read_i2c_block_data() prototype. Users outside the kernel tree will notice at compilation time, and will have to update their code. * User-space has access to i2c_smbus_xfer() directly using i2c-dev, so the changed expectations would affect tools such as i2cdump. In order to preserve binary compatibility, we give I2C_SMBUS_I2C_BLOCK_DATA a new numeric value, and define I2C_SMBUS_I2C_BLOCK_BROKEN with the old numeric value. When i2c-dev receives a transaction with the old value, it can convert it to the new format on the fly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10i2c: Refactor a kfree in i2c-devJean Delvare
Refactor kfree(i2c_dev) into return_i2c_dev(). This saves some code and makes more sense, as the memory is allocated in get_free_i2c_dev(). Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-10i2c: Fix return value check in i2c-devAkinobu Mita
device_create() returns error code as pointer on failures. This patch checks the return value of device_create() by using IS_ERR(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Whitespace cleanupsDavid Brownell
Remove extraneous whitespace from various i2c headers and core files, like space-before-tab and whitespace at end of line. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-10i2c: Use put_user instead of copy_to_user where possibleJean Delvare
This speeds up the I2C_FUNCS ioctl by 5 to 8% in my tests. Signed-off-by: Jean Delvare <khali@linux-fr.org> Laughed-at-by: Mark M. Hoffman <mhoffman@lightlink.com>
2006-12-08[PATCH] struct path: convert i2c-driversJosef Sipek
2006-12-01I2C: convert i2c-dev to use struct device instead of struct class_deviceGreg Kroah-Hartman
As class_device is going away eventually... Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-dev: attach/detach_adapter cleanupsJean Delvare
i2c-dev: attach/detach_adapter cleanups * Only print that an adapter was attached when it succeeds. * i2c_dev == NULL on detach simply means that the attach failed before, this isn't an error per se. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c: __must_check fixes, i2c-devJean Delvare
i2c: __must_check fixes (i2c-dev) Check for error on sysfs file creation. Check for error on device creation. Delete sysfs file on device destruction. I couldn't test this one beyond compilation, as it applies on top of another patch in Greg's tree [1] which breaks all my systems when I apply it (my udev isn't recent enough.) Anyone with bleeding edge udev is welcome to test and report. [1] http://www.kernel.org/pub/linux/kernel/people/gregkh/gregkh-2.6/patches/i2c/i2c-dev-device.patch Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-dev: Drop the client templateJean Delvare
i2c-dev: Drop the client template Drop the i2c-dev client template. This saves about 360 bytes of memory. I got the idea from a similar cleanup Hans-Frieder Vogt made to i2c-nforce2 recently. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-dev: Use a list for data storageJean Delvare
i2c-dev: Use a list for data storage Use a list instead of a static array for storing the i2c-dev data. Given that most systems have less than 10 i2c busses, most of the space was wasted, so this saves around 1 kB of memory (2 kB on 64-bit archs.) The drawback is that lookup was in O(1) and is now in O(N), but given that the values of N are always small, I don't think this is a problem. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26i2c-dev: CleanupsJean Delvare
i2c-dev: Cleanups * We no more need to include platform_device.h. * Delete the to_i2c_dev macro, which is no more used (and no more valid either.) * Drop i2c_dev.minor. Now that the minor number always matches the i2c adapter number, this field is redundant with i2c_dev.adap->nr. * Delete i2c_dev_get_by_adapter() which is now redundant with i2c_dev_get_by_minor() for the same reason. * Drop the local variable dev in i2cdev_attach_adapter(), we can easily do without it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] I2C: I2C controllers go into right place on sysfsDavid Brownell
I2C creates some sysfs nodes in the wrong places: not as children of parent controllers, but as their peers (!). This puts them into the right place always, instead of just when the adapter is on the platform bus. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: drop empty i2c_driver.command implementationsLaurent Riffard
Given that implementing i2c_driver.command is optional, there is no point in an empty implementation thereof. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Michael Geng <linux@MichaelGeng.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: move i2c-dev to use dynamic class devicesGreg Kroah-Hartman
i2c-dev doesn't use the reference counting logic of struct class_device so move it to the dynamic method. This makes the code paths simpler and the driver smaller. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 1 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the core of the i2c drivers: it removes .name and .owner fields from the struct i2c_device and modify various functions to use struct device fields instead. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] I2C: remove devfs support from i2c-dev driverGreg Kroah-Hartman
as devfs is gone, this isn't needed anymore. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: kzalloc conversion, other driversDeepak Saxena
Use kzalloc instead of kmalloc+memset in all remaining i2c bus and chip drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Cleanup i2c-dev ioctl debug messageJean Delvare
Cleanup the ioctl debug message in i2c-dev. In particular, the minor number is redundant now that the minor number and the adapter number are kept in sync. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Improve core debugging messagesJean Delvare
The debugging messages in i2c-core are more confusing than helpful. Some lack their trailing newline, some lack a prefix, some are redundant, some lack precious information. Here is my attempt to introduce some standardization in there. I also changed two messages in i2c-dev to make it clear they come from i2c-dev. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: Spelling fixes for drivers/i2c/i2c-dev.cTobias Klauser
This patch fixes a misspelling in a comment section. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: drivers/i2c/*: #include <linux/config.h> cleanupAlexey Dobriyan
Files that don't use CONFIG_* stuff shouldn't include config.h Files that use CONFIG_* stuff should include config.h It's that simple. ;-) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
