It seems that clk_use() and clk_unuse() are additional complexity
which isn't required anymore. Remove them from the clock framework
to avoid the additional confusion which they cause, and update all
ARM machine types except for OMAP.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
This patch updates the .owner field for various struct xxxx_driver variables,
other than pci_driver.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Signed-off-by: Jean Delvare <khali@linux-fr>
Acked-by: Mark A. Greer <mgreer@mvista.com>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Acked-by: Deepak Saxena <dsaxena@mvista.com>
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
The name member of the i2c_algorithm is never used, although all
drivers conscientiously fill it. We can drop it completely, this
structure doesn't need to have a name.
Here are some spelling corrections for drivers/i2c.
occured -> occurred
intialization -> initialization
Everytime -> Every time
transfering -> transferring
relevent -> relevant
continous -> continuous
neccessary -> necessary
explicitely -> explicitly
Celcius -> Celsius
differenciate -> differentiate
Signed-off-by: Steven Cole <elenstev@mesatop.com>
Files that don't use CONFIG_* stuff shouldn't include config.h
Files that use CONFIG_* stuff should include config.h
It's that simple. ;-)
Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru>
infrastructure for it.
Let it rip!
