path: root/drivers/i2c/busses/i2c-pxa.c
2008-10-07[ARM] pxa: move i2c register and bit definitions into i2c-pxa.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-03[ARM] 5278/1: i2c-pxa fast mode supportJonathan Cameron
Add fast_mode option to i2c_pxa_platform_data and use it to set the ICR_FM bit appropriately when i2c_pxa_reset is called. Parameter called fast_mode rather than frequency as this driver is also used for the i2c_pxa_pwr bus which has different normal and fast frequencies. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-09[I2C] pxa: provide late suspend and early resume hooksRussell King
Properly hook the I2C driver into the PM code; the previous fix for this (ece5f7b3c4fde70a1ae4add7372ebca5c90bc34d) worked around the platform where I2C is required to be available early during resume. It has been found to be sufficient to use the early resume hook for this function, so the original hack can die. Leave the hack in place for the PIO transfer handler though. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-09[ARM] 5203/1: i2c-pxa: fix scheduling while atomic in i2c_pxa_abort()Dmitry Baryshkov
i2c_pxa_abort can be called from the atomic context. Change it to use mdelay and counted loop. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-09[ARM] 5201/1: PXA3xx: Add support for power i2c busMike Rapoport
Add power I2C support for PXA3xx processors Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-15Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: (56 commits) i2c: Add detection capability to new-style drivers i2c: Call client_unregister for new-style devices too i2c: Clean up old chip drivers i2c-ibm_iic: Register child nodes i2c: New-style EEPROM driver using device IDs i2c: Export the i2c_bus_type symbol i2c-au1550: Fix PM support i2c-dev: Delete empty detach_client callback i2c: Drop stray references to lm_sensors i2c: Check for ACPI resource conflicts i2c-ocores: basic PM support i2c-sibyte: SWARM I2C board initialization i2c-i801: Fix handling of error conditions i2c-i801: Rename local variable temp to status i2c-i801: Properly report bus arbitration loss i2c-i801: Remove verbose debugging messages i2c-algo-pcf: Drop unused struct members i2c-algo-pcf: Multi-master lost-arbitration improvement i2c: Deprecate the legacy gpio drivers i2c-pxa: Initialize early ...
2008-07-14i2c-pxa: Initialize earlyUli Luckas
Initialize the pxa i2c bus during subsystem initialization to make it available during driver initialization (e.g. display powerup for pxafb). Signed-off-by: Uli Luckas <u.luckas@road.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-09Merge branches 'pxa-misc', 'pxa-pwm' and 'pxa-multi' into pxaRussell King
2008-07-07[ARM] 5135/1: pxa: drop superfluous asm/arch/pxa2xx-gpio.h includesPhilipp Zabel
Both i2c-pxa.c and irq.c still include pxa2xx-gpio.h although is is not needed anymore. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-06-02[ARM] 5075/1: i2c-pxa: move i2c pin setup and PCFR_PI2CEN handling into ↵Philipp Zabel
arch/arm/mach-pxa This fixes a build error introduced when the power manager register definitions were moved into pxa2xx-regs.h. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-22i2c: Fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable I2C platform drivers, to allow module auto loading. [ db: add some more drivers ] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-22i2c: Replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-24i2c-pxa: Misc fixesWolfram Sang
While working on the PCA9564-platform driver, I sometimes had a glimpse at the pxa-driver. I found some suspicious places, and this patch contains my suggestions. Note: They are not tested, due to no hardware. [JD: Some more fixes.] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Mike Rapoport <mike@compulab.co.il> Tested-by: Eric Miao <ymiao3@marvell.com>
2008-02-17[ARM] 4827/1: fix two warnings in drivers/i2c/busses/i2c-pxa.cHolger Schurig
This fixes two warnings: * unused static defined function decode_ICR() when compiled without CONFIG_I2C_PXA_SLAVE * a sparse warning about a void function returning something Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-27i2c-pxa: Add polling transferMike Rapoport
Add polling I2C transfer implementation for PXA I2C. This is needed for cases where I2C transactions have to occur at times interrups are disabled. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: eric miao <eric.miao@marvell.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-01-27i2c-pxa: Remove hardcoded #ifdef and use cpu_is_pxa27xeric miao
remove #ifdef CONFIG_PXA27x .. #endif and use cpu_is_pxaXXXX() macros so that a single binary can support PXA25x/PXA27x/PXA3xx at run-time. Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-19i2c-pxa, rename BIT macro to PXA_BITJiri Slaby
i2c-pxa, rename BIT macro to PXA_BIT BIT macro will be global definiton of (1 << x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Nicolas Pitre <nico@cam.org> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[ARM] pxa: update pxa i2c driver to use clk supportRussell King
2007-09-09i2c-pxa: Fix adapter numberJean Delvare
It turns out that platform_device.id is a "u32" so testing it for being nonnegative is useless when setting up an i2c adapte. Instead, do what the platform_bus code does and test it against the value "-1". Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-07-12i2c-pxa: Support new-style I2C driversRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-26[ARM] 4403/1: Make the PXA-I2C driver work with lockdep validatorEnrico Scholz
Using lockdep validator causes warnings like INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. [<c00241a0>] (dump_stack+0x0/0x14) from [<c00520f8>] (__lock_acquire+0x150/0xc40) [<c0051fa8>] (__lock_acquire+0x0/0xc40) from [<c00530a0>] (lock_acquire+0x5c/0x70) [<c0053044>] (lock_acquire+0x0/0x70) from [<c01d9e44>] (_spin_lock_irq+0x48/0x58) r7:c07e5144 r6:00000000 r5:c015fb94 r4:c07e50b8 [<c01d9dfc>] (_spin_lock_irq+0x0/0x58) from [<c015fb94>] (i2c_pxa_xfer+0x110/0x2e0) r5:c07e50b8 r4:0000001f This is caused by memcpy'ing a statical initialized spin-lock. This patch removes a static pxa_i2c structure which was used only as a source for this memcpy() operation. Instead of, members and the spinlock will be initialized manually. Signed-off-by: Enrico Scholz <enrico.scholz@sigma-chemnitz.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-10arm: fix i2c-pxa buildRussell King
From commit 7d054817b780e664bed6701b2aa637718e1905b7: > According to the PXA27x developer's manual, we shall do so. We shall also at least compile test our changes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (82 commits) [ARM] Add comments marking in-use ptrace numbers [ARM] Move syscall saving out of the way of utrace [ARM] 4360/1: S3C24XX: regs-udc.h remove unused macro [ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h header [ARM] mm 10: allow memory type to be specified with ioremap [ARM] mm 9: add additional device memory types [ARM] mm 8: define mem_types table L1 bit 4 to be for ARMv6 [ARM] iop: add missing parens in macro [ARM] mm 7: remove duplicated __ioremap() prototypes ARM: OMAP: fix OMAP1 mpuio suspend/resume oops ARM: OMAP: MPUIO wake updates ARM: OMAP: speed up gpio irq handling ARM: OMAP: plat-omap changes for 2430 SDP ARM: OMAP: gpio object shrinkage, cleanup ARM: OMAP: /sys/kernel/debug/omap_gpio ARM: OMAP: Implement workaround for GPIO wakeup bug in OMAP2420 silicon ARM: OMAP: Enable 24xx GPIO autoidling [ARM] 4318/2: DSM-G600 Board Support [ARM] 4227/1: minor head.S fixups [ARM] 4328/1: Move i.MX UART regs to driver ...
2007-05-01i2c: SPIN_LOCK_UNLOCKED cleanupMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup, use __SPIN_LOCK_UNLOCKED instead. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-05-01i2c-pxa: Clean transaction stopJean Delvare
It was reported to me that the i2c-pxa driver was not able to process more that 50 transactions per second. Investigation revealed that the I2C unit was busy for 20 ms after every transaction. The reason seems to be that we forget to clear the STOP and ACKNACK bits at the end of the transaction. According to the PXA27x developer's manual, we shall do so. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Nicolas Pitre <nico@cam.org>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4246/1: i2c-pxa: add adapter class to platform specific dataMatej Kenda
Reposted patch for kernel 2.6.21-rc2. The driver i2c-pxa doesn't set the class member in i2c_adapter, which is used to register the I2C adapter. The hwmon (sensors) drivers (e.g. adm1021) that are connected to a i2c-pxa adapter don't attach because they expect that the adapter supports class I2C_CLASS_HWMON. This patch adds functionality to allow platforms to set the class and pass it as platform_data to the i2c-pxa driver. Sample usage in platform code: static struct i2c_pxa_platform_data my_i2c_platform_data = { .class = I2C_CLASS_HWMON }; static void __init my_platform_init(void) { (void) platform_add_devices(devices, ARRAY_SIZE(devices)); pxa_set_i2c_info(&my_i2c_platform_data); } Signed-off-by: Matej Kenda <matej.kenda@hermes-softlab.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4144/1: Fix for patch #4099/1 with CONFIG_I2C_PXA_SLAVE setGuennadi Liakhovetski
Switch the i2c-pxa driver to actually using the platform device information and let it handle the power i2c bus on pxa27x too. Original version of this patch didn't compile with CONFIG_I2C_PXA_SLAVE set. Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove EEPROM slave emulation from i2c-pxa driver.Russell King
The i2c-pxa driver should not contain EEPROM slave-mode emulation; this is something the platform should provide where required. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-28[ARM] Fix i2c-pxa slave mode supportRussell King
i2c-pxa times out when trying to enable slave mode due to an incorrect test. Also, check that i2c->slave is non-NULL before dereferencing it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] i2c: Semaphore to mutex conversions, part 3Jean Delvare
Cleanup after the semaphores to mutexes conversions in the i2c subsystem. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-06[PATCH] i2c: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]). Some trailing whitespaces are also removed. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-12[ARM] 3237/1: PXA I2C driver updatesRichard Purdie
Patch from Richard Purdie This patch adds a check to see if the pxa i2c interface is enabled before allowing it to be used and resets it if found to be disabled. This automatically restores the interface if the device has been suspended and resumed without causing any suspend/resume call ordering issues. The patch also fixes a build warning and adds an appropriate module licence (the module is gpl according to the header). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-14[I2C] Add a functionality method, and remove algorithm idsRussell King
This allows i2c-pxa to finally build. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[I2C] Clean up i2c-pxa debugging/printksRussell King
Fix up comments made by review by gregkh. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-15[PATCH] I2C: Add PXA I2C driverRussell King
Add support for the I2C PXA driver. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
