The PM reference count is not expected to be incremented on
return in lpi2c_imx_master_enable.
However, pm_runtime_get_sync will increment the PM reference
count even failed. Forgetting to putting operation will result
in a reference leak here.
Replace it with pm_runtime_resume_and_get to keep usage
counter balanced.
Fixes: 13d6eb20fc79 ("i2c: imx-lpi2c: add runtime pm support")
Signed-off-by: Qinglang Miao <miaoqinglang@huawei.com>
Signed-off-by: Wolfram Sang <wsa@kernel.org>
it will print an error message by itself when platform_get_irq()
goes wrong. so don't need dev_err() in here again.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Suggested-by: Markus Elfring <Markus.Elfring@web.de>
Signed-off-by: Dejin Zheng <zhengdejin5@gmail.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Since we have generic definitions for bus frequencies, let's use them.
Reviewed-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de>
Acked-by: Robert Richter <rrichter@marvell.com>
Reviewed-by: Thor Thayer <thor.thayer@linux.intel.com>
Acked-by: Elie Morisse <syniurge@gmail.com>
Acked-by: Nehal Shah <nehal-bakulchandra.shah@amd.com>
Reviewed-by: Brendan Higgins <brendanhiggins@google.com>
Acked-by: Scott Branden <scott.branden@broadcom.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Baruch Siach <baruch@tkos.co.il>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Oleksij Rempel <o.rempel@pengutronix.de>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Reviewed-by: Chris Brandt <chris.brandt@renesas.com>
Reviewed-by: Baolin Wang <baolin.wang7@gmail.com>
Reviewed-by: Pierre-Yves MORDRET <pierre-yves.mordret@st.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Reviewed-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Use the new helper devm_platform_ioremap_resource() which wraps the
platform_get_resource() and devm_ioremap_resource() together, to
simplify the code.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Acked-by: Dong Aisheng <aisheng.dong@nxp.com>
Use __maybe_unused for power management related functions
instead of #if CONFIG_PM_SLEEP to simply the code.
mx8dv never entered into production and there is no other place
in the kernel referring to this SoC, so remove it from the
driver's compatible entry.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Adopt the SPDX license identifier headers to ease license compliance
management.
Because it looks neater.
For diolan, this allows factoring out some code that is now common
between if and else.
For eg20t, pch_i2c_writebytes is always called with a write in
msgs->flags, and pch_i2c_readbytes with a read.
For imx, i2c_imx_dma_write and i2c_imx_write are always called with a
write in msgs->flags, and i2c_imx_read with a read.
For qup, qup_i2c_write_tx_fifo_v1 is always called with a write in
qup->msg->flags.
For stu300, also restructure debug output for resends, since that
code as a result is only handling debug output.
Reviewed-by: Guenter Roeck <linux@roeck-us.net> [diolan]
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> [efm32 and imx]
Acked-by: Linus Walleij <linus.walleij@linaro.org> [stu300]
Signed-off-by: Peter Rosin <peda@axentia.se>
Add runtime pm support to dynamically manage the clock to avoid enable/disable
clock in frequently that can improve the i2c bus transfer performance.
And use pm_runtime_force_suspend/resume() instead of lpi2c_imx_suspend/resume().
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"I2C has for you two new drivers (Tegra BPMP and STM32F4), interrupt
support for pca954x muxes, and a bunch of driver bugfixes and
improvements. Nothing really special this cycle.
A few commits have been added to my tree just recently. Those are the
Tegra BPMP driver and a few straightforward bugfixes or cleanups which
I prefer to have upstream rather soonish. The rest had proper
linux-next exposure"
* 'i2c/for-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (25 commits)
i2c: thunderx: Replace pci_enable_msix()
i2c: exynos5: fix arbitration lost handling
i2c: exynos5: disable fifo-almost-empty irq signal when necessary
i2c: at91: ensure state is restored after suspending
i2c: bcm2835: Avoid possible NULL ptr dereference
i2c: Add Tegra BPMP I2C proxy driver
dt-bindings: Add Tegra186 BPMP I2C binding
misc: eeprom: at24: use device_property_*() functions instead of of_get_property()
i2c: mux: pca954x: Add interrupt controller support
dt: bindings: i2c-mux-pca954x: Add documentation for interrupt controller
i2c: mux: pca954x: Add missing pca9542 definition to chip_desc
i2c: riic: correctly finish transfers
i2c: i801: Add support for Intel Gemini Lake
i2c: mux: pca9541: Export OF device ID table as module aliases
i2c: mux: pca954x: Export OF device ID table as module aliases
i2c: mux: mlxcpld: remove unused including <linux/version.h>
i2c: busses: constify i2c_algorithm structures
i2c: i2c-mux-gpio: rename i2c-gpio-mux to i2c-mux-gpio
i2c: sh_mobile: document support for r8a7796 (R-Car M3-W)
i2c: i2c-cros-ec-tunnel: Reduce logging noise
Declare i2c_algorithm structures as const as they are only stored in the
algo field of an i2c_adapter structure. This field is of type const, so
i2c_algorithm structures having this property can be made const too.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> for
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
When system enters VLLS mode, module power is turned off. As a result,
all registers are reset to HW default value. After exiting VLLS mode,
registers are still in default mode. As a result, the pinctrl settings
are incorrect, which will affect the module function.
The patch recovers the pinctrl setting when exit VLLS mode.
Signed-off-by: Gao Pan <pandy.gao@nxp.com>
Reviewed-by: Vladimir Zapolskiy <vz@mleia.com>
[wsa: added missing include]
The lpi2c fifo size is a read only parameter resides Parameter
Register. It's better to read lpi2c tx/rx fifo size in probe()
other than just define a macro for it.
This patch adds lpi2c bus driver to support new i.MX products
which use lpi2c instead of the old imx i2c.
The lpi2c can continue operating in stop mode when an appropriate
clock is available. It is also designed for low CPU overhead with
DMA offloading of FIFO register accesses.
Reviewed-by: Fugang Duan <B38611@freescale.com>
