[ Upstream commit 6c7f25cae54b840302e4f1b371dbf318fbf09ab2 ]
According to Intel (R) Axxia TM Lionfish Communication Processor
Peripheral Subsystem Hardware Reference Manual, the AXXIA I2C module
have a programmable Master Wait Timer, which among others, checks the
time between commands send in manual mode. When a timeout (25ms) passes,
TSS bit is set in Master Interrupt Status register and a Stop command is
issued by the hardware.
The axxia_i2c_xfer(), does not properly handle this situation, however.
For each message a separate axxia_i2c_xfer_msg() is called and this
function incorrectly assumes that any interrupt might happen only when
waiting for completion. This is mostly correct but there is one
exception - a master timeout can trigger if enough time has passed
between individual transfers. It will, by definition, happen between
transfers when the interrupts are disabled by the code. If that happens,
the hardware issues Stop command.
The interrupt indicating timeout will not be triggered as soon as we
enable them since the Master Interrupt Status is cleared when master
mode is entered again (which happens before enabling irqs) meaning this
error is lost and the transfer is continued even though the Stop was
issued on the bus. The subsequent operations completes without error but
a bogus value (0xFF in case of read) is read as the client device is
confused because aborted transfer. No error is returned from
master_xfer() making caller believe that a valid value was read.
To fix the problem, the TSS bit (indicating timeout) in Master Interrupt
Status register is checked before each transfer. If it is set, there was
a timeout before this transfer and (as described above) the hardware
already issued Stop command so the transaction should be aborted thus
-ETIMEOUT is returned from the master_xfer() callback. In order to be
sure no timeout was issued we can't just read the status just before
starting new transaction as there will always be a small window of time
(few CPU cycles at best) where this might still happen. For this reason
we have to temporally disable the timer before checking for TSS bit.
Disabling it will, however, clear the TSS bit so in order to preserve
that information, we have to read it in ISR so we have to ensure that
the TSS interrupt is not masked between transfers of one transaction.
There is no need to call bus recovery or controller reinitialization if
that happens so it's skipped.
Signed-off-by: Krzysztof Adamski <krzysztof.adamski@nokia.com>
Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Because it looks neater.
For diolan, this allows factoring out some code that is now common
between if and else.
For eg20t, pch_i2c_writebytes is always called with a write in
msgs->flags, and pch_i2c_readbytes with a read.
For imx, i2c_imx_dma_write and i2c_imx_write are always called with a
write in msgs->flags, and i2c_imx_read with a read.
For qup, qup_i2c_write_tx_fifo_v1 is always called with a write in
qup->msg->flags.
For stu300, also restructure debug output for resends, since that
code as a result is only handling debug output.
Reviewed-by: Guenter Roeck <linux@roeck-us.net> [diolan]
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> [efm32 and imx]
Acked-by: Linus Walleij <linus.walleij@linaro.org> [stu300]
Signed-off-by: Peter Rosin <peda@axentia.se>
axxia_i2c_init() uses clk_get_rate() for idev->i2c_clk. clk_get_rate()
should only be called if the clock is enabled, so ensure that by moving
the clk_prepare_enable() call before the call to axxia_i2c_init().
Found by Linux Driver Verification project (linuxtesting.org).
Fixes: 08678b850cd0 ("i2c: axxia: Add I2C driver for AXM55xx")
Signed-off-by: Tobias Jordan <Tobias.Jordan@elektrobit.com>
Check for i2c_adapter_quirks structures that are only stored in the
quirks field of an i2c_adapter structure. This field is declared
const, so i2c_adapter_quirks structures that have this property can be
declared as const also.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Ray Jui <ray.jui@broadcom.com> # for bcm-iproc
axxia_i2c_probe() does not disable clock in case of failure
in i2c_add_adapter(). Also it ignores returned value from
clk_prepare_enable().
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
The core will do this for us now.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Acked-by: Peter Korsgaard <peter@korsgaard.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
Use recovery framework and implement bus recovery using "Bus Monitor" register.
Tests show that shortening SDA to GND results in "completion" timeout with
"BUSY" bit still set, so initiate recovery in this case.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
return type of wait_for_completion_timeout is unsigned long not int. The
return variable is renamed to reflect its use and the type adjusted to
unsigned long.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Add I2C bus driver for the controller found in the LSI Axxia family SoCs. The
driver implements 10-bit addressing and SMBus transfer modes via emulation
(including SMBus block data read).
Signed-off-by: Anders Berg <anders.berg@avagotech.com>
