path: root/drivers/i2c/busses/i2c-ali1563.c
2012-12-22i2c: remove __dev* attributes from subsystemBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> (for ocores and mux-gpio) Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> (for i2c-gpio) Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> (for puf3) Acked-by: Barry Song <baohua.song@csr.com> (for sirf) Reviewed-by: Jean Delvare <khali@linux-fr.org> [wsa: Fixed "foo* bar" flaws while we are here] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-07-24i2c/busses: Use module_pci_driverAxel Lin
Convert the drivers in drivers/i2c/busses/* to usemodule_pci_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Tomoya MORINAGA <tomoya.rohm@gmail.com>
2012-01-12i2c: Convert to DEFINE_PCI_DEVICE_TABLEAxel Lin
Convert static struct pci_device_id *[] to static DEFINE_PCI_DEVICE_TABLE tables. Use DEFINE_PCI_DEVICE_TABLE ensures we make the pci_device_id table const and marked as __devinitconst. This also fixes some warnings from checkpatch: e.g. WARNING: Use DEFINE_PCI_DEVICE_TABLE for struct pci_device_id #1096: FILE: i2c/busses/i2c-intel-mid.c:1096: +static struct pci_device_id intel_mid_i2c_ids[] = { Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Olof Johansson <olof@lixom.net> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Acked-by: Dirk Brandewie <dirk.brandewie@gmail.com> Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c: Make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-01-16i2c-ali1563: Remove sparse warningsMárton Németh
Remove the following sparse warnings (see "make C=1"): * drivers/i2c/busses/i2c-ali1563.c:91:3: warning: do-while statement is not a compound statement * drivers/i2c/busses/i2c-ali1563.c:161:3: warning: do-while statement is not a compound statement Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2009-01-07i2c: Use snprintf to set adapter namesJean Delvare
Use snprintf instead of sprintf to set adapter names, it's safer. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Check for ACPI resource conflictsJean Delvare
Check for ACPI resource conflicts in i2c bus drivers. I've included all recent SMBus master drivers for PC hardware. I've voluntarily left out: * Drivers that don't run on PCs: they can't conflict with ACPI. * Bit-banged bus device drivers: it's very unlikely that ACPI would deal with such buses. Signed-off-by: Jean Delvare <jdelvare@suse.de>
2008-07-14i2c: Let bus drivers add SPD to their classJean Delvare
Let general purpose I2C/SMBus bus drivers add SPD to their class. Once this is done, we will be able to tell the eeprom driver to only probe for SPD EEPROMs and similar on these buses. Note that I took a conservative approach here, adding I2C_CLASS_SPD to many drivers that have no idea whether they can host SPD EEPROMs or not. This is to make sure that the eeprom driver doesn't stop probing buses where SPD EEPROMs or equivalent live. So, bus driver maintainers and users should feel free to remove the SPD class from drivers those buses never have SPD EEPROMs or they don't want the eeprom driver to bind to them. Likewise, feel free to add the SPD class to any bus driver I might have missed. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Consistently reject unsupported transactionsJean Delvare
Many PC SMBus host controller drivers don't properly handle the case where they are requested to achieve a transaction they do not support. Update them so that the consistently print a warning message and return a single error value in this case. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-07-14i2c: Bus drivers return -Errno not -1David Brownell
Tighten error paths used by various i2c adapters (mostly x86) so they return real fault/errno codes instead of a "-1" (which is most often interpreted as "-EPERM"). Build tested, with eyeball review. One minor initial goal is to have adapters consistently return the code "-ENXIO" when addressing a device doesn't get an ACK response, at least in the probe paths where they are already good at stifling related logspam. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-ali1563: Fix device initializationJean Delvare
The i2c-ali1563 initialization looks quite broken to me: * If the I/O space isn't enabled, we forcibly set 3 bits in the PCI configuration space instead of just the one enabling the I/O space. * After that we pretend to check if the write worked, but we don't actually read the new value from the register. * It's probably not a good idea to enable the I/O space if no base address has been set. So I propose the following changes to that part of the driver: * Merge ali1563_enable() into ali1563_setup(). * Check the base address before the I/O space enabled bit. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Rudolf Marek <r.marek@assembler.cz>
2007-02-13i2c-ali1563: Improve the status messagesJean Delvare
Improve the status messages printed by the i2c-ali1563 driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rudolf Marek <r.marek@assembler.cz>
2006-12-12hwmon: Update Rudolf Marek's e-mail addressJean Delvare
The Silicon Hill club is not what it used to be. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-09-26i2c: Constify i2c_algorithm declarations, part 2Jean Delvare
i2c: Constify i2c_algorithm declarations, part 2 Make struct i2c_algorithm declarations const in all i2c bus drivers where it is possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-10-28[PATCH] Owner field additions to many i2c drivers, 1 of 5Laurent Riffard
This patch updates .owner field for various struct pci_driver variables. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] i2c: Reuse name strings in i2c bus driversJean Delvare
Clean up name string usage in 12 i2c bus drivers: * Use the i2c_adapter name for requesting the I/O region rather than redefining a new string. * Do not initialize the i2c_adapter name to "unset". This should save a few data bytes here and there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/i2c/busses/i2c-ali1535.c | 6 +++--- drivers/i2c/busses/i2c-ali1563.c | 6 ++++-- drivers/i2c/busses/i2c-ali15x3.c | 5 +++-- drivers/i2c/busses/i2c-amd756.c | 5 ++--- drivers/i2c/busses/i2c-amd8111.c | 4 +++- drivers/i2c/busses/i2c-i801.c | 4 ++-- drivers/i2c/busses/i2c-nforce2.c | 4 ++-- drivers/i2c/busses/i2c-piix4.c | 4 ++-- drivers/i2c/busses/i2c-sis5595.c | 5 +++-- drivers/i2c/busses/i2c-sis630.c | 6 ++++-- drivers/i2c/busses/i2c-sis96x.c | 5 +++-- drivers/i2c/busses/i2c-via.c | 4 ++-- 12 files changed, 33 insertions(+), 25 deletions(-)
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (4/7)Jean Delvare
There are no more users of i2c_algorithm.id, so we can finally drop this structure member. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.name (1/7)Jean Delvare
The name member of the i2c_algorithm is never used, although all drivers conscientiously fill it. We can drop it completely, this structure doesn't need to have a name. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-31[PATCH] I2C: ALI1563 SMBus driver fixR.Marek@sh.cvut.cz
This patch fixes "grave" bugs in i2c-ali1563 driver. It seems on recent chipset revisions the HSTS_DONE is set only for block transfers, so we must detect the end of ordinary transaction other way. Also due to missing and mask, setting other transfer modes was not possible. Moreover the continous byte mode transfer uses DAT0 for command rather than CMD command. All those changes were tested with help of Chunhao Huang from Winbond. I'm willing to maintain the driver. Second patch adds me as maintainer if this is neccessary. Signed-Off-By: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
