commit 6746eae4bbaddcc16b40efb33dab79210828b3ce upstream.
cti_enable_hw() and cti_disable_hw() are called from an atomic context
so shouldn't use runtime PM because it can result in a sleep when
communicating with firmware.
Since commit 3c6656337852 ("Revert "firmware: arm_scmi: Add clock
management to the SCMI power domain""), this causes a hang on Juno when
running the Perf Coresight tests or running this command:
perf record -e cs_etm//u -- ls
This was also missed until the revert commit because pm_runtime_put()
was called with the wrong device until commit 692c9a499b28 ("coresight:
cti: Correct the parameter for pm_runtime_put")
With lock and scheduler debugging enabled the following is output:
coresight cti_sys0: cti_enable_hw -- dev:cti_sys0 parent: 20020000.cti
BUG: sleeping function called from invalid context at drivers/base/power/runtime.c:1151
in_atomic(): 1, irqs_disabled(): 128, non_block: 0, pid: 330, name: perf-exec
preempt_count: 2, expected: 0
RCU nest depth: 0, expected: 0
INFO: lockdep is turned off.
irq event stamp: 0
hardirqs last enabled at (0): [<0000000000000000>] 0x0
hardirqs last disabled at (0): [<ffff80000822b394>] copy_process+0xa0c/0x1948
softirqs last enabled at (0): [<ffff80000822b394>] copy_process+0xa0c/0x1948
softirqs last disabled at (0): [<0000000000000000>] 0x0
CPU: 3 PID: 330 Comm: perf-exec Not tainted 6.0.0-00053-g042116d99298 #7
Hardware name: ARM LTD ARM Juno Development Platform/ARM Juno Development Platform, BIOS EDK II Sep 13 2022
Call trace:
dump_backtrace+0x134/0x140
show_stack+0x20/0x58
dump_stack_lvl+0x8c/0xb8
dump_stack+0x18/0x34
__might_resched+0x180/0x228
__might_sleep+0x50/0x88
__pm_runtime_resume+0xac/0xb0
cti_enable+0x44/0x120
coresight_control_assoc_ectdev+0xc0/0x150
coresight_enable_path+0xb4/0x288
etm_event_start+0x138/0x170
etm_event_add+0x48/0x70
event_sched_in.isra.122+0xb4/0x280
merge_sched_in+0x1fc/0x3d0
visit_groups_merge.constprop.137+0x16c/0x4b0
ctx_sched_in+0x114/0x1f0
perf_event_sched_in+0x60/0x90
ctx_resched+0x68/0xb0
perf_event_exec+0x138/0x508
begin_new_exec+0x52c/0xd40
load_elf_binary+0x6b8/0x17d0
bprm_execve+0x360/0x7f8
do_execveat_common.isra.47+0x218/0x238
__arm64_sys_execve+0x48/0x60
invoke_syscall+0x4c/0x110
el0_svc_common.constprop.4+0xfc/0x120
do_el0_svc+0x34/0xc0
el0_svc+0x40/0x98
el0t_64_sync_handler+0x98/0xc0
el0t_64_sync+0x170/0x174
Fix the issue by removing the runtime PM calls completely. They are not
needed here because it must have already been done when building the
path for a trace.
Fixes: 835d722ba10a ("coresight: cti: Initial CoreSight CTI Driver")
Cc: stable <stable@kernel.org>
Reported-by: Aishwarya TCV <Aishwarya.TCV@arm.com>
Reported-by: Cristian Marussi <Cristian.Marussi@arm.com>
Suggested-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: James Clark <james.clark@arm.com>
Reviewed-by: Mike Leach <mike.leach@linaro.org>
Tested-by: Mike Leach <mike.leach@linaro.org>
[ Fix build warnings ]
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Link: https://lore.kernel.org/r/20221025131032.1149459-1-suzuki.poulose@arm.com
[ Upstream commit 4d45bc82df667ad9e9cb8361830e54fc1264e993 ]
When the following configs are enabled:
* CORESIGHT
* CORESIGHT_SOURCE_ETM4X
* UBSAN
* UBSAN_TRAP
Clang fails assemble the kernel with the error:
<instantiation>:1:7: error: expected constant expression in '.inst' directive
.inst (0xd5200000|((((2) << 19) | ((1) << 16) | (((((((((((0x160 + (i * 4))))) >> 2))) >> 7) & 0x7)) << 12) | ((((((((((0x160 + (i * 4))))) >> 2))) & 0xf)) << 8) | (((((((((((0x160 + (i * 4))))) >> 2))) >> 4) & 0x7)) << 5)))|(.L__reg_num_x8))
drivers/hwtracing/coresight/coresight-etm4x-core.c:702:4: note: while in
macro instantiation
etm4x_relaxed_read32(csa, TRCCNTVRn(i));
drivers/hwtracing/coresight/coresight-etm4x.h:403:4: note: expanded from
macro 'etm4x_relaxed_read32'
read_etm4x_sysreg_offset((offset), false)))
drivers/hwtracing/coresight/coresight-etm4x.h:383:12: note: expanded
from macro 'read_etm4x_sysreg_offset'
__val = read_etm4x_sysreg_const_offset((offset)); \
drivers/hwtracing/coresight/coresight-etm4x.h:149:2: note: expanded from
macro 'read_etm4x_sysreg_const_offset'
READ_ETM4x_REG(ETM4x_OFFSET_TO_REG(offset))
drivers/hwtracing/coresight/coresight-etm4x.h:144:2: note: expanded from
macro 'READ_ETM4x_REG'
read_sysreg_s(ETM4x_REG_NUM_TO_SYSREG((reg)))
arch/arm64/include/asm/sysreg.h:1108:15: note: expanded from macro
'read_sysreg_s'
asm volatile(__mrs_s("%0", r) : "=r" (__val)); \
arch/arm64/include/asm/sysreg.h:1074:2: note: expanded from macro '__mrs_s'
" mrs_s " v ", " __stringify(r) "\n" \
Consider the definitions of TRCSSCSRn and TRCCNTVRn:
drivers/hwtracing/coresight/coresight-etm4x.h:56
#define TRCCNTVRn(n) (0x160 + (n * 4))
drivers/hwtracing/coresight/coresight-etm4x.h:81
#define TRCSSCSRn(n) (0x2A0 + (n * 4))
Where the macro parameter is expanded to i; a loop induction variable
from etm4_disable_hw.
When any compiler can determine that loops may be unrolled, then the
__builtin_constant_p check in read_etm4x_sysreg_offset() defined in
drivers/hwtracing/coresight/coresight-etm4x.h may evaluate to true. This
can lead to the expression `(0x160 + (i * 4))` being passed to
read_etm4x_sysreg_const_offset. Via the trace above, this is passed
through READ_ETM4x_REG, read_sysreg_s, and finally to __mrs_s where it
is string-ified and used directly in inline asm.
Regardless of which compiler or compiler options determine whether a
loop can or can't be unrolled, which determines whether
__builtin_constant_p evaluates to true when passed an expression using a
loop induction variable, it is NEVER safe to allow the preprocessor to
construct inline asm like:
asm volatile (".inst (0x160 + (i * 4))" : "=r"(__val));
^ expected constant expression
Instead of read_etm4x_sysreg_offset() using __builtin_constant_p(), use
__is_constexpr from include/linux/const.h instead to ensure only
expressions that are valid integer constant expressions get passed
through to read_sysreg_s().
This is not a bug in clang; it's a potentially unsafe use of the macro
arguments in read_etm4x_sysreg_offset dependent on __builtin_constant_p.
Link: https://github.com/ClangBuiltLinux/linux/issues/1310
Reported-by: Arnd Bergmann <arnd@kernel.org>
Reported-by: Tao Zhang <quic_taozha@quicinc.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Link: https://lore.kernel.org/r/20220708231520.3958391-1-ndesaulniers@google.com
[ Upstream commit ff46a601afc5a66a81c3945b83d0a2caeb88e8bc ]
Add support for the Trace Hub in Raptor Lake-S CPU.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Link: https://lore.kernel.org/r/20220705082637.59979-7-alexander.shishkin@linux.intel.com
[ Upstream commit 23e2de5826e2fc4dd43e08bab3a2ea1a5338b063 ]
Add support for the Trace Hub in Raptor Lake-S PCH.
Link: https://lore.kernel.org/r/20220705082637.59979-6-alexander.shishkin@linux.intel.com
[ Upstream commit 802a9a0b1d91274ef10d9fe429b4cc1e8c200aef ]
Add support for the Trace Hub in Meteor Lake-P.
Link: https://lore.kernel.org/r/20220705082637.59979-5-alexander.shishkin@linux.intel.com
[ Upstream commit ac12ad3ccf6d386e64a9d6a890595a2509d24edd ]
After commit f5ff79fddf0e ("dma-mapping: remove CONFIG_DMA_REMAP") there's
a chance of DMA buffer getting allocated via vmalloc(), which messes up
the mmapping code:
> RIP: msc_mmap_fault [intel_th_msu]
> Call Trace:
> <TASK>
> __do_fault
> do_fault
Fix this by accounting for vmalloc possibility.
Fixes: ba39bd830605 ("intel_th: msu: Switch over to scatterlist")
Link: https://lore.kernel.org/r/20220705082637.59979-4-alexander.shishkin@linux.intel.com
[ Upstream commit 82f76a4a720791d889de775b5f7541d601efc8bd ]
The return value of dma_alloc_coherent() needs to be checked.
To avoid use of null pointer in sg_set_buf() in case of the failure of
alloc.
Fixes: f220df66f676 ("intel_th: msu-sink: An example msu buffer "sink"")
Signed-off-by: Jiasheng Jiang <jiasheng@iscas.ac.cn>
Link: https://lore.kernel.org/r/20220705082637.59979-3-alexander.shishkin@linux.intel.com
[ Upstream commit 086c28ab7c5699256aced0049aae9c42f1410313 ]
If an error occurs after calling 'pci_alloc_irq_vectors()',
'pci_free_irq_vectors()' must be called as already done in the remove
function.
Fixes: 7b7036d47c35 ("intel_th: pci: Use MSI interrupt signalling")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Link: https://lore.kernel.org/r/20220705082637.59979-2-alexander.shishkin@linux.intel.com
commit 2af89ebacf299b7fba5f3087d35e8a286ec33706 upstream.
coresight devices track their connections (output connections) and
hold a reference to the fwnode. When a device goes away, we walk through
the devices on the coresight bus and make sure that the references
are dropped. This happens both ways:
a) For all output connections from the device, drop the reference to
the target device via coresight_release_platform_data()
b) Iterate over all the devices on the coresight bus and drop the
reference to fwnode if *this* device is the target of the output
connection, via coresight_remove_conns()->coresight_remove_match().
However, the coresight_remove_match() doesn't clear the fwnode field,
after dropping the reference, this causes use-after-free and
additional refcount drops on the fwnode.
e.g., if we have two devices, A and B, with a connection, A -> B.
If we remove B first, B would clear the reference on B, from A
via coresight_remove_match(). But when A is removed, it still has
a connection with fwnode still pointing to B. Thus it tries to drops
the reference in coresight_release_platform_data(), raising the bells
like :
[ 91.990153] ------------[ cut here ]------------
[ 91.990163] refcount_t: addition on 0; use-after-free.
[ 91.990212] WARNING: CPU: 0 PID: 461 at lib/refcount.c:25 refcount_warn_saturate+0xa0/0x144
[ 91.990260] Modules linked in: coresight_funnel coresight_replicator coresight_etm4x(-)
crct10dif_ce coresight ip_tables x_tables ipv6 [last unloaded: coresight_cpu_debug]
[ 91.990398] CPU: 0 PID: 461 Comm: rmmod Tainted: G W T 5.19.0-rc2+ #53
[ 91.990418] Hardware name: ARM LTD ARM Juno Development Platform/ARM Juno Development Platform, BIOS EDK II Feb 1 2019
[ 91.990434] pstate: 600000c5 (nZCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 91.990454] pc : refcount_warn_saturate+0xa0/0x144
[ 91.990476] lr : refcount_warn_saturate+0xa0/0x144
[ 91.990496] sp : ffff80000c843640
[ 91.990509] x29: ffff80000c843640 x28: ffff800009957c28 x27: ffff80000c8439a8
[ 91.990560] x26: ffff00097eff1990 x25: ffff8000092b6ad8 x24: ffff00097eff19a8
[ 91.990610] x23: ffff80000c8439a8 x22: 0000000000000000 x21: ffff80000c8439c2
[ 91.990659] x20: 0000000000000000 x19: ffff00097eff1a10 x18: ffff80000ab99c40
[ 91.990708] x17: 0000000000000000 x16: 0000000000000000 x15: ffff80000abf6fa0
[ 91.990756] x14: 000000000000001d x13: 0a2e656572662d72 x12: 657466612d657375
[ 91.990805] x11: 203b30206e6f206e x10: 6f69746964646120 x9 : ffff8000081aba28
[ 91.990854] x8 : 206e6f206e6f6974 x7 : 69646461203a745f x6 : 746e756f63666572
[ 91.990903] x5 : ffff00097648ec58 x4 : 0000000000000000 x3 : 0000000000000027
[ 91.990952] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00080260ba00
[ 91.991000] Call trace:
[ 91.991012] refcount_warn_saturate+0xa0/0x144
[ 91.991034] kobject_get+0xac/0xb0
[ 91.991055] of_node_get+0x2c/0x40
[ 91.991076] of_fwnode_get+0x40/0x60
[ 91.991094] fwnode_handle_get+0x3c/0x60
[ 91.991116] fwnode_get_nth_parent+0xf4/0x110
[ 91.991137] fwnode_full_name_string+0x48/0xc0
[ 91.991158] device_node_string+0x41c/0x530
[ 91.991178] pointer+0x320/0x3ec
[ 91.991198] vsnprintf+0x23c/0x750
[ 91.991217] vprintk_store+0x104/0x4b0
[ 91.991238] vprintk_emit+0x8c/0x360
[ 91.991257] vprintk_default+0x44/0x50
[ 91.991276] vprintk+0xcc/0xf0
[ 91.991295] _printk+0x68/0x90
[ 91.991315] of_node_release+0x13c/0x14c
[ 91.991334] kobject_put+0x98/0x114
[ 91.991354] of_node_put+0x24/0x34
[ 91.991372] of_fwnode_put+0x40/0x5c
[ 91.991390] fwnode_handle_put+0x38/0x50
[ 91.991411] coresight_release_platform_data+0x74/0xb0 [coresight]
[ 91.991472] coresight_unregister+0x64/0xcc [coresight]
[ 91.991525] etm4_remove_dev+0x64/0x78 [coresight_etm4x]
[ 91.991563] etm4_remove_amba+0x1c/0x2c [coresight_etm4x]
[ 91.991598] amba_remove+0x3c/0x19c
Reproducible by: (Build all coresight components as modules):
#!/bin/sh
while true
do
for m in tmc stm cpu_debug etm4x replicator funnel
do
modprobe coresight_${m}
done
do
rmmode coresight_${m}
done
done
Cc: stable@vger.kernel.org
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Mike Leach <mike.leach@linaro.org>
Cc: Leo Yan <leo.yan@linaro.org>
Fixes: 37ea1ffddffa ("coresight: Use fwnode handle instead of device names")
Link: https://lore.kernel.org/r/20220614214024.3005275-1-suzuki.poulose@arm.com
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
[ Upstream commit 1adff542d67a2ed1120955cb219bfff8a9c53f59 ]
The panic notifier infrastructure executes registered callbacks when
a panic event happens - such callbacks are executed in atomic context,
with interrupts and preemption disabled in the running CPU and all other
CPUs disabled. That said, mutexes in such context are not a good idea.
This patch replaces a regular mutex with a mutex_trylock safer approach;
given the nature of the mutex used in the driver, it should be pretty
uncommon being unable to acquire such mutex in the panic path, hence
no functional change should be observed (and if it is, that would be
likely a deadlock with the regular mutex).
Fixes: 2227b7c74634 ("coresight: add support for CPU debug module")
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@igalia.com>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Link: https://lore.kernel.org/r/20220427224924.592546-10-gpiccoli@igalia.com
commit 8c1d3f79d9ca48e406b78e90e94cf09a8c076bf2 upstream.
It is possibe that probe failure issue happens when the device
and its child_device's probe happens at the same time.
In coresight_make_links, has_conns_grp is true for parent, but
has_conns_grp is false for child device as has_conns_grp is set
to true in coresight_create_conns_sysfs_group. The probe of parent
device will fail at this condition. Add has_conns_grp check for
child device before make the links and make the process from
device_register to connection_create be atomic to avoid this
probe failure issue.
Suggested-by: Mike Leach <mike.leach@linaro.org>
Signed-off-by: Mao Jinlong <quic_jinlmao@quicinc.com>
Link: https://lore.kernel.org/r/20220309142206.15632-1-quic_jinlmao@quicinc.com
[ Added Cc stable ]
commit cfa5dbcdd7aece76f3415284569f2f384aff0253 upstream.
device_register() calls device_initialize(),
according to doc of device_initialize:
Use put_device() to give up your reference instead of freeing
* @dev directly once you have called this function.
To prevent potential memleak, use put_device() for error handling.
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Fixes: 85e2414c518a ("coresight: syscfg: Initial coresight system configuration")
Link: https://lore.kernel.org/r/20220124124121.8888-1-linmq006@gmail.com
commit ea75a342aed5ed72c87f38fbe0df2f5df7eae374 upstream.
It's impossible to program a valid value for TRCCONFIGR.QE
when TRCIDR0.QSUPP==0b10. In that case the following is true:
Q element support is implemented, and only supports Q elements without
instruction counts. TRCCONFIGR.QE can only take the values 0b00 or 0b11.
Currently the low bit of QSUPP is checked to see if the low bit of QE can
be written to, but as you can see when QSUPP==0b10 the low bit is cleared
making it impossible to ever write the only valid value of 0b11 to QE.
0b10 would be written instead, which is a reserved QE value even for all
values of QSUPP.
The fix is to allow writing the low bit of QE for any non zero value of
QSUPP.
This change also ensures that the low bit is always set, even when the
user attempts to only set the high bit.
Fixes: d8c66962084f ("coresight-etm4x: Controls pertaining to the reset, mode, pe and events")
Link: https://lore.kernel.org/r/20220120113047.2839622-2-james.clark@arm.com
commit a08025b3fe56185290a1ea476581f03ca733f967 upstream.
If a CPU is offline during the driver init, we could end up causing
a kernel crash trying to register the coresight device for the TRBE
instance. The trbe_cpudata for the TRBE instance is initialized only
when it is probed. Otherwise, we could end up dereferencing a NULL
cpudata->drvdata.
e.g:
[ 0.149999] coresight ete0: CPU0: ete v1.1 initialized
[ 0.149999] coresight-etm4x ete_1: ETM arch init failed
[ 0.149999] coresight-etm4x: probe of ete_1 failed with error -22
[ 0.150085] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000050
[ 0.150085] Mem abort info:
[ 0.150085] ESR = 0x96000005
[ 0.150085] EC = 0x25: DABT (current EL), IL = 32 bits
[ 0.150085] SET = 0, FnV = 0
[ 0.150085] EA = 0, S1PTW = 0
[ 0.150085] Data abort info:
[ 0.150085] ISV = 0, ISS = 0x00000005
[ 0.150085] CM = 0, WnR = 0
[ 0.150085] [0000000000000050] user address but active_mm is swapper
[ 0.150085] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 0.150085] Modules linked in:
[ 0.150085] Hardware name: FVP Base RevC (DT)
[ 0.150085] pstate: 00800009 (nzcv daif -PAN +UAO -TCO BTYPE=--)
[ 0.150155] pc : arm_trbe_register_coresight_cpu+0x74/0x144
[ 0.150155] lr : arm_trbe_register_coresight_cpu+0x48/0x144
[ 0.150237] Call trace:
[ 0.150237] arm_trbe_register_coresight_cpu+0x74/0x144
[ 0.150237] arm_trbe_device_probe+0x1c0/0x2d8
[ 0.150259] platform_drv_probe+0x94/0xbc
[ 0.150259] really_probe+0x1bc/0x4a8
[ 0.150266] driver_probe_device+0x7c/0xb8
[ 0.150266] device_driver_attach+0x6c/0xac
[ 0.150266] __driver_attach+0xc4/0x148
[ 0.150266] bus_for_each_dev+0x7c/0xc8
[ 0.150266] driver_attach+0x24/0x30
[ 0.150266] bus_add_driver+0x100/0x1e0
[ 0.150266] driver_register+0x78/0x110
[ 0.150266] __platform_driver_register+0x44/0x50
[ 0.150266] arm_trbe_init+0x28/0x84
[ 0.150266] do_one_initcall+0x94/0x2bc
[ 0.150266] do_initcall_level+0xa4/0x158
[ 0.150266] do_initcalls+0x54/0x94
[ 0.150319] do_basic_setup+0x24/0x30
[ 0.150319] kernel_init_freeable+0xe8/0x14c
[ 0.150319] kernel_init+0x14/0x18c
[ 0.150319] ret_from_fork+0x10/0x30
[ 0.150319] Code: f94012c8 b0004ce2 9134a442 52819801 (f9402917)
[ 0.150319] ---[ end trace d23e0cfe5098535e ]---
[ 0.150346] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Fix this by skipping the step, if we are unable to probe the CPU.
Fixes: 3fbf7f011f24 ("coresight: sink: Add TRBE driver")
Reported-by: Bransilav Rankov <branislav.rankov@arm.com>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: stable <stable@vger.kernel.org>
Tested-by: Branislav Rankov <branislav.rankov@arm.com>
Reviewed-by: Anshuman Khandual <anshuman.khandual@arm.com>
Link: https://lore.kernel.org/r/20211014142238.2221248-1-suzuki.poulose@arm.com
commit bb5293e334af51b19b62d8bef1852ea13e935e9b upstream.
The TRBE driver wrongly treats the aux private data as the TRBE driver
specific buffer for a given perf handle, while it is the ETM PMU's
event specific data. Fix this by correcting the instance to use
appropriate helper.
Link: https://lore.kernel.org/r/20210921134121.2423546-2-suzuki.poulose@arm.com
[Fixed 13 character SHA down to 12]
commit 692c9a499b286ea478f41b23a91fe3873b9e1326 upstream.
The input parameter of the function pm_runtime_put should be the
same in the function cti_enable_hw and cti_disable_hw. The correct
parameter to use here should be dev->parent.
Signed-off-by: Tao Zhang <quic_taozha@quicinc.com>
Reviewed-by: Leo Yan <leo.yan@linaro.org>
Link: https://lore.kernel.org/r/1629365377-5937-1-git-send-email-quic_taozha@quicinc.com
This fixes warnings with -Wimplicit-function-declaration, e.g.
drivers/hwtracing/coresight/coresight-syscfg.c:455:15: error:
implicit declaration of function 'kzalloc' [-Werror,
-Wimplicit-function-declaration]
csdev_item = kzalloc(sizeof(struct cscfg_registered_csdev),
GFP_KERNEL);
Link: https://lore.kernel.org/r/20210830172820.2840433-1-jiancai@google.com
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Jian Cai <jiancai@google.com>
Link: https://lore.kernel.org/r/20210913164613.1675791-2-mathieu.poirier@linaro.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the big set of driver core patches for 5.15-rc1.
These do change a number of different things across different
subsystems, and because of that, there were 2 stable tags created that
might have already come into your tree from different pulls that did
the following
- changed the bus remove callback to return void
- sysfs iomem_get_mapping rework
Other than those two things, there's only a few small things in here:
- kernfs performance improvements for huge numbers of sysfs users at
once
- tiny api cleanups
- other minor changes
All of these have been in linux-next for a while with no reported
problems, other than the before-mentioned merge issue"
* tag 'driver-core-5.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (33 commits)
MAINTAINERS: Add dri-devel for component.[hc]
driver core: platform: Remove platform_device_add_properties()
ARM: tegra: paz00: Handle device properties with software node API
bitmap: extend comment to bitmap_print_bitmask/list_to_buf
drivers/base/node.c: use bin_attribute to break the size limitation of cpumap ABI
topology: use bin_attribute to break the size limitation of cpumap ABI
lib: test_bitmap: add bitmap_print_bitmask/list_to_buf test cases
cpumask: introduce cpumap_print_list/bitmask_to_buf to support large bitmask and list
sysfs: Rename struct bin_attribute member to f_mapping
sysfs: Invoke iomem_get_mapping() from the sysfs open callback
debugfs: Return error during {full/open}_proxy_open() on rmmod
zorro: Drop useless (and hardly used) .driver member in struct zorro_dev
zorro: Simplify remove callback
sh: superhyway: Simplify check in remove callback
nubus: Simplify check in remove callback
nubus: Make struct nubus_driver::remove return void
kernfs: dont call d_splice_alias() under kernfs node lock
kernfs: use i_lock to protect concurrent inode updates
kernfs: switch kernfs to use an rwsem
kernfs: use VFS negative dentry caching
The functions get_online_cpus() and put_online_cpus() have been
deprecated during the CPU hotplug rework. They map directly to
cpus_read_lock() and cpus_read_unlock().
Replace deprecated CPU-hotplug functions with the official version.
The behavior remains unchanged.
Link: https://lore.kernel.org/r/20210803141621.780504-15-bigeasy@linutronix.de
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: coresight@lists.linaro.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: https://lore.kernel.org/r/20210818194022.379573-12-mathieu.poirier@linaro.org
Adds configfs subsystem and attributes to the configuration manager
to enable the listing of loaded configurations and features.
The default values of feature parameters can be accessed and altered
from these attributes to affect all installed devices using the feature.
Link: https://lore.kernel.org/r/20210723165444.1048-10-mike.leach@linaro.org
Signed-off-by: Mike Leach <mike.leach@linaro.org>
Link: https://lore.kernel.org/r/20210818194022.379573-10-mathieu.poirier@linaro.org
Preload set of configurations.
This patch creates a small set of preloaded configurations and features
that are available immediately after coresight has been initialised.
The current set provides a strobing feature for ETMv4, that creates a
periodic sampling of trace by switching trace generation on and off
using counters in the ETM.
A configuration called "autofdo" is also provided that uses the 'strobing'
feature and provides a couple of preset values, selectable on the perf
command line.
Link: https://lore.kernel.org/r/20210723165444.1048-9-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-9-mathieu.poirier@linaro.org
Adds in handlers to allow the ETMv4 to use the complex configuration
support. Features and configurations can be loaded and selected in the
device.
Link: https://lore.kernel.org/r/20210723165444.1048-8-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-8-mathieu.poirier@linaro.org
Add calls to activate the selected configuration as perf starts
and stops the tracing session.
Link: https://lore.kernel.org/r/20210723165444.1048-7-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-7-mathieu.poirier@linaro.org
Configurations are first activated, then when any coresight device is
enabled, the active configurations are checked and any matching
one is enabled.
This patch provides the activation / enable API.
Link: https://lore.kernel.org/r/20210723165444.1048-6-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-6-mathieu.poirier@linaro.org
Loaded coresight configurations are registered in the cs_etm\events sub
directory. This extends the etm-perf code to handle these registrations,
and the cs_syscfg driver to perform the registration on load.
Link: https://lore.kernel.org/r/20210723165444.1048-5-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-5-mathieu.poirier@linaro.org
Adds a set of generic support functions that allow devices to set and save
features values on the device, and enable and disable configurations.
Additional functions for other common operations including feature
reset.
Link: https://lore.kernel.org/r/20210723165444.1048-4-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-4-mathieu.poirier@linaro.org
API for individual devices to register with the syscfg management
system is added.
Devices register with matching information, and any features or
configurations that match will be loaded into the device.
The feature and configuration loading is extended so that on load these
are loaded into any currently registered devices. This allows
configuration loading after devices have been registered.
Link: https://lore.kernel.org/r/20210723165444.1048-3-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-3-mathieu.poirier@linaro.org
Creates an system management API to allow complex configurations and
features to be programmed into a CoreSight infrastructure.
A feature is defined as a programming set for a device or class of
devices.
A configuration is a set of features across the system that are enabled
for a trace session.
The API will manage system wide configuration, and allow complex
programmed features to be added to individual device instances, and
provide for system wide configuration selection on trace capture
operations.
This patch creates the initial data object and the initial API for
loading configurations and features.
Link: https://lore.kernel.org/r/20210723165444.1048-2-mike.leach@linaro.org
Link: https://lore.kernel.org/r/20210818194022.379573-2-mathieu.poirier@linaro.org
The driver core ignores the return value of this callback because there
is only little it can do when a device disappears.
This is the final bit of a long lasting cleanup quest where several
buses were converted to also return void from their remove callback.
Additionally some resource leaks were fixed that were caused by drivers
returning an error code in the expectation that the driver won't go
away.
With struct bus_type::remove returning void it's prevented that newly
implemented buses return an ignored error code and so don't anticipate
wrong expectations for driver authors.
Reviewed-by: Tom Rix <trix@redhat.com> (For fpga)
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Reviewed-by: Cornelia Huck <cohuck@redhat.com> (For drivers/s390 and drivers/vfio)
Acked-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk> (For ARM, Amba and related parts)
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Chen-Yu Tsai <wens@csie.org> (for sunxi-rsb)
Acked-by: Pali Rohár <pali@kernel.org>
Acked-by: Mauro Carvalho Chehab <mchehab@kernel.org> (for media)
Acked-by: Hans de Goede <hdegoede@redhat.com> (For drivers/platform)
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-By: Vinod Koul <vkoul@kernel.org>
Acked-by: Juergen Gross <jgross@suse.com> (For xen)
Acked-by: Lee Jones <lee.jones@linaro.org> (For mfd)
Acked-by: Johannes Thumshirn <jth@kernel.org> (For mcb)
Acked-by: Johan Hovold <johan@kernel.org>
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> (For slimbus)
Acked-by: Kirti Wankhede <kwankhede@nvidia.com> (For vfio)
Acked-by: Maximilian Luz <luzmaximilian@gmail.com>
Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> (For ulpi and typec)
Acked-by: Samuel Iglesias Gonsálvez <siglesias@igalia.com> (For ipack)
Acked-by: Geoff Levand <geoff@infradead.org> (For ps3)
Acked-by: Yehezkel Bernat <YehezkelShB@gmail.com> (For thunderbolt)
Acked-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> (For intel_th)
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> (For pcmcia)
Acked-by: Rafael J. Wysocki <rafael@kernel.org> (For ACPI)
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> (rpmsg and apr)
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> (For intel-ish-hid)
Acked-by: Dan Williams <dan.j.williams@intel.com> (For CXL, DAX, and NVDIMM)
Acked-by: William Breathitt Gray <vilhelm.gray@gmail.com> (For isa)
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (For firewire)
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> (For hid)
Acked-by: Thorsten Scherer <t.scherer@eckelmann.de> (For siox)
Acked-by: Sven Van Asbroeck <TheSven73@gmail.com> (For anybuss)
Acked-by: Ulf Hansson <ulf.hansson@linaro.org> (For MMC)
Acked-by: Wolfram Sang <wsa@kernel.org> # for I2C
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Finn Thain <fthain@linux-m68k.org>
Link: https://lore.kernel.org/r/20210713193522.1770306-6-u.kleine-koenig@pengutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char / misc driver updates from Greg KH:
"Here is the big set of char / misc and other driver subsystem updates
for 5.14-rc1. Included in here are:
- habanalabs driver updates
- fsl-mc driver updates
- comedi driver updates
- fpga driver updates
- extcon driver updates
- interconnect driver updates
- mei driver updates
- nvmem driver updates
- phy driver updates
- pnp driver updates
- soundwire driver updates
- lots of other tiny driver updates for char and misc drivers
This is looking more and more like the "various driver subsystems
mushed together" tree...
issues"
* tag 'char-misc-5.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (292 commits)
mcb: Use DEFINE_RES_MEM() helper macro and fix the end address
PNP: moved EXPORT_SYMBOL so that it immediately followed its function/variable
bus: mhi: pci-generic: Add missing 'pci_disable_pcie_error_reporting()' calls
bus: mhi: Wait for M2 state during system resume
bus: mhi: core: Fix power down latency
intel_th: Wait until port is in reset before programming it
intel_th: msu: Make contiguous buffers uncached
intel_th: Remove an unused exit point from intel_th_remove()
stm class: Spelling fix
nitro_enclaves: Set Bus Master for the NE PCI device
misc: ibmasm: Modify matricies to matrices
misc: vmw_vmci: return the correct errno code
siox: Simplify error handling via dev_err_probe()
fpga: machxo2-spi: Address warning about unused variable
lkdtm/heap: Add init_on_alloc tests
selftests/lkdtm: Enable various testable CONFIGs
lkdtm: Add CONFIG hints in errors where possible
lkdtm: Enable DOUBLE_FAULT on all architectures
lkdtm/heap: Add vmalloc linear overflow test
lkdtm/bugs: XFAIL UNALIGNED_LOAD_STORE_WRITE
kernel.h is being used as a dump for all kinds of stuff for a long time.
Here is the attempt to start cleaning it up by splitting out panic and
oops helpers.
There are several purposes of doing this:
- dropping dependency in bug.h
- dropping a loop by moving out panic_notifier.h
- unload kernel.h from something which has its own domain
At the same time convert users tree-wide to use new headers, although for
the time being include new header back to kernel.h to avoid twisted
indirected includes for existing users.
[akpm@linux-foundation.org: thread_info.h needs limits.h]
[andriy.shevchenko@linux.intel.com: ia64 fix]
Link: https://lkml.kernel.org/r/20210520130557.55277-1-andriy.shevchenko@linux.intel.com
Link: https://lkml.kernel.org/r/20210511074137.33666-1-andriy.shevchenko@linux.intel.com
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Co-developed-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Mike Rapoport <rppt@linux.ibm.com>
Acked-by: Corey Minyard <cminyard@mvista.com>
Acked-by: Christian Brauner <christian.brauner@ubuntu.com>
Acked-by: Wei Liu <wei.liu@kernel.org>
Acked-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Sebastian Reichel <sre@kernel.org>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
Acked-by: Stephen Boyd <sboyd@kernel.org>
Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Acked-by: Helge Deller <deller@gmx.de> # parisc
Some devices don't drain their pipelines if we don't make sure that
the corresponding output port is in reset before programming it for
a new trace capture, resulting in bits of old trace appearing in the
new trace capture. Fix that by explicitly making sure the reset is
asserted before programming new trace capture.
Link: https://lore.kernel.org/r/20210621151246.31891-5-alexander.shishkin@linux.intel.com
We already keep the multiblock mode buffers uncached, but forget the
single mode. Address this.
Link: https://lore.kernel.org/r/20210621151246.31891-4-alexander.shishkin@linux.intel.com
As described in the added comment device_for_each_child() never returns
a non-zero value. So remove the corresponding error check.
This simplifies the quest to make struct bus_type::remove() return void.
Link: https://lore.kernel.org/r/20210621151246.31891-3-alexander.shishkin@linux.intel.com
If the symlink is unable to be created, the driver goes
ahead and continues device creation. Instead lets propagate
the failure, and fail the probe.
Link: https://lore.kernel.org/r/20210526204042.2681700-1-jeremy.linton@arm.com
Fixes: 8a7365c2d418 ("coresight: Expose device connections via sysfs")
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
Link: https://lore.kernel.org/r/20210614175901.532683-7-mathieu.poirier@linaro.org
commit 6f755e85c332 ("coresight: Add helper for inserting synchronization
packets") removed trailing '\0' from barrier_pkt array and updated the
call sites like etb_update_buffer() to have proper checks for barrier_pkt
size before read but missed updating tmc_update_etf_buffer() which still
reads barrier_pkt past the array size resulting in KASAN out-of-bounds
bug. Fix this by adding a check for barrier_pkt size before accessing
like it is done in etb_update_buffer().
BUG: KASAN: global-out-of-bounds in tmc_update_etf_buffer+0x4b8/0x698
Read of size 4 at addr ffffffd05b7d1030 by task perf/2629
Call trace:
dump_backtrace+0x0/0x27c
show_stack+0x20/0x2c
dump_stack+0x11c/0x188
print_address_description+0x3c/0x4a4
__kasan_report+0x140/0x164
kasan_report+0x10/0x18
__asan_report_load4_noabort+0x1c/0x24
etm_event_stop+0x248/0x2d8
etm_event_del+0x20/0x2c
event_sched_out+0x214/0x6f0
group_sched_out+0xd0/0x270
ctx_sched_out+0x2ec/0x518
__perf_event_task_sched_out+0x4fc/0xe6c
__schedule+0x1094/0x16a0
preempt_schedule_irq+0x88/0x170
arm64_preempt_schedule_irq+0xf0/0x18c
el1_irq+0xe8/0x180
perf_event_exec+0x4d8/0x56c
setup_new_exec+0x204/0x400
load_elf_binary+0x72c/0x18c0
search_binary_handler+0x13c/0x420
load_script+0x500/0x6c4
exec_binprm+0x118/0x654
__do_execve_file+0x77c/0xba4
__arm64_compat_sys_execve+0x98/0xac
el0_svc_common+0x1f8/0x5e0
el0_svc_compat_handler+0x84/0xb0
el0_svc_compat+0x10/0x50
The buggy address belongs to the variable:
barrier_pkt+0x10/0x40
Memory state around the buggy address:
ffffffd05b7d0f00: fa fa fa fa 04 fa fa fa fa fa fa fa 00 00 00 00
ffffffd05b7d0f80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffffffd05b7d1000: 00 00 00 00 00 00 fa fa fa fa fa fa 00 00 00 03
ffffffd05b7d1080: fa fa fa fa 00 02 fa fa fa fa fa fa 03 fa fa fa
ffffffd05b7d1100: fa fa fa fa 00 00 00 00 05 fa fa fa fa fa fa fa
Link: https://lore.kernel.org/r/20210505093430.18445-1-saiprakash.ranjan@codeaurora.org
Fixes: 0c3fc4d5fa26 ("coresight: Add barrier packet for synchronisation")
Signed-off-by: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
Link: https://lore.kernel.org/r/20210614175901.532683-6-mathieu.poirier@linaro.org
"attr" is checked by perf framework, so remove the redundant check in
etm4_parse_event_config().
Link: https://lore.kernel.org/r/1620912469-52222-4-git-send-email-liuqi115@huawei.com
Signed-off-by: Junhao He <hejunhao2@hisilicon.com>
Signed-off-by: Qi Liu <liuqi115@huawei.com>
Link: https://lore.kernel.org/r/20210614175901.532683-5-mathieu.poirier@linaro.org
Remove unnecessary assignment of "path" in coresight_release_path().
Link: https://lore.kernel.org/r/1620912469-52222-3-git-send-email-liuqi115@huawei.com
Link: https://lore.kernel.org/r/20210614175901.532683-4-mathieu.poirier@linaro.org
Currently the pointer "sink" might be checked before initialized. Fix
this by initializing this pointer.
Link: https://lore.kernel.org/r/1620912469-52222-2-git-send-email-liuqi115@huawei.com
Fixes: 6d578258b955 ("coresight: Make sysfs functional on topologies with per core sink")
Link: https://lore.kernel.org/r/20210614175901.532683-3-mathieu.poirier@linaro.org
Let the krealloc_array() check for multiplication overflow.
Link: https://lore.kernel.org/r/20210520135041.56163-1-andriy.shevchenko@linux.intel.com
Link: https://lore.kernel.org/r/20210614175901.532683-2-mathieu.poirier@linaro.org
Pull kvm updates from Paolo Bonzini:
"This is a large update by KVM standards, including AMD PSP (Platform
Security Processor, aka "AMD Secure Technology") and ARM CoreSight
(debug and trace) changes.
ARM:
- CoreSight: Add support for ETE and TRBE
- Stage-2 isolation for the host kernel when running in protected
mode
- Guest SVE support when running in nVHE mode
- Force W^X hypervisor mappings in nVHE mode
- ITS save/restore for guests using direct injection with GICv4.1
- nVHE panics now produce readable backtraces
- Guest support for PTP using the ptp_kvm driver
- Performance improvements in the S2 fault handler
x86:
- AMD PSP driver changes
- Optimizations and cleanup of nested SVM code
- AMD: Support for virtual SPEC_CTRL
- Optimizations of the new MMU code: fast invalidation, zap under
read lock, enable/disably dirty page logging under read lock
- /dev/kvm API for AMD SEV live migration (guest API coming soon)
- support SEV virtual machines sharing the same encryption context
- support SGX in virtual machines
- add a few more statistics
- improved directed yield heuristics
- Lots and lots of cleanups
Generic:
- Rework of MMU notifier interface, simplifying and optimizing the
architecture-specific code
- a handful of "Get rid of oprofile leftovers" patches
- Some selftests improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (379 commits)
KVM: selftests: Speed up set_memory_region_test
selftests: kvm: Fix the check of return value
KVM: x86: Take advantage of kvm_arch_dy_has_pending_interrupt()
KVM: SVM: Skip SEV cache flush if no ASIDs have been used
KVM: SVM: Remove an unnecessary prototype declaration of sev_flush_asids()
KVM: SVM: Drop redundant svm_sev_enabled() helper
KVM: SVM: Move SEV VMCB tracking allocation to sev.c
KVM: SVM: Explicitly check max SEV ASID during sev_hardware_setup()
KVM: SVM: Unconditionally invoke sev_hardware_teardown()
KVM: SVM: Enable SEV/SEV-ES functionality by default (when supported)
KVM: SVM: Condition sev_enabled and sev_es_enabled on CONFIG_KVM_AMD_SEV=y
KVM: SVM: Append "_enabled" to module-scoped SEV/SEV-ES control variables
KVM: SEV: Mask CPUID[0x8000001F].eax according to supported features
KVM: SVM: Move SEV module params/variables to sev.c
KVM: SVM: Disable SEV/SEV-ES if NPT is disabled
KVM: SVM: Free sev_asid_bitmap during init if SEV setup fails
KVM: SVM: Zero out the VMCB array used to track SEV ASID association
x86/sev: Drop redundant and potentially misleading 'sev_enabled'
KVM: x86: Move reverse CPUID helpers to separate header file
KVM: x86: Rename GPR accessors to make mode-aware variants the defaults
CONFIG_CORESIGHT_SOURCE_ETM4X is undefined when built as module,
CONFIG_CORESIGHT_SOURCE_ETM4X_MODULE is defined instead.
Therefore code in format_attr_contextid_show() not correctly complied
when coresight built as module.
Use IS_ENABLED(CONFIG_CORESIGHT_SOURCE_ETM4X) to correct this.
Link: https://lore.kernel.org/r/20210414194808.22872-1-mike.leach@linaro.org
Fixes: 88f11864cf1d ("coresight: etm-perf: Support PID tracing for kernel at EL2")
Link: https://lore.kernel.org/r/20210415202404.945368-2-mathieu.poirier@linaro.org
It appears that the STM code didn't manage to accurately decypher the
delicate inner workings of an alternative thought process behind the
UUID API and directly called generate_random_uuid() that clearly needs
to be a static function in lib/uuid.c.
At the same time, said STM code is poking directly at the byte array
inside the uuid_t when it uses the UUID for its internal purposes.
Fix these two transgressions by using intended APIs instead.
[ash: changed back to uuid_t and updated the commit message]
Link: https://lore.kernel.org/r/20210415091555.88085-1-alexander.shishkin@linux.intel.com
This adds support for the Trace Hub in Alder Lake-M PCH.
Cc: stable@vger.kernel.org # v4.14+
Link: https://lore.kernel.org/r/20210414171251.14672-8-alexander.shishkin@linux.intel.com
This adds support for the Trace Hub in Rocket Lake CPUs.
Cc: stable <stable@vger.kernel.org> # v4.14+
Link: https://lore.kernel.org/r/20210414171251.14672-7-alexander.shishkin@linux.intel.com
Consistently use "< ... +1" in for loops.
Fix of-by-one in for_each_set_bit().
Signed-off-by: Pavel Machek <pavel@denx.de>
Link: https://lore.kernel.org/lkml/20190724095841.GA6952@amd/
Link: https://lore.kernel.org/r/20210414171251.14672-6-alexander.shishkin@linux.intel.com
The only usage of them is to pass their address to sysfs_create_group()
and sysfs_remove_group(), both which have pointers to const
attribute_group structs as input. Make them const to allow the compiler
to put them in read-only memory.
Signed-off-by: Rikard Falkeborn <rikard.falkeborn@gmail.com>
Link: https://lore.kernel.org/r/20210414171251.14672-5-alexander.shishkin@linux.intel.com
Anything that deals with drvdata structures should leave them intact.
Reflect this in function signatures.
Link: https://lore.kernel.org/r/20210414171251.14672-4-alexander.shishkin@linux.intel.com
Fix the following clang warning:
drivers/hwtracing/stm/policy.c:60:21: warning: unused function
'stp_policy_node_name' [-Wunused-function].
Reported-by: Abaci Robot <abaci@linux.alibaba.com>
Signed-off-by: Jiapeng Chong <jiapeng.chong@linux.alibaba.com>
Link: https://lore.kernel.org/r/20210414171251.14672-2-alexander.shishkin@linux.intel.com
In case of error, the function devm_kasprintf() returns NULL
pointer not ERR_PTR(). The IS_ERR() test in the return value
check should be replaced with NULL test.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: https://lore.kernel.org/r/20210409094901.1903622-1-weiyongjun1@huawei.com
