The sparse tool complains as follows:
drivers/hwtracing/coresight/coresight-core.c:26:1: warning:
symbol '__pcpu_scope_csdev_sink' was not declared. Should it be static?
As csdev_sink is not used outside of coresight-core.c after the
introduction of coresight_[set|get]_percpu_sink() helpers, this
change marks it static.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: https://lore.kernel.org/r/20210409094900.1902783-1-weiyongjun1@huawei.com
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Fix the following checkpatch warning:
WARNING: 'compoment' may be misspelled - perhaps 'component'?
Link: https://lore.kernel.org/r/1616487086-50418-1-git-send-email-liuqi115@huawei.com
Signed-off-by: Qi Liu <liuqi115@huawei.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Link: https://lore.kernel.org/r/20210407160007.418053-4-mathieu.poirier@linaro.org
drivers/hwtracing/coresight/coresight-etm-perf.c:61:25: warning:
symbol 'format_attr_contextid' was not declared. Should it be static?
This symbol is not used outside of coresight-etm-perf.c, so this
commit marks it static.
Link: https://lore.kernel.org/r/20210308123250.2417947-1-weiyongjun1@huawei.com
Link: https://lore.kernel.org/r/20210407160007.418053-3-mathieu.poirier@linaro.org
Add ETM PID for Cortex-A78 to the list of supported ETMs.
Link: https://lore.kernel.org/r/20210213112829.26834-1-saiprakash.ranjan@codeaurora.org
Reviewed-by: Mike Leach <mike.leach@linaro.org>
Signed-off-by: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
Link: https://lore.kernel.org/r/20210407160007.418053-2-mathieu.poirier@linaro.org
Trace Buffer Extension (TRBE) implements a trace buffer per CPU which is
accessible via the system registers. The TRBE supports different addressing
modes including CPU virtual address and buffer modes including the circular
buffer mode. The TRBE buffer is addressed by a base pointer (TRBBASER_EL1),
an write pointer (TRBPTR_EL1) and a limit pointer (TRBLIMITR_EL1). But the
access to the trace buffer could be prohibited by a higher exception level
(EL3 or EL2), indicated by TRBIDR_EL1.P. The TRBE can also generate a CPU
private interrupt (PPI) on address translation errors and when the buffer
is full. Overall implementation here is inspired from the Arm SPE driver.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Mike Leach <mike.leach@linaro.org>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Anshuman Khandual <anshuman.khandual@arm.com>
[ Mark the buffer truncated on WRAP event, error code cleanup ]
Link: https://lore.kernel.org/r/20210405164307.1720226-18-suzuki.poulose@arm.com
Add support for dedicated sinks that are bound to individual CPUs. (e.g,
TRBE). To allow quicker access to the sink for a given CPU bound source,
keep a percpu array of the sink devices. Also, add support for building
a path to the CPU local sink from the ETM.
This adds a new percpu sink type CORESIGHT_DEV_SUBTYPE_SINK_PERCPU_SYSMEM.
This new sink type is exclusively available and can only work with percpu
source type device CORESIGHT_DEV_SUBTYPE_SOURCE_PROC.
This defines a percpu structure that accommodates a single coresight_device
which can be used to store an initialized instance from a sink driver. As
these sinks are exclusively linked and dependent on corresponding percpu
sources devices, they should also be the default sink device during a perf
session.
Outwards device connections are scanned while establishing paths between a
source and a sink device. But such connections are not present for certain
percpu source and sink devices which are exclusively linked and dependent.
Build the path directly and skip connection scanning for such devices.
Tested-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[Moved the set/get percpu sink APIs from TRBE patch to here
Fixed build break on arm32]
Link: https://lore.kernel.org/r/20210405164307.1720226-17-suzuki.poulose@arm.com
The context associated with an ETM for a given perf event
includes :
- handle -> the perf output handle for the AUX buffer.
- the path for the trace components
- the buffer config for the sink.
The path and the buffer config are part of the "aux_priv" data
(etm_event_data) setup by the setup_aux() callback, and made available
via perf_get_aux(handle).
Now with a sink supporting IRQ, the sink could "end" an output
handle when the buffer reaches the programmed limit and would try
to restart a handle. This could fail if there is not enough
space left the AUX buffer (e.g, the userspace has not consumed
the data). This leaves the "handle" disconnected from the "event"
and also the "perf_get_aux()" cleared. This all happens within
the sink driver, without the etm_perf driver being aware.
Now when the event is actually stopped, etm_event_stop()
will need to access the "event_data". But since the handle
is not valid anymore, we loose the information to stop the
"trace" path. So, we need a reliable way to access the etm_event_data
even when the handle may not be active.
This patch replaces the per_cpu handle array with a per_cpu context
for the ETM, which tracks the "handle" as well as the "etm_event_data".
The context notes the etm_event_data at etm_event_start() and clears
it at etm_event_stop(). This makes sure that we don't access a
stale "etm_event_data" as we are guaranteed that it is not
freed by free_aux() as long as the event is active and tracing,
also provides us with access to the critical information
needed to wind up a session even in the absence of an active
output_handle.
This is not an issue for the legacy sinks as none of them supports
an IRQ and is centrally handled by the etm-perf.
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: Leo Yan <leo.yan@linaro.org>
Link: https://lore.kernel.org/r/20210405164307.1720226-16-suzuki.poulose@arm.com
Add ETE as one of the supported device types we support
with ETM4x driver. The devices are named following the
existing convention as ete<N>.
ETE mandates that the trace resource status register is programmed
before the tracing is turned on. For the moment simply write to
it indicating TraceActive.
Link: https://lore.kernel.org/r/20210405164307.1720226-14-suzuki.poulose@arm.com
Add support for handling the system registers for Embedded Trace
Extensions (ETE). ETE shares most of the registers with ETMv4 except
for some and also adds some new registers. Re-arrange the ETMv4x list
to share the common definitions and add the ETE sysreg support.
Link: https://lore.kernel.org/r/20210405164307.1720226-13-suzuki.poulose@arm.com
ETE may not implement the OS lock and instead could rely on
the PE OS Lock for the trace unit access. This is indicated
by the TRCOLSR.OSM == 0b100. Add support for handling the
PE OS lock
Reviewed-by: mike.leach <mike.leach@linaro.org>
Link: https://lore.kernel.org/r/20210405164307.1720226-12-suzuki.poulose@arm.com
If a graph node is not found for a given node, of_get_next_endpoint()
will emit the following error message :
OF: graph: no port node found in /<node_name>
If the given component doesn't have any explicit connections (e.g,
ETE) we could simply ignore the graph parsing. As for any legacy
component where this is mandatory, the device will not be usable
as before this patch. Updating the DT bindings to Yaml and enabling
the schema checks can detect such issues with the DT.
Link: https://lore.kernel.org/r/20210405164307.1720226-11-suzuki.poulose@arm.com
When a sink is not specified by the user, the etm perf driver
finds a suitable sink automatically, based on the first ETM
where this event could be scheduled. Then we allocate the
sink buffer based on the selected sink. This is fine for a
CPU bound event as the "sink" is always guaranteed to be
reachable from the ETM (as this is the only ETM where the
event is going to be scheduled). However, if we have a thread
bound event, the event could be scheduled on any of the ETMs
on the system. In this case, currently we automatically select
a sink and exclude any ETMs that cannot reach the selected
sink. This is problematic especially for 1x1 configurations.
We end up in tracing the event only on the "first" ETM,
as the default sink is local to the first ETM and unreachable
from the rest. However, we could allow the other ETMs to
trace if they all have a sink that is compatible with the
"selected" sink and can use the sink buffer. This can be
easily done by verifying that they are all driven by the
same driver and matches the same subtype. Please note
that at anytime there can be only one ETM tracing the event.
Adding support for different types of sinks for a single
event is complex and is not something that we expect
on a sane configuration.
Tested-by: Linu Cherian <lcherian@marvell.com>
Link: https://lore.kernel.org/r/20210405164307.1720226-10-suzuki.poulose@arm.com
If the CPU implements Arm v8.4 Trace filter controls (FEAT_TRF),
move the ETM to trace prohibited region using TRFCR, while disabling.
Link: https://lore.kernel.org/r/20210405164307.1720226-9-suzuki.poulose@arm.com
When the kernel is running at EL2, the PID is stored in CONTEXTIDR_EL2.
So, tracing CONTEXTIDR_EL1 doesn't give us the pid of the process.
Thus we should trace the VMID with VMIDOPT set to trace CONTEXTIDR_EL2
instead of CONTEXTIDR_EL1. Given that we have an existing config
option "contextid" and this will be useful for tracing virtual machines
(when we get to support virtualization).
So instead, this patch extends option CTXTID with an extra bit
ETM_OPT_CTXTID2 (bit 15), thus on an EL2 kernel, we will have another
bit available for the perf tool: ETM_OPT_CTXTID is for kernel running in
EL1, ETM_OPT_CTXTID2 is used when kernel runs in EL2 with VHE enabled.
The tool must be backward compatible for users, i.e, "contextid" today
traces PID and that should remain the same; for this purpose, the perf
tool is updated to automatically set corresponding bit for the
"contextid" config, therefore, the user doesn't have to bother which EL
the kernel is running.
i.e, perf record -e cs_etm/contextid/u --
will always do the "pid" tracing, independent of the kernel EL.
The driver parses the format "contextid", which traces CONTEXTIDR_EL1
for ETM_OPT_CTXTID (on EL1 kernel) and traces CONTEXTIDR_EL2 for
ETM_OPT_CTXTID2 (on EL2 kernel).
Besides the enhancement for format "contexid", extra two formats are
introduced: "contextid1" and "contextid2". This considers to support
tracing both CONTEXTIDR_EL1 and CONTEXTIDR_EL2 when the kernel is
running at EL2. Finally, the PMU formats are defined as follow:
"contextid1": Available on both EL1 kernel and EL2 kernel. When the
kernel is running at EL1, "contextid1" enables the PID
tracing; when the kernel is running at EL2, this enables
tracing the PID of guest applications.
"contextid2": Only usable when the kernel is running at EL2. When
selected, enables PID tracing on EL2 kernel.
"contextid": Will be an alias for the option that enables PID
tracing. I.e,
contextid == contextid1, on EL1 kernel.
contextid == contextid2, on EL2 kernel.
Cc: Al Grant <al.grant@arm.com>
[ Added two config formats: contextid1, contextid2 ]
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Link: https://lore.kernel.org/r/20210206150833.42120-4-leo.yan@linaro.org
Link: https://lore.kernel.org/r/20210211172038.2483517-3-mathieu.poirier@linaro.org
In theory, the options should be arbitrary values and are neutral for
any ETM version; so far perf tool uses ETMv3.5/PTM ETMCR config bits
except for register's bit definitions, also uses as options.
This can introduce confusion, especially if we want to add a new option
but the new option is not supported by ETMv3.5/PTM ETMCR. But on the
other hand, we cannot change options since these options are generic
CoreSight PMU ABI.
For easier maintenance and avoid confusion, this patch refines the
comment to clarify perf options, and gives out the background info for
these bits are coming from ETMv3.5/PTM. Afterwards, we should take
these options as general knobs, and if there have any confliction with
ETMv3.5/PTM, should consider to define saperate macros for ETMv3.5/PTM
ETMCR config bits.
Suggested-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Link: https://lore.kernel.org/r/20210206150833.42120-2-leo.yan@linaro.org
Link: https://lore.kernel.org/r/20210211172038.2483517-2-mathieu.poirier@linaro.org
This was non-trivial to get right because commits
c23bc382ef0e ("coresight: etm4x: Refactor probing routine") and
5214b563588e ("coresight: etm4x: Add support for sysreg only devices")
changed the code flow considerably. With this change the driver can be
built again.
Fixes: 0573d3fa4864 ("Merge branch 'devel-stable' of git://git.armlinux.org.uk/~rmk/linux-arm into char-misc-next")
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
Link: https://lore.kernel.org/r/20210205130848.20009-1-uwe@kleine-koenig.org
char-misc-next
This merges from linux-arm at 860660fd829e ("ARM: 9055/1: mailbox:
arm_mhuv2: make remove callback return void") into char-misc-next to get
the amba fixes from Uwe.
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: Russell King <linux@armlinux.org.uk>
TRCSTALLCTLR register is only implemented if
TRCIDR3.STALLCTL == 0b1
Make sure the driver touches the register only it is implemented.
Link: https://lore.kernel.org/r/20210127184617.3684379-1-suzuki.poulose@arm.com
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20210201181351.1475223-32-mathieu.poirier@linaro.org
v8.4 tracing extensions added support for trace filtering controlled
by TRFCR_ELx. This must be programmed to allow tracing at EL1/EL2 and
EL0. The timestamp used is the virtual time. Also enable CONTEXIDR_EL2
tracing if we are running the kernel at EL2.
Link: https://lore.kernel.org/r/20210110224850.1880240-29-suzuki.poulose@arm.com
Cc: Will Deacon <will@kernel.org>
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Jonathan Zhou <jonathan.zhouwen@huawei.com>
[ Move the trace filtering setup etm_init_arch_data() and clean ups]
Link: https://lore.kernel.org/r/20210201181351.1475223-31-mathieu.poirier@linaro.org
Add support for devices with system instruction access only.
They don't have a memory mapped interface and thus are not
AMBA devices. System register access is not permitted to
TRCPDCR and thus skip access to them.
Link: https://lore.kernel.org/r/20210110224850.1880240-26-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-28-mathieu.poirier@linaro.org
As we are about to add support for system register based devices,
we don't get an AMBA pid. So, the detection code could check
the system registers running on the CPU to check for the architecture
specific features. Thus we move the arch feature detection to
run on the CPU. We cannot always read the PID from the HW, as the
PID could be overridden by DT for broken devices. So, use the
PID from AMBA layer if available.
Link: https://lore.kernel.org/r/20210110224850.1880240-25-suzuki.poulose@arm.com
Cc: liuqi115@huawei.com
Link: https://lore.kernel.org/r/20210201181351.1475223-27-mathieu.poirier@linaro.org
CoreSight ETM with system register access may not have a
memory mapped i/o access. Refactor the ETM specific probing
into a common routine to allow reusing the code for such ETMs.
Link: https://lore.kernel.org/r/20210110224850.1880240-24-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-26-mathieu.poirier@linaro.org
ETM v4.4 onwards adds support for system instruction access
to the ETM. Detect the support on an ETM and switch to using the
mode when available.
Link: https://lore.kernel.org/r/20210110224850.1880240-23-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-25-mathieu.poirier@linaro.org
As per the specification any update to the TRCPRGCTLR must be synchronized
by a context synchronization event (in our case an explicist ISB) before
the TRCSTATR is checked.
Link: https://lore.kernel.org/r/20210110224850.1880240-22-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-24-mathieu.poirier@linaro.org
Expose the TRCDEVARCH register via the sysfs for component
detection. Given that the TRCIDR1 may not completely identify
the ETM component and instead need to use TRCDEVARCH, expose
this via sysfs for tools to use it for identification.
Link: https://lore.kernel.org/r/20210110224850.1880240-21-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-23-mathieu.poirier@linaro.org
We have been using TRCIDR1 for detecting the ETM version. This
is in preparation for the future IP support.
Link: https://lore.kernel.org/r/20210110224850.1880240-20-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-22-mathieu.poirier@linaro.org
In preparation to detect the support for system instruction
support, move the detection of the device access to the target
CPU.
Link: https://lore.kernel.org/r/20210110224850.1880240-19-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-21-mathieu.poirier@linaro.org
We are about to rely on TRCDEVARCH for detecting the ETM
and its architecture version, falling back to TRCIDR1 if
the former is not implemented (in older broken implementations).
Also, we use the architecture version information to
make some decisions. Streamline the architecture version
handling by adding helpers.
Link: https://lore.kernel.org/r/20210110224850.1880240-18-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-20-mathieu.poirier@linaro.org
etm4_get_access_type() calculates the exception level bits
for use in address comparator registers. This is also used
by the TRCVICTLR register by shifting to the required position.
This patch cleans up the logic to make etm4_get_access_type()
calculate a generic mask which can be used by all users by
shifting to their field.
No functional changes intended.
Link: https://lore.kernel.org/r/20210110224850.1880240-17-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-19-mathieu.poirier@linaro.org
We rely on the ETM architecture version to decide whether
Secure EL2 is available on the CPU for excluding the level
for address comparators and viewinst main control register.
We must instead use the TRCDIDR3.EXLEVEL_S field to detect
the supported levels.
Link: https://lore.kernel.org/r/20210110224850.1880240-16-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-18-mathieu.poirier@linaro.org
The Software lock is not implemented for system instructions
based accesses. So, skip the lock register access in such
cases.
Link: https://lore.kernel.org/r/20210110224850.1880240-15-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-17-mathieu.poirier@linaro.org
Define the fields of the DEVARCH register for identifying
a component as an ETMv4.x unit. Going forward, we use the
DEVARCH register for the component identification, rather
than the TRCIDR3.
Link: https://lore.kernel.org/r/20210110224850.1880240-14-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-16-mathieu.poirier@linaro.org
Some of the management registers in ETMv4.x are not accessible
via system register instructions. Thus we must hide the sysfs
files exposing them to the userspace, to prevent system crashes.
This patch adds an is_visible() routine to control the visibility
at runtime for the registers that may not be accessed.
Link: https://lore.kernel.org/r/20210110224850.1880240-13-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-15-mathieu.poirier@linaro.org
ETM architecture defines the system instructions for accessing
via register accesses. Add basic support for accessing a given
register via system instructions.
We split the list of registers as :
1) Accessible only from memory mapped interface
2) Accessible from system register instructions.
All registers are accessible via the memory-mapped interface.
However, some registers are not accessible via the system
instructions. This list is then used to further filter out
the files we expose via sysfs.
Link: https://lore.kernel.org/r/20210110224850.1880240-12-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-14-mathieu.poirier@linaro.org
As we are about define a switch..case table for individual register
access by offset for implementing the system instruction support,
document the possible set of registers for each group to make
it easier to correlate.
Link: https://lore.kernel.org/r/20210110224850.1880240-11-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-13-mathieu.poirier@linaro.org
Some of the ETM management registers are not accessible via
system instructions. Thus we need to filter accesses to these
registers depending on the access mechanism for the ETM at runtime.
The driver can cope with this for normal operation, by regular
checks. But the driver also exposes them via sysfs, which now
needs to be removed.
So far, we have used the generic coresight sysfs helper macros
to export a given device register, defining a "show" operation
per register. This is not helpful to filter the files at runtime,
based on the access.
In order to do this dynamically, we need to filter the attributes
by offsets and hard coded "show" functions doesn't make this easy.
Thus, switch to extended attributes, storing the offset in the scratch
space. This allows us to implement filtering based on the offset and
also saves us some text size. This will be later used for determining
a given attribute must be "visible" via sysfs.
Link: https://lore.kernel.org/r/20210110224850.1880240-10-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-12-mathieu.poirier@linaro.org
Convert all register accesses from etm4x driver to use a wrapper
to allow switching the access at runtime with little overhead.
co-developed by sed tool ;-), mostly equivalent to :
s/readl\(_relaxed\)\?(drvdata->base + \(.*\))/etm4x_\1_read32(csdev, \2)
s/writel\(_relaxed\)\?(\(.*\), drvdata->base + \(.*\))/etm4x_\1_write32(csdev, \2, \3)
We don't want to replace them with the csdev_access_* to
avoid a function call for every register access for system
register access. This is a prepartory step to add system
register access later where the support is available.
Link: https://lore.kernel.org/r/20210110224850.1880240-9-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-11-mathieu.poirier@linaro.org
As we are about to add support for sysreg access to ETM4.4+ components,
make sure that we read the registers only on the host CPU.
Link: https://lore.kernel.org/r/20210110224850.1880240-8-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-10-mathieu.poirier@linaro.org
Convert the generic CLAIM tag management APIs to use the
device access layer abstraction.
Link: https://lore.kernel.org/r/20210110224850.1880240-7-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-9-mathieu.poirier@linaro.org
Convert the generic routines to use the new access abstraction layer
gradually, starting with coresigth_timeout.
Link: https://lore.kernel.org/r/20210110224850.1880240-6-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-8-mathieu.poirier@linaro.org
Prepare the TPIU driver to make use of the CoreSight device access
abstraction layer. The driver touches the device even before the
coresight device is registered. Thus we could be accessing the
devices without a csdev. As we are about to use the abstraction
layer for accessing the device, pass in the access directly
to avoid having to deal with the un-initialised csdev.
Link: https://lore.kernel.org/r/20210110224850.1880240-5-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-7-mathieu.poirier@linaro.org
We are about to introduce support for sysreg access to ETMv4.4+
component. Since there are generic routines that access the
registers (e.g, CS_LOCK/UNLOCK , claim/disclaim operations, timeout)
and in order to preserve the logic of these operations at a
single place we introduce an abstraction layer for the accesses
to a given device.
Link: https://lore.kernel.org/r/20210110224850.1880240-4-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-6-mathieu.poirier@linaro.org
When the ETM is affected by Qualcomm errata, modifying the
TRCPDCR could cause the system hang. Even though this is
taken care of during enable/disable ETM, the ETM state
save/restore could still access the TRCPDCR. Make sure
we skip the access during the save/restore.
Found by code inspection.
Link: https://lore.kernel.org/r/20210110224850.1880240-3-suzuki.poulose@arm.com
Fixes: 02510a5aa78d ("coresight: etm4x: Add support to skip trace unit power up")
Cc: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
Cc: Tingwei Zhang <tingwei@codeaurora.org>
Tested-by: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
Reviewed-by: Sai Prakash Ranjan <saiprakash.ranjan@codeaurora.org>
Link: https://lore.kernel.org/r/20210201181351.1475223-5-mathieu.poirier@linaro.org
TRCSSPCICR<n> is present only if all of the following are true:
TRCIDR4.NUMSSCC > n.
TRCIDR4.NUMPC > 0b0000 .
TRCSSCSR<n>.PC == 0b1
Add a helper function to check all the conditions.
Link: https://lore.kernel.org/r/20210110224850.1880240-2-suzuki.poulose@arm.com
Link: https://lore.kernel.org/r/20210201181351.1475223-4-mathieu.poirier@linaro.org
Add AMBA UCI id to support Cortex-A55(Ananke) and Cortex-A75(Promethus).
Reviewed by: Mike Leach <mike.leach@linaro.org>
Link: https://lore.kernel.org/r/20210118065549.197489-1-zhang.lyra@gmail.com
Signed-off-by: Bin Ji <bin.ji@unisoc.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@unisoc.com>
Link: https://lore.kernel.org/r/20210201181351.1475223-3-mathieu.poirier@linaro.org
cti_plat_create_connection()
A local variable was used only within an else branch.
Thus move the definition for the variable “cs_fwnode” into
the corresponding code block.
This issue was detected by using the Coccinelle software.
Link: https://lore.kernel.org/r/c1b09b27-9012-324f-28d0-ba820dc468a5@web.de
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Link: https://lore.kernel.org/r/20210201181351.1475223-2-mathieu.poirier@linaro.org
All amba drivers return 0 in their remove callback. Together with the
driver core ignoring the return value anyhow, it doesn't make sense to
return a value here.
Change the remove prototype to return void, which makes it explicit that
returning an error value doesn't work as expected. This simplifies changing
the core remove callback to return void, too.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org> # for drivers/memory
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Suzuki K Poulose <suzuki.poulose@arm.com> # for hwtracing/coresight
Acked-By: Vinod Koul <vkoul@kernel.org> # for dmaengine
Acked-by: Guenter Roeck <linux@roeck-us.net> # for watchdog
Acked-by: Wolfram Sang <wsa@kernel.org> # for I2C
Acked-by: Takashi Iwai <tiwai@suse.de> # for sound
Acked-by: Vladimir Zapolskiy <vz@mleia.com> # for memory/pl172
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Link: https://lore.kernel.org/r/20210126165835.687514-5-u.kleine-koenig@pengutronix.de
This adds support for the Trace Hub in Alder Lake-P.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Link: https://lore.kernel.org/r/20210115195917.3184-3-alexander.shishkin@linux.intel.com
Cc: stable <stable@vger.kernel.org>
In stm_heartbeat_init(): return value gets reset after the first
iteration by stm_source_register_device(), so allocation failures
after that will, after a clean up, return success. Fix that.
Fixes: 119291853038 ("stm class: Add heartbeat stm source device")
Signed-off-by: Wang Hui <john.wanghui@huawei.com>
Link: https://lore.kernel.org/r/20210115195917.3184-2-alexander.shishkin@linux.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char / misc driver updates from Greg KH:
"Here is the big char/misc driver update for 5.11-rc1.
Continuing the tradition of previous -rc1 pulls, there seems to be
more and more tiny driver subsystems flowing through this tree.
Lots of different things, all of which have been in linux-next for a
while with no reported issues:
- extcon driver updates
- habannalab driver updates
- mei driver updates
- uio driver updates
- binder fixes and features added
- soundwire driver updates
- mhi bus driver updates
- phy driver updates
- coresight driver updates
- fpga driver updates
- speakup driver updates
- slimbus driver updates
- various small char and misc driver updates"
* tag 'char-misc-5.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (305 commits)
extcon: max77693: Fix modalias string
extcon: fsa9480: Support TI TSU6111 variant
extcon: fsa9480: Rewrite bindings in YAML and extend
dt-bindings: extcon: add binding for TUSB320
extcon: Add driver for TI TUSB320
slimbus: qcom: fix potential NULL dereference in qcom_slim_prg_slew()
siox: Make remove callback return void
siox: Use bus_type functions for probe, remove and shutdown
spmi: Add driver shutdown support
spmi: fix some coding style issues at the spmi core
spmi: get rid of a warning when built with W=1
uio: uio_hv_generic: use devm_kzalloc() for private data alloc
uio: uio_fsl_elbc_gpcm: use device-managed allocators
uio: uio_aec: use devm_kzalloc() for uio_info object
uio: uio_cif: use devm_kzalloc() for uio_info object
uio: uio_netx: use devm_kzalloc() for or uio_info object
uio: uio_mf624: use devm_kzalloc() for uio_info object
uio: uio_sercos3: use device-managed functions for simple allocs
uio: uio_dmem_genirq: finalize conversion of probe to devm_ handlers
uio: uio_dmem_genirq: convert simple allocations to device-managed
