When part of a path but not identified as a sink, the EFT has to
be configured as a link and placed in HW FIFO mode. As such when
enabling a path, call the right configuration function based on
the role the ETF if playing in this trace run.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
>From a core framework point of view an STM device is a source that is
treated the same way as any other tracers. Unlike tracers though STM
devices are not associated with a CPU. As such it doesn't make sense
to associate the path from an STM device to its sink with a per-cpu
variable as it is done for tracers.
This patch simply adds another global variable to keep STM paths and the
processing in coresight_enable/disable() is updated to deal with STM
devices properly.
Signed-off-by: Chunyan Zhang <zhang.chunyan@linaro.org>
activated and enable are already unsigned type,
no need to change them to unsigned.
Signed-off-by: Li Pengcheng <lipengcheng8@huawei.com>
Signed-off-by: Li Zhong <lizhong11@hisilicon.com>
None of the Kconfig currently controlling compilation of any of
the files here are tristate, meaning that none of it currently
is being built as a module by anyone.
We need not be concerned about .remove functions and blocking the
unbind sysfs operations, since that was already done in a recent
commit.
Lets remove any remaining modular references, so that when reading the
drivers there is no doubt they are builtin-only.
All drivers get mostly the same changes, so they are handled in batch.
Changes are (1) convert to builtin_amba_driver, (2) delete module.h
include where unused, and (3) relocate the description into the
comments so we don't need MODULE_DESCRIPTION and associated tags.
The etm3x and etm4x use module_param_named, and have been adjusted
to just include moduleparam.h for that purpose.
In commit f309d4443130bf814e991f836e919dca22df37ae ("platform_device:
better support builtin boilerplate avoidance") we introduced the
builtin_driver macro.
Here we use that support and extend it to amba driver registration,
so where a driver is clearly non-modular and builtin-only, we can
update with the simple mapping of
module_amba_driver(...) ---> builtin_amba_driver(...)
Since module_amba_driver() uses the same init level priority as
builtin_amba_driver() the init ordering remains unchanged with
this commit.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Adding an operation mode to the sink->enable() API in order
to prevent simultaneous access from different callers.
TPIU and TMC won't be supplemented with the AUX area
API immediately and as such ignore the new mode.
That way traces can be enabled and disabled automatically
from the Perf subystem using the PMU abstraction.
Adding a new mode to source API enable() in order to
distinguish where the request comes from. That way it is
possible to perform different operations based on where
the request was issued from.
The ETM4x driver is also modified to keep in sync with the
new interface.
Moving PM runtime operations in Coresight devices enable() and
disable() API to the framework core when a path is setup. That
way the runtime core doesn't have to be involved everytime a
path is enabled. It also avoids calling runtime PM operations
in IRQ context.
Add an API allowing external code to quickly get a handle on the
sink within a path. The sink is always last, but adding an API allows
to keep the path's node structure private and remove redundant checks.
When using the Coresight framework from the sysFS interface a
tracer is always handling a single session and as such, a path
can be associated with a tracer. But when supporting multiple
session per tracer there is no guarantee that sessions will always
have the same path from source to sink.
This patch is removing the automatic association between path and
tracers. The building of a path and enablement of the components
in the path are decoupled, allowing for the association of a path
with a session rather than a tracer.
To keep backward functionality with the current sysFS access methods
a per-cpu place holder is used to keep a handle on the path built when
tracers are enabled. Lastly APIs to build paths and enable tracers are
made public so that other subsystem can interact with the Coresight
framework.
In function 'coresight_unregister()', all references to the csdev that
is being taken away need to be removed from the topology. Otherwise
building the next coresight path from source to sink may use memory
that has been released.
The reference count taken by function bus_find_device() needs
to be released if a child device is found, something this patch
is adding.
Reported-by: Rabin Vincent <rabin@rab.in>
In its current form the code never frees csdev->refcnt allocated
in coresight_register(). There is also a problem with csdev->conns
that is freed before device_unregister() rather than in the device
release function.
This patch addresses both issues by moving kfree(csdev->conns) to
coresight_device_release() and freeing csdev->refcnt, also in
the same function.
On some platform the following lockdep error occurs when doing simple
manipulations:
[ 23.197021]
[ 23.198608] ======================================================
[ 23.205078] [ INFO: possible circular locking dependency detected ]
[ 23.211639] 4.4.0-rc8-00025-gbbf360b #172 Not tainted
[ 23.216918] -------------------------------------------------------
[ 23.223480] sh/858 is trying to acquire lock:
[ 23.228057] (coresight_mutex){+.+.+.}, at: [<c0415d40>] coresight_enable+0x1c/0x1b4
[ 23.236206]
[ 23.236206] but task is already holding lock:
[ 23.242309] (s_active#52){++++.+}, at: [<c01d4b40>] kernfs_fop_write+0x5c/0x1c0
[ 23.250122]
[ 23.250122] which lock already depends on the new lock.
[ 23.250122]
[ 23.258697]
[ 23.258697] the existing dependency chain (in reverse order) is:
[ 23.266510]
-> #1 (s_active#52){++++.+}:
[ 23.270843] [<c01d30ec>] __kernfs_remove+0x294/0x35c
[ 23.276672] [<c01d3e44>] kernfs_remove_by_name_ns+0x44/0x8c
[ 23.283172] [<c01d6318>] remove_files+0x3c/0x84
[ 23.288543] [<c01d66b4>] sysfs_remove_group+0x48/0x9c
[ 23.294494] [<c01d6734>] sysfs_remove_groups+0x2c/0x3c
[ 23.300506] [<c030b658>] device_remove_attrs+0x5c/0x74
[ 23.306549] [<c030c290>] device_del+0x110/0x218
[ 23.311950] [<c030c3c4>] device_unregister+0x2c/0x6c
[ 23.317779] [<c04156d8>] coresight_unregister+0x30/0x40
[ 23.323883] [<c041a290>] etm_probe+0x228/0x2e8
[ 23.329193] [<c02bc760>] amba_probe+0xe4/0x160
[ 23.334503] [<c0310540>] driver_probe_device+0x23c/0x480
[ 23.340728] [<c0310820>] __driver_attach+0x9c/0xa0
[ 23.346374] [<c030e400>] bus_for_each_dev+0x70/0xa4
[ 23.352142] [<c030fcf4>] driver_attach+0x24/0x28
[ 23.357604] [<c030f86c>] bus_add_driver+0x1e0/0x278
[ 23.363372] [<c0310d48>] driver_register+0x80/0x100
[ 23.369110] [<c02bc508>] amba_driver_register+0x58/0x5c
[ 23.375244] [<c0749514>] etm_driver_init+0x18/0x1c
[ 23.380889] [<c0009918>] do_one_initcall+0xc4/0x20c
[ 23.386657] [<c0715e7c>] kernel_init_freeable+0x160/0x208
[ 23.392974] [<c052d7fc>] kernel_init+0x18/0xf0
[ 23.398254] [<c0010850>] ret_from_fork+0x14/0x24
[ 23.403747]
-> #0 (coresight_mutex){+.+.+.}:
[ 23.408447] [<c008ed60>] lock_acquire+0xe4/0x210
[ 23.413909] [<c0530a30>] mutex_lock_nested+0x74/0x450
[ 23.419860] [<c0415d40>] coresight_enable+0x1c/0x1b4
[ 23.425689] [<c0416030>] enable_source_store+0x58/0x68
[ 23.431732] [<c030b358>] dev_attr_store+0x20/0x2c
[ 23.437286] [<c01d55e8>] sysfs_kf_write+0x50/0x54
[ 23.442871] [<c01d4ba8>] kernfs_fop_write+0xc4/0x1c0
[ 23.448699] [<c015b60c>] __vfs_write+0x34/0xe4
[ 23.454040] [<c015bf38>] vfs_write+0x98/0x174
[ 23.459228] [<c015c7a8>] SyS_write+0x4c/0xa8
[ 23.464355] [<c00107c0>] ret_fast_syscall+0x0/0x1c
[ 23.470031]
[ 23.470031] other info that might help us debug this:
[ 23.470031]
[ 23.478393] Possible unsafe locking scenario:
[ 23.478393]
[ 23.484619] CPU0 CPU1
[ 23.489349] ---- ----
[ 23.494079] lock(s_active#52);
[ 23.497497] lock(coresight_mutex);
[ 23.503906] lock(s_active#52);
[ 23.509918] lock(coresight_mutex);
[ 23.513702]
[ 23.513702] *** DEADLOCK ***
[ 23.513702]
[ 23.519897] 3 locks held by sh/858:
[ 23.523529] #0: (sb_writers#7){.+.+.+}, at: [<c015ec38>] __sb_start_write+0xa8/0xd4
[ 23.531799] #1: (&of->mutex){+.+...}, at: [<c01d4b38>] kernfs_fop_write+0x54/0x1c0
[ 23.539916] #2: (s_active#52){++++.+}, at: [<c01d4b40>] kernfs_fop_write+0x5c/0x1c0
[ 23.548156]
[ 23.548156] stack backtrace:
[ 23.552734] CPU: 0 PID: 858 Comm: sh Not tainted 4.4.0-rc8-00025-gbbf360b #172
[ 23.560302] Hardware name: Generic OMAP4 (Flattened Device Tree)
[ 23.566589] Backtrace:
[ 23.569152] [<c00154d4>] (dump_backtrace) from [<c00156d0>] (show_stack+0x18/0x1c)
[ 23.577087] r7:ed4b8570 r6:c0936400 r5:c07ae71c r4:00000000
[ 23.583038] [<c00156b8>] (show_stack) from [<c027e69c>] (dump_stack+0x98/0xc0)
[ 23.590606] [<c027e604>] (dump_stack) from [<c008a750>] (print_circular_bug+0x21c/0x33c)
[ 23.599090] r5:c0939d60 r4:c0936400
[ 23.602874] [<c008a534>] (print_circular_bug) from [<c008e370>] (__lock_acquire+0x1c98/0x1d88)
[ 23.611877] r10:00000003 r9:c0fd7a5c r8:ed4b8550 r7:ed4b8570 r6:ed4b8000 r5:c0ff69e4
[ 23.620117] r4:c0936400 r3:ed4b8550
[ 23.623901] [<c008c6d8>] (__lock_acquire) from [<c008ed60>] (lock_acquire+0xe4/0x210)
[ 23.632080] r10:00000000 r9:00000000 r8:60000013 r7:c07cb7b4 r6:00000001 r5:00000000
[ 23.640350] r4:00000000
[ 23.643005] [<c008ec7c>] (lock_acquire) from [<c0530a30>] (mutex_lock_nested+0x74/0x450)
[ 23.651458] r10:ecc0bf80 r9:edbe7dcc r8:ed4b8000 r7:c0fd7a5c r6:c0415d40 r5:00000000
[ 23.659729] r4:c07cb780
[ 23.662384] [<c05309bc>] (mutex_lock_nested) from [<c0415d40>] (coresight_enable+0x1c/0x1b4)
[ 23.671234] r10:ecc0bf80 r9:edbe7dcc r8:ed733c00 r7:00000000 r6:ed733c00 r5:00000002
[ 23.679473] r4:ed762140
[ 23.682128] [<c0415d24>] (coresight_enable) from [<c0416030>] (enable_source_store+0x58/0x68)
[ 23.691070] r7:00000000 r6:ed733c00 r5:00000002 r4:ed762160
[ 23.697052] [<c0415fd8>] (enable_source_store) from [<c030b358>] (dev_attr_store+0x20/0x2c)
[ 23.705780] r5:edbe7dc0 r4:c0415fd8
[ 23.709533] [<c030b338>] (dev_attr_store) from [<c01d55e8>] (sysfs_kf_write+0x50/0x54)
[ 23.717834] r5:edbe7dc0 r4:c030b338
[ 23.721618] [<c01d5598>] (sysfs_kf_write) from [<c01d4ba8>] (kernfs_fop_write+0xc4/0x1c0)
[ 23.730163] r7:00000000 r6:00000000 r5:00000002 r4:edbe7dc0
[ 23.736145] [<c01d4ae4>] (kernfs_fop_write) from [<c015b60c>] (__vfs_write+0x34/0xe4)
[ 23.744323] r10:00000000 r9:ecc0a000 r8:c0010964 r7:ecc0bf80 r6:00000002 r5:c01d4ae4
[ 23.752593] r4:ee385a40
[ 23.755249] [<c015b5d8>] (__vfs_write) from [<c015bf38>] (vfs_write+0x98/0x174)
[ 23.762908] r9:ecc0a000 r8:c0010964 r7:ecc0bf80 r6:000ab0d8 r5:00000002 r4:ee385a40
[ 23.771057] [<c015bea0>] (vfs_write) from [<c015c7a8>] (SyS_write+0x4c/0xa8)
[ 23.778442] r8:c0010964 r7:00000002 r6:000ab0d8 r5:ee385a40 r4:ee385a40
[ 23.785522] [<c015c75c>] (SyS_write) from [<c00107c0>] (ret_fast_syscall+0x0/0x1c)
[ 23.793457] r7:00000004 r6:00000001 r5:000ab0d8 r4:00000002
[ 23.799652] coresight-etb10 54162000.etb: ETB enabled
[ 23.805084] coresight-funnel 54164000.funnel: FUNNEL inport 0 enabled
[ 23.811859] coresight-replicator 44000000.ocp:replicator: REPLICATOR enabled
[ 23.819335] coresight-funnel 54158000.funnel: FUNNEL inport 0 enabled
[ 23.826110] coresight-etm3x 5414c000.ptm: ETM tracing enabled
The locking in coresight_unregister() is not required as the only customers of
the function are drivers themselves when an initialisation failure has been
encoutered.
Connection child names associated to ports can sometimes be NULL,
which is the case when booting a system on QEMU or when the Coresight
power domain isn't switched on.
This patch is adding a check to make sure a NULL string isn't fed
to strcmp(), something that avoid crashing the system.
Cc: <stable@vger.kernel.org> # v3.18+
Reported-by: Tyler Baker <tyler.baker@linaro.org>
Add comment to function coresight_enable_path() to make
sure there is no misunderstanding about what the code does.
Keeping drivers related to HW tracing on ARM, i.e coresight,
under "drivers/coresight" doesn't make sense when other
architectures start rolling out technologies of the same
nature.
As such creating a new "drivers/hwtracing" directory where all
drivers of the same kind can reside, reducing namespace
pollution under "drivers/".
