path: root/drivers/hwmon
2010-08-25hwmon: (k8temp) Differentiate between AM2 and ASB1Andreas Herrmann
Commit 8bf0223ed515be24de0c671eedaff49e78bebc9c (hwmon, k8temp: Fix temperature reporting for ASB1 processor revisions) fixed temperature reporting for ASB1 CPUs. But those CPU models (model 0x6b, 0x6f, 0x7f) were packaged both as AM2 (desktop) and ASB1 (mobile). Thus the commit leads to wrong temperature reporting for AM2 CPU parts. The solution is to determine the package type for models 0x6b, 0x6f, 0x7f. This is done using BrandId from CPUID Fn8000_0001_EBX[15:0]. See "Constructing the processor Name String" in "Revision Guide for AMD NPT Family 0Fh Processors" (Rev. 3.46). Cc: Rudolf Marek <r.marek@assembler.cz> Cc: stable@kernel.org [.32.x, .33.x, .34.x, .35.x] Reported-by: Vladislav Guberinic <neosisani@gmail.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-25hwmon: (ads7871) Fix ads7871_probe error pathsAxel Lin
1. remove 'status' variable 2. remove unneeded initialization of 'err' variable 3. return missing error code if sysfs_create_group fail. 4. fix the init sequence as: - check hardware existence - kzalloc for ads7871_data - sysfs_create_group - hwmon_device_register Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-25hwmon: (coretemp) Fix harmless build warningJean Delvare
Fix the following build warning: CC [M] drivers/hwmon/coretemp.o drivers/hwmon/coretemp.c: In function "coretemp_init": drivers/hwmon/coretemp.c:521: warning: unused variable "n" drivers/hwmon/coretemp.c:521: warning: unused variable "p" Introduced by commit 851b29cb3b196cb66452ec964ab5f66c9c9cd1ed. When you drop code, you also have to drop the variables this code was using. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com>
2010-08-20revert "hwmon: f71882fg: add support for the Fintek F71808E"Andrew Morton
Revert commit 7721fea3d0fd93fb4d000eb737b444369358d6d3 ("hwmon: f71882fg: add support for the Fintek F71808E"). Hans said: : A second review after I've received a data sheet for this device from : Fintek has turned up a few bugs. : : Unfortunately Giel (nor I) have time to fix this in time for the 2.6.36 : cycle. Therefor I would like to see this patch reverted as not having any : support for the hwmon function of this superio chip is better then having : unreliable support. Cc: Giel van Schijndel <me@mortis.eu> Cc: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14hwmon: (via-cputemp) Remove bogus "SHOW" global variableH. Peter Anvin
The via-cputemp hwmon driver was probably intending "typedef enum { ... } SHOW;", but the "typedef" was missing creating a global variable named "SHOW". There is absolutely no reason to have this in the global namespace. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Harald Welte <HaraldWelte@viatech.com> Cc: Juerg Haefliger <juergh@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: jc42 depends on I2CRandy Dunlap
jc42 uses i2c interfaces, so it should depend on I2C. drivers/hwmon/jc42.c:426: error: implicit declaration of function 'i2c_check_functionality' drivers/hwmon/jc42.c:521: error: implicit declaration of function 'i2c_smbus_read_word_data' drivers/hwmon/jc42.c:529: error: implicit declaration of function 'i2c_smbus_write_word_data' drivers/hwmon/jc42.c:580: error: implicit declaration of function 'i2c_add_driver' drivers/hwmon/jc42.c:585: error: implicit declaration of function 'i2c_del_driver' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (pc87427) Move sysfs file removal to a separate functionJean Delvare
The sysfs file removal code is the same in the probe error path and in the remove function, so move it to a separate function to avoid code duplication. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add temperature monitoring supportJean Delvare
Add support for the 6 temperature monitoring channels of the PC87427. Note that the sensors resolution can vary, and I couldn't find a way to figure it out, so we might have to compensate in user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add support for the second logical deviceJean Delvare
The second logical device contains the voltage and temperature registers. We have to extend the driver to support a second logical device before we can add support for these features. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add support for manual fan speed controlJean Delvare
Add initial support for PWM outputs of the PC87427 Super-I/O chip. Only mode change and manual fan speed control are supported. Automatic mode configuration isn't supported, and won't be until at least one board is known, which makes uses of the PWM outputs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Minor style cleanupsJean Delvare
Follow the best practice of the day. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Handle disabled fan inputs properlyJean Delvare
Most fan input pins of the PC87427 can have alternate functions. Update the driver to check the configuration register and only support fan inputs which are really used for fan monitoring. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (w83627ehf) Add support for W83667HG-BGuenter Roeck
Add support for W83667HG-B (very similar to the W83667HG). Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (w83627ehf) Driver cleanupGuenter Roeck
- Moved fan pwm register array pointers into per-instance data. - Only read fan pwm data for installed/supported fans. - Update fan max output and fan step output information from data in registers. - Create max_output and step_output attribute files only if respective fan pwm registers exist. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: Add driver for SMSC EMC2103 temperature monitor and fan controllerSteve Glendinning
SMSC's EMC2103 family of temperature/fan controllers have 1 onboard and up to 3 external temperature sensors, and allow closed-loop control of one fan. This patch adds support for them. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (asc7621) Clean up and improve detect functionJean Delvare
* The dev variable is never used. * Detect functions only need to set info->type, not client->name. * Include the device address in the log message. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: George Joseph <george.joseph@fairview5.com> Cc: Ken Milmore <ken.milmore@googlemail.com>
2010-08-14hwmon: (it87) Export labels for internal sensorsJean Delvare
Some voltage sensors can be wired internally to the IT87xxF chip's own power supply channels. In that case, we can inform user-space that the wiring is known by exporting proper labels for these sensors. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (lm75) Add suspend/resume featureShubhrajyoti Datta
There is a shutdown feature at suspend it can be enabled to reduce current consumption and resume it can be switched off. Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (emc1403) Add power supportAlan Cox
Add back the power interface we lost due to a slight misunderstanding of the maintainers wishes. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (ltc4245) Expose all GPIO pins as analog voltagesIra W. Snyder
Add support for exposing all GPIO pins as analog voltages. Though this is not an ideal use of the chip, some hardware engineers may decide that the LTC4245 meets their design requirements when studying the datasheet. The GPIO pins are sampled in round-robin fashion, meaning that a slow reader will see stale data. A userspace application can detect this, because it will get -EAGAIN when reading from a sysfs file which contains stale data. Users can choose to use this feature on a per-chip basis by using either platform data or the OF device tree (where applicable). Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (pc87360) Fix device resource declarationJean Delvare
It's not OK to call platform_device_add_resources() multiple times in a row. Despite its name, this functions sets the resources, it doesn't add them. So we have to prepare an array with all the resources, and then call platform_device_add_resources() once. Before this fix, only the last I/O resource would be actually registered. The other I/O resources were leaked. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: stable@kernel.org
2010-08-14hwmon: (k8temp) Adjust confusing if indentationJulia Lawall
Move the if(err) statement after the if into the if branch indicated by its indentation. The preceding if(err) test implies that err cannot be nonzero unless the if branch is taken. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces5@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p4) cocci.print_secs("after",p5) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (40 commits) mfd: Fix incorrect kfree(i2c) in wm8994-core i2c_driver probe mfd: Fix incorrect kfree(i2c) in wm831x-core i2c_driver probe mfd: Fix incorrect kfree(i2c) in tps6507x i2c_driver probe mfd: Add TPS6586x driver mfd: Use macros instead of some constant magic numbers for menelaus mfd: Fix menelaus mmc slot 2 misconfiguration mfd: Missing slab.h includes mfd: Fix wrong wm8350-core kfree in error path mfd: Fix wm8994_device_init() return value mfd: Avoid calling platform_device_put() twice in ucb1400 probe error path mfd: Annotate tc6387xb probe/remove routines with __devinit/__devexit mfd: Fix tc6387xb resource reclaim mfd: Fix wrong goto labels for tc6393xb error handling mfd: Get rid of now unused mc13783 private header hwmon: Don't access struct mc13783 directly from mc13783-adc mfd: New mc13783 function exposing flags mfd: Check jz4740-adc kmalloc() result mfd: Fix jz4740-adc resource reclaim in probe error path mfd: Add WM8321 support mfd: Add stmpe auto sleep feature ...
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-12hwmon: Don't access struct mc13783 directly from mc13783-adcUwe Kleine-König
There is a shiny new mc13783 API function that can be used instead. While at it refactor the code a bit to reduce code duplication a bit. This removes the last user of <linux/mfd/mc13783-private.h> and so this include file can go away. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-11fix "hwmon: coretemp: update hotplug condition check"Andrew Morton
In commit 0dca94baeab4 ("hwmon: coretemp: update hotplug condition check") we merged v2 of this patch. Update that to v3. The difference is to remove the new and unnecesary references to CPU_*_FROZEN. Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: f71882fg: add support for the Fintek F71808EGiel van Schijndel
Allow device probing to recognise the Fintek F71808E. Sysfs interface: * Fan/pwm control is the same as for F71889FG * Temperature and voltage sensor handling is largely the same as for the F71889FG - Has one temperature sensor less (doesn't have temp3) - Misses one voltage sensor (doesn't have V6, thus in6_input refers to what in7_input refers for F71889FG) For the purpose of the sysfs interface fxxxx_in_temp_attr[] is split up such that it can largely be reused. Signed-off-by: Giel van Schijndel <me@mortis.eu> Cc: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/hwmon/coretemp.c: remove unneeded #ifdef CONFIG_HOTPLUG_CPUAndrew Morton
register_hotcpu_notifier() is designed to make these ifdefs unnecessary. Cc: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: coretemp: documentation update and cleanupChen Gong
Update coretemp supported CPU TjMax lists and some cleanup work. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: coretemp: enable coretemp device add operation failureChen Gong
If one coretemp device can't be added, it should allow subsequent adding operation because every new-added device will create a new sysfs group, not an additional sensor sys entry. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: coretemp: update hotplug condition checkChen Gong
Fix two errors in hotplug. One is for hotplug notifier. The other is unnecessary driver unregister. Because even none of online cpus supports coretemp, we can't assume new onlined cpu doesn't support it either. If related driver is unregistered there we have no chance to use coretemp from then on. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@intel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: add support for JEDEC JC 42.4 compliant temperature sensorsGuenter Roeck
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09hwmon: driver for SMM665 Six-Channel Active DC Output Controller/MonitorGuenter Roeck
This driver adds support for the monitoring features of the Summit Microelectronics SMM665 Six-Channel Active DC Output Controller/Monitor. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09drivers/hwmon/hdaps.c: add Lenovo Thinkpad T400 to the whitelistRitesh Raj Sarraf
Add Lenovo Thinkpad T400. I have done the testing on my laptop. The hdaps module detects the device and the hdapsd daemon is able to [un]park the disk. Signed-off-by: Ritesh Raj Sarraf <rrs@debian.org> Cc: Frank Seidel <frank@f-seidel.de> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-06Merge branch 'x86-hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hwmon: Package Level Thermal/Power: pkgtemp documentation x86, hwmon: Package Level Thermal/Power: power limit x86, hwmon: Package Level Thermal/Power: thermal throttling handler x86, hwmon: Package Level Thermal/Power: pkgtemp hwmon driver
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-08-05HWMON: Add JZ4740 ADC driverLars-Peter Clausen
Add support for reading the ADCIN pin of the ADC unit on JZ4740 SoCs. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: lm-sensors@lm-sensors.org Acked-by: Jean Delvare <khali@linux-fr.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1425/ Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-03x86, hwmon: Package Level Thermal/Power: pkgtemp hwmon driverFenghua Yu
This patch adds a hwmon driver for package level thermal control. The driver dumps package level thermal information through sysfs interface so that upper level application (e.g. lm_sensor) can retrive the information. Instead of having the package level hwmon code in coretemp, I write a seperate driver pkgtemp because: First, package level thermal sensors include not only sensors for each core, but also sensors for uncore, memory controller or other components in the package. Logically it will be clear to have a seperate hwmon driver for package level hwmon to monitor wider range of sensors in a package. Merging package thermal driver into core thermal driver doesn't make sense and may mislead. Secondly, merging the two drivers together may cause coding mess. It's easier to include various package level sensors info if more sensor information is implemented. Coretemp code needs to consider a lot of legacy machine cases. Pkgtemp code only considers platform starting from Sandy Bridge. On a 1Sx4Cx2T Sandy Bridge platform, lm-sensors dumps the pkgtemp and coretemp: pkgtemp-isa-0000 Adapter: ISA adapter physical id 0: +33.0°C (high = +79.0°C, crit = +99.0°C) coretemp-isa-0000 Adapter: ISA adapter Core 0: +32.0°C (high = +79.0°C, crit = +99.0°C) coretemp-isa-0001 Adapter: ISA adapter Core 1: +32.0°C (high = +79.0°C, crit = +99.0°C) coretemp-isa-0002 Adapter: ISA adapter Core 2: +32.0°C (high = +79.0°C, crit = +99.0°C) coretemp-isa-0003 Adapter: ISA adapter Core 3: +32.0°C (high = +79.0°C, crit = +99.0°C) [ hpa: folded v3 patch removing improper global variable "SHOW" ] Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> LKML-Reference: <1280448826-12004-3-git-send-email-fenghua.yu@intel.com> Reviewed-by: Len Brown <len.brown@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-09hwmon: (coretemp) Properly label the sensorsJean Delvare
Don't assume that CPU entry number and core ID always match. It worked in the simple cases (single CPU, no HT) but fails on multi-CPU systems. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Huaxu Wan <huaxu.wan@intel.com> Cc: stable@kernel.org
2010-07-09hwmon: (coretemp) Skip duplicate CPU entriesJean Delvare
On hyper-threaded CPUs, each core appears twice in the CPU list. Skip the second entry to avoid duplicate sensors. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Huaxu Wan <huaxu.wan@intel.com> Cc: stable@kernel.org
2010-07-09hwmon: (it87) Fix in7 on IT8720FJean Delvare
The IT8720F has no VIN7 pin, so VCCH should always be routed internally to VIN7 with an internal divider. Curiously, there still is a configuration bit to control this, which means it can be set incorrectly. And even more curiously, many boards out there are improperly configured, even though the IT8720F datasheet claims that the internal routing of VCCH to VIN7 is the default setting. So we force the internal routing in this case. It turns out that all boards with the wrong setting are from Gigabyte, so I suspect a BIOS bug. But it's easy enough to workaround in the driver, so let's do it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jean-Marc Spaggiari <jean-marc@spaggiari.org> Cc: stable@kernel.org
2010-07-09hwmon: (k8temp) Fix temperature reporting for ASB1 processor revisionsAndreas Herrmann
Reported temperature for ASB1 CPUs is too high. Add ASB1 CPU revisions (these are also non-desktop variants) to the list of CPUs for which the temperature fixup is not required. Example: (from LENOVO ThinkPad Edge 13, 01972NG, system was idle) Current kernel reports $ sensors k8temp-pci-00c3 Adapter: PCI adapter Core0 Temp: +74.0 C Core0 Temp: +70.0 C Core1 Temp: +69.0 C Core1 Temp: +70.0 C With this patch I have $ sensors k8temp-pci-00c3 Adapter: PCI adapter Core0 Temp: +54.0 C Core0 Temp: +51.0 C Core1 Temp: +48.0 C Core1 Temp: +49.0 C Cc: stable@kernel.org [.32.x .33.x, .34.x] Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-20hwmon: (k8temp) Bypass core swapping on single-core processorsJean Delvare
Commit a2e066bba2aad6583e3ff648bf28339d6c9f0898 introduced core swapping for CPU models 64 and later. I recently had a report about a Sempron 3200+, model 95, for which this patch broke temperature reading. It happens that this is a single-core processor, so the effect of the swapping was to read a temperature value for a core that didn't exist, leading to an incorrect value (-49 degrees C.) Disabling core swapping on singe-core processors should fix this. Additional comment from Andreas: The BKDG says Thermal Sensor Core Select (ThermSenseCoreSel)-Bit 2. This bit selects the CPU whose temperature is reported in the CurTemp field. This bit only applies to dual core processors. For single core processors CPU0 Thermal Sensor is always selected. k8temp_probe() correctly detected that SEL_CORE can't be used on single core CPU. Thus k8temp did never update the temperature values stored in temp[1][x] and -49 degrees was reported. For single core CPUs we must use the values read into temp[0][x]. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Rick Moritz <rhavin@gmx.net> Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: stable@kernel.org
2010-06-20hwmon: (i5k_amb) Fix sysfs attribute for lockdepKAMEZAWA Hiroyuki
i5k_amb.ko uses dynamically allocated memory (by kmalloc) for attributes passed to sysfs. So, sysfs_attr_init() should be called for working happy with lockdep. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org [2.6.34 only]
2010-06-20hwmon: (k10temp) Do not blacklist known working CPU modelsJean Delvare
When detecting AM2+ or AM3 socket with DDR2, only blacklist cores which are known to exist in AM2+ format. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: stable@kernel.org
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-27hwmon: (lm75) Add support for the Texas Instruments TMP105Shubhrajyoti Datta
Add support for the Texas Instruments TMP105 temperature sensor device. Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-27hwmon: (ltc4245) Read only one GPIO pinIra W. Snyder
Read only one of the GPIO pins as an analog voltage. The ADC can be switched to a different GPIO pin at runtime, but this is not supported. Previously, this driver would report the analog voltage of the currently selected GPIO pin as all three GPIO voltages: in9_input, in10_input and in11_input. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
