path: root/drivers/hwmon/lm80.c
2013-04-07hwmon: Fix checkpatch warning 'quoted string split across lines'Guenter Roeck
Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-01-25hwmon: Replace SENSORS_LIMIT with clamp_valGuenter Roeck
SENSORS_LIMIT and the generic clamp_val have the same functionality, and clamp_val is more efficient. This patch reduces text size by 9052 bytes and bss size by 11624 bytes for x86_64 builds. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: George Joseph <george.joseph@fairview5.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-07-21hwmon: (lm80) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-18hwmon: (lm80) Add detection of NatSemi/TI LM96080Jean Delvare
Add detection of the National Semiconductor (now Texas Instruments) LM96080. It is functionally compatible with the LM80 but detection is completely different. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-18hwmon: (lm80) Fix multi-line commentsGuenter Roeck
2012-03-18hwmon: convert drivers/hwmon/* to use module_i2c_driver()Axel Lin
This patch converts the drivers in drivers/hwmon/* to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Corentin Labbe <corentin.labbe@geomatys.fr> Cc: Dirk Eibach <eibach@gdsys.de> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Riku Voipio <riku.voipio@iki.fi> Cc: Guillaume Ligneul <guillaume.ligneul@gmail.com> Cc: David George <david.george@ska.ac.za> Cc: "Hans J. Koch" <hjk@hansjkoch.de> Cc: Marc Hulsman <m.hulsman@tudelft.nl> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-18hwmon: (lm80) reset device if error occurredFrans Meulenbroeks
If an error occurs while updating (e.g. because the chip was disconnected) the device needs to be reinitialized in order to get back to 11 bit temperature and set the fan divider. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-18hwmon: (lm80) fix checkpatch warningsFrans Meulenbroeks
fix: WARNING: simple_strtol is obsolete, use kstrtol instead WARNING: simple_strtoul is obsolete, use kstrtoul instead Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> [guenter.roeck@ericsson.com: kstrtol->kstrtoul where appropriate] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-03-18hwmon: (lm80) add error handlingFrans Meulenbroeks
The LM80 driver currently does not return errors after I2C access failures. Add it. Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2012-01-05hwmon: (lm80) fix checkpatch messagesFrans Meulenbroeks
Fixed all checkpatch messages except simple_strto* -> kstr* This will be addressed in a separate patch Also left one line-too-long message as it was only a little bit too long and would become less readable compile-tested: no warnings or errors Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2009-12-14i2c: Drop I2C_CLIENT_INSMOD_1Jean Delvare
This macro simply declares an enum, so drivers might as well declare it themselves. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Get rid of struct i2c_client_address_dataJean Delvare
Struct i2c_client_address_data only contains one field at this point, which makes its usefulness questionable. Get rid of it and pass simple address lists around instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2009-12-14i2c: Drop the kind parameter from detect callbacksJean Delvare
The "kind" parameter always has value -1, and nobody is using it any longer, so we can remove it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Wolfram Sang <w.sang@pengutronix.de>
2008-07-16hwmon: (lm80) Convert to a new-style i2c driverJean Delvare
The new-style lm80 driver implements the optional detect() callback to cover the use cases of the legacy driver. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-18hwmon: normal_i2c arrays should be constMark M. Hoffman
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (lm80) Add individual alarm filesJean Delvare
The new libsensors needs these individual alarm files. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (lm80) De-macro the sysfs callbacksJean Delvare
Use standard dynamic sysfs callbacks instead of macro-generated functions. This makes the code more readable, and the binary smaller (by about 34%). As a side note, another benefit of this type of cleanup is that they shrink the build time. For example, this cleanup saves about 29% of the lm80 driver build time. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: (lm80) Various cleanupsJean Delvare
* Drop trailing whitespace * Fold a long line * Rename new_client to client * Drop redundant initializations to 0 * Drop bogus comment Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2008-02-07hwmon: Discard useless I2C driver IDsJean Delvare
Many I2C hwmon drivers define a driver ID but no other code references these, meaning that they are useless. Discard them, along with a few IDs which are defined but never used at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2006-09-28hwmon: Fix unchecked return status, batch 2Mark M. Hoffman
hwmon: Fix unchecked return status, batch 2 Fix up some hwmon drivers so that they no longer ignore return status from device_create_file(). Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-23[PATCH] hwmon: Semaphore to mutex conversionsIngo Molnar
convert drivers/hwmon/*.c semaphore use to mutexes. the conversion was generated via scripts, and the result was validated automatically via a script as well. all affected hwmon drivers were build-tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 3 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the hwmon drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: Static function fixes, 3 of 4Ben Dooks
Fixup functions that have been declared static and then actually defined without the static on. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] hwmon: kzalloc conversionDeepak Saxena
Use kzalloc instead of kmalloc+memset in all hardware monitoring drivers. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (04/11)Jean Delvare
i2c_probe and i2c_detect now do the exact same thing and operate on the same data structure, so we can have everyone call i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: refactor message in i2c_detach_clientJean Delvare
We could refactor the error message 34 different i2c drivers print if i2c_detach_client() fails in this function itself. Saves quite a few lines of code. Documentation is updated to reflect that change. Note that this patch should be applied after Rudolf Marek's w83792d patches. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (7/9)Jean Delvare
Kill normal_isa in header files, documentation and all chip drivers, as it is no more used. normal_i2c could be renamed to normal, but I decided not to do so at the moment, so as to limit the number of changes. This might be done later as part of the i2c_probe/i2c_detect merge. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C hwmon: add hwmon sysfs class to driversMark M. Hoffman
This patch modifies sensors chip drivers to make use of the new sysfs class "hwmon". Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-11[PATCH] I2C: Move hwmon drivers (2/3)Jean Delvare
Part 2: Move the driver files themselves. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
