path: root/drivers/hwmon/gl520sm.c
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (07/11)Jean Delvare
The only part left in i2c-sensor is the VRM/VRD/VID handling code. This is in no way related to i2c, so it doesn't belong there. Move the code to hwmon, where it belongs. Note that not all hardware monitoring drivers do VRM/VRD/VID operations, so less drivers depend on hwmon-vid than there were depending on i2c-sensor. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (06/11)Jean Delvare
The only thing left in i2c-sensor.h are module parameter definition macros. It's only an extension of what i2c.h offers, and this extension is not sensors-specific. As a matter of fact, a few non-sensors drivers use them. So we better merge them in i2c.h, and get rid of i2c-sensor.h altogether. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (04/11)Jean Delvare
i2c_probe and i2c_detect now do the exact same thing and operate on the same data structure, so we can have everyone call i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: refactor message in i2c_detach_clientJean Delvare
We could refactor the error message 34 different i2c drivers print if i2c_detach_client() fails in this function itself. Saves quite a few lines of code. Documentation is updated to reflect that change. Note that this patch should be applied after Rudolf Marek's w83792d patches. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C: Separate non-i2c hwmon drivers from i2c-core (7/9)Jean Delvare
Kill normal_isa in header files, documentation and all chip drivers, as it is no more used. normal_i2c could be renamed to normal, but I decided not to do so at the moment, so as to limit the number of changes. This might be done later as part of the i2c_probe/i2c_detect merge. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] I2C hwmon: add hwmon sysfs class to driversMark M. Hoffman
This patch modifies sensors chip drivers to make use of the new sysfs class "hwmon". Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-29[PATCH] I2C: use time_after in 3 chip driversJean Delvare
A few i2c drivers were not updated to use time_after() yet. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[PATCH] I2C: Move hwmon drivers (2/3)Jean Delvare
Part 2: Move the driver files themselves. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. From: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
