Replace S_<PERMS> with octal values.
The conversion was done automatically with coccinelle. The semantic patches
and the scripts used to generate this commit log are available at
https://github.com/groeck/coccinelle-patches/hwmon/.
This patch does not introduce functional changes. It was verified by
compiling the old and new files and comparing text and data sizes.
Cc: Henrik Rydberg <rydberg@bitmath.org>
... and __initconst if applicable.
Based on similar work for an older kernel in the Grsecurity patch.
[JD: fix toshiba-wmi build]
[JD: add htcpen]
[JD: move __initconst where checkscript wants it]
Signed-off-by: Jean Delvare <jdelvare@suse.de>
gcc 7.1 complains that the driver uses sprintf() and thus does not validate
the length of output buffers.
drivers/hwmon/applesmc.c: In function 'applesmc_show_fan_position':
drivers/hwmon/applesmc.c:82:21: warning:
'%d' directive writing between 1 and 5 bytes into a region of size 4
Fix the problem by using scnprintf() instead of sprintf() throughout the
driver. Also explicitly limit the number of supported fans to avoid actual
buffer overruns and thus invalid keys.
Fix the following "maybe used uninitialized" warnings by
initializing the variables to keep the compiler quiet.
There is no "used uninitialized" in this case.
CC [M] drivers/hwmon/applesmc.o
drivers/hwmon/applesmc.c: In function ‘applesmc_init_smcreg’:
drivers/hwmon/applesmc.c:595:43: warning: ‘right_light_sensor’
may be used uninitialized in this function [-Wmaybe-uninitialized]
s->num_light_sensors = left_light_sensor + right_light_sensor;
drivers/hwmon/applesmc.c:540:26: note: ‘right_light_sensor’ was
declared here
bool left_light_sensor, right_light_sensor;
drivers/hwmon/applesmc.c:595:43: warning: ‘left_light_sensor’ may
drivers/hwmon/applesmc.c:540:7: note: ‘left_light_sensor’ was
declared here
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
s/ressources/resources/
Signed-off-by: Bastien Nocera <hadess@hadess.net>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The crash reported and investigated in commit 5f4513 turned out to be
caused by a change to the read interface on newer (2012) SMCs.
Tests by Chris show that simply reading the data valid line is enough
for the problem to go away. Additional tests show that the newer SMCs
no longer wait for the number of requested bytes, but start sending
data right away. Apparently the number of bytes to read is no longer
specified as before, but instead found out by reading until end of
data. Failure to read until end of data confuses the state machine,
which eventually causes the crash.
As a remedy, assuming bit0 is the read valid line, make sure there is
nothing more to read before leaving the read function.
Tested to resolve the original problem, and runtested on MBA3,1,
MBP4,1, MBP8,2, MBP10,1, MBP10,2. The patch seems to have no effect on
machines before 2012.
Tested-by: Chris Murphy <chris@cmurf.com>
Cc: stable@vger.kernel.org
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
After reports from Chris and Josh Boyer of a rare crash in applesmc,
Guenter pointed at the initialization problem fixed below. The patch
has not been verified to fix the crash, but should be applied
regardless.
Reported-by: <jwboyer@fedoraproject.org>
Suggested-by: Guenter Roeck <linux@roeck-us.net>
appropriate
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Alistair John Strachan <alistair@devzero.co.uk>
Cc: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Alistair John Strachan <alistair@devzero.co.uk>
These drivers use IS_ERR so they should include <linux/err.h>.
Acked-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Luca Tettamanti <kronos.it@gmail.com>
A heavy-load test on a MacBookPro6,1 is still showing a substantial
amount of read errors. Increasing the maximum wait time to 128 ms
resolves the issue.
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
The behavior of the SMC has changed several times over the years,
causing read failures in the driver. It seems the problem can be
explained by a shift in SMC speed combined with improper action on
status codes.
We should first wait for the SMC to settle, which was the most
frequent response on the old slow machines. Then, if the SMC is busy,
we need to try again later by resending the command. This was the most
likely response until 2012. Now, with a shorter wait time, we are
again most likely to poll while the SMC is settling, and as a result
we see high failure rates on many old and new models.
With the distinction between busy and failure, we can also wait longer
before retrying, without sacrificing speed. This seems to bring
failures down to virtually zero on all models.
Tested on: MBA1,1 MBA3,1 MBA5,1 MBA5,2 MBP9,2
Tested-by: Adam Somerville <adamsomerville@gmail.com>
Tested-by: Hubert Eichner <hubert.georg.eichner@gmail.com>
Not all sensors in the T range are useful temperatures. This patch
creates a subset of sensors to be exported to userland, excluding the
unknown types.
There are many userland reports of sensors with unreasonably small and
large temperatures. There seem to be several reasons for this:
Firstly, the major sensor type (sp78) is actually a signed number.
This explains why some sensors show very small or large values - they
are in fact all small, but of different sign.
Secondly, the other sensor type (1-hex) is not properly understood; it
may be that it is not a temperature after all.
Thirdly, some sensors are differential in nature, showing changes over
time rather than absolute numbers. This explains why those values are
small and of varying sign.
This patch interprets the sp78 type as signed short, but keeps the
original scaling. For other types, -EINVAL is returned, since the
nature of those sensors is unknown.
The 2012 series of MacBooks have a faster SMC, and the current driver
timings do not work at all. Tests show that decreasing the minimum
wait time, from 64 us to 16 us, works well. Since this is still larger
than the original minimum of 10 us used before 2008, there is nothing
inherently problematic with changing it. The fail frequency on older
machines seems to increase slightly, but not enough to be noticeable.
Tested on MBA11, MBA31, MBA5,2, MBP9,2.
The patch was originally written by adamski99 (ubuntuforums.org) and
later tested by janhouse (bbs.archlinux.org).
The special motion sensor mapping is unnecessary; remove it.
I've not had a gmail address for years. This commit updates the
address to my actual working one.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Key lookups may call read_smc() with a fixed-length key string,
and if the lookup fails, trailing stack content may appear in the
kernel log. Fixed with this patch.
Some error paths do not set a result, leading to the (false)
assumption that the value may be used uninitialized. Set results for
those paths as well.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
replaced strict_strtol with kstrtol and
replaced strict_strtuol with kstrtuol
This satisfies checkpatch -f
Compile tested only: no warnings or errors given
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
The switch to dynamically allocated sysfs attributes left the
internal lockdep members uninitialized, causing a formal bug.
This patch adds sysfs_attr_init() to the node creation function,
remedying the problem.
Reported-and-tested-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
This patch fixes all checkpatch errors and most of the checkpatch warnings.
It also fixes the range check in applesmc_store_fan_speed().
With the preceding patches, git blame assigns about half of
the file to the present author. Add a line to the copyright
to reflect this.
Make the driver report a single line on success.
Given the dynamic node construction method, the setup of the
accelerometer, light sensor and keyboard backlight sysfs nodes
can be simplified. This patch does not contain any logic changes.
With the dynamic temperature group in place, the setup of fans
can be simplified. This patch sets up the fans dynamically, removing
a hundred lines of code.
With temperature keys being determined automatically, the dmi match
data is only used to assign features that can easily be detected from
the smc. This patch removes the dmi match data altogether, and reduces
the match table to the main machine models.
The recent Macbooks have temperature registers of a new type.
This patch adds the logic to handle them.
The current driver creates temperature files based on a list
of temperature keys given per device. Apart from slow adaption
to new machine models, the number of sensors also depends on
the number of processors. This patch looks up the temperature
keys dynamically, thereby supporting all models.
One main problem with the current driver is the inability to quickly
search for supported keys, resulting in detailed feature maps per
machine model which are cumbersome to maintain.
This patch adds a register lookup table, which enables binary search
for supported keys. The lookup also reduces the io frequency, so the
original mutex is replaced by locks around the actual io.
[guenter.roeck@ericsson.com: Added value range check to key_at_index_store()]
Added #define pr_fmt KBUILD_MODNAME ": " fmt
Converted printks to pr_<level>
Coalesced any long formats
Removed prefixes from formats
The device init is used to reset the accelerometer. Failure to reset
is not severe enough to stop loading the module or to resume from
hibernation. This patch relaxes failure to a warning and drops
output in case of success.
Cc: stable@kernel.org
This patch add support for the MacBookAir3,1 and MacBookAir3,2 to the
applesmc driver.
[rydberg@euromail.se: minor cleanup]
Signed-off-by: Edgar Hucek <gimli@dark-green.com>
The Apple SMC uses a systematic labeling scheme for the hardware
temperature sensors. This scheme is currently hidden from
userland. Since the sensor set, and consequently the numbering,
differs between models, an extensive database of configurations is
required for an application such as fan control. This patch adds the
SMC labels to the hwmon sysfs interface, allowing applications to use
the sensors more intelligibly.
[rydberg@euromail.se: fixed error handling]
Signed-off-by: Alex Murray <murray.alex@gmail.com>
This patch adds generic support for the MacBook Pro 7 family
based on the 7,1 model.
This patch adds generic support for the MacBook Pro 6 family
based on the 6,2 model.
[rydberg@euromail.se: patch cleanup]
Signed-off-by: Bernhard Froemel <froemel@vmars.tuwien.ac.at>
The MacBookPro 5,3 model has two fans, whereas the 5,4 model has
only one. This patch adds explicit support for the 5,3 and 5,4 models.
The current code will not remove the sysfs files for fan numbers three
and up. Also, upon exit, fans one and two are removed regardless of
their existence. This patch cleans up the sysfs error handling for
the fans.
Add the iMac9,1 and the MacBookPro2,2 temperature sensors to hwmon
driver applesmc to fix kernel bug #14429:
https://bugzilla.kernel.org/show_bug.cgi?id=14429
Acked-by: Nicolas Boichat <nicolas@boichat.ch>
On resume from suspend, the driver currently resets the logical state as
if it was brought up from halt. This patch uses the
dev_pm_ops.resume/restore methods to synchronize the hardware with the
memorized logical state, in effect bringing back the accelerometer and
backlight to the state prior to suspend. Works for both suspend to ram
and hibernation. The patch has zero effect on the running state.
Cc: Nicolas Boichat <nicolas@boichat.ch>
Drivers should be including <linux/io.h> instead of <asm/io.h>.
Cc: Juerg Haefliger <juergh@gmail.com>
Cc: Frank Seidel <frank@f-seidel.de>
Acked-by: Jim Cromie <jim.cromie@gmail.com>
Cc: "Mark M. Hoffman" <mhoffman@lightlink.com>
Cc: Roger Lucas <vt8231@hiddenengine.co.uk>
MacPro 3 have more temperature sensors than the previous MacPro's also the
sensor THTG has been removed. This patch add supports for the newer
temperature sensors in the MacPro3.
Signed-off-by: Bharath Ramesh <bramesh@vt.edu>
The light sensors ALV0 and ALV1 on newer MacBooks (early 2008 and later)
changed to report 10 bytes instead the earlier 6, and the sensor encoding
subsequently changed. As a result, the reported light sensors readings
are much too low.
Via experiments leading up to this patch, it seems only the ALV0 is
reporting data, and the most useful value therein is a 10-bit big-endian
value at offset 6. This suggests that a new protocol was added as a
backward-compatible replacement on top of the old one.
This patch makes applesmc report the improved light sensor reading for the
new machines, on a scale in conformance with earlier ones.
Add temperature sensor support for MacBook Air 2.
make use of the new dmi device loading support to automatically load the
applesmc driver based on the dmi_match table.
In order to analyze the SMC of the newer MacPros, applesmc needs to
recognize the machine. This patch adds the missing generic dmi_match
entry for MacPro models.
Add temperature sensor support for iMac 6.
Tested-by: Caleb Hyde <caleb.hyde@gmail.com>
This patch adds accelerometer and temperature sensor support for Macbook 4.
