path: root/drivers/hwmon/abituguru.c
2013-05-13hwmon: fix error return code in abituguru_probe()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: stable@vger.kernel.org Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-04-07hwmon: Fix 'Macros with complex values' checkpatch errorsGuenter Roeck
Fix: ERROR: Macros with complex values should be enclosed in parenthesis when it is seen due to complex code and not due to multi-line variable declarations. Cc: Hans de Goede <hdegoede@redhat.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Acked-by: Alistair John Strachan <alistair@devzero.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-04-07hwmon: checkpatch cleanup: Replace printk with pr_debug or dev_dbg as ↵Guenter Roeck
appropriate Cc: Hans de Goede <hdegoede@redhat.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Henrik Rydberg <rydberg@euromail.se> Acked-by: Alistair John Strachan <alistair@devzero.co.uk> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-11-28hwmon: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28hwmon: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28hwmon: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-23hwmon: (abituguru) Convert to use devm_ functionsGuenter Roeck
Convert to use devm_ functions to reduce code size and simplify the code. Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-07-21hwmon: (abituguru) Use struct dev_pm_ops for power managementRafael J. Wysocki
Make the Abit uGuru driver define its PM callbacks through a struct dev_pm_ops object rather than by using legacy PM hooks in struct platform_driver. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> [linux@roeck-us.net: CONFIG_PM->CONFIG_PM_SLEEP, and remove unnecessary ()] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-03-18hwmon: (abituguru) Fix checkpatch issuesGuenter Roeck
Fixed: ERROR: do not use assignment in if condition ERROR: else should follow close brace '}' ERROR: switch and case should be at the same indent WARNING: simple_strtoul is obsolete, use kstrtoul instead Modify multi-line comments to follow Documentation/CodingStyle. Not fixed: WARNING: msleep < 20ms can sleep for up to 20ms Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-25hwmon: (abituguru) Depend on DMIJean Delvare
The abituguru drivers are only built on X86, where DMI support is now enabled by default. So let these drivers depend on DMI, for the following gains: * Robustness and safety. Detection of these devices is weak and uses non-standard methods, it should really be limited to Abit boards unless the user explicitly asks otherwise. * Code simplicity. The code is easier to read without ifdefs. * Better build testing coverage. Now there's only one way to build the drivers, so no risk of build failure on exotic systems. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Alistair John Strachan <alistair@devzero.co.uk> Acked-by: Hans de Goede <hdegoede@redhat.com>
2011-03-21hwmon: (abituguru*) Update my email addressHans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-01-08hwmon: (abituguru) Use pr_fmt and pr_<level>Joe Perches
Added #define pr_fmt KBUILD_MODNAME ": " fmt Converted printks to pr_<level> Coalesced any long formats Removed prefixes from formats Added a few static strings to standardize logging messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2009-09-15hwmon: Include <linux/io.h> instead of <asm/io.h>H Hartley Sweeten
Drivers should be including <linux/io.h> instead of <asm/io.h>. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Nicolas Boichat <nicolas@boichat.ch> Cc: Juerg Haefliger <juergh@gmail.com> Cc: Frank Seidel <frank@f-seidel.de> Acked-by: Jim Cromie <jim.cromie@gmail.com> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Roger Lucas <vt8231@hiddenengine.co.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-10-14Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: (53 commits) hwmon: (vt8231) fix sparse warning hwmon: (sis5595) fix sparse warning hwmon: (w83627hf) don't assume bank 0 hwmon: (w83627hf) Fix setting fan min right after driver load hwmon: (w83627hf) De-macro sysfs callback functions hwmon: Add new combined driver for FSC chips hwmon: (ibmpex) Release IPMI user if hwmon registration fails hwmon: (dme1737) Add sch311x support hwmon: (dme1737) group functions logically hwmon: (dme1737) cleanups hwmon: IBM power meter driver hwmon: (coretemp) Add support for Celeron 4xx hwmon: (lm87) Disable VID when it should be hwmon: (w83781d) Add individual alarm and beep files hwmon: VRM is not read from registers MAINTAINERS: update hwmon subsystem git trees hwmon: Fix the code examples in documentation hwmon: update sysfs interface document - error handling hwmon: (thmc50) Fix a debug message hwmon: (thmc50) Don't create temp3 if not enabled ...
2007-10-09hwmon: Convert from class_device to deviceTony Jones
Convert from class_device to device for hwmon_device_register/unregister Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-10-09drivers/firmware: const-ify DMI API and internalsJeff Garzik
Three main sets of changes: 1) dmi_get_system_info() return value should have been marked const, since callers should not be changing that data. 2) const-ify DMI internals, since DMI firmware tables should, whenever possible, be marked const to ensure we never ever write to that data area. 3) const-ify DMI API, to enable marking tables const where possible in low-level drivers. And if we're really lucky, this might enable some additional optimizations on the part of the compiler. The bulk of the changes are #2 and #3, which are interrelated. #1 could have been a separate patch, but it was so small compared to the others, it was easier to roll it into this changeset. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-19hwmon: refuse to load abituguru driver on non-Abit boardsHans de Goede
With this patch the abituguru refuses to load on non Abit motherboards, as discussed in lkml CONFIG_BREAK_MY_MACHINE thread. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: Add support for newer uGuru'sHans de Goede
This patch adds a new driver for the hardware monitoring features of the third revision of the Abit uGuru chip, found on recent Abit motherboards. This is an entirely different beast then the first and second revision (its again a winbond microcontroller, but the "protocol" to talk to it and the bank addresses are very different. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: fix detection of abituguru volt inputsHans de Goede
This patch fixes the detection of volt inputs with a reading of more then 240 units. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-07-19hwmon: Fix a potential race condition on unloadJean Delvare
Fix a potential race condition when some hardware monitoring platform drivers are being unloaded. I believe that the driver data pointer shouldn't be cleared before all the sysfs files are removed, otherwise a sysfs callback might attempt to dereference a NULL pointer. I'm not sure exactly what the driver core protects drivers against, so let's play it safe. While we're here, clear the driver data pointer when probe fails, so as to not leave an invalid pointer behind us. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2007-02-14hwmon/abituguru: Fix unchecked return statusHans de Goede
Fix an unused return value warning for the abituguru driver. Also make sure the sysfs files are created before we register with the hwmon class, and delete the sysfs files on driver removal. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-04[PATCH] severing module.h->sched.hAl Viro
2006-09-28abituguru: Add suspend/resume supportHans de Goede
This patch contains rudimentary suspend / resume support for the uguru, this protects the uguru and the driver against suspend / resume cycles, so there is no reason to unload the driver in your suspend / resume scripts. Only include suspend / resume functions when CONFIG_PM is set. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-26[PATCH] hwmon: abituguru timeout fixesHans de Goede
This patch contains 2 sets of fixes for the abituguru: 1) Much improved timeout handling, drasticly reducing the amount of timeout errors on some motherboards 2) Fix the exit paths in the bank1 sensor type detect code to always restore the original settings even on an error. Without this our special test settings could remain seriously confusing the system BIOS's setup menu. Both are very much related and are must haves, to avoid messing up the uguru CMOS settings. Detailed changes: - Much improved timeout / wait for status handling. Many thanks to Sunil Kumar, for all his testing, ideas and patches! The code now first busy waits, polling the uguru for the expected status as this usually succeeds pretty quickly (within 90 reads). To avoid unnecessary CPU burn in timeout conditions, the amount of busy waiting has been halved from previous versions (120 tries instead of 250). This is not a problem, because this version goes to sleep after 120 attemps for 1 jiffy and then tries again, it does this sleep and try again 5 times before finally giving up. This (almost?) completly removes the timeout errors some people have seen regulary. Apparently some older uguru versions sometimes are distracted for a (relatively) long time. This solves this. - These timeout errors not only occur in the sending address part of reading the uguru but also in the wait for read state, so errors in this state are now handled as retryable just like send address state errors and are only logged and reported to userspace if 3 executive tries fail. - Fix a very nasty bug in the bank1 sensor type detection code, where it would not restore the original settings in any of the error paths! - Since not successfully restoring the original settings can seriously confuse the system BIOS (hang when entering the relevant setup menu), we now try restoring them 3 times before giving up. Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] hwmon: Fix for first generation Abit uGuru chipsHans de Goede
Now that the abituguru driver is seeing some more widespread testing it has turned out that one the first generation of Abit uGuru motherboards, with uGuru revision 1, the autodetect bank1 sensor type code doesn't (always) work. This patch adds a module param to override the autodetect, and it adds validity checks for the value of the 2 other autodetection override module params. An example of howto use the new param can be found here: http://lm-sensors.org/wiki/Configurations/Abit/AN7 Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] abituguru: Fix fan detectionHans de Goede
One of my testers had a problem where the driver only saw 2 of the 4 fan sensors his uGuru has, this fixes this. -accept 0x40 (bit 6) being high as a valid fan sensor setting for all fans not just fan 1, I have a feeling this bit indicates whether or not a fan is actually connected . Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] abituguru: Review fixesHans de Goede
Fixes to the Abit uGuru driver as requested in review by Jean Delvare: - exactly calculate the sysfs_names array length using macro - use snprintf when generating names to double check that the sysfs_names array does not overflow. - use ARRAY_SIZE and / or defines to determine number of loops in for loops instead of using hardcoded values. - In abituguru_probe(), refactor the error path leaving a single call to kfree Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[PATCH] abituguru: New hardware monitoring driverHans de Goede
New hardware monitoring driver for the Abit uGuru Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
