This driver now uses regmap APIs, so it needs to select REGMAP_I2C.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Simplify code and reduce code size by using the new hwmon
registration API.
registration API.
This patch adds hardware temperature and power reading support for
APM X-Gene SoC using the mailbox communication interface.
Signed-off-by: Hoan Tran <hotran@apm.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
This driver implements hardware monitoring and watchdog support
for the FTS BMC Chip "Teutates".
Signed-off-by: Thilo Cestonaro <thilo@cestona.ro>
[groeck: Updated subject and description; fixed dependencies]
By converting the driver to regmap, we can use regmap to cache non-volatile
registers. Stop caching the temperature register; while potentially reading
it more often can result in reading it more often than necessary, this is
offset by the gain due to not re-reading the limit registers.
A positive side effect of this change is that limit registers can now be
read and updated before the first temperature conversion is complete.
Acked-by: Nishanth Menon <nm@ti.com>
Convert to use regmap. Leave caching to regmap and drop the register
update function. While this can result in additional read operations
if the temperature register is read continuously, it avoids re-reading
the limit registers and thus overall reduces complexity.
MCP9808 is not officially compliant to JC-42, similar to MCP9804,
but its registers are compatible to JC-42.
Signed-off-by: Alison Schofield <amsfield22@gmail.com>
Cc: Daniel Baluta <daniel.baluta@gmail.com>
Add support for the the INA3221 26v capable, Triple channel,
Bi-Directional, Zero-Drift, Low-/High-Side, Current/Voltage Monitor
with I2C interface.
Signed-off-by: Andrew F. Davis <afd@ti.com>
This driver implements support for the Sensirion SHT3x-DIS chip,
a humidity and temperature sensor. Temperature is measured
in degrees celsius, relative humidity is expressed as a percentage.
In the sysfs interface, all values are scaled by 1000,
i.e. the value for 31.5 degrees celsius is 31500.
Signed-off-by: Pascal Sachs <pascal.sachs@sensirion.com>
[groeck: Fixed 'Variable length array is used' gcc warning]
IT8628E is functionally identical to IT8620E.
Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
This patch adds CONFIG_CPU_SUP_AMD as the dependence of fam15h_power
driver. Because the following patch will use the interface from
x86/kernel/cpu/amd.c.
Otherwise, the below error might be encountered:
All errors (new ones prefixed by >>):
drivers/built-in.o: In function `fam15h_power_probe':
>> fam15h_power.c:(.text+0x26e3a3): undefined reference to
>> `amd_get_cores_per_cu'
fam15h_power.c:(.text+0x26e41e): undefined reference to
Reported-by: build test robot <lkp@intel.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Huang Rui <ray.huang@amd.com>
Add basic support for the Maxim Integrated MAX31722/MAX31723 SPI
temperature sensors / thermostats.
Includes:
- ACPI support;
- raw temperature readings;
- power management
Datasheet:
https://datasheets.maximintegrated.com/en/ds/MAX31722-MAX31723.pdf
Signed-off-by: Tiberiu Breana <tiberiu.a.breana@intel.com>
Create a driver to support the hardware monitoring chip present in
the Zyxel NSA320 and some of the other Zyxel NAS devices.
The driver reads fan speed and temperature from a suitably
pre-programmed MCU on the device.
Signed-off-by: Adam Baker <linux@baker-net.org.uk>
[groeck: Dropped .owner field initialization]
This patch adds support for the Murata NCP15XH103 thermistor series.
Signed-off-by: Joseph McNally <jmcna06@gmail.com>
This adds support for the Linear Technology LTC2990 I2C System Monitor.
The LTC2990 supports a combination of voltage, current and temperature
monitoring. This driver currently only supports reading two currents
by measuring two differential voltages across series resistors, in
addition to the Vcc supply voltage and internal temperature.
This is sufficient to support the Topic Miami SOM which uses this chip
to monitor the currents flowing into the FPGA and the CPU parts.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
HTU21 is now supported by IIO, and can be instantiated as hwmon driver
using the iio-hwmon bridge. An explicit hwmon driver is no longer needed.
Cc: William Markezana <william.markezana@meas-spec.com>
Cc: Ludovic Tancerel <ludovic.tancerel@maplehightech.com>
Cc: Jonathan Cameron <jic23@kernel.org>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
If CONFIG_BITREVERSE is not built-in, the sht15 driver fails to link:
drivers/built-in.o: In function `sht15_crc8':
drivers/hwmon/sht15.c:195: undefined reference to `byte_rev_table'
This adds a Kconfig 'select' statement, like all other users of
bitrev.h have it.
Fixes: 33836ee98533 ("hwmon:change sht15_reverse()")
The newly added scpi thermal support is broken when the scpi driver
is built-in but the thermal driver is a loadable module:
drivers/built-in.o: In function `scpi_hwmon_probe':
(.text+0x444d70): undefined reference to `thermal_zone_of_sensor_unregister'
(.text+0x444d94): undefined reference to `thermal_zone_of_sensor_register'
drivers/built-in.o: In function `scpi_hwmon_remove':
(text+0x444e6c): undefined reference to `thermal_zone_of_sensor_unregister'
This uses the same Kconfig trick that we have in a couple of other
drivers already to ensure we can only select the driver in valid
configurations when either THERMAL_OF is disabled, or when with a
dependency on CONFIG_THERMAL that can force SCPI to be a loadable
module in the case I was hitting.
Fixes: 68acc77a2d51 ("hwmon: Support thermal zones registration for SCP temperature sensors")
Since a0de56c81fcf ("hwmon: (ina2xx) convert driver to using regmap")
the driver requires REGMAP_I2C to build. Select it by default
in Kconfig.
Reported-by: Guo Chunrong <B40290@freescale.com>
Cc: Marc Titinger <mtitinger@baylibre.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Fixes: a0de56c81fcf ("hwmon: (ina2xx) convert driver to using regmap")
Pull ARM SoC driver updates from Olof Johansson:
"As we've enabled multiplatform kernels on ARM, and greatly done away
with the contents under arch/arm/mach-*, there's still need for
SoC-related drivers to go somewhere.
Many of them go in through other driver trees, but we still have
drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code
that might be shared between ARM and ARM64 (or just in general makes
sense to not have under the architecture directory).
This branch contains mostly such code:
- Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to
communicate with power management blocks on these SoCs for use by
clock, regulator and bus frequency drivers.
- Allwinner Reduced Serial Bus driver, again used to communicate with
PMICs.
- Drivers for ARM's SCPI (System Control Processor). Not to be
confused with PSCI (Power State Coordination Interface). SCPI is
used to communicate with the assistant embedded cores doing power
management, and we have yet to see how many of them will implement
this for their hardware vs abstracting in other ways (or not at all
like in the past).
- To make confusion between SCPI and PSCI more likely, this release
also includes an update of PSCI to interface version 1.0.
- Rockchip support for power domains.
- A driver to talk to the firmware on Raspberry Pi"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits)
soc: qcom: smd-rpm: Correct size of outgoing message
bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus
bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings
ARM: bcm2835: add mutual inclusion protection
drivers: psci: make PSCI 1.0 functions initialization version dependent
dt-bindings: Correct paths in Rockchip power domains binding document
soc: rockchip: power-domain: don't try to print the clock name in error case
soc: qcom/smem: add HWSPINLOCK dependency
clk: berlin: add cpuclk
ARM: berlin: dts: add CLKID_CPU for BG2Q
ARM: bcm2835: Add the Raspberry Pi firmware driver
soc: qcom: smem: Move RPM message ram out of smem DT node
soc: qcom: smd-rpm: Correct the active vs sleep state flagging
soc: qcom: smd: delete unneeded of_node_put
firmware: qcom-scm: build for correct architecture level
soc: qcom: smd: Correct SMEM items for upper channels
qcom-scm: add missing prototype for qcom_scm_is_available()
qcom-scm: fix endianess issue in __qcom_scm_is_call_available
soc: qcom: smd: Reject send of too big packets
soc: qcom: smd: Handle big endian CPUs
git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into next/drivers
Merge "ARM System Control and Power Interface(SCPI) support" from Sudeep Holla
It adds support for the following features provided by SCP firmware
using different subsystems in Linux:
1. SCPI mailbox protocol driver which using mailbox framework
2. Clocks provided by SCP using clock framework
3. CPU DVFS(cpufreq) using existing arm-big-little driver
4. SCPI based sensors including temperature sensors
* tag 'arm-scpi-for-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux:
hwmon: Support sensors exported via ARM SCP interface
firmware: arm_scpi: Extend to support sensors
Documentation: add DT bindings for ARM SCPI sensors
cpufreq: arm_big_little: add SCPI interface driver
clk: scpi: add support for cpufreq virtual device
clk: add support for clocks provided by SCP(System Control Processor)
firmware: add support for ARM System Control and Power Interface(SCPI) protocol
Documentation: add DT binding for ARM System Control and Power Interface(SCPI) protocol
The driver supports the Maxim MAX31790.
Signed-off-by: Il Han <corone.il.han@gmail.com>
Create a driver to add support for SoC sensors exported by the System
Control Processor (SCP) via the System Control and Power Interface
(SCPI). The supported sensor types is one of voltage, temperature,
current, and power.
The sensor labels and values provided by the SCP are exported via the
hwmon sysfs interface.
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Cc: Sudeep Holla <sudeep.holla@arm.com>
NCT6793D is register compatible with NCT6792D.
Also move nct6775_sio_names[] closer to enum kinds to simplify
adding new chips.
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
Add support for the IT8732F. This chip is pretty similar to IT8721F,
with the main difference being that the ADC LSB is 10.9 mV instead of
12 mV.
Signed-off-by: Justin Maggard <jmaggard@netgear.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
Add hwmon driver for the Microchip TC74.
The TC74 is a single-input 8-bit I2C temperature sensor,
with +-2 degrees centigrade accuracy.
Signed-off-by: Maciej Szmigiero <mail@maciej.szmigiero.name>
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is
not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer
functionality only, can still be compiled if GPIOLIB is not enabled.
Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where
appropriate.
Cc: Jean Delvare <jdelvare@suse.de>
Cc: lm-sensors@lm-sensors.org
This patch adds support for the ntc thermistor NCPXXWF104 series.
Signed-off-by: Beomho Seo <beomho.seo@samsung.com>
This patch splits CONFIG_I8K compile option to SENSORS_DELL_SMM and CONFIG_I8K.
Option SENSORS_DELL_SMM is now used to enable compilation of dell-smm-hwmon
driver and old CONFIG_I8K option to enable /proc/i8k interface in driver.
So this change allows to compile dell-smm-hwmon driver without legacy /proc/i8k
interface which is needed only for old Dell Inspirion models or for userspace
i8kutils package.
For backward compatibility when CONFIG_I8K is enabled then also SENSORS_DELL_SMM
is enabled and so driver dell-smm-hwmon (with /proc/i8k) is compiled.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
IT8620E is mostly compatible to IT7828F. Add generic support for it.
IT8620E supports up to 6 fan tachometers and 6 pwm controls.
Support for the 6th tachometer and for the additional pwm controls
are addded in separate patches.
IT8790E is a super-IO chip with three fan tachometers. It is mostly
compatible to IT8728F, but only supports three fan tachometers
instead of five.
Fix build error when CONFIG_THERMAL=m and SENSORS_GPIO_FAN=y
by preventing that combination.
Fixes these build errors:
drivers/built-in.o: In function `gpio_fan_remove':
gpio-fan.c:(.text+0x21e97e): undefined reference to `thermal_cooling_device_unregister'
drivers/built-in.o: In function `gpio_fan_probe':
gpio-fan.c:(.text+0x21efbc): undefined reference to `thermal_cooling_device_register'
Cc: Simon Guinot <sguinot@lacie.com>
Fix build errors when CONFIG_THERMAL=m and SENSORS_PWM_FAN=y
by restricting SENSORS_PWM_FAN to 'm' when THERMAL=m.
drivers/built-in.o: In function `pwm_fan_remove':
pwm-fan.c:(.text+0x22ba58): undefined reference to `thermal_cooling_device_unregister'
drivers/built-in.o: In function `pwm_fan_probe':
pwm-fan.c:(.text+0x22bebb): undefined reference to `thermal_of_cooling_device_register'
pwm-fan.c:(.text+0x22bf11): undefined reference to `thermal_cdev_update'
Cc: Kamil Debski <k.debski@samsung.com>
The NCT7904D is a hardware monitor supporting up to 20 voltage sensors,
internal temperature sensor, Intel PECI and AMD SB-TSI CPU temperature
interface, up to 12 fan tachometer inputs, up to 4 fan control channels
with SmartFan.
Signed-off-by: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru>
[Guenter Roeck: Fixed whitespace errors, dropped redundant comment]
IT8786E is mostly compatible with IT8771 / IT8772.
Parameters determined by testing various combinations.
Signed-off-by: Thomas Lorblanches <zlika_ese@hotmail.com>
[Guenter Roeck: merged from github, addressed review comments]
TS3000GB0 has a new device ID (0x2913). Since IDT's datasheets suggest
that the upper 8 bit of the device ID reflect the chip ID and the lower
8 bit reflect the version number, modify the code to accept all chips
with ID 0x29xx.
Also add support for TS3001 and TSE2004.
Some of the datasheets for older chips are no longer available from
the IDT web site, so replace explicit links in the documentation with
a generic note.
IT8781F is mostly compatible to IT8782F. Major difference is that it only
supports four instead of six UART channels, and therefore does not share
the uart6 pins.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kconfig updates from Michal Marek:
"Yann E Morin was supposed to take over kconfig maintainership, but
this hasn't happened. So I'm sending a few kconfig patches that I
collected:
- Fix for missing va_end in kconfig
- merge_config.sh displays used if given too few arguments
- s/boolean/bool/ in Kconfig files for consistency, with the plan to
only support bool in the future"
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: use va_end to match corresponding va_start
merge_config.sh: Display usage if given too few arguments
kconfig: use bool instead of boolean for type definition attributes
Simplify code and reduce code size by using regmap to access i2c registers.
Reviewed-and-Tested-by: Robert Rosengren <robert.rosengren@axis.com>
Add support for "ina231" as compatible string, and update
Documentation and Kconfig accordingly.
Tested with the Exynos5422-based odroid-xu3 board which has on-board
INA231 sensors.
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The Intel 5500, 5520 and X58 chipsets embed a digital thermal sensor.
This new driver supports it.
Note that on many boards the sensor seems to be disabled and reports
the minimum value (36.5 degrees Celsius) all the time.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Tested-by: Romain Dolbeau <romain@dolbeau.org>
Support for keyword 'boolean' will be dropped later on.
No functional change.
Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com
Signed-off-by: Christoph Jaeger <cj@linux.com>
Signed-off-by: Patrick Titiano <ptitiano@baylibre.com>
[Bartosz Golaszewski: prepared for submission, code review fixes]
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
[Guenter Roeck: Merged two patches into one]
LM95233 is similar to LM95234, but it only supports two
instead of four external temperature sensors.
LM95235 is register compatible to LM95245.
Also update link to LM95245 data sheet, and drop the link to the
datasheet from the driver source to simplify code maintenance.
NCT6792D is similar to NCT6791D. Only beep control and temperature
monitoring registers are different.
NCT7802Y is an I2C based hardware monitoring chip from Nuvoton.
