path: root/drivers/hid
2018-11-27HID: uhid: forbid UHID_CREATE under KERNEL_DS or elevated privilegesEric Biggers
commit 8c01db7619f07c85c5cd81ec5eb83608b56c88f5 upstream. When a UHID_CREATE command is written to the uhid char device, a copy_from_user() is done from a user pointer embedded in the command. When the address limit is KERNEL_DS, e.g. as is the case during sys_sendfile(), this can read from kernel memory. Alternatively, information can be leaked from a setuid binary that is tricked to write to the file descriptor. Therefore, forbid UHID_CREATE in these cases. No other commands in uhid_char_write() are affected by this bug and UHID_CREATE is marked as "obsolete", so apply the restriction to UHID_CREATE only rather than to uhid_char_write() entirely. Thanks to Dmitry Vyukov for adding uhid definitions to syzkaller and to Jann Horn for commit 9da3f2b740544 ("x86/fault: BUG() when uaccess helpers fault on kernel addresses"), allowing this bug to be found. Reported-by: syzbot+72473edc9bf4eb1c6556@syzkaller.appspotmail.com Fixes: d365c6cfd337 ("HID: uhid: add UHID_CREATE and UHID_DESTROY events") Cc: <stable@vger.kernel.org> # v3.6+ Cc: Jann Horn <jannh@google.com> Cc: Andy Lutomirski <luto@kernel.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Jann Horn <jannh@google.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-21HID: hiddev: fix potential Spectre v1Breno Leitao
commit f11274396a538b31bc010f782e05c2ce3f804c13 upstream. uref->usage_index can be indirectly controlled by userspace, hence leading to a potential exploitation of the Spectre variant 1 vulnerability. This field is used as an array index by the hiddev_ioctl_usage() function, when 'cmd' is either HIDIOCGCOLLECTIONINDEX, HIDIOCGUSAGES or HIDIOCSUSAGES. For cmd == HIDIOCGCOLLECTIONINDEX case, uref->usage_index is compared to field->maxusage and then used as an index to dereference field->usage array. The same thing happens to the cmd == HIDIOC{G,S}USAGES cases, where uref->usage_index is checked against an array maximum value and then it is used as an index in an array. This is a summary of the HIDIOCGCOLLECTIONINDEX case, which matches the traditional Spectre V1 first load: copy_from_user(uref, user_arg, sizeof(*uref)) if (uref->usage_index >= field->maxusage) goto inval; i = field->usage[uref->usage_index].collection_index; return i; This patch fixes this by sanitizing field uref->usage_index before using it to index field->usage (HIDIOCGCOLLECTIONINDEX) or field->value in HIDIOC{G,S}USAGES arrays, thus, avoiding speculation in the first load. Cc: <stable@vger.kernel.org> Signed-off-by: Breno Leitao <leitao@debian.org> v2: Contemplate cmd == HIDIOC{G,S}USAGES case Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-10HID: hid-ntrig: add error handling for sysfs_create_groupZhouyang Jia
[ Upstream commit 44d4d51de9a3534a2b63d69efda02a10e66541e4 ] When sysfs_create_group fails, the lack of error-handling code may cause unexpected results. This patch adds error-handling code after calling sysfs_create_group. Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-29HID: sony: Support DS4 dongleRoderick Colenbrander
commit de66a1a04c25f2560a8dca7a95e2a150b0d5e17e upstream. Add support for USB based DS4 dongle device, which allows connecting a DS4 through Bluetooth, but hides Bluetooth from the host system. Signed-off-by: Roderick Colenbrander <roderick.colenbrander@sony.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-29HID: sony: Update device idsRoderick Colenbrander
commit cf1015d65d7c8a5504a4c03afb60fb86bff0f032 upstream. Support additional DS4 model. Signed-off-by: Roderick Colenbrander <roderick.colenbrander@sony.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-24HID: wacom: Correct touch maximum XY of 2nd-gen IntuosJason Gerecke
[ Upstream commit 3b8d573586d1b9dee33edf6cb6f2ca05f4bca568 ] The touch sensors on the 2nd-gen Intuos tablets don't use a 4096x4096 sensor like other similar tablets (3rd-gen Bamboo, Intuos5, etc.). The incorrect maximum XY values don't normally affect userspace since touch input from these devices is typically relative rather than absolute. It does, however, cause problems when absolute distances need to be measured, e.g. for gesture recognition. Since the resolution of the touch sensor on these devices is 10 units / mm (versus 100 for the pen sensor), the proper maximum values can be calculated by simply dividing by 10. Fixes: b5fd2a3e92 ("Input: wacom - add support for three new Intuos devices") Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-06HID: i2c-hid: check if device is there before really probingDmitry Torokhov
[ Upstream commit b3a81b6c4fc6730ac49e20d789a93c0faabafc98 ] On many Chromebooks touch devices are multi-sourced; the components are electrically compatible and one can be freely swapped for another without changing the OS image or firmware. To avoid bunch of scary messages when device is not actually present in the system let's try testing basic communication with it and if there is no response terminate probe early with -ENXIO. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-06HID: hid-plantronics: Re-resend Update to map button for PTT productsTerry Junge
[ Upstream commit 37e376df5f4993677c33968a0c19b0c5acbf1108 ] Add a mapping for Push-To-Talk joystick trigger button. Tested on ChromeBox/ChromeBook with various Plantronics devices. Signed-off-by: Terry Junge <terry.junge@plantronics.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-17HID: usbhid: add quirk for innomedia INNEX GENESIS/ATARI adapterTomasz Kramkowski
commit 9547837bdccb4af127528b36a73377150658b4ac upstream. The (1292:4745) Innomedia INNEX GENESIS/ATARI adapter needs HID_QUIRK_MULTI_INPUT to split the device up into two controllers instead of inputs from both being merged into one. Signed-off-by: Tomasz Kramkowski <tk@the-tk.com> Acked-By: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11HID: debug: check length before copy_to_user()Daniel Rosenberg
commit 717adfdaf14704fd3ec7fa2c04520c0723247eac upstream. If our length is greater than the size of the buffer, we overflow the buffer Cc: stable@vger.kernel.org Signed-off-by: Daniel Rosenberg <drosen@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11HID: hiddev: fix potential Spectre v1Gustavo A. R. Silva
commit 4f65245f2d178b9cba48350620d76faa4a098841 upstream. uref->field_index, uref->usage_index, finfo.field_index and cinfo.index can be indirectly controlled by user-space, hence leading to a potential exploitation of the Spectre variant 1 vulnerability. This issue was detected with the help of Smatch: drivers/hid/usbhid/hiddev.c:473 hiddev_ioctl_usage() warn: potential spectre issue 'report->field' (local cap) drivers/hid/usbhid/hiddev.c:477 hiddev_ioctl_usage() warn: potential spectre issue 'field->usage' (local cap) drivers/hid/usbhid/hiddev.c:757 hiddev_ioctl() warn: potential spectre issue 'report->field' (local cap) drivers/hid/usbhid/hiddev.c:801 hiddev_ioctl() warn: potential spectre issue 'hid->collection' (local cap) Fix this by sanitizing such structure fields before using them to index report->field, field->usage and hid->collection Notice that given that speculation windows are large, the policy is to kill the speculation on the first load and not worry if it can be completed with a dependent load/store [1]. [1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2 Cc: stable@vger.kernel.org Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11HID: i2c-hid: Fix "incomplete report" noiseJason Andryuk
commit ef6eaf27274c0351f7059163918f3795da13199c upstream. Commit ac75a041048b ("HID: i2c-hid: fix size check and type usage") started writing messages when the ret_size is <= 2 from i2c_master_recv. However, my device i2c-DLL07D1 returns 2 for a short period of time (~0.5s) after I stop moving the pointing stick or touchpad. It varies, but you get ~50 messages each time which spams the log hard. [ 95.925055] i2c_hid i2c-DLL07D1:01: i2c_hid_get_input: incomplete report (83/2) This has also been observed with a i2c-ALP0017. [ 1781.266353] i2c_hid i2c-ALP0017:00: i2c_hid_get_input: incomplete report (30/2) Only print the message when ret_size is totally invalid and less than 2 to cut down on the log spam. Fixes: ac75a041048b ("HID: i2c-hid: fix size check and type usage") Reported-by: John Smith <john-s-84@gmx.net> Cc: stable@vger.kernel.org Signed-off-by: Jason Andryuk <jandryuk@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30HID: roccat: prevent an out of bounds read in kovaplus_profile_activated()Dan Carpenter
[ Upstream commit 7ad81482cad67cbe1ec808490d1ddfc420c42008 ] We get the "new_profile_index" value from the mouse device when we're handling raw events. Smatch taints it as untrusted data and complains that we need a bounds check. This seems like a reasonable warning otherwise there is a small read beyond the end of the array. Fixes: 0e70f97f257e ("HID: roccat: Add support for Kova[+] mouse") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Silvan Jegen <s.jegen@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24HID: hidraw: Fix crash on HIDIOCGFEATURE with a destroyed deviceRodrigo Rivas Costa
commit a955358d54695e4ad9f7d6489a7ac4d69a8fc711 upstream. Doing `ioctl(HIDIOCGFEATURE)` in a tight loop on a hidraw device and then disconnecting the device, or unloading the driver, can cause a NULL pointer dereference. When a hidraw device is destroyed it sets 0 to `dev->exist`. Most functions check 'dev->exist' before doing its work, but `hidraw_get_report()` was missing that check. Cc: stable@vger.kernel.org Signed-off-by: Rodrigo Rivas Costa <rodrigorivascosta@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24HID: core: Fix size as type u32Aaron Ma
commit 6de0b13cc0b4ba10e98a9263d7a83b940720b77a upstream. When size is negative, calling memset will make segment fault. Declare the size as type u32 to keep memset safe. size in struct hid_report is unsigned, fix return type of hid_report_len to u32. Cc: stable@vger.kernel.org Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24HID: Fix hid_report_len usageAaron Ma
commit 3064a03b94e60388f0955fcc29f3e8a978d28f75 upstream. Follow the change of return type u32 of hid_report_len, fix all the types of variables those get the return value of hid_report_len to u32, and all other code already uses u32. Cc: stable@vger.kernel.org Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24HID: i2c-hid: fix size check and type usageAaron Ma
commit ac75a041048b8c1f7418e27621ca5efda8571043 upstream. When convert char array with signed int, if the inbuf[x] is negative then upper bits will be set to 1. Fix this by using u8 instead of char. ret_size has to be at least 3, hid_input_report use it after minus 2 bytes. Cc: stable@vger.kernel.org Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22HID: elo: clear BTN_LEFT mappingJiri Kosina
[ Upstream commit 9abd04af951e5734c9d5cfee9b49790844b734cf ] ELO devices have one Button usage in GenDesk field, which makes hid-input map it to BTN_LEFT; that confuses userspace, which then considers the device to be a mouse/touchpad instead of touchscreen. Fix that by unmapping BTN_LEFT and keeping only BTN_TOUCH in place. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22HID: clamp input to logical range if no null stateTomasz Kramkowski
[ Upstream commit c3883fe06488a483658ba5d849b70e49bee15e7c ] This patch fixes an issue in drivers/hid/hid-input.c where values outside of the logical range are not clamped when "null state" bit of the input control is not set. This was discussed on the lists [1] and this change stems from the fact due to the ambiguity of the HID specification it might be appropriate to follow Microsoft's own interpretation of the specification. As noted in Microsoft's documentation [2] in the section titled "Required HID usages for digitizers" it is noted that values reported outside the logical range "will be considered as invalid data and the value will be changed to the nearest boundary value (logical min/max)." This patch fixes an issue where the (1292:4745) Innomedia INNEX GENESIS/ATARI reports out of range values for its X and Y axis of the DPad which, due to the null state bit being unset, are forwarded to userspace as is. Now these values will get clamped to the logical range before being forwarded to userspace. This device was also used to test this patch. This patch expands on commit 3f3752705dbd ("HID: reject input outside logical range only if null state is set"). [1]: http://lkml.kernel.org/r/20170307131036.GA853@gaia.local [2]: https://msdn.microsoft.com/en-us/library/windows/hardware/dn672278(v=vs.85).asp Signed-off-by: Tomasz Kramkowski <tk@the-tk.com> Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22HID: reject input outside logical range only if null state is setValtteri Heikkilä
[ Upstream commit 3f3752705dbd50b66b66ad7b4d54fe33d2f746ed ] This patch fixes an issue in drivers/hid/hid-input.c where USB HID control null state flag is not checked upon rejecting inputs outside logical minimum-maximum range. The check should be made according to USB HID specification 1.11, section 6.2.2.5, p.31. The fix will resolve issues with some game controllers, such as: https://bugzilla.kernel.org/show_bug.cgi?id=68621 [tk@the-tk.com: shortened and fixed spelling in commit message] Signed-off-by: Valtteri Heikkilä <rnd@nic.fi> Signed-off-by: Tomasz Kramkowski <tk@the-tk.com> Acked-By: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28usb: ldusb: add PIDs for new CASSY devices supported by this driverKarsten Koop
commit 52ad2bd8918158266fc88a05f95429b56b6a33c5 upstream. This patch adds support for new CASSY devices to the ldusb driver. The PIDs are also added to the ignore list in hid-quirks. Signed-off-by: Karsten Koop <kkoop@ld-didactic.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16HID: quirks: Fix keyboard + touchpad on Toshiba Click Mini not workingHans de Goede
commit edfc3722cfef4217c7fe92b272cbe0288ba1ff57 upstream. The Toshiba Click Mini uses an i2c attached keyboard/touchpad combo (single i2c_hid device for both) which has a vid:pid of 04F3:0401, which is also used by a bunch of Elan touchpads which are handled by the drivers/input/mouse/elan_i2c driver, but that driver deals with pure touchpads and does not work for a combo device such as the one on the Toshiba Click Mini. The combo on the Mini has an ACPI id of ELAN0800, which is not claimed by the elan_i2c driver, so check for that and if it is found do not ignore the device. This fixes the keyboard/touchpad combo on the Mini not working (although with the touchpad in mouse emulation mode). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25HID: xinmo: fix for out of range for THT 2P arcade controller.Peter Stein
[ Upstream commit 9257821c5a1dc57ef3a37f7cbcebaf548395c964 ] There is a new clone of the XIN MO arcade controller which has same issue with out of range like the original. This fix will solve the issue where 2 directions on the joystick are not recognized by the new THT 2P arcade controller with device ID 0x75e1. In details the new device ID is added the hid-id list and the hid-xinmo source code. Signed-off-by: Peter Stein <peter@stuntstein.dk> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-16HID: chicony: Add support for another ASUS Zen AiO keyboardDaniel Drake
[ Upstream commit f2f10b7e722a75c6d75a7f7cd06b0eee3ae20f7c ] Add support for media keys on the keyboard that comes with the Asus V221ID and ZN241IC All In One computers. The keys to support here are WLAN, BRIGHTNESSDOWN and BRIGHTNESSUP. This device is not visibly branded as Chicony, and the USB Vendor ID suggests that it is a JESS device. However this seems like the right place to put it: the usage codes are identical to the currently supported devices, and this driver already supports the ASUS AIO keyboard AK1D. Signed-off-by: Daniel Drake <drake@endlessm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18HID: usbhid: fix out-of-bounds bugJaejoong Kim
commit f043bfc98c193c284e2cd768fefabe18ac2fed9b upstream. The hid descriptor identifies the length and type of subordinate descriptors for a device. If the received hid descriptor is smaller than the size of the struct hid_descriptor, it is possible to cause out-of-bounds. In addition, if bNumDescriptors of the hid descriptor have an incorrect value, this can also cause out-of-bounds while approaching hdesc->desc[n]. So check the size of hid descriptor and bNumDescriptors. BUG: KASAN: slab-out-of-bounds in usbhid_parse+0x9b1/0xa20 Read of size 1 at addr ffff88006c5f8edf by task kworker/1:2/1261 CPU: 1 PID: 1261 Comm: kworker/1:2 Not tainted 4.14.0-rc1-42251-gebb2c2437d80 #169 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Workqueue: usb_hub_wq hub_event Call Trace: __dump_stack lib/dump_stack.c:16 dump_stack+0x292/0x395 lib/dump_stack.c:52 print_address_description+0x78/0x280 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 kasan_report+0x22f/0x340 mm/kasan/report.c:409 __asan_report_load1_noabort+0x19/0x20 mm/kasan/report.c:427 usbhid_parse+0x9b1/0xa20 drivers/hid/usbhid/hid-core.c:1004 hid_add_device+0x16b/0xb30 drivers/hid/hid-core.c:2944 usbhid_probe+0xc28/0x1100 drivers/hid/usbhid/hid-core.c:1369 usb_probe_interface+0x35d/0x8e0 drivers/usb/core/driver.c:361 really_probe drivers/base/dd.c:413 driver_probe_device+0x610/0xa00 drivers/base/dd.c:557 __device_attach_driver+0x230/0x290 drivers/base/dd.c:653 bus_for_each_drv+0x161/0x210 drivers/base/bus.c:463 __device_attach+0x26e/0x3d0 drivers/base/dd.c:710 device_initial_probe+0x1f/0x30 drivers/base/dd.c:757 bus_probe_device+0x1eb/0x290 drivers/base/bus.c:523 device_add+0xd0b/0x1660 drivers/base/core.c:1835 usb_set_configuration+0x104e/0x1870 drivers/usb/core/message.c:1932 generic_probe+0x73/0xe0 drivers/usb/core/generic.c:174 usb_probe_device+0xaf/0xe0 drivers/usb/core/driver.c:266 really_probe drivers/base/dd.c:413 driver_probe_device+0x610/0xa00 drivers/base/dd.c:557 __device_attach_driver+0x230/0x290 drivers/base/dd.c:653 bus_for_each_drv+0x161/0x210 drivers/base/bus.c:463 __device_attach+0x26e/0x3d0 drivers/base/dd.c:710 device_initial_probe+0x1f/0x30 drivers/base/dd.c:757 bus_probe_device+0x1eb/0x290 drivers/base/bus.c:523 device_add+0xd0b/0x1660 drivers/base/core.c:1835 usb_new_device+0x7b8/0x1020 drivers/usb/core/hub.c:2457 hub_port_connect drivers/usb/core/hub.c:4903 hub_port_connect_change drivers/usb/core/hub.c:5009 port_event drivers/usb/core/hub.c:5115 hub_event+0x194d/0x3740 drivers/usb/core/hub.c:5195 process_one_work+0xc7f/0x1db0 kernel/workqueue.c:2119 worker_thread+0x221/0x1850 kernel/workqueue.c:2253 kthread+0x3a1/0x470 kernel/kthread.c:231 ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:431 Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Jaejoong Kim <climbbb.kim@gmail.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12HID: i2c-hid: allocate hid buffers for real worst caseAdrian Salido
commit 8320caeeffdefec3b58b9d4a7ed8e1079492fe7b upstream. The buffer allocation is not currently accounting for an extra byte for the report id. This can cause an out of bounds access in function i2c_hid_set_or_send_report() with reportID > 15. Signed-off-by: Adrian Salido <salidoa@google.com> Reviewed-by: Benson Leung <bleung@chromium.org> Signed-off-by: Guenter Roeck <groeck@chromium.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06HID: ignore Petzl USB headlampJiri Kosina
[ Upstream commit 08f9572671c8047e7234cbf150869aa3c3d59a97 ] This headlamp contains a dummy HID descriptor which pretends to be a mouse-like device, but can't be used as a mouse at all. Reported-by: Lukas Ocilka <lukas.ocilka@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05HID: i2c-hid: Add sleep between POWER ON and RESETBrendan McGrath
[ Upstream commit a89af4abdf9b353cdd6f61afc0eaaac403304873 ] Support for the Asus Touchpad was recently added. It turns out this device can fail initialisation (and become unusable) when the RESET command is sent too soon after the POWER ON command. Unfortunately the i2c-hid specification does not specify the need for a delay between these two commands. But it was discovered the Windows driver has a 1ms delay. As a result, this patch modifies the i2c-hid module to add a sleep inbetween the POWER ON and RESET commands which lasts between 1ms and 5ms. See https://github.com/vlasenko/hid-asus-dkms/issues/24 for further details. Signed-off-by: Brendan McGrath <redmcg@redmandi.dyndns.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29HID: Add quirk for Dell PIXART OEM mouseSebastian Parschauer
commit 3db28271f0feae129262d30e41384a7c4c767987 upstream. This mouse is also known under other IDs. It needs the quirk ALWAYS_POLL or will disconnect in runlevel 1 or 3. Signed-off-by: Sebastian Parschauer <sparschauer@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07HID: wacom: Have wacom_tpc_irq guard against possible NULL dereferenceJason Gerecke
commit 2ac97f0f6654da14312d125005c77a6010e0ea38 upstream. The following Smatch complaint was generated in response to commit 2a6cdbd ("HID: wacom: Introduce new 'touch_input' device"): drivers/hid/wacom_wac.c:1586 wacom_tpc_irq() error: we previously assumed 'wacom->touch_input' could be null (see line 1577) The 'touch_input' and 'pen_input' variables point to the 'struct input_dev' used for relaying touch and pen events to userspace, respectively. If a device does not have a touch interface or pen interface, the associated input variable is NULL. The 'wacom_tpc_irq()' function is responsible for forwarding input reports to a more-specific IRQ handler function. An unknown report could theoretically be mistaken as e.g. a touch report on a device which does not have a touch interface. This can be prevented by only calling the pen/touch functions are called when the pen/touch pointers are valid. Fixes: 2a6cdbd ("HID: wacom: Introduce new 'touch_input' device") Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com> Reviewed-by: Ping Cheng <ping.cheng@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09HID: wacom: Fix poor prox handling in 'wacom_pl_irq'Jason Gerecke
commit 282e4637bc1c0b338708bcebd09d31c69abec070 upstream. Commit 025bcc1 performed cleanup work on the 'wacom_pl_irq' function, making it follow the standards used in the rest of the codebase. The change unintiontionally allowed the function to send input events from reports that are not marked as being in prox. This can cause problems as the report values for X, Y, etc. are not guaranteed to be correct. In particular, occasionally the tablet will send a report with these values set to zero. If such a report is received it can caus an unexpected jump in the XY position. This patch surrounds more of the processing code with a proximity check, preventing these zeroed reports from overwriting the current state. To be safe, only the tool type and ABS_MISC events should be reported when the pen is marked as being out of prox. Fixes: 025bcc1540 ("HID: wacom: Simplify 'wacom_pl_irq'") Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com> Reviewed-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26HID: corsair: fix control-transfer error handlingJohan Hovold
commit 7a546af50eb78ab99840903083231eb635c8a566 upstream. Make sure to check for short control transfers in order to avoid parsing uninitialised buffer data and leaking it to user space. Note that the backlight and macro-mode buffer constraints are kept as loose as possible in order to avoid any regressions should the current buffer sizes be larger than necessary. Fixes: 6f78193ee9ea ("HID: corsair: Add Corsair Vengeance K90 driver") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26HID: corsair: fix DMA buffers on stackJohan Hovold
commit 6d104af38b570d37aa32a5803b04c354f8ed513d upstream. Not all platforms support DMA to the stack, and specifically since v4.9 this is no longer supported on x86 with VMAP_STACK either. Note that the macro-mode buffer was larger than necessary. Fixes: 6f78193ee9ea ("HID: corsair: Add Corsair Vengeance K90 driver") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15HID: hid-cypress: validate length of reportGreg Kroah-Hartman
commit 1ebb71143758f45dc0fa76e2f48429e13b16d110 upstream. Make sure we have enough of a report structure to validate before looking at it. Reported-by: Benoit Camredon <benoit.camredon@airbus.com> Tested-by: Benoit Camredon <benoit.camredon@airbus.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-11-10HID: usbhid: add ATEN CS962 to list of quirky devicesOliver Neukum
commit cf0ea4da4c7df11f7a508b2f37518e0f117f3791 upstream. Like many similar devices it needs a quirk to work. Issuing the request gets the device into an irrecoverable state. Signed-off-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15HID: core: prevent out-of-bound readingsBenjamin Tissoires
[ Upstream commit 50220dead1650609206efe91f0cc116132d59b3f ] Plugging a Logitech DJ receiver with KASAN activated raises a bunch of out-of-bound readings. The fields are allocated up to MAX_USAGE, meaning that potentially, we do not have enough fields to fit the incoming values. Add checks and silence KASAN. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20HID: uhid: fix timeout when probe races with IORoderick Colenbrander
commit 67f8ecc550b5bda03335f845dc869b8501d25fd0 upstream. Many devices use userspace bluetooth stacks like BlueZ or Bluedroid in combination with uhid. If any of these stacks is used with a HID device for which the driver performs a HID request as part .probe (or technically another HID operation), this results in a deadlock situation. The deadlock results in a 5 second timeout for I/O operations in HID drivers, so isn't fatal, but none of the I/O operations have a chance of succeeding. The root cause for the problem is that uhid only allows for one request to be processed at a time per uhid instance and locks out other operations. This means that if a user space is creating a new HID device through 'UHID_CREATE', which ultimately triggers '.probe' through the HID layer. Then any HID request e.g. a read for calibration data would trigger a HID operation on uhid again, but it won't go out to userspace, because it is still stuck in UHID_CREATE. In addition bluetooth stacks are typically single threaded, so they wouldn't be able to handle any requests while waiting on uhid. Lucikly the UHID spec is somewhat flexible and allows for fixing the issue, without breaking user space. The idea which the patch implements as discussed with David Herrmann is to decouple adding of a hid device (which triggers .probe) from UHID_CREATE. The work will kick off roughly once UHID_CREATE completed (or else will wait a tiny bit of time in .probe for a lock). A HID driver has to call HID to call 'hid_hw_start()' as part of .probe once it is ready for I/O, which triggers UHID_START to user space. Any HID operations should function now within .probe and won't deadlock because userspace is stuck on UHID_CREATE. We verified this patch on Bluedroid with Android 6.0 and on desktop Linux with BlueZ stacks. Prior to the patch they had the deadlock issue. [jkosina@suse.cz: reword subject] Signed-off-by: Roderick Colenbrander <roderick.colenbrander@sony.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16HID: sony: do not bail out when the sixaxis refuses the output reportBenjamin Tissoires
commit 19f4c2ba869517048add62c202f9645b6adf5dfb upstream. When setting the operational mode, some third party (Speedlink Strike-FX) gamepads refuse the output report. Failing here means we refuse to initialize the gamepad while this should be harmless. The weird part is that the initial commit that added this: a7de9b8 ("HID: sony: Enable Gasia third-party PS3 controllers") mentions this very same controller as one requiring this output report. Anyway, it's broken for one user at least, so let's change it. We will report an error, but at least the controller should work. And no, these devices present themselves as legacy Sony controllers (VID:PID of 054C:0268, as in the official ones) so there are no ways of discriminating them from the official ones. https://bugzilla.redhat.com/show_bug.cgi?id=1255325 Reported-and-tested-by: Max Fedotov <thesourcehim@gmail.com> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Laura Abbott <labbott@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27HID: multitouch: enable palm rejection for Windows Precision TouchpadAllen Hung
commit 6dd2e27a103d716921cc4a1a96a9adc0a8e3ab57 upstream. The usage Confidence is mandary to Windows Precision Touchpad devices. If it is examined in input_mapping on a WIndows Precision Touchpad, a new add quirk MT_QUIRK_CONFIDENCE desgned for such devices will be applied to the device. A touch with the confidence bit is not set is determined as invalid. Tested on Dell XPS13 9343 Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Tested-by: Andy Lutomirski <luto@kernel.org> # XPS 13 9350, BIOS 1.4.3 Signed-off-by: Allen Hung <allen_hung@dell.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27HID: hiddev: validate num_values for HIDIOCGUSAGES, HIDIOCSUSAGES commandsScott Bauer
commit 93a2001bdfd5376c3dc2158653034c20392d15c5 upstream. This patch validates the num_values parameter from userland during the HIDIOCGUSAGES and HIDIOCSUSAGES commands. Previously, if the report id was set to HID_REPORT_ID_UNKNOWN, we would fail to validate the num_values parameter leading to a heap overflow. Signed-off-by: Scott Bauer <sbauer@plzdonthack.me> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27HID: elo: kill not flush the workOliver Neukum
commit ed596a4a88bd161f868ccba078557ee7ede8a6ef upstream. Flushing a work that reschedules itself is not a sensible operation. It needs to be killed. Failure to do so leads to a kernel panic in the timer code. Signed-off-by: Oliver Neukum <ONeukum@suse.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11HID: Fix boot delay for Creative SB Omni Surround 5.1 with quirkNazar Mokrynskyi
commit 567a44ecb44eb2584ddb93e962cfb133ce77e0bb upstream. Needed for v2 of the device firmware, otherwise kernel will stuck for few seconds and throw "usb_submit_urb(ctrl) failed: -1" early on system boot. Signed-off-by: Nazar Mokrynskyi <nazar@mokrynskyi.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-11HID: wacom: Add support for DTK-1651Ping Cheng
commit e1123fe975852cc0970b4e53ea65ca917e54c923 upstream. DTK-1651 is a display pen-only tablet Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20HID: usbhid: fix inconsistent reset/resume/reset-resume behaviorAlan Stern
commit 972e6a993f278b416a8ee3ec65475724fc36feb2 upstream. The usbhid driver has inconsistently duplicated code in its post-reset, resume, and reset-resume pathways. reset-resume doesn't check HID_STARTED before trying to restart the I/O queues. resume fails to clear the HID_SUSPENDED flag if HID_STARTED isn't set. resume calls usbhid_restart_queues() with usbhid->lock held and the others call it without holding the lock. The first item in particular causes a problem following a reset-resume if the driver hasn't started up its I/O. URB submission fails because usbhid->urbin is NULL, and this triggers an unending reset-retry loop. This patch fixes the problem by creating a new subroutine, hid_restart_io(), to carry out all the common activities. It also adds some checks that were missing in the original code: After a reset, there's no need to clear any halted endpoints. After a resume, if a reset is pending there's no need to restart any I/O until the reset is finished. After a resume, if the interrupt-IN endpoint is halted there's no need to submit the input URB until the halt has been cleared. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Daniel Fraga <fragabr@gmail.com> Tested-by: Daniel Fraga <fragabr@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20HID: wacom: fix Bamboo ONE oopsBenjamin Tissoires
commit 580549ef6b3e3fb3b958de490ca99f43a089a2cf upstream. Looks like recent changes in the Wacom driver made the Bamboo ONE crashes. The tablet behaves as if it was a regular Bamboo device with pen, touch and pad, but there is no physical pad connected to it. The weird part is that the pad is still sending events and given that there is no input node connected to it, we get anull pointer exception. Link: https://bugzilla.redhat.com/show_bug.cgi?id=1317116 Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Acked-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12HID: fix hid_ignore_special_drivers module parameterBenjamin Tissoires
commit 4392bf333388cabdad5afe5b1500002d7b9c318e upstream. hid_ignore_special_drivers works fine until hid_scan_report autodetects and reassign devices (for hid-multitouch, hid-microsoft and hid-rmi). Simplify the handling of the parameter: if it is there, use hid-generic, no matter what, and if not, scan the device or rely on the hid_have_special_driver table. This was detected while trying to disable hid-multitouch on a Surface Pro cover which prevented to use the keyboard. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12HID: multitouch: force retrieving of Win8 signature blobBenjamin Tissoires
commit 45c5c6828214605eaefa6755c47bd1a2c7eb203e upstream. The Synaptics 0x11e5 over I2C found in the Asus T100-CHI requires to fetch the signature blob to actually start sending events. With this patch, we should be close enough to the Windows driver which checks the content of the blob at plugin to validate or not the touchscreen. Link: https://bugzilla.kernel.org/show_bug.cgi?id=113481 Fixes: 6d4f5440 ("HID: multitouch: Fetch feature reports on demand for Win8 devices") Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12HID: i2c-hid: fix OOB write in i2c_hid_set_or_send_report()Dmitry Torokhov
commit 3b654288b196ceaa156029d9457ccbded0489b98 upstream. Even though hid_hw_* checks that passed in data_len is less than HID_MAX_BUFFER_SIZE it is not enough, as i2c-hid does not necessarily allocate buffers of HID_MAX_BUFFER_SIZE but rather checks all device reports and select largest size. In-kernel users normally just send as much data as report needs, so there is no problem, but hidraw users can do whatever they please: BUG: KASAN: slab-out-of-bounds in memcpy+0x34/0x54 at addr ffffffc07135ea80 Write of size 4101 by task syz-executor/8747 CPU: 2 PID: 8747 Comm: syz-executor Tainted: G BU 3.18.0 #37 Hardware name: Google Tegra210 Smaug Rev 1,3+ (DT) Call trace: [<ffffffc00020ebcc>] dump_backtrace+0x0/0x258 arch/arm64/kernel/traps.c:83 [<ffffffc00020ee40>] show_stack+0x1c/0x2c arch/arm64/kernel/traps.c:172 [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffc001958114>] dump_stack+0x90/0x140 lib/dump_stack.c:50 [< inline >] print_error_description mm/kasan/report.c:97 [< inline >] kasan_report_error mm/kasan/report.c:278 [<ffffffc0004597dc>] kasan_report+0x268/0x530 mm/kasan/report.c:305 [<ffffffc0004592e8>] __asan_storeN+0x20/0x150 mm/kasan/kasan.c:718 [<ffffffc0004594e0>] memcpy+0x30/0x54 mm/kasan/kasan.c:299 [<ffffffc001306354>] __i2c_hid_command+0x2b0/0x7b4 drivers/hid/i2c-hid/i2c-hid.c:178 [< inline >] i2c_hid_set_or_send_report drivers/hid/i2c-hid/i2c-hid.c:321 [<ffffffc0013079a0>] i2c_hid_output_raw_report.isra.2+0x3d4/0x4b8 drivers/hid/i2c-hid/i2c-hid.c:589 [<ffffffc001307ad8>] i2c_hid_output_report+0x54/0x68 drivers/hid/i2c-hid/i2c-hid.c:602 [< inline >] hid_hw_output_report include/linux/hid.h:1039 [<ffffffc0012cc7a0>] hidraw_send_report+0x400/0x414 drivers/hid/hidraw.c:154 [<ffffffc0012cc7f4>] hidraw_write+0x40/0x64 drivers/hid/hidraw.c:177 [<ffffffc0004681dc>] vfs_write+0x1d4/0x3cc fs/read_write.c:534 [< inline >] SYSC_pwrite64 fs/read_write.c:627 [<ffffffc000468984>] SyS_pwrite64+0xec/0x144 fs/read_write.c:614 Object at ffffffc07135ea80, in cache kmalloc-512 Object allocated with size 268 bytes. Let's check data length against the buffer size before attempting to copy data over. Reported-by: Alexander Potapenko <glider@google.com> Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12HID: logitech: fix Dual Action gamepad supportGrazvydas Ignotas
commit 5d74325a2201376a95520a4a38a1ce2c65761c49 upstream. The patch that added Logitech Dual Action gamepad support forgot to update the special driver list for the device. This caused the logitech driver not to probe unless kernel module load order was favorable. Update the special driver list to fix it. Thanks to Simon Wood for the idea. Cc: Vitaly Katraew <zawullon@gmail.com> Fixes: 56d0c8b7c8fb ("HID: add support for Logitech Dual Action gamepads") Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17HID: multitouch: fix input mode switching on some Elan panelsBenjamin Tissoires
commit 73e7d63efb4d774883a338997943bfa59e127085 upstream. as reported by https://bugzilla.kernel.org/show_bug.cgi?id=108481 This bug reports mentions 6d4f5440 ("HID: multitouch: Fetch feature reports on demand for Win8 devices") as the origin of the problem but this commit actually masked 2 firmware bugs that are annihilating each other: The report descriptor declares two features in reports 3 and 5: 0x05, 0x0d, // Usage Page (Digitizers) 318 0x09, 0x0e, // Usage (Device Configuration) 320 0xa1, 0x01, // Collection (Application) 322 0x85, 0x03, // Report ID (3) 324 0x09, 0x22, // Usage (Finger) 326 0xa1, 0x00, // Collection (Physical) 328 0x09, 0x52, // Usage (Inputmode) 330 0x15, 0x00, // Logical Minimum (0) 332 0x25, 0x0a, // Logical Maximum (10) 334 0x75, 0x08, // Report Size (8) 336 0x95, 0x02, // Report Count (2) 338 0xb1, 0x02, // Feature (Data,Var,Abs) 340 0xc0, // End Collection 342 0x09, 0x22, // Usage (Finger) 343 0xa1, 0x00, // Collection (Physical) 345 0x85, 0x05, // Report ID (5) 347 0x09, 0x57, // Usage (Surface Switch) 349 0x09, 0x58, // Usage (Button Switch) 351 0x15, 0x00, // Logical Minimum (0) 353 0x75, 0x01, // Report Size (1) 355 0x95, 0x02, // Report Count (2) 357 0x25, 0x03, // Logical Maximum (3) 359 0xb1, 0x02, // Feature (Data,Var,Abs) 361 0x95, 0x0e, // Report Count (14) 363 0xb1, 0x03, // Feature (Cnst,Var,Abs) 365 0xc0, // End Collection 367 The report ID 3 presents 2 input mode features, while only the first one is handled by the device. Given that we did not checked if one was previously assigned, we were dealing with the ignored featured and we should never have been able to switch this panel into the multitouch mode. However, the firmware presents an other bugs which allowed 6d4f5440 to counteract the faulty report descriptor. When we request the values of the feature 5, the firmware answers "03 03 00". The fields are correct but the report id is wrong. Before 6d4f5440, we retrieved all the features and injected them in the system. So when we called report 5, we injected in the system the report 3 with the values "03 00". Setting the second input mode to 03 in this report changed it to "03 03" and the touchpad switched to the mt mode. We could have set anything in the second field because the actual value (the first 03 in this report) was given by the query of report ID 5. To sum up: 2 bugs in the firmware were hiding that we were accessing the wrong feature. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
