path: root/drivers/hid
2013-03-08Merge branch 'for-3.9/upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fix from Jiri Kosina: "Bugfix for a long-standing bug in logitech-dj driver causing all sorts of random initialization problems, finally debugged by Benjamin Tissoires with help of Bob Bowles." * 'for-3.9/upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: logitech-dj: do not directly call hid_output_raw_report() during probe
2013-03-07HID: logitech-dj: do not directly call hid_output_raw_report() during probeBenjamin Tissoires
hid_output_raw_report() makes a direct call to usb_control_msg(). However, some USB3 boards have shown that the usb device is not ready during the .probe(). This blocks the entire usb device, and the paired mice, keyboards are not functional. The dmesg output is the following: [ 11.912287] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-2/input2 [ 11.912537] logitech-djreceiver 0003:046D:C52B.0003: logi_dj_probe:logi_dj_recv_query_paired_devices error:-32 [ 11.912636] logitech-djreceiver: probe of 0003:046D:C52B.0003 failed with error -32 Relying on the scheduled call to usbhid_submit_report() fixes the problem. related bugs: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1072082 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1039143 https://bugzilla.redhat.com/show_bug.cgi?id=840391 https://bugzilla.kernel.org/show_bug.cgi?id=49781 Reported-and-tested-by: Bob Bowles <bobjohnbowles@gmail.com> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - Some cleanups at V4L2 documentation - new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor, sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging driver - Lots of missing MAINTAINERS entries added - several em28xx driver improvements, including its conversion to videobuf2 - several fixups on drivers to make them to better comply with the API - DVB core: add support for DVBv5 stats, allowing the implementation of statistics for new standards like ISDB - mb86a20s: add statistics to the driver - lots of new board additions, cleanups, and driver improvements. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits) [media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff) [media] rtl28xxu: Add USB IDs for Compro VideoMate U620F [media] em28xx: add usb id for terratec h5 rev. 3 [media] media: rc: gpio-ir-recv: add support for device tree parsing [media] mceusb: move check earlier to make smatch happy [media] radio-si470x doc: add info about v4l2-ctl and sox+alsa [media] staging: media: Remove unnecessary OOM messages [media] sh_vou: Use vou_dev instead of vou_file wherever possible [media] sh_vou: Use video_drvdata() [media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions [media] mt9t112: mt9t111 format set up differs from mt9t112 [media] sh-mobile-ceu-camera: fix SHARPNESS control default Revert "[media] fc0011: Return early, if the frequency is already tuned" [media] cx18/ivtv: fix regression: remove __init from a non-init function [media] em28xx: fix analog streaming with USB bulk transfers [media] stv0900: remove unnecessary null pointer check [media] fc0011: Return early, if the frequency is already tuned [media] fc0011: Add some sanity checks and cleanups [media] fc0011: Fix xin value clamping Revert "[media] [PATH,1/2] mxl5007 move reset to attach" ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID subsystem updates from Jiri Kosina: "HID subsystem and drivers update. Highlights: - new support of a group of Win7/Win8 multitouch devices, from Benjamin Tissoires - fix for compat interface brokenness in uhid, from Dmitry Torokhov - conversion of drivers to use hid_driver helper, by H Hartley Sweeten - HID over I2C transport received ACPI enumeration support, written by Mika Westerberg - there is an ongoing effort to make HID sensor hubs independent of USB transport. The first self-contained part of this work is provided here, done by Mika Westerberg - a few smaller fixes here and there, support for a couple new devices added" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (43 commits) HID: Correct Logitech order in hid-ids.h HID: LG4FF: Remove unnecessary deadzone code HID: LG: Prevent the Logitech Gaming Wheels deadzone HID: LG: Fix detection of Logitech Speed Force Wireless (WiiWheel) HID: LG: Add support for Logitech Momo Force (Red) Wheel HID: hidraw: print message when succesfully initialized HID: logitech: split accel, brake for Driving Force wheel HID: logitech: add report descriptor for Driving Force wheel HID: add ThingM blink(1) USB RGB LED support HID: uhid: make creating devices work on 64/32 systems HID: wiimote: fix nunchuck button parser HID: blacklist Velleman data acquisition boards HID: sensor-hub: don't limit the driver only to USB bus HID: sensor-hub: get rid of unused sensor_hub_grabbed_usages[] table HID: extend autodetect to handle I2C sensors as well HID: ntrig: use input_configured() callback to set the name HID: multitouch: do not use pointers towards hid-core HID: add missing GENERIC_HARDIRQ dependency HID: multitouch: make MT_CLS_ALWAYS_TRUE the new default class HID: multitouch: fix protocol for Elo panels ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg Kroah-Hartman: "Here's the big char/misc driver patches for 3.9-rc1. Nothing major here, just lots of different driver updates (mei, hyperv, ipack, extcon, vmci, etc.). All of these have been in the linux-next tree for a while." * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (209 commits) w1: w1_therm: Add force-pullup option for "broken" sensors w1: ds2482: Added 1-Wire pull-up support to the driver vme: add missing put_device() after device_register() fails extcon: max8997: Use workqueue to check cable state after completing boot of platform extcon: max8997: Set default UART/USB path on probe extcon: max8997: Consolidate duplicate code for checking ADC/CHG cable type extcon: max8997: Set default of ADC debounce time during initialization extcon: max8997: Remove duplicate code related to set H/W line path extcon: max8997: Move defined constant to header file extcon: max77693: Make max77693_extcon_cable static extcon: max8997: Remove unreachable code extcon: max8997: Make max8997_extcon_cable static extcon: max77693: Remove unnecessary goto statement to improve readability extcon: max77693: Convert to devm_input_allocate_device() extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming style CREDITS: update email and address of Harald Hoyer extcon: arizona: Use MICDET for final microphone identification extcon: arizona: Always take the first HPDET reading as the final one extcon: arizona: Clear _trig_sts bits after jack detection extcon: arizona: Don't HPDET magic when headphones are enabled ...
2013-02-21Merge branches 'for-3.9/sony' and 'for-3.9/steelseries' into for-linusJiri Kosina
Conflicts: drivers/hid/hid-core.c
2013-02-21Merge branches 'for-3.9/logitech', 'for-3.9/multitouch', 'for-3.9/ntrig', ↵Jiri Kosina
'for-3.9/thingm' and 'for-3.9/upstream' into for-linus
2013-02-21Merge branches 'for-3.8/upstream-fixes', 'for-3.9/hid-sensor', ↵Jiri Kosina
'for-3.9/hidraw' and 'for-3.9/i2c-hid' into for-linus Conflicts: drivers/hid/i2c-hid/i2c-hid.c
2013-02-20HID: Correct Logitech order in hid-ids.hSimon Wood
Reorders a couple of device IDs (Logitech controllers) to ensure that they are in hexidecimal order. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-20HID: LG4FF: Remove unnecessary deadzone codeSimon Wood
This patch removes code which is now unnecessary for setting the fuzz/flat characterics for the logitech DFP wheel. This is now done in the previous patch by marking the wheel as a multi-axis device. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-20HID: LG: Prevent the Logitech Gaming Wheels deadzoneSimon Wood
This patch ensures that the Logitech wheels are not initialised with default fuzz/flat values, by marking them as multiaxis devices (rather than joysticks). Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-20HID: LG: Fix detection of Logitech Speed Force Wireless (WiiWheel)Simon Wood
Previously 'LG4FF' was only used for the WiiWheel, however it is now used for all the Logitech Wheels. This patch corrects the detection mechanism for the patching the report descriptor to ensure only the WiiWheel will be patched. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-20HID: LG: Add support for Logitech Momo Force (Red) WheelSimon Wood
This patch provides a modified report descriptor to split accelerator and brake, and adds the 'NO_GET' flag to prevent it hanging on connection. Note: for convience this patch is against the follow patch which was applied earlier this week. https://patchwork.kernel.org/patch/2153471/ Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-19HID: hidraw: print message when succesfully initializedJiri Kosina
Print a message when hidraw has been succesfully initialized. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-19HID: logitech: split accel, brake for Driving Force wheelPaul Sbarra
Signed-off-by: Paul Sbarra <sbarra.paul@gmail.com> Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-19HID: logitech: add report descriptor for Driving Force wheelPaul Sbarra
This is the original report descriptor as reported by lsusb -vd 046d:c294. Signed-off-by: Paul Sbarra <sbarra.paul@gmail.com> Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-19HID: add ThingM blink(1) USB RGB LED supportVivien Didelot
The ThingM blink(1) is an open source hardware USB RGB LED. It contains an internal EEPROM, allowing to configure up to 12 light patterns. A light pattern is a RGB color plus a fade time. This driver registers a LED class instance with additional sysfs attributes to support basic functions such as setting RGB colors, fade and playing. Other functions are still accessible through the hidraw interface. At this time, the only documentation for the device is the firmware source code from ThingM, plus a few schematics. They are available at: https://github.com/todbot/blink1 This patch is version 3. It updates the name of the source file, the driver and the led sysfs entry, according to comments from Jiri Kosina and Simon Wood. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: uhid: make creating devices work on 64/32 systemsDmitry Torokhov
Unfortunately UHID interface, as it was introduced, is broken with 32 bit userspace running on 64 bit kernels as it uses a pointer in its userspace facing API. Fix it by checking if we are executing compat task and munge the request appropriately. Reported-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: wiimote: fix nunchuck button parserDavid Herrmann
The buttons of the Wii Remote Nunchuck extension are actually active low. Fix the parser to forward the inverted values. The comment in the function always said "0 == pressed" but the implementation was wrong from the beginning. Cc: stable@vger.kernel.org Reported-by: Victor Quicksilver <victor.quicksilver@gmail.com> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: blacklist Velleman data acquisition boardsIan Abbott
These are simple data acquistion boards, not HID devices and are handled by the vmk80xx comedi driver. At least one of them (10cf:5500) misidentifies itself as a HID in its USB interface descriptor. Ignore all these devices. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: sensor-hub: don't limit the driver only to USB busMika Westerberg
We now have two transport mediums: USB and I2C, where sensor hubs can exists. So instead of constraining the driver to only these two we let it to match any HID bus as long as the group is HID_GROUP_SENSOR_HUB. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: sensor-hub: get rid of unused sensor_hub_grabbed_usages[] tableMika Westerberg
This table is not used anywhere in the driver so kill it. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: extend autodetect to handle I2C sensors as wellMika Westerberg
Since the advent of HID over I2C protocol, it is possible to have sensor hubs behind I2C bus as well. We can autodetect this in a same way than USB sensor hubs. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-18HID: ntrig: use input_configured() callback to set the nameBenjamin Tissoires
The use of input_configured() allows the ntrig driver to actually change the name of the input and its bitmask before it is added to the input subsystem. Thus, the logs are coherents and udev catch the real bitmask when the device is added. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Rafi Rubin <rafi@seas.upenn.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-07HID: multitouch: do not use pointers towards hid-coreBenjamin Tissoires
The previous implementation registered a pointer towards hid-core to the value of contact count. This is not safe and may be difficult to debug if hid-core ever changes its implementation. The use of regular indexes is a better choice. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-07HID: add missing GENERIC_HARDIRQ dependencyHeiko Carstens
HID Sensors framework support (CONFIG_HID_SENSOR_HUB) unconditionally selects MFD_CORE which however depends on GENERIC_HARDIRQS. So add this dependency to HID_SENSOR_HUB as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: make MT_CLS_ALWAYS_TRUE the new default classBenjamin Tissoires
By running a test on all the traces of the devices I have, I noticed that the class MT_CLS_ALWAYS_TRUE could handle all the devices I've seen so far without any other quirks. I guess this is the behavior Win 7 requires in its driver. We can change the default class then and keep the existing classes for backward compatibility and performances for some of them. Two operations have been done: * replaced MT_CLS_DEFAULT by MT_CLS_NSMU * then replaced MT_CLS_ALWAYS_TRUE by MT_CLS_DEFAULT Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: fix protocol for Elo panelsBenjamin Tissoires
The previous protocol was nearly working, but when several fingers were present on the sensor, those that were not moving were not updated in the next report, introducing a lot of releases. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Conflicts: drivers/hid/hid-multitouch.c Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: fix protocol for Cando 2087:0a02Benjamin Tissoires
Cando 2087:0a02 was broken, this fixes it. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: fix protocol for Sitronix 1403:5001Benjamin Tissoires
Since the inclusion of this device in hid-multitouch, the device did not forward any events. Using the serial class makes it working again. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: ensure that serial devices make no use of contact countBenjamin Tissoires
The serial protocol makes contact count a redondant information, and sometimes it is not reliable (TRS-Star are in this case). Disabling the use of contact count for these devices is thus safer. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: fix Win8 protocol for Sharp like devicesBenjamin Tissoires
The Sharp LC-20FE1-W screen (04dd:9681) behaves like the Nexio 42". It may report out of ranges values that are filtered out by relying on the Contact Count HID field. Adding the quirk MT_QUIRK_CONTACT_CNT_ACCURATE makes hid-multitouch strongest against this kind of device, without breaking the current devices. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: add support for Nexio 42" panelBenjamin Tissoires
This device is the worst device I saw. It keeps TipSwitch and InRange at 1 for fingers that are not touching the panel. The solution is to rely on the field ContactCount, which is accurate as the correct information are packed at the begining of the frame. Unfortunately, CountactCount is most of the time at the end of the report. The solution is to pick it when we have the whole report in raw_event. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: multitouch: use the callback "report" instead of sequential eventsBenjamin Tissoires
Nexio 42" devices requires to rely on the HID field Contact Count to compute the valid values. However, this field is most of the time at the end of the report, meaning that we need to get the all report parsed before processing it. This patch does not introduce functional changes. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-05HID: core: add "report" hook, called once the report has been parsedBenjamin Tissoires
This callback is called when the parsing of the report has been done by hid-core (so after the calls to .event). The hid drivers can now have access to the whole report by relying on the values stored in the different fields. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-02-01Merge branch 'for-3.8/upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid PullHID fixes from Jiri Kosina: - fix i2c-hid and hidraw interaction, by Benjamin Tissoires - a quirk to make a particular device (Formosa IR receiver) work properly, by Nicholas Santos * 'for-3.8/upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: i2c-hid: fix i2c_hid_output_raw_report HID: usbhid: quirk for Formosa IR receiver HID: remove x bit from sensor doc
2013-01-31HID: i2c-hid: fix i2c_hid_output_raw_reportBenjamin Tissoires
i2c_hid_output_raw_report is used by hidraw to forward set_report requests. The current implementation of i2c_hid_set_report needs to take the report_id as an argument. The report_id is stored in the first byte of the buffer in argument of i2c_hid_output_raw_report. Not removing the report_id from the given buffer adds this byte 2 times in the command, leading to a non working command. Reported-by: Andrew Duggan <aduggan@synaptics.com> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31HID: steelseries: fix out of bound array accessJiri Kosina
The last field of the driver_data->leds[] array is used to store the special toggle for setting all leds simultaneously, so we need to allocate appropriate number of led_classdev pointers. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31HID: steelseries: rename driver to be compliant with other driversJiri Kosina
We usually group drivers on a per-vendor basis, implementing device-specific deviations from the standard in vendor-specific driver. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31USB: HID: Steelseries SRW-S1 Add support controlling all LEDs simultaneouslySimon Wood
This patch to the SRW-S1 driver adds the ability to control all LEDs simultaneously as testing showed that it was slow (noticably!!) when seting or clearing all the LEDs in turn. It adds a 'RPMALL' LED, whose behavoir is asserted to all the LEDs in the bar graph, individual LEDs can subsequently be turned on/off individually. Signed-off-by: Simon Wood <simon@mungewell.org> Tested-by: John Murphy <rosegardener@freeode.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31USB: HID: Steelseries SRW-S1 Add support for LEDsSimon Wood
This patch to the SRW-S1 driver adds support for the LED RPM meter on the front of the device. The LEDs are controlled via /sys/class/leds interface, with an individual control for each of the 15 LEDs. Signed-off-by: Simon Wood <simon@mungewell.org> Tested-by: John Murphy <rosegardener@freeode.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31USB: HID: Steelseries SRW-S1 Add support for dialsSimon Wood
This patch to the SRW-S1 driver re-writes the HID descriptor to insert a section for the 3 dials on the device, previously these were contained within a 'Manufacturer Specific' usage page. Signed-off-by: Simon Wood <simon@mungewell.org> Tested-by: John Murphy <rosegardener@freeode.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-31USB: HID: SRW-S1 Gaming Wheel DriverSimon Wood
Add support the SRW-S1 by patching HID descriptor to read axis as Generic Desktop X, Y and Z (rather than Usage page being 'Simulation'). Signed-off-by: Simon Wood <simon@mungewell.org> Tested-by: John Murphy <rosegardener@freeode.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-25Drivers: hid: hid-hyperv: Use consolidated GUID definitionsK. Y. Srinivasan
Use the consolidated GUID definitions in the Hyper-V mouse driver. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-24Merge branch 'v4l_for_linus' into staging/for_v3.9Mauro Carvalho Chehab
* v4l_for_linus: (464 commits) [media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures [media] uvcvideo: Cleanup leftovers of partial revert [media] uvcvideo: Return -EACCES when trying to set a read-only control Linux 3.8-rc3 mm: reinstante dropped pmd_trans_splitting() check cred: Remove tgcred pointer from struct cred drm/ttm: fix fence locking in ttm_buffer_object_transfer ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms drm/prime: drop reference on imported dma-buf come from gem xen/netfront: improve truesize tracking ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array sctp: fix Kconfig bug in default cookie hmac selection EDAC: Cleanup device deregistering path ... Conflicts: drivers/media/pci/dm1105/dm1105.c drivers/media/platform/soc_camera/mx2_camera.c
2013-01-22HID: clean up quirk for Sony RF receiversFernando Luis Vázquez Cao
Document what the fix-up is does and make it more robust by ensuring that it is only applied to the USB interface that corresponds to the mouse (sony_report_fixup() is called once per interface during probing). Cc: linux-input@vger.kernel.org Cc: linux-usb@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
