path: root/drivers/hid
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: hid-multitouch: minor fixes based on additional review HID: Switch turbox/mosart touchscreen to hid-mosart HID: add Add Cando touch screen 10.1-inch product id HID: hid-mulitouch: add support for the 'Sensing Win7-TwoFinger' HID: hid-multitouch: add support for Cypress TrueTouch panels HID: hid-multitouch: support for PixCir-based panels HID: set HID_MAX_FIELD at 128 HID: add feature_mapping callback
2011-01-11HID: hid-multitouch: minor fixes based on additional reviewBenjamin Tissoires
* amended Kconfig (PixCir and Hanvon are the same panel but with different name) * insert field name in mt_class and retrieving it in mt_probe * add 2 quirks: MT_QUIRK_VALID_IS_INRANGE, MT_QUIRK_VALID_IS_CONFIDENCE, in order to find the field "valid" * inlined slot_is_contactid and slot_is_contact_number * cosmetics changes (tabs and comments) * do not send unnecessary properties once the touch is up Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Acked-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: Switch turbox/mosart touchscreen to hid-mosartBenjamin Tissoires
This device used the MULTI_INPUT quirk whereas it could be used with hid-mosart instead to support the multitouch part. Reference: https://bugs.launchpad.net/ubuntu/+bug/620609/ Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: add Add Cando touch screen 10.1-inch product idBenjamin Tissoires
This device has been reported to be an hid-cando one. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: hid-mulitouch: add support for the 'Sensing Win7-TwoFinger'Benjamin Tissoires
Added support for the 'Sensing Win7-TwoFinger' panel by GeneralTouch found on some tablets. Because of conflicting VID/PID, this conflicts with previous support for some single-touch panels by GeneralTouch Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Stéphane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: hid-multitouch: add support for Cypress TrueTouch panelsBenjamin Tissoires
Added support for Cypress TrueTouch panels, which detect up to 10 fingers Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Stéphane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: hid-multitouch: support for PixCir-based panelsBenjamin Tissoires
Created a driver for PixCir based dual-touch panels, including the one in the Hanvon tablet. This is done in a code structure aimed at unifying support for several existing HID multitouch panels. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Stéphane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-11HID: add feature_mapping callbackBenjamin Tissoires
Currently hid doesn't export the features it knows to the specific modules. Some information can be really important in such features: MosArt and Cypress devices are by default not in a multitouch mode. We have to send the value 2 on the right feature. This patch exports to the module the features report so they can find the right feature to set up the correct mode. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Acked-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (34 commits) HID: roccat: Update sysfs attribute doc HID: roccat: don't use #pragma pack HID: roccat: Add support for Roccat Kone[+] v2 HID: roccat: reduce number of functions in kone and pyra drivers HID: roccat: declare meaning of pack pragma usage in driver headers HID: roccat: use class for char device for sysfs attribute creation sysfs: Introducing binary attributes for struct class HID: hidraw: add compatibility ioctl() for 32-bit applications. HID: hid-picolcd: Fix memory leak in picolcd_debug_out_report() HID: picolcd: fix misuse of logical operation in place of bitop HID: usbhid: base runtime PM on modern API HID: replace offsets values with their corresponding BTN_* defines HID: hid-mosart: support suspend/resume HID: hid-mosart: ignore buttons report HID: hid-picolcd: don't use flush_scheduled_work() HID: simplify an index check in hid_lookup_collection HID: Hoist assigns from ifs HID: Remove superfluous __inline__ HID: Use vzalloc for vmalloc/memset(,0...) HID: Add and use hid_<level>: dev_<level> equivalents ...
2011-01-08HID: roccat: don't use #pragma packJiri Kosina
Replace #pragma pack ocurences with __atribute__((__packed__)); Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: Add support for Roccat Kone[+] v2Stefan Achatz
This patch adds support for Roccat Kone[+] gaming mouse. Kone[+] is an enhanced version of the old Kone with more memory for macros, a better sensor and more functionality. This driver is conceptual similar to the existing Kone and Pyra drivers. Userland tools can soon be found at http://sourceforge.net/projects/roccat Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: reduce number of functions in kone and pyra driversStefan Achatz
The profile number is now passed via bin_attribute->private instead of function parameter to reduce number of functions. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: declare meaning of pack pragma usage in driver headersStefan Achatz
Using pack pragma to prevent padding bytes in binary data structures used for hardware communication. Explanation of these pragmas was requested. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08HID: roccat: use class for char device for sysfs attribute creationStefan Achatz
Adding sysfs attributes to an already created device raises no userland notification. Now the device drivers associate the devices attributes with a class and use this for roccat event char device creation. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-08Merge branches 'upstream' and 'upstream-fixes' into for-linusJiri Kosina
2011-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits) Input: wacom_w8001 - support pen or touch only devices Input: wacom_w8001 - use __set_bit to set keybits Input: bu21013_ts - fix misuse of logical operation in place of bitop Input: i8042 - add Acer Aspire 5100 to the Dritek list Input: wacom - add support for digitizer in Lenovo W700 Input: psmouse - disable the synaptics extension on OLPC machines Input: psmouse - fix up Synaptics comment Input: synaptics - ignore bogus mt packet Input: synaptics - add multi-finger and semi-mt support Input: synaptics - report clickpad property input: mt: Document interface updates Input: fix double equality sign in uevent Input: introduce device properties hid: egalax: Add support for Wetab (726b) Input: include MT library as source for kerneldoc MAINTAINERS: Update input-mt entry hid: egalax: Add support for Samsung NB30 netbook hid: egalax: Document the new devices in Kconfig hid: egalax: Add support for Wetab hid: egalax: Convert to MT slots ... Fixed up trivial conflict in drivers/input/keyboard/Kconfig
2011-01-04HID: hidraw: add compatibility ioctl() for 32-bit applications.Alan Ott
Added the ioctl function to the compat_ioctl pointer in the file_operations struct. Before this, some ioctls would fail for 32-bit apps on 64-bit systems. Signed-off-by: Alan Ott <alan@signal11.us> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-03HID: hid-picolcd: Fix memory leak in picolcd_debug_out_report()Jesper Juhl
We have a memory leak in drivers/hid/hid-picolcd.c::picolcd_debug_out_report() in an error path.. We are not always freeing the memory allocated to 'buff' - this patch makes sure we always kfree() what we allocate with kmalloc() when it is no longer needed. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-27HID: picolcd: fix misuse of logical operation in place of bitopDavid Sterba
CC: Bruno Prémont <bonbons@linux-vserver.org> CC: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-22HID: usbhid: base runtime PM on modern APIOliver Neukum
This patch doesn't alter functionality, but removes a dedicated kernel thread. Signed-off-by: Oliver Neukum <oneukum@suse.de> Tested-by: Maulik Mankad <x0082077@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-21USB: add support for Dream Cheeky DL100B Webmail Notifier (1d34:0004)Melchior FRANZ
So far the USBLED driver only supports Delcom's "USB Visual Signal Indicator" (http://www.delcomproducts.com/products_USBLMP.asp). The driver generates virtual files "red", "green", and "blue" under the device's /sys/ directory, where color values can be read from and written to. This patch adds support for Dream Cheeky's "DL100B Webmail Notifier" (http://www.dreamcheeky.com/webmail-notifier -- available from several shops, such as http://www.conrad.at/ce/de/product/777048/USB-WEBMAIL). This device isn't as pretty as Delcom's, but it's *far* cheaper, and its 3 LEDs can be set in 32 brightness steps each. The grey envelope contour can easily be removed, leaving a rather neutral white box (with a few small holes), which is useful for generic signalling purposes. Of course, the small circuit board can easily be put into a prettier case. The DL100B device pretends to be a HID, but the HID descriptor shows that it's not overly useful as such (see below). The patch therefore removes the "HID-ness" (hid-core.c, hid-ids.h), and adds the necessary commands to usbled.c. The protocol info comes from the developer's manual that Dream Cheeky kindly provided (815DeveloperManual.pdf). HID descriptor: 0: 05 01 Usage Page 'Generic Desktop Controls' 2: 09 10 Usage 'Reserved' 4: a1 01 Collection 'Application (mouse, keyboard)' 6: 05 00 Usage Page 'Undefined' 8: 19 10 Usage Minimum = 16 10: 29 11 Usage Maximum = 17 12: 15 00 Logical Minimum = 0 14: 25 0f Logical Maximum = 15 16: 75 08 Report Size = 8 18: 95 08 Report Count = 8 20: 91 02 Output data *var abs lin pref-state null-pos non-vol bit-field 22: 19 10 Usage Minimum = 16 24: 29 11 Usage Maximum = 17 26: 15 00 Logical Minimum = 0 28: 25 0f Logical Maximum = 15 30: 75 08 Report Size = 8 32: 95 08 Report Count = 8 34: 81 00 Input data array abs lin pref-state null-pos non-vol bit-field 36: c0 End Collection Signed-off-by: Melchior FRANZ <mfranz@aon.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-18hid: egalax: Add support for Wetab (726b)Andy Ross
This patch adds support for another Wetab device (726b), and grabs it accordingly in hid-core. [rydberg@euromail.se: rename and log message changes] Signed-off-by: Andy Ross <andy@plausible.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Add support for Samsung NB30 netbookRichard Nauber
The Samsung NB30 touch has a DWAV dual-touch device. This patch adds the NB30 to the list of supported devices, and grabs it accordingly in hid-core. [rydberg@euromail.se: rename and log message changes] Signed-off-by: Richard Nauber <Richard.Nauber@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Document the new devices in KconfigHenrik Rydberg
Add the new supported devices to the kernel menu config help text. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Add support for WetabHenrik Rydberg
The Wetab tablet dual-touch controller works the same way as the one in the Joojoo tablet. This patch adds the Wetab to the list of supported devices, and grabs it accordingly in hid-core. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Convert to MT slotsHenrik Rydberg
The firmware in the joojoo reports touches sequentially, one per report, which confuses the current driver. A further complication is the absense of any indication of a touch frame. This patch converts the driver to the MT slots protocol, and outputs one full touch frame per report. This way, proper handling for both firmwares is ensured. Tested-by: Philipp Merkel <mail@philmerk.de> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Add event filteringHenrik Rydberg
Use estimated signal-to-noise ratios to reduce noise and limit the amount of events emitted. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Report zero as minimum pressureHenrik Rydberg
The firmware reports a logical minimum of one, but in order for userspace applications to correctly map all reported values to non-zero pressure, the driver needs to report a logical minimum of zero. Fixed with this patch. Tested-by: Philipp Merkel <mail@philmerk.de> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Correct for device resolution report errorHenrik Rydberg
The firmware of both supported devices report a X/Y maximum of 4095, whereas in reality, it is eight times larger. Fixed with this patch. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16hid: egalax: Setup input device manuallyHenrik Rydberg
The hid core does not yet handle input filtering. Take over the setup of the input device, so that proper signal-to-noise ratios can be used. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Stephane Chatty <chatty@enac.fr> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16input: mt: Move tracking and pointer emulation to input-mtHenrik Rydberg
The drivers using the type B protocol all report tracking information the same way. The contact id is semantically equivalent to ABS_MT_SLOT, and the handling of ABS_MT_TRACKING_ID only complicates the driver. The situation can be improved upon by providing a common pointer emulation code, thereby removing the need for the tracking id in the driver. This patch moves all tracking event handling over to the input core, simplifying both the existing drivers and the ones currently in preparation. Acked-by: Ping Cheng <pingc@wacom.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16input: mt: Collect slots initialization codeHenrik Rydberg
The MT slots devices all follow the same initialization pattern of creating slots and hinting about buffer size. Let drivers call an initialization function instead, and make sure it can be called repeatedly without side effects. Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-16input: mt: Break out slots handlingHenrik Rydberg
In preparation for common code to handle a larger set of MT slots devices, move the slots handling over to a separate file. Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
2010-12-14HID: replace offsets values with their corresponding BTN_* definesFlorian Fainelli
Instead of using magic values, use their corresponding BTN_* defines from linux/input.h. Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-14HID: hid-mosart: support suspend/resumeBenjamin Tissoires
The device has 2 modes. The first one is an emulation of a touchscreen by sending left and right button, and the second mode is the one used in dual-touch (sending trackingID, touch and else). In case of a suspend/resume, the device switch back to the first mode described above (with left and right buttons). This adds a hook in .reset_resume for the device to be switched to the correct mode (I just copied the code in mosart_probe). Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-14HID: hid-mosart: ignore buttons reportBenjamin Tissoires
This commit allows the device to be recognized as a touchscreen, and not a touchpad by xf86-input-evdev. The device has 2 modes. The first one is an emulation of a touchscreen by sending left and right button, and the second mode is the one used in dual-touch (sending trackingID, touch and else). That's why there is a hid report containing left and right buttons (9000001 and 9000002). The point is that xorg relies on these fields to determine if it's a touchpad or a touchscreen. Clearing the report (return -1) makes xorg detecting it out of the box as a quite pleasant (dual)touchscreen. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@enac.fr> Acked-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-11HID: hid-picolcd: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush picolcd_fb_cleanup on exit instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-10Merge branch 'master' into upstreamJiri Kosina
2010-12-10HID: simplify an index check in hid_lookup_collectionJoe Perches
Save the struct hid_collection * in a temporary to shorten the generated code a bit and perhaps improve readability. $ size drivers/hid/hid-core.o* text data bss dec hex filename 16460 78 8 16546 40a2 drivers/hid/hid-core.o.new 16469 78 8 16555 40ab drivers/hid/hid-core.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-10HID: Hoist assigns from ifsJoe Perches
2010-12-10HID: Remove superfluous __inline__Joe Perches
2010-12-10HID: Use vzalloc for vmalloc/memset(,0...)Joe Perches
2010-12-10HID: Add and use hid_<level>: dev_<level> equivalentsJoe Perches
Neaten current uses of dev_<level> by adding and using hid specific hid_<level> macros. Convert existing uses of dev_<level> uses to hid_<level>. Convert hid-pidff printk uses to hid_<level>. Remove err_hid and use hid_err instead. Add missing newlines to logging messages where necessary. Coalesce format strings. Add and use pr_fmt(fmt) KBUILD_MODNAME ": " fmt Other miscellaneous changes: Add const struct hid_device * argument to hid-core functions extract() and implement() so hid_<level> can be used by them. Fix bad indentation in hid-core hid_input_field function that calls extract() function above. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-09HID: magicmouse: Don't report REL_{X,Y} for Magic TrackpadChase Douglas
With the recent switch to having the hid layer handle standard axis initialization, the Magic Trackpad now reports relative axes. This would be fine in the normal mode, but the driver puts the device in multitouch mode where no relative events are generated. Also, userspace software depends on accurate axis information for device type detection. Thus, ignoring the relative axes from the Magic Trackpad is best. Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-08HID: add hid_hw_open/close/power() handlersDmitry Torokhov
Instead of exposing the guts of hid->ll_driver relationship to HID sub-drivers provide these helpers to encapsulate the details. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-07HID: Consolidate device existence checks in hiddev_ioctlValentine Barshak
Currently, if the device has been removed before hiddev_ioctl(), the -EIO is returned. If it's removed while hiddev_ioctl() is in progress, some commands are still processed fine, others return -ENODEV. This change takes the "existancelock" before processing ioctl commands and releases it at the end. If the device has been removed, always returns -ENODEV. Signed-off-by: Valentine Barshak <vbarshak@mvista.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-07HID: Fix race between disconnect and hiddev_ioctlValentine Barshak
A USB HID device can be disconnected at any time. If this happens right before or while hiddev_ioctl is in progress, the hiddev_ioctl tries to access invalid hiddev->hid pointer. When the hid device is disconnected, the hiddev_disconnect() ends up with a call to hid_device_release() which frees hid_device, but doesn't set the hiddev->hid pointer to NULL. If the deallocated memory region has been re-used by the kernel, this can cause a crash or memory corruption. Since disconnect can happen at any time, we can't initialize struct hid_device *hid = hiddev->hid at the beginning of ioctl and then use it. This change checks hiddev->exist flag while holding the existancelock and uses hid_device only if it exists. Signed-off-by: Valentine Barshak <vbarshak@mvista.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: length resolution should be reported units/mm HID: add support for F430 Force Feedback Wheel HID: egalax: Use kzalloc HID: Remove KERN_DEBUG from dbg_hid use Manually fixed trivial conflict in drivers/hid/hid-input.c (due to removal of KERN_DEBUG from dbg_hid use clashing with new keycode interface switch)
2010-12-02HID: length resolution should be reported units/mmDmitry Torokhov
Input ABI requires reporting resolution on main axes in units per millimeter, not units per inch, so we need to convert accordingly. Tested-by: Nikolai Kondrashov <spbnick@gmail.com> Acked-by: Nikolai Kondrashov <spbnick@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
