commit 40ee3381dd1010432acc13e907329029096c5bfc upstream.
drm_helper_hpd_irq_event queues another work proc to go and deliver
the user-space event, and that function also wants to hold the config
mutex, so we shouldn't hold the mutex across the
drm_helper_hpd_irq_event call.
Signed-off-by: Keith Packard <keithp@keithp.com>
commit a65e34c79c88895766ab1f8a5afa451eed26622b upstream.
Hotplug detection is a mode setting operation and must hold the
struct_mutex or risk colliding with other mode setting operations.
In particular, the display port hotplug function attempts to re-train
the link if the monitor is supposed to be running when plugged back
in. If that happens while mode setting is underway, the link will get
scrambled, leaving it in an inconsistent state.
This is a special case -- usually the driver mode setting entry points
are covered by the upper level DRM code, but in this case the function
is invoked as a work function not under the control of DRM.
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit f3234706a77bd6e1592ae71fb3268e04cb030dba upstream.
Physically-addressed hardware status pages are initialized early in
the driver load process by i915_init_phys_hws. For UMS environments,
the ring structure is not initialized until the X server starts. At
that point, the entire ring structure is re-initialized with all new
values. Any values set in the ring structure (including
ring->status_page.page_addr) will be lost when the ring is
re-initialized.
This patch moves the initialization of the status_page.page_addr value
to intel_render_ring_init_dri.
commit 9c54c0dd948d715ccfd79e97d852f80eeb53254a upstream.
Per the specs and to address
https://bugs.freedesktop.org/show_bug.cgi?id=36888.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 302983e9059e9ef5de3ca7671918eeb237c5971e upstream.
Consider a 1600x900 panel, upscaling a 1360x768 mode, full-aspect. The
old math would give you:
scaled_width = 1600 * 768; /* 1228800 */
scaled_height = 1360 * 900; /* 1224000 */
if (scaled_width > scaled_height) { /* pillarbox, and true */
width = 1224000 / 768; /* int(1593.75) = 1593 */
x = (1600 - 1593 + 1) / 2; /* 4 */
y = 0;
height = 768;
This is broken. The total width of scanout would then be 1593 + 4 + 4,
or 1601, which is wider than the panel itself. The hardware very
dutifully implements this, and you end up with a black 45° diagonal from
the top-left corner to the bottom edge of the screen. It's a cool
effect and all, but not what you wanted. Similar things happen for the
letterbox case.
The problem is that you have an integer number of pixels, which means
it's usually impossible to upscale equally on both axes. 1360/768 is
1.7708, 1600/900 is 1.7777. Since we're constrained on the one axis,
the other one wants to come out as an even number of pixels (the panel
is almost certainly even on both axes, and the x/y offsets will be
applied on both sides). In the math above, if 'width' comes out even,
rounding down is correct; if it's odd, you'd rather round up. So just
increment width/height in those cases.
Tested on a Lenovo T500 (Ironlake).
Signed-off-by: Adam Jackson <ajax@redhat.com>
Tested-By: Daniel Manrique <daniel.manrique@canonical.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38851
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit d522d9cc5bdd41214084383fc3e6d882f6916a78 upstream.
Log PCI subsystem vendor and subsystem device ID in addition to
PCI vendor and device ID during kernel mode initialisation. This helps
to better identify radeon devices of third-party vendors, e. g. for
bug analysis.
Tested for kernel 2.6.35, 2.6.38 and 3.0 on Asus M2A-VM HDMI board
Signed-off-by: Thomas Reim <reimth@gmail.com>
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
Acked-by: Stephen Michaels <Stephen.Micheals@gmail.com>
commit a81b31e9fc98e067b7e7f1244861c97e44268e2d upstream.
ECS A740GM-M with ATI RADEON 2100 sends data to i2c bus
for a DVI connector that is not implemented/existent on the board.
Fix by applying extented DDC probing for this connector.
Requires [PATCH] drm/radeon: Extended DDC Probing for Connectors
with Improperly Wired DDC Lines
Tested for kernel 2.6.38 on Asus ECS A740GM-M board
BugLink: http://bugs.launchpad.net/bugs/810926
Lines (here: Asus M2A-VM HDMI)
commit e384fab8c6f3ca88600bcb2ebdf0eb2f90864fab upstream.
Some integrated ATI Radeon chipset implementations with add-on HDMI card
(e. g. Asus M2A-VM HDMI) indicate the availability of a DDC even
when the add-on card is not plugged in or HDMI is disabled in BIOS setup.
In this case, drm_get_edid() and drm_edid_block_valid() periodically
dump data and kernel errors into system log files and onto terminals.
For these connectors DDC probing is extended by a check for a correct
EDID header. Only in case a valid EDID header is also found, the
(HDMI or DVI) connector will be used by the Radeon driver. This prevents
the kernel driver from useless flooding of logs and terminal sessions with
EDID dumps and error messages.
This patch adds a flag 'requires_extended_probe' to the radeon_connector
structure. In function radeon_connector_needs_extended_probe() this flag
can be set on a chipset family/vendor/connector type specific basis.
In addition, function radeon_ddc_probe() has been adapted to perform
extended DDC probing if required by the connector's flag.
Requires function drm_edid_header_is_valid() in DRM module provided by
[PATCH] drm: Separate EDID Header Check from EDID Block Check.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=668196
BugLink: http://bugs.launchpad.net/bugs/7228066
commit 051963d4832ed61e5ae74f5330b0a94489e101b9 upstream.
Provides function drm_edid_header_is_valid() for EDID header check
and replaces EDID header check part of function drm_edid_block_valid()
by a call of drm_edid_header_is_valid().
This is a prerequisite to extend DDC probing, e. g. in function
radeon_ddc_probe() for Radeon devices, by a central EDID header check.
commit 4639dd21e759e32125adc7171abf6cb8140d54cf upstream.
Need to add vddci setting to pm init as well as
resume. Fixes hangs on load on some boards.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=38754
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5a96a899bbdee86024ab9ea6d02b9e242faacbed upstream.
DPEncoderService newer than 1.1 can't properly program the DP (display port)
link training. When facing such version use the DIGxEncoderControl method
instead. Fix DP link training on some R7XX.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 6dd666333ddee39903d86f870d5c40d9f100e0cc upstream.
Those chips have crt2_ddc bus.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=39672
git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6:
drm/i915: Fix unfenced alignment on pre-G33 hardware
drm/i915: Add quirk to disable SSC on Lenovo U160 LVDS
Align unfenced buffers on older hardware to the power-of-two object
size. The docs suggest that it should be possible to align only to a
power-of-two tile height, but using the already computed fence size is
easier and always correct. We also have to make sure that we unbind
misaligned buffers upon tiling changes.
In order to prevent a repetition of this bug, we change the interface
to the alignment computation routines to force the caller to provide
the requested alignment and size of the GTT binding rather than assume
the current values on the object.
Reported-and-tested-by: Sitosfe Wheeler <sitsofe@yahoo.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=36326
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: stable@kernel.org
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
We've tried several times to make this machine 'just work', but every
patch that does causes many other machines to fail. This adds a quirk
which special cases this hardware and forces ssc to be
disabled. There's no way to override this from the command line; that
would be a significantly more invasive change.
This patch fixes #36656 on fdo bugzilla:
https://bugs.freedesktop.org/show_bug.cgi?id=36656
References: https://bugs.freedesktop.org/show_bug.cgi?id=36656
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms/evergreen: emit SQ_LDS_RESOURCE_MGMT for blits
agp/intel: Fix typo in G4x_GMCH_SIZE_VT_2M
drm/radeon/kms: fix typo in read_disabled vbios code
drm/radeon/kms: use correct BUS_CNTL reg on rs600
drm/radeon/kms: fix backend map typo on juniper
drm/radeon/kms: fix regression in hotplug
Compute drivers may change this, so make sure to emit it to
avoid errors in bo blits.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=39119
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
drm/i915/ringbuffer: Idling requires waiting for the ring to be empty
Revert "drm/i915: enable rc6 by default"
drm/i915: Clean up i915_driver_load failure path
drm/i915: Enable GPU reset on Ivybridge.
drm/i915/dp: manage sink power state if possible
drm/i915/dp: consolidate AUX retry code
drm/i915/dp: remove DPMS mode tracking from DP
drm/i915/dp: try to read receiver capabilities 3 times when detecting
drm/i915/dp: read more receiver capability bits on hotplug
drm/i915/dp: use DP DPCD defines when looking at DPCD values
drm/i915/dp: retry link status read 3 times on failure
...which is measured by the size and not the amount of space remaining.
Waiting upon size-8, did one of two things. In the common case with more
than 8 bytes available to write into the ring, it would return
immediately. Otherwise, it would timeout given the impossible condition
of waiting for more space than is available in the ring, leading to
warnings such as:
[drm:intel_cleanup_ring_buffer] *ERROR* failed to quiesce render ring
whilst cleaning up: -16
Reviewed-by: Eric Anholt <eric@anholt.net>
This reverts commit a51f7a66fb5e4af5ec4286baef940d06594b59d2.
We still have a few Ironlake and Sandybridge machines which fail when
RC6 is enabled. Better luck next release?
i915_driver_load adds a write-combining MTRR region for the GTT
aperture to improve memory speeds through the aperture. If
i915_driver_load fails after this, it would not have cleaned up the
MTRR. This shouldn't cause any problems, except for consuming an MTRR
register. Still, it's best to clean up completely in the failure path,
which is easily done by calling mtrr_del if the mtrr was successfully
allocated.
i915_driver_load calls i915_gem_load which register
i915_gem_inactive_shrink. If i915_driver_load fails after calling
i915_gem_load, the shrinker will be left registered. When called, it
will access freed memory and crash. The fix is to unregister the shrinker in the
failure path using code duplicated from i915_driver_unload.
i915_driver_load also has some incorrect gotos in the error cleanup
paths:
* After failing to initialize the GTT (which cannot happen, btw,
intel_gtt_get returns a fixed (non-NULL) value), it tries to
free the uninitialized WC IO mapping. Fixed this by changing the
target from out_iomapfree to out_rmmap
Tested-by: Lin Ming <ming.m.lin@intel.com>
BUS_CNTL reg and bits moved between pre-PCIE and PCIE asics.
BUS_CNTL is at 0x30 on rs600, not 0x4c.
Don't enable backends that don't exist.
Skip connectors that do not have an HPD pin.
Should fix:
https://bugs.freedesktop.org/show_bug.cgi?id=39027
Tested-by: Rafał Miłecki <zajec5@gmail.com>
evergreen+ asics have 2-6 crtcs. Don't access crtc registers
for crtc regs that don't exist as they have very high latency
and may cause problems on some asics. The previous code missed
a few cases and was not fine grained enough (missed the 4 crtc
case for example).
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=38800
v2: fix typo noticed by Chris Bandy <cbandy@jbandy.com>
Reviewed-by: Michel Dänzer <michel@daenzer.net>
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
According to the hardware documentation, GDRST is exactly the same as on
Sandybridge. So simply enable the existing code.
Signed-off-by: Kenneth Graunke <kenneth@whitecape.org>
On sinks with a DPCD rev of 1.1 or greater, we can send sink power
management commands to address 0x600 per section 5.1.5 of the
DisplayPort 1.1a spec.
Reviewed-by: Keith Packard <keithp@keithp.com>
When checking link status during a hot plug event or detecting sink
presence, we need to retry 3 times per the spec (section 9.1 of the 1.1a
DisplayPort spec). Consolidate the retry code into a
native_aux_read_retry function for use by get_link_status and _detect.
We currently use this when a hot plug event is received, only checking
the link status and re-training if we had previously configured a link.
However if we want to preserve the DP configuration across both hot plug
and DPMS events (which we do for userspace apps that don't respond to
hot plug uevents), we need to unconditionally check the link and try to
bring it up on hot plug.
If ->detect is called too soon after a hot plug event, the sink may not
be ready yet. So try up to 3 times with 1ms sleeps in between tries to
get the data (spec dictates that receivers must be ready to respond within
1ms and that sources should try 3 times).
See section 9.1 of the 1.1a DisplayPort spec.
When a hotplug event is received, we need to check the receiver cap bits
in case they've changed (as they might with a hub or chain config).
Makes it easier to search for DP related constants.
Especially after a hotplug or power status change, the sink may not
reply immediately to a link status query. So retry 3 times per the spec
to really make sure nothing is there.
Sometimes we could be controlling a device (such as an NVIDIA Tesla) that
has no crtcs/encoders/connectors.
One could argue that the driver should unset DRIVER_MODESET in this case,
but that changes a whole heap of the DRM's other behaviours, and it's much
easier to just be a modesetting driver without any outputs.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
ib pool weren't free for various newer asic on module unload.
This doesn't cause much arm but still could be candidate for
stable.
cc: stable@kernel.org
Only affects BE systems.
Revert "drm/nvc0: recognise 0xdX chipsets as NV_C0"
drm/radeon/kms: fix typo in cayman reg offset
drm/radeon/kms: use correct reg on fusion when reading back mem config
drm/i915: apply HWSTAM writes to Ivy Bridge as well
drm/i915: move IRQ function table init to i915_irq.c
drm/i915/overlay: Fix unpinning along init error paths
drm/i915: Don't call describe_obj on NULL pointers
drm/i915: Hold struct_mutex during i915_save_state/i915_restore_state
Oh boy. That was a bad gamble. PDISP has changed.
This reverts commit cdf81a235f11c8a55023c6b181d21d519a8a5967.
In an attempt to fix 38862 and 38863.
Tested-by: Kenneth Graunke <kenneth@whitecape.org>
CE variant requires a different chremap setup.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=35472
This lets us make the various IRQ functions static and helps avoid
problems like the one fixed in "drm/i915: Use chipset-specific irq
installers" where one of the exported functions was called rather than
the chipset specific version.
This also fixes a UMS-mode bug -- the correct irq functions for IRL
and later chips were only getting loaded in the KMS path.
Reviewed-by: Ben Widawsky <ben@bwidawsk.net>
As pointed out by Dan Carpenter, it was seemingly possible to hit an error
whilst mapping the buffer for the regs (except the only likely error
returns should not happen during init) and so leak a pin count on the
bo. To handle this we would need to reacquire the struct mutex, so for
simplicity rearrange for the lock to be held for the entire function.
For extra pedagogy, test that we only call init once.
The vbios rom is >64k on a lot of modern asics. Increase
the fetch size for atrm to make sure we don't miss part
of a larger rom.
Reported-by: Pavel Roskin <proski@gnu.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38777
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
Lots of register access in these functions, some of which requires the
struct mutex.
These functions now hold the struct mutex across the calls to
i915_save_display and i915_restore_display, and so the internal mutex
calls in those functions have been removed. To ensure that no-one else
was calling them (and hence violating the new required locking
invarient), those functions have been made static.
gen6_enable_rps locks the struct mutex, and so i915_restore_state
unlocks the mutex around calls to that function.
