The way the mode probing works is this:
1. All modes currently on the mode list are marked as UNVERIFIED
2. New modes are on the probed_modes list (they start with
status OK)
3. Modes are moved from the probed_modes list to the actual
mode list. If a mode already on the mode list is deemed
to match one of the probed modes, the duplicate is dropped
and the mode status updated to OK. After this the
probed_modes list will be empty.
4. All modes on the mode list are verified to not violate any
constraints. Any that do are marked as such.
5. Any mode left with a non-OK status is pruned from the list,
with an appropriate debug message.
What all this means is that any mode on the original list that
didn't have a duplicate on the probed_modes list, should be left
with status UNVERFIED (or previously could have been left with
some other status, but never OK).
I broke that in
commit 05acaec334fc ("drm: Reorganize probed mode validation")
by always assigning something to the mode->status during the validation
step. So any mode from the old list that still passed the validation
would be left on the list with status OK in the end.
Fix this by not doing the basic mode validation unless the mode
already has status OK (meaning it came from the probed_modes list,
or at least a duplicate of it was on that list). This way we will
correctly prune away any mode from the old mode list that didn't
appear on the probed_modes list.
Cc: stable@vger.kernel.org
Cc: Adam Jackson <ajax@redhat.com>
Fixes: 05acaec334fc ("drm: Reorganize probed mode validation")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449177255-9515-2-git-send-email-ville.syrjala@linux.intel.com
Testcase: igt/kms_force_connector_basic/prune-stale-modes
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=93332
[danvet: Also applying to drm-misc to avoid too much conflict hell -
there's a big pile of patches from Ville on top of this one.]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
git://anongit.freedesktop.org/drm-intel into drm-fixes
Here are some i915 fixes for v4.4, sorry for being late this week.
* tag 'drm-intel-fixes-2015-12-11' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Do a better job at disabling primary plane in the noatomic case.
drm/i915/skl: Double RC6 WRL always on
drm/i915/skl: Disable coarse power gating up until F0
drm/i915: Remove incorrect warning in context cleanup
omap_fbdev always creates a framebuffer with ARGB8888 pixel format. On
OMAP3 we have VIDEO1 overlay that does not support ARGB8888, and on
OMAP2 none of the overlays support ARGB888.
This patch changes the omap_fbdev's fb to XRGB8888, which is supported
by all platforms.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Tested-by: H. Nikolaus Schaller <hns@goldelico.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
There are few defects in vga_get() related to signal hadning:
- we shouldn't check for pending signals for TASK_UNINTERRUPTIBLE
case;
- if we found pending signal we must remove ourself from wait queue
and change task state back to running;
- -ERESTARTSYS is more appropriate, I guess.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
into drm-fixes
some big endian fixes and one regression fix.
* 'drm-fixes-4.4' of git://people.freedesktop.org/~agd5f/linux:
radeon: Fix VCE IB test on Big-Endian systems
radeon: Fix VCE ring test for Big-Endian systems
radeon/cik: Fix GFX IB test on Big-Endian
drm/amdgpu: fix the lost duplicates checking
When disable_noatomic is called plane_mask is not correct yet, and
plane_state->visible = true is left as true after disabling the primary
plane.
Other planes are already disabled as part of crtc sanitization, only the
primary is left active. But the plane_mask is not updated here. It gets
updated during fb takeover in modeset_gem_init, or set to the new value
on resume.
This means that to disable the primary plane 1 << drm_plane_index(primary)
needs to be used.
Afterwards because the crtc is no longer active it's forbidden to keep
plane_state->visible set, or a WARN_ON in
intel_plane_atomic_calc_changes triggers. There are other code points
that rely on accurate plane_state->visible too, so make sure the bool is
cleared.
The other planes are already disabled in intel_sanitize_crtc, so they
don't have to be handled here.
Cc: stable@vger.kernel.org #v4.3, v4.2?
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92655
Tested-by: Tomas Mezzadra <tmezzadra@gmail.com>
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/5652DB88.9070208@linux.intel.com
(cherry picked from commit 54a4196188eab82e6f0a5f05716626e9f18b8fb6)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
This patch makes the VCE IB test pass on Big-Endian systems. It converts
to little-endian the contents of the VCE message.
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
This patch fixes the VCE ring test when running on Big-Endian machines.
Every write to the ring needs to be translated to little-endian.
This patch makes the IB test on the GFX ring pass for CI-based cards
installed in Big-Endian machines.
Signed-off-by: Chunming Zhou <David1.Zhou@amd.com>
Reviewed-by: Jammy Zhou <Jammy.Zhou@amd.com>
git://people.freedesktop.org/~thomash/linux into drm-fixes
Pull request of 2015-12-08
A couple of fixes for vmwgfx. A WARN() fix by Dan Carpenter,
a TTM read/write lock imbalance causing occasional hangs with Wayland and
an implementation of cursor_set2 to fix incorrectly offset Wayland cursors.
* tag 'vmwgfx-fixes-4.4-151208' of git://people.freedesktop.org/~thomash/linux:
drm/vmwgfx: Implement the cursor_set2 callback v2
drm/vmwgfx: fix a warning message
drm/ttm: Fixed a read/write lock imbalance
Just the one commit I mentioned earlier, making the PGOB workaround the
default.
* 'linux-4.4' of https://github.com/skeggsb/linux:
drm/nouveau/pmu: remove whitelist for PGOB-exit WAR, enable by default
NVIDIA have indicated that the workaround is required on all GK10[467]
boards that have the PGOB fuse set.
I've left the commandline option in place for now, as paranoia.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
WaRsDoubleRc6WrlWithCoarsePowerGating should
be enabled for all Skylakes. Make it so.
Cc: Sagar Arun Kamble <sagar.a.kamble@intel.com>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Reviewed-by: Sagar Arun Kamble <sagar.a.kamble@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449505785-20812-2-git-send-email-mika.kuoppala@intel.com
(cherry picked from commit e7674b8c31717dd0c58b3a9493d43249722071eb)
Cc: stable@vger.kernel.org # v4.3+
There is conflicting info between E0 and F0 steppings
for this workarounds. Trust more authoritative source and
be conservative and extend also for F0.
This prevents numerous (>50) gpu hangs with SKL GT4e
during piglit run.
References: HSD: gen9lp/2134184
Link: http://patchwork.freedesktop.org/patch/msgid/1449505785-20812-1-git-send-email-mika.kuoppala@intel.com
(cherry picked from commit 6686ece19f7446f0e29c77d9e0402e1d0ce10c48)
Fixes native drm clients like Fedora 23 Wayland which now appears to
be able to use cursor hotspots without strange cursor offsets.
Also fixes a couple of ignored error paths.
Since the core drm cursor hotspot is incompatible with the legacy vmwgfx
hotspot (the core drm hotspot is reset when the drm_mode_cursor ioctl
is used), we need to keep track of both and add them when the device
hotspot is set. We assume that either is always zero.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
Commit e9f24d5fb7cf3628b195b18ff3ac4e37937ceeae
Author: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Date: Mon Oct 5 13:26:36 2015 +0100
drm/i915: Clean up associated VMAs on context destruction
Added a warning based on an incorrect assumption that all VMAs
in a VM will be on the inactive list at the point last reference
to a context and VM is dropped.
This is not true because i915_gem_object_retire__read will not
put VMA on the inactive list until all activities on the object
in question (in all VMs) have been retired.
As a consequence, whether or not a context/VM will be destroyed
with its VMAs still on the active list, can depend on completely
unrelated activities using the same object from a different
context or engine.
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92638
Testcase: igt/gem_request_retire/retire-vma-not-inactive
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Michel Thierry <michel.thierry@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1448025816-25584-1-git-send-email-tvrtko.ursulin@linux.intel.com
(cherry picked from commit 408952d43b27a54437244c56c0e0d8efa5607926)
into drm-next
A few more last minute fixes for 4.4 on top of my pull request from
earlier this week. The big change here is a vblank regression fix due to
commit 4dfd6486 "drm: Use vblank timestamps to guesstimate how many vblanks
were missed". Beyond that, a hotplug fix and a few VM fixes.
drm/amdgpu: Fixup hw vblank counter/ts for new drm_update_vblank_count() (v3)
drm/radeon: Fixup hw vblank counter/ts for new drm_update_vblank_count() (v2)
drm/radeon: Retry DDC probing on DVI on failure if we got an HPD interrupt
drm/amdgpu: add spin lock to protect freed list in vm (v2)
drm/amdgpu: partially revert "drm/amdgpu: fix VM_CONTEXT*_PAGE_TABLE_END_ADDR" v2
drm/amdgpu: take a BO reference for the user fence
drm/amdgpu: take a BO reference in the display code
drm/amdgpu: set snooped flags only on system addresses v2
drm/amdgpu: fix race condition in amd_sched_entity_push_job
drm/amdgpu: add err check for pin userptr
add blacklist for thinkpad T40p
drm/amdgpu: fix VM page table reference counting
drm/amdgpu: fix userptr flags check
vblanks were missed" introduced in Linux 4.4-rc1 makes the drm core
more fragile to drivers which don't update hw vblank counters and
vblank timestamps in sync with firing of the vblank irq and
essentially at leading edge of vblank.
This exposed a problem with radeon-kms/amdgpu-kms which do not
satisfy above requirements:
The vblank irq fires a few scanlines before start of vblank, but
programmed pageflips complete at start of vblank and
vblank timestamps update at start of vblank, whereas the
hw vblank counter increments only later, at start of vsync.
This leads to problems like off by one errors for vblank counter
updates, vblank counters apparently going backwards or vblank
timestamps apparently having time going backwards. The net result
is stuttering of graphics in games, or little hangs, as well as
total failure of timing sensitive applications.
See bug #93147 for an example of the regression on Linux 4.4-rc:
https://bugs.freedesktop.org/show_bug.cgi?id=93147
This patch tries to align all above events better from the
viewpoint of the drm core / of external callers to fix the problem:
1. The apparent start of vblank is shifted a few scanlines earlier,
so the vblank irq now always happens after start of this extended
vblank interval and thereby drm_update_vblank_count() always samples
the updated vblank count and timestamp of the new vblank interval.
To achieve this, the reporting of scanout positions by
radeon_get_crtc_scanoutpos() now operates as if the vblank starts
radeon_crtc->lb_vblank_lead_lines before the real start of the hw
vblank interval. This means that the vblank timestamps which are based
on these scanout positions will now update at this earlier start of
vblank.
2. The driver->get_vblank_counter() function will bump the returned
vblank count as read from the hw by +1 if the query happens after
the shifted earlier start of the vblank, but before the real hw increment
at start of vsync, so the counter appears to increment at start of vblank
in sync with the timestamp update.
3. Calls from vblank irq-context and regular non-irq calls are now
treated identical, always simulating the shifted vblank start, to
avoid inconsistent results for queries happening from vblank irq vs.
happening from drm_vblank_enable() or vblank_disable_fn().
4. The radeon_flip_work_func will delay mmio programming a pageflip until
the start of the real vblank iff it happens to execute inside the shifted
earlier start of the vblank, so pageflips now also appear to execute at
start of the shifted vblank, in sync with vblank counter and timestamp
updates. This to avoid some races between updates of vblank count and
timestamps that are used for swap scheduling and pageflip execution which
could cause pageflips to execute before the scheduled target vblank.
The lb_vblank_lead_lines "fudge" value is calculated as the size of
the display controllers line buffer in scanlines for the given video
mode: Vblank irq's are triggered by the line buffer logic when the line
buffer refill for a video frame ends, ie. when the line buffer source read
position enters the hw vblank. This means that a vblank irq could fire at
most as many scanlines before the current reported scanout position of the
crtc timing generator as the number of scanlines the line buffer can
maximally hold for a given video mode.
This patch has been successfully tested on a RV730 card with DCE-3 display
engine and on a evergreen card with DCE-4 display engine, in single-display
and dual-display configuration, with different video modes.
A similar patch is needed for amdgpu-kms to fix the same problem.
Limitations:
- Maybe replace the udelay() in the flip_work_func() by a suitable
usleep_range() for a bit better efficiency? Will try that.
- Line buffer sizes in pixels are hard-coded on < DCE-4 to a value
i just guessed to be high enough to work ok, lacking info on the true
sizes atm.
Probably fixes: fdo#93147
Port of Mario's radeon fix to amdgpu.
(v1) Reviewed-by: Mario Kleiner <mario.kleiner.de@gmail.com>
(v2) Refine amdgpu_flip_work_func() for better efficiency.
In amdgpu_flip_work_func, replace the busy waiting udelay(5)
with event lock held by a more performance and energy efficient
usleep_range() until at least predicted true start of hw vblank,
with some slack for scheduler happiness. Release the event lock
during waits to not delay other outputs in doing their stuff, as
the waiting can last up to 200 usecs in some cases.
Also small fix to code comment and formatting in that function.
(v2) Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
(v3) Fix crash in crtc disabled case
vblank.
Limitations:
sizes atm.
Fixes: fdo#93147
Cc: Alex Deucher <alexander.deucher@amd.com>
Cc: Michel Dänzer <michel.daenzer@amd.com>
Cc: Harry Wentland <Harry.Wentland@amd.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
(v1) Tested-by: Dave Witbrodt <dawitbro@sbcglobal.net>
(v2) Refine radeon_flip_work_func() for better efficiency:
In radeon_flip_work_func, replace the busy waiting udelay(5)
Retested on DCE-3 and DCE-4 to verify it still works nicely.
HPD signals on DVI ports can be fired off before the pins required for
DDC probing actually make contact, due to the pins for HPD making
contact first. This results in a HPD signal being asserted but DDC
probing failing, resulting in hotplugging occasionally failing.
This is somewhat rare on most cards (depending on what angle you plug
the DVI connector in), but on some cards it happens constantly. The
Radeon R5 on the machine used for testing this patch for instance, runs
into this issue just about every time I try to hotplug a DVI monitor and
as a result hotplugging almost never works.
Rescheduling the hotplug work for a second when we run into an HPD
signal with a failing DDC probe usually gives enough time for the rest
of the connector's pins to make contact, and fixes this issue.
Signed-off-by: Lyude <cpaul@redhat.com>
there is a protection fault about freed list when OCL test.
add a spin lock to protect it.
v2: drop changes in vm_fini
Signed-off-by: JimQu <jim.qu@amd.com>
The gtt_end is already inclusive, we don't need to subtract one here.
v2 (chk): keep the fix for the VM code, cause here it really applies.
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Anatoli Antonovitch <anatoli.antonovitch@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
No need for a GEM reference here.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
No need for the GEM reference here.
Not necessary for VRAM.
v2: no need to check if ttm is NULL.
Apparently pre-nv50 pageflip events happen before the actual vblank
period. Therefore that functionality got semi-disabled in
commit af4870e406126b7ac0ae7c7ce5751f25ebe60f28
Author: Mario Kleiner <mario.kleiner.de@gmail.com>
Date: Tue May 13 00:42:08 2014 +0200
drm/nouveau/kms/nv04-nv40: fix pageflip events via special case.
Unfortunately that hack got uprooted in
commit cc1ef118fc099295ae6aabbacc8af94d8d8885eb
Author: Thierry Reding <treding@nvidia.com>
Date: Wed Aug 12 17:00:31 2015 +0200
drm/irq: Make pipe unsigned and name consistent
Triggering a warning when trying to sample the vblank timestamp for a
non-existing pipe. There's a few ways to fix this:
- Open-code the old behaviour, which just enshrines this slight
breakage of the userspace ABI.
- Revert Mario's commit and again inflict broken timestamps, again not
pretty.
- Fix this for real by delaying the pageflip TS until the next vblank
interrupt, thereby making it accurate.
This patch implements the third option. Since having a page flip
interrupt that happens when the pageflip gets armed and not when it
completes in the next vblank seems to be fairly common (older i915 hw
works very similarly) create a new helper to arm vblank events for
such drivers.
v2 (Mario Kleiner):
- Fix function prototypes in drmP.h
- Add missing vblank_put() for pageflip completion without
pageflip event.
- Initialize sequence number for queued pageflip event to avoid
trouble in drm_handle_vblank_events().
- Remove dead code and spelling fix.
v3 (Mario Kleiner):
- Add a signed-off-by and cc stable tag per Ilja's advice.
v4 (Thierry Reding):
- Fix kerneldoc typo, discovered by Michel Dänzer
- Rearrange tags and changelog
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=106431
Cc: Thierry Reding <treding@nvidia.com>
Cc: Mario Kleiner <mario.kleiner.de@gmail.com>
Acked-by: Ben Skeggs <bskeggs@redhat.com>
Cc: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
A client calling drmSetMaster() using a file descriptor that was opened
when another client was master would inherit the latter client's master
object and all its authenticated clients.
This is unwanted behaviour, and when this happens, instead allocate a
brand new master object for the client calling drmSetMaster().
Fixes a BUG() throw in vmw_master_set().
Cc: <stable@vger.kernel.org>
git://git.pengutronix.de/git/pza/linux into drm-fixes
imx-drm crtc, plane, parallel panel, and TV encoder fixes
- Use drm_crtc_send_vblank_event to fix per crtc vblank handling
- Move the crtc device of_node assignment out of the ipuv3-crtc driver into
ipu-common code, where the devices are created.
- Fix parallel display support with simple-panels
- Remove some unused fields and superfluous checks
- Switch to universal planes and add error handling for primary plane creation
- Fix module autoload for TV encoder driver
* tag 'imx-drm-fixes-2015-12-01' of git://git.pengutronix.de/git/pza/linux:
drm: imx: imx-tve: Fix module autoload for OF platform driver
drm: imx: convert to drm_crtc_send_vblank_event()
GPU-DRM-IMX: Delete an unnecessary check before drm_fbdev_cma_restore_mode()
drm/imx: Remove of_node assignment from ipuv3-crtc driver probe
gpu: ipu-v3: Assign of_node of child platform devices to corresponding ports
gpu: ipu-v3: Remove reg_offset field
gpu: ipu-v3: drop unused dmfc field from client platform data
drm/imx: parallel-display: allow to determine bus format from the connected panel
drm/imx: ipuv3-crtc: Return error if ipu_plane_init() fails for primary plane
drm/imx: switch to universal planes
Another batch of drm/i915 fixes for v4.4, on top of the ones from
earlier this week. One timeout handling regression fix from Chris, and
backport of five patches from our -next to fix a power management
related HDMI hotplug regression.
* tag 'drm-intel-fixes-2015-12-03' of git://anongit.freedesktop.org/drm-intel:
drm/i915: take a power domain reference while checking the HDMI live status
drm/i915: add MISSING_CASE to a few port/aux power domain helpers
drm/i915/ddi: fix intel_display_port_aux_power_domain() after HDMI detect
drm/i915: Introduce a gmbus power domain
drm/i915: Clean up AUX power domain handling
drm/i915: Check the timeout passed to i915_wait_request
As soon as we leave the spinlock after the job has been added to the job
queue, we can no longer rely on the job's data to be available.
I have seen a null-pointer dereference due to sched == NULL in
amd_sched_wakeup via amd_sched_entity_push_job and
amd_sched_ib_submit_kernel_helper. Since the latter initializes
sched_job->sched with the address of the ring scheduler, which is
guaranteed to be non-NULL, this race appears to be a likely culprit.
Signed-off-by: Nicolai Hähnle <nicolai.haehnle@amd.com>
Bugzilla: https://bugs.freedesktop.org/attachment.cgi?bugid=93079
Missing error check if the operation failed.
There are platforms that don't need the full GMBUS power domain (BXT)
while others do (PCH, VLV/CHV). For optimizing this we would need to add
a new power domain, but it's not clear how much we would benefit given
the short time we hold the reference. So for now let's keep things
simple.
This fixes a regression introduced in
commit 237ed86c693d8a8e4db476976aeb30df4deac74b
Author: Sonika Jindal <sonika.jindal@intel.com>
Date: Tue Sep 15 09:44:20 2015 +0530
drm/i915: Check live status before reading edid
v2:
- fix commit message, PCH won't take any redundant power resource after
this change (Ville)
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
[fix commit message in v2 (Imre)]
[Cherry-picked from drm-intel-next-queued 29bb94bb (Imre)]
Signed-off-by: Imre Deak <imre.deak@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1448643329-18675-6-git-send-email-imre.deak@intel.com
MISSING_CASE() would have been useful to track down a recent problem in
intel_display_port_aux_power_domain(), so add it there and a few related
helpers. This was also suggested by Ville in his review of the latest
DMC/DC changes, we forgot to address that.
Reviewed-by: Patrik Jakobsson <patrik.jakobsson@linux.intel.com>
[Cherry-picked from drm-intel-next-queued b9fec167 (Imre)]
Link: http://patchwork.freedesktop.org/patch/msgid/1448643329-18675-5-git-send-email-imre.deak@intel.com
Due to the current sharing of the DDI encoder between DP and HDMI
connectors we can run the DP detection after the HDMI detection has
already set the shared encoder's type. For now solve this keeping the
current behavior and running the detection in this case too. For a proper
solution Ville suggested to split the encoder into an HDMI and DP one, that
can be done as a follow-up.
This issue triggers the WARN in intel_display_port_aux_power_domain() and
was introduced in:
commit 25f78f58e5bfb46a270ce4d690fb49dc104558b1
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Date: Mon Nov 16 15:01:04 2015 +0100
CC: Patrik Jakobsson <patrik.jakobsson@linux.intel.com>
CC: Ville Syrjälä <ville.syrjala@linux.intel.com>
[Cherry-picked from drm-intel-next-queued 651174a4 (Imre)]
Link: http://patchwork.freedesktop.org/patch/msgid/1448643329-18675-4-git-send-email-imre.deak@intel.com
Currently the gmbus code uses intel_aux_display_runtime_get/put in an
effort to make sure the hardware is powered up sufficiently for gmbus.
That function only takes the runtime PM reference which on VLV/CHV/BXT
is not enough. We need the disp2d/pipe-a well on VLV/CHV and power well
2 on BXT. So add a new power domnain for gmbus and kill off the now
unused intel_aux_display_runtime_get/put. And change
intel_hdmi_set_edid() to use the gmbus power domain too since that's all
we need there.
Also toss in a BUILD_BUG_ON() to catch problems if we run out of
bits for power domains. We're already really close to the limit...
[Patrik: Add gmbus string to debugfs output]
[Cherry-picked from drm-intel-next-queued f0ab43e6 (Imre)]
Link: http://patchwork.freedesktop.org/patch/msgid/1448643329-18675-3-git-send-email-imre.deak@intel.com
Introduce intel_display_port_aux_power_domain() which simply returns
the appropriate AUX power domain for a specific port, and then replace
the intel_display_port_power_domain() with calls to the new function
in the DP code. As long as we're not actually enabling the port we don't
need the lane power domains, and those are handled now purely from
modeset_update_crtc_power_domains().
My initial motivation for this was to see if I could keep the DPIO power
wells powered down while doing AUX on CHV, but turns out I can't so this
doesn't change anything for CHV at least. But I think it's still a
worthwile change.
v2: Add case for PORT E. Default to POWER_DOMAIN_AUX_D for now. (Ville)
[Cherry-picked from drm-intel-next-queued 25f78f58 (Imre)]
Link: http://patchwork.freedesktop.org/patch/msgid/1448643329-18675-2-git-send-email-imre.deak@intel.com
https://github.com/markyzq/kernel-drm-rockchip into drm-fixes
Rockchip fixes from Mark.
* 'drm-fixes-rockchip-2015-12-02' of https://github.com/markyzq/kernel-drm-rockchip:
drm/rockchip: Use CRTC vblank event interface
drm/rockchip: Fix module autoload for OF platform driver
drm/rockchip: vop: fix window origin calculation
drm/rockchip: unset pgoff when mmap'ing gems
drm/rockchip: vop: Correct enabled clocks during setup
Passing -1 as the pipe for vblank events now triggers a WARN_ON, but had
previously made multi-screen unusable anyway. Pass the correct pipe to
the event-send function, and use the new API to make this a bit easier
for us.
Fixes WARN present since cc1ef118fc for every pageflip event sent:
[ 209.549969] ------------[ cut here ]------------
[ 209.554592] WARNING: CPU: 3 PID: 238 at drivers/gpu/drm/drm_irq.c:924 drm_vblank_count_and_time+0x80/0x88 [drm]()
[ 209.564832] Modules linked in: [...]
[ 209.612401] CPU: 3 PID: 238 Comm: irq/41-ff940000 Tainted: G W 4.3.0-rc6+ #71
[ 209.620647] Hardware name: Rockchip (Device Tree)
[ 209.625348] [<c001bb80>] (unwind_backtrace) from [<c001615c>] (show_stack+0x20/0x24)
[ 209.633079] [<c001615c>] (show_stack) from [<c02b2c50>] (dump_stack+0x8c/0x9c)
[ 209.640289] [<c02b2c50>] (dump_stack) from [<c0052e88>] (warn_slowpath_common+0x94/0xc4)
[ 209.648364] [<c0052e88>] (warn_slowpath_common) from [<c0052f74>] (warn_slowpath_null+0x2c/0x34)
[ 209.657139] [<c0052f74>] (warn_slowpath_null) from [<bf17dc30>] (drm_vblank_count_and_time+0x80/0x88 [drm])
[ 209.666875] [<bf17dc30>] (drm_vblank_count_and_time [drm]) from [<bf17e484>] (drm_send_vblank_event+0x74/0x7c [drm])
[ 209.677385] [<bf17e484>] (drm_send_vblank_event [drm]) from [<bf4c1144>] (vop_win_state_complete+0x4c/0x70 [rockchip_drm_vop])
[ 209.688757] [<bf4c1144>] (vop_win_state_complete [rockchip_drm_vop]) from [<bf4c3bdc>] (vop_isr_thread+0x170/0x1d4 [rockchip_drm_vop])
[ 209.700822] [<bf4c3bdc>] (vop_isr_thread [rockchip_drm_vop]) from [<c00ab93c>] (irq_thread_fn+0x2c/0x50)
[ 209.710284] [<c00ab93c>] (irq_thread_fn) from [<c00abcac>] (irq_thread+0x13c/0x188)
[ 209.717927] [<c00abcac>] (irq_thread) from [<c00723c8>] (kthread+0xec/0x104)
[ 209.724965] [<c00723c8>] (kthread) from [<c0011638>] (ret_from_fork+0x14/0x3c)
[ 209.732171] ---[ end trace 0690bc604f5d535d ]---
Signed-off-by: Daniel Stone <daniels@collabora.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Heiko Stuebner <heiko@sntech.de>
Tested-By: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Thierry Reding <treding@nvidia.com>
This platform driver has a OF device ID table but the OF module
alias information is not created so module autoloading won't work.
Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
VOP_WINx_DSP_ST does not require subtracting 1 from the values written to
it. It actually causes the screen to be shifted by one pixel.
Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
Tested-by: Yakir Yang <ykk@rock-chips.com>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Dominik Behr <dbehr@chromium.org>
Commit 371f0f085f629 ("ARM: 8426/1: dma-mapping: add missing range check
in dma_mmap()") introduced offset-checking for mappings, which collides
with the fake-offset the drm sets for gems.
Other drm-drivers set this offset to 0 before doing the mapping, so
this looks like the correct way to go for rockchip as well.
Fixes: 371f0f085f629 ("ARM: 8426/1: dma-mapping: add missing range check in dma_mmap()")
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
When doing the initial setup both the hclk and the aclk need to be
enabled otherwise the board will simply hang. This only occurs when
building the vop driver as a module, when its built-in the initial setup
happens to run before the clock framework shuts of unused clocks
(including the aclk).
While there also switch to doing prepare and enable in one step rather
then separate steps to reduce the amount of code required.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Acked-by: Mark Yao <mark.yao@rock-chips.com>
Tested-by: Romain Perier <romain.perier@gmail.com>
We have relied upon the sole caller (wait_ioctl) validating the timeout
argument. However, when waiting for multiple requests I forgot to ensure
that the timeout was still positive on the later requests. This is more
simply done inside __i915_wait_request.
Fixes regression introduced in
commit b47161858ba13c9c7e03333132230d66e008dd55
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Mon Apr 27 13:41:17 2015 +0100
drm/i915: Implement inter-engine read-read optimisations
The impact of the regression is 1 jiffie for each extra active ring for
a wait_ioctl with a timeout -- I don't think anyone has noticed.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Lionel Landwerlin <lionel.g.landwerlin@linux.intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1448544702-5594-1-git-send-email-chris@chris-wilson.co.uk
Avoid the sticky preferred mode bit by using the no-merge version of the
function (this allows gnome-shell to resize to lower resolutions than
the default resolution)
Signed-off-by: Marc-André Lureau <marcandre.lureau@redhat.com>
few i915 fixes.
* tag 'drm-intel-fixes-2015-11-30' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Don't override output type for DDI HDMI
drm/i915: Don't compare has_drrs strictly in pipe config
drm/i915: Mark uneven memory banks on gen4 desktop as unknown swizzling
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Thinkpad T40p needs agpmode 1.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
We use the reservation object of the page directory for the page tables as
well, because of this the page directory should be freed last. Ensure that
by keeping a reference from the page tables to the directory.
That got messed up while porting it from Radeon.
